[GRASS-SVN] r31376 - in grass/trunk/raster: r.le/r.le.patch
r.le/r.le.pixel r.le/r.le.setup r.le/r.le.trace r.mapcalc
r.support/front r.univar2 r.watershed/front
svn_grass at osgeo.org
Fri May 16 14:40:49 EDT 2008
Author: epatton
Date: 2008-05-16 14:40:49 -0400 (Fri, 16 May 2008)
New Revision: 31376
grass/trunk/raster/r.le/r.le.patch/description.html
grass/trunk/raster/r.le/r.le.pixel/description.html
grass/trunk/raster/r.le/r.le.setup/description.html
grass/trunk/raster/r.le/r.le.trace/description.html
grass/trunk/raster/r.mapcalc/r.mapcalc.html
grass/trunk/raster/r.support/front/description.html
grass/trunk/raster/r.univar2/r.univar.html
grass/trunk/raster/r.univar2/r3.univar.html
grass/trunk/raster/r.watershed/front/description.html
Raster manpage HTML tags uniformily lowercased, part DEUX
Modified: grass/trunk/raster/r.le/r.le.patch/description.html
--- grass/trunk/raster/r.le/r.le.patch/description.html 2008-05-16 18:39:44 UTC (rev 31375)
+++ grass/trunk/raster/r.le/r.le.patch/description.html 2008-05-16 18:40:49 UTC (rev 31376)
@@ -1,37 +1,37 @@
-<H2>DESCRIPTION</H2>
+<h2>DESCRIPTION</h2>
-The <EM>r.le.patch</EM> module calculates attribute, patch size, core
+The <em>r.le.patch</em> module calculates attribute, patch size, core
(interior) size, shape, fractal dimension, and perimeter measures for sets
of patches in a landscape.
-<H2>NOTES</H2>
+<h2>NOTES</h2>
Full instructions can be found in the <b>r.le manual</b> (see "REFERENCES"
-section below) and the <em><A HREF="r.le.setup.html">r.le.setup</A></em>
+section below) and the <em><a href="r.le.setup.html">r.le.setup</a></em>
help page.
-<H2>REFERENCES</H2>
+<h2>REFERENCES</h2>
Baker, W.L. and Y. Cai. 1992. The r.le programs for multiscale analysis of
landscape structure using the GRASS geographical information system.
Landscape Ecology 7(4):291-302.
-<P>
+<p>
The <A href="http://grass.itc.it/gdp/landscape/r_le_manual5.pdf"><i>r.le</i>
manual: Quantitative analysis of landscape structures</a> (GRASS 5; 2001)
-<H2>SEE ALSO</H2>
+<h2>SEE ALSO</h2>
-<EM>
-<!-- <A HREF="r.le.dist.html">r.le.dist</A>,
-<A HREF="r.le.null.html">r.le.null</A>, -->
-<A HREF="r.le.pixel.html">r.le.pixel</A>,
-<!-- <A HREF="r.le.rename.html">r.le.rename</A>, -->
-<A HREF="r.le.setup.html">r.le.setup</A>,
-<A HREF="r.le.trace.html">r.le.trace</A></EM>
+<em>
+<!-- <a href="r.le.dist.html">r.le.dist</a>,
+<a href="r.le.null.html">r.le.null</a>, -->
+<a href="r.le.pixel.html">r.le.pixel</a>,
+<!-- <a href="r.le.rename.html">r.le.rename</a>, -->
+<a href="r.le.setup.html">r.le.setup</a>,
+<a href="r.le.trace.html">r.le.trace</a></em>
-<H2>AUTHOR</H2>
+<h2>AUTHOR</h2>
William L. Baker Department of Geography and Recreation University of
Wyoming Laramie, Wyoming 82071 U.S.A.
Modified: grass/trunk/raster/r.le/r.le.pixel/description.html
--- grass/trunk/raster/r.le/r.le.pixel/description.html 2008-05-16 18:39:44 UTC (rev 31375)
+++ grass/trunk/raster/r.le/r.le.pixel/description.html 2008-05-16 18:40:49 UTC (rev 31376)
@@ -1,36 +1,36 @@
-The <EM>r.le.pixel</EM> module contains a set of measures for attributes,
+The <em>r.le.pixel</em> module contains a set of measures for attributes,
diversity, texture, juxtaposition, and edge.
-<H2>NOTES</H2>
+<h2>NOTES</h2>
help page.
-<P>
+<p>
-<H2>SEE ALSO</H2>
+<h2>SEE ALSO</h2>
-<EM>
-<A HREF="r.le.patch.html">r.le.patch</A>,
+<em>
+<a href="r.le.patch.html">r.le.patch</a>,
-<H2>AUTHOR</H2>
+<h2>AUTHOR</h2>
Modified: grass/trunk/raster/r.le/r.le.setup/description.html
--- grass/trunk/raster/r.le/r.le.setup/description.html 2008-05-16 18:39:44 UTC (rev 31375)
+++ grass/trunk/raster/r.le/r.le.setup/description.html 2008-05-16 18:40:49 UTC (rev 31376)
@@ -1,30 +1,30 @@
-<EM>r.le.setup</EM> program is used to set
+<em>r.le.setup</em> program is used to set
up the sampling and analysis framework that will be used by the other
-<EM>r.le</EM> programs.
+<em>r.le</em> programs.
-<H2>NOTES</H2>
+<h2>NOTES</h2>
<i>Full instructions can be found in the <b>r.le manual</b> (see "REFERENCES"
section below).</i>
-<P>
+<p>
The first menu allows the user to define a rectangular sampling frame,
select how sampling will be done (regions, sampling units, moving window),
setup the limits for groups and classes, and change the color table.
Use the left mouse button to make your choice.
-<P>
+<p>
Information about the structure of the landscape is obtained by overlaying
a set of sampling areas on top of a specified part (the sampling frame of
a map layer, and then calculating specific structural measures for the part
of the map layer that corresponds to the area in each sampling area.
-<P>
+<p>
-To setup a <EM><B>sampling frame</B></EM> click on SAMPLING FRAME in the
+To setup a <em><b>sampling frame</b></em> click on SAMPLING FRAME in the
main menu. The program will ask "Will the sampling frame (total area
within which sampling units are distributed) be the whole map? (y/n) [y]"
Just hit a carriage return to accept the default, which is to use the
@@ -40,9 +40,9 @@
setup procedures unless you change it. You can change it at any time by
simply clicking on SAMPLING FRAME again.
-<P>
+<p>
-A <EM><B>sampling area</B></EM> may be one of four things. First, it is
+A <em><b>sampling area</b></em> may be one of four things. First, it is
possible to treat the entire map layer as the one (and only) sampling area.
Second, if the map layer can be divided into meaningful geographical regions,
then it is possible to treat the regions themselves as sampling areas.
@@ -51,16 +51,16 @@
layer as a whole. The fourth and final option is that the sampling area
may be moved systematically across the map as a moving window.
-<P>
+<p>
If regions are to be used as the sampling areas , then the user can use
-<EM>r.le.setup</EM> to draw regions or any existing map of regions can
+<em>r.le.setup</em> to draw regions or any existing map of regions can
simply be used directly. To draw regions and create a new regions map
-in <EM>r.le.setup</EM> select "REGIONS" from the first <EM>r.le.setup</EM>
+in <em>r.le.setup</em> select "REGIONS" from the first <em>r.le.setup</em>
menu, and the user is asked to do the following:
-<DL>
-<PRE>
+<dl>
+<pre>
1. "ENTER THE NEW REGION MAP NAME:". Only a new raster map name is
acceptable. The user can type LIST to find out the existing raster map
names in this location and mapset.
@@ -75,48 +75,48 @@
3. A "REGION OPTIONS:" menu is displayed and the user should use the mouse
to select one of
- the options:<BR>
+ the options:<br>
"DRAW MORE": repeat the above process and setup another region.
"START OVER": abandon the previous setup and start all over again.
"DONE-SAVE": save the regions outlined so far and exit this procedure.
"QUIT-NO SAVE": quit the procedure without saving the regions.
-</PRE>
-</DL>
+</pre>
+</dl>
Once the "DONE-SAVE" option is selected, the new raster map of the sampling
regions is generated. It is displayed on the monitor window for several
seconds, the monitor window is refreshed, the main menu is displayed again,
and the program is ready for other setup work. Note that you cannot draw
-regions in areas outside the mask, if a mask is present (see <EM>r.mask</EM>
+regions in areas outside the mask, if a mask is present (see <em>r.mask</em>
command).
-<P>
+<p>
-The user can also use the GRASS <EM>r.digit</EM> or <EM>v.digit</EM>
+The user can also use the GRASS <em>r.digit</em> or <em>v.digit</em>
programs to digitize circular or polygonal regions and to create a
-sampling regions map without using <EM>r.le.setup</EM>. Or, as mention
+sampling regions map without using <em>r.le.setup</em>. Or, as mention
above, an existing raster map can be used as a regions map.
-<P>
+<p>
If sampling units are to be used as the sampling areas (Fig. 2), then
-choose "SAMPLING UNITS" from the first <EM>r.le.setup</EM> menu.
-The program checks the <EM>r.le.para</EM> subdirectory for an existing
+choose "SAMPLING UNITS" from the first <em>r.le.setup</em> menu.
+The program checks the <em>r.le.para</em> subdirectory for an existing
"units" file from a previous setup session and allows the user to rename
this file (to save it) before proceeding. The r.le.setup program will
otherwise overwrite the "units" file. Then the following choice is
displayed followed by a series of other choices:
-<DL>
-<DD>
-<PRE>
+<dl>
+<dd>
+<pre>
Which do you want to do?
(1) Use the keyboard to enter sampling unit parameters
(2) Draw the sampling units with the mouse
Enter 1 or 2:
-</PRE>
-</DL>
+</pre>
+</dl>
When sampling units are defined using the keyboard, the user inputs the
shape and size (scale) of the sampling units by specifying dimensions
@@ -127,58 +127,58 @@
can directly determine the method of sampling unit distribution as well
as the shape, size, and number of sampling units.
-<P>
+<p>
If the choice is made to define sampling units using the keyboard, the
following series of questions must be answered:
-<DL>
-<DD>
-<PRE>
+<dl>
+<dd>
+<pre>
How many different SCALES do you want (1-15)?
-</PRE>
-</DL>
+</pre>
+</dl>
The user is asked to specify the number of scales that will be used.
-The <EM>r.le</EM> programs allow the user to simultaneously sample the
+The <em>r.le</em> programs allow the user to simultaneously sample the
same map with the same measures using sampling areas of different sizes.
Currently there can be between 1 and 15 scales that can be sampled
simultaneously. Substantial output can be produced if many scales are used.
-<P>
+<p>
Sampling units must be placed spatially into the landscape. There are
five options for doing this :
-<P>
+<p>
-<EM>Random nonoverlapping</EM><BR>
+<em>Random nonoverlapping</em><br>
Sampling units are placed in the landscape by randomly choosing numbers
that specify the location of the upper left corner of each sampling unit,
subject to the constraint that successive sampling units not overlap other
sampling units or the edge of the landscape, and that they must be entirely
-within the area defined by the mask (see <EM>r.mask</EM> command) if one
+within the area defined by the mask (see <em>r.mask</em> command) if one
exists.
-<P>
+<p>
-<EM>Systematic contiguous</EM><BR>
+<em>Systematic contiguous</em><br>
Sampling units are placed side by side across the rows. The user will
be able to enter a row and column to indicate where the upper left corner
of the systematic contiguous framework should be placed. Rows are numbered
from the top down beginning with row 1 of the sampling frame. Columns are
numbered from left to right, beginning with column 1 of the sampling frame.
A random starting location can be obtained by using a standard random
-number table to choose the starting row and column. The <EM>r.le.setup</EM>
+number table to choose the starting row and column. The <em>r.le.setup</em>
program does not avoid placing the set of sampling units over areas
outside the mask. The user will have to make sure that sampling units do
not extend outside the mask by choosing a particular starting row and
column or by drawing a sampling frame before placing the set of sampling
units.
-<P>
+<p>
-<EM>Systematic noncontiguous</EM><BR>
+<em>Systematic noncontiguous</em><br>
The user must specify the starting row and column as in #2 above and the
amount of spacing (in pixels) between sampling units. Horizontal and
vertical spacing are identical. Sampling units are again placed side by
@@ -186,9 +186,9 @@
placing sampling units outside the masked area; the user will have to
position the set of units to avoid areas outside the mask.
-<P>
+<p>
-<EM>Stratified random</EM><BR>
+<em>Stratified random</em><br>
The strata are rectangular areas within which single sampling units
are randomly located. The user must first specify the starting row
and column as in #2 above. Then the user must specify the number of
@@ -196,15 +196,15 @@
does not avoid placing sampling units outside the masked area; the user
will have to position the set of units to avoid areas outside the mask.
-<P>
+<p>
-<EM>Centered over sites</EM><BR>
+<em>Centered over sites</em><br>
The user must specify the name of a sitefile containing point locations.
A single sampling unit is placed with its center over each site in the site
file. This is a useful approach for determining the landscape structure
around points, such as around the location of wildlife observations.
-<P>
+<p>
The user is prompted to enter a ratio that defines the shape of the
sampling units. Sampling units may have any rectangular shape,
@@ -213,13 +213,13 @@
dimension/vertical dimension) as a real number. For example, to obtain
a sampling unit 10 columns wide by 4 rows long specify the ratio as 2.5
(10/4).
-<DL>
-<DD>
-<PRE>
- Recommended maximum SIZE is m in x cell total area. <BR>
+<dl>
+<dd>
+<pre>
+ Recommended maximum SIZE is m in x cell total area. <br>
What size (in cells) for each sampling unit of scale n?
-</PRE>
-</DL>
+</pre>
+</dl>
The user is then given the recommended maximum possible size for a
sampling unit (in pixels) and asked to input the size of sampling units
@@ -229,16 +229,16 @@
the size, the program determines the nearest actual number of rows and
columns, and hence size, that is closest to the requested size, given
the shape requested earlier.
-<DL>
-<DD>
-<PRE>
+<dl>
+<dd>
+<pre>
The nearest size is x cells wide X y cells high = xy cells
Is this size OK? (y/n) [y]
Maximum NUMBER of units in scale n is p?
What NUMBER of sampling units do you want to try to use?
-</PRE>
-</DL>
+</pre>
+</dl>
The maximum number of units that can be placed over the map, given the
shape and size of the units, is then given. The user can then choose
@@ -249,12 +249,12 @@
the columns and down the rows. The user can then specify a particular
layout (e.g., 6 units could be placed as 2 rows of 3 per row or as 3
rows of 2 per row).
-<DL>
-<DD>
-<PRE>
+<dl>
+<dd>
+<pre>
Is this set of sampling units OK? (y/n) [y]
-</PRE>
-</DL>
+</pre>
+</dl>
Finally, the set of sampling units is displayed on the screen (e.g., Fig. 1)
and the user is asked whether it is acceptable. If the answer is no, then
@@ -262,34 +262,34 @@
the menu for "Methods of sampling unit distribution" so that the user can
try the sampling unit setup again.
-<P>
+<p>
The choice is made to define sampling units using the mouse, then the
following menu for use with the mouse is displayed:
-<DL>
-<DD>
-<PRE>
+<dl>
+<dd>
+<pre>
Outline the standard sampling unit of scale n.
Left button: Check unit size
Middle button: Move cursor
Right button: Lower right corner of unit here
-</PRE>
-</DL>
+</pre>
+</dl>
The user can then use the mouse and the rubber band box to outline the
standard sampling unit. Once it has been outlined, the number of columns
and rows in the unit, the ratio of width/length and the size of the unit,
in cells, will be displayed. After this first unit is outlined, then a
new menu is displayed:
-<DL>
-<DD>
-<PRE>
+<dl>
+<dd>
+<pre>
Outline more sampling units of scale n?
Left button: Exit
Middle button: Check unit position
Right button: Lower right corner of next unit here
-</PRE>
-</DL>
+</pre>
+</dl>
The user can then place more units identical to the standard unit by
simply clicking the right mouse button where the lower right corner of
@@ -300,7 +300,7 @@
Warning messages are issued for all three of these errors and a sampling
unit is simply not placed.
-<P>
+<p>
Using this procedure a rectangular "window" or single sampling area is
moved systematically across the map to produce a new map (Fig. 2,3).
@@ -310,10 +310,10 @@
when defining class or group limits (section 2.3.2.) is used if
distributional measures are chosen with the moving window sampling
method. In this case, the user should manually edit the
-<EM>r.le.para/recl_tb</EM> file so that the desired group is listed as
+<em>r.le.para/recl_tb</em> file so that the desired group is listed as
the first group in this file.
-<P>
+<p>
Sampling begins with the upper left corner of the window placed over
the upper left corner of the sampling frame. It is strongly recommended
@@ -334,7 +334,7 @@
are smaller by approximately (m-1)/2 rows and columns, where m is the
number of rows or columns in the window.
-<P>
+<p>
If the "MOVE-WINDOW" option in the main menu is selected, first the
program checks for an existing "move_wind" file, in the r.le.para
@@ -347,123 +347,123 @@
ideas about how moving window size and sampling frame area affect
the needed time to complete the analyses.
-<P>
+<p>
-The <EM>r.le</EM> programs <EM>r.le.dist</EM> and <EM>r.le.patch</EM>
+The <em>r.le</em> programs <em>r.le.dist</em> and <em>r.le.patch</em>
allow the attribute categories in the input map to be reclassed into
several attribute groups, and reports the analysis results by each of
these attribute groups. It is necessary to setup group limits for
-all measures that say "by gp" when typing "<EM>r.le.dist help</EM>"
-or "<EM>r.le.patch help</EM>" at the GRASS prompt. The same reclassing
+all measures that say "by gp" when typing "<em>r.le.dist help</em>"
+or "<em>r.le.patch help</em>" at the GRASS prompt. The same reclassing
can be done with the measurement indices (e.g., size), except that each
"cohort" (class) of the reclassed indices is called an index class
instead of a group. It is also necessary to setup class limits for
-all measures that say "by class" when typing "<EM>r.le.dist help</EM>"
+all measures that say "by class" when typing "<em>r.le.dist help</em>"
-<P>
+<p>
Group/class limits are setup by choosing "GROUP/CLASS LIMITS" from the
-main menu upon starting <EM>r.le.setup</EM>, or you can create the files
+main menu upon starting <em>r.le.setup</em>, or you can create the files
manually using a text editor. The program checks for existing group/class
-limit files in subdirectory <EM>r.le.para</EM> and allows the user to
+limit files in subdirectory <em>r.le.para</em> and allows the user to
rename these files prior to continuing. If the files are not renamed
the program will overwrite them. The files are named recl_tb (attribute
group limits), size (size class limits), shape_PA (shape index class
limits for perimeter/area index), shape_CPA (shape index class limits
for corrected perimeter/area index), shape_RCC (shape index class limits
for related circumscribing circle index), and from_to (for the
-<EM>r.le.dist</EM> program distance methods m7-m9).
+<em>r.le.dist</em> program distance methods m7-m9).
-<P>
+<p>
Attribute groups and index classes are defined in a different way.
-In the <EM>r.le</EM> programs attribute groups are defined as in the
+In the <em>r.le</em> programs attribute groups are defined as in the
following example:
-<DL>
-<DD>
-<PRE>
- 1, 3, 5, 7, 9 <B>thru</B> 21 = 1 (comment)
- 31 <B>thru</B> 50 = 2 (comment)
- <B>end</B>
-</PRE>
-</DL>
+<dl>
+<dd>
+<pre>
+ 1, 3, 5, 7, 9 <b>thru</b> 21 = 1 (comment)
+ 31 <b>thru</b> 50 = 2 (comment)
+ <b>end</b>
+</pre>
+</dl>
In this example, the existing categories 1, 3, 5, 7, {9, 10, ... 20, 21}
are included in the new group 1, while {31, 32, 33, ..., 49, 50} are
included in the new group 2. The characters in bold are the "key words"
that are required in the definition. Each line is called one "reclass rule".
-<P>
+<p>
The GRASS reclass convention is adopted here with a little modification
-(see "<EM>r.reclass</EM>" command in the GRASS User's Manual).
+(see "<em>r.reclass</em>" command in the GRASS User's Manual).
The difference is that r.le only allows one rule for each group while the
-GRASS <EM>r.reclass</EM> command allows more than one. The definition of
+GRASS <em>r.reclass</em> command allows more than one. The definition of
"from" and "to" groups is simply the extension of the GRASS reclass rule.
The advantage of using the GRASS reclass convention is that the user can
generate a permanent reclassed map, using GRASS programs, directly from the
-<EM>r.le</EM> setup results.
+<em>r.le</em> setup results.
-<P>
+<p>
-The <EM>r.le</EM> measurement index classes are defined by the lower
+The <em>r.le</em> measurement index classes are defined by the lower
limits of the classes, as in the following example:
-<DL>
-<DD>
-<PRE>
- 0.0, 10.0, 50.0, 200.0, <B>-999</B>
-</PRE>
-</DL>
+<dl>
+<dd>
+<pre>
+ 0.0, 10.0, 50.0, 200.0, <b>-999</b>
+</pre>
+</dl>
This means:
-<DL>
-<DD>
-<PRE>
+<dl>
+<dd>
+<pre>
if v >= 0.0 and v < 10.0 then v belongs to index class 1;
if v >= 10.0 and v < 50.0 then v belongs to index class 2;
if v >= 50.0 and v < 200.0 then v belongs to index class 3;
if v >= 200.0 then v belongs to index class 4;
-</PRE>
-</DL>
+</pre>
+</dl>
-where v is the calculated index value and <B>-999</B> marks the end of
+where v is the calculated index value and <b>-999</b> marks the end of
the index class definition. The measurement index can be the size index,
one of the three shape indices, or one of the three distance indices.
The program is currently designed to allow no more than 25 attribute
groups, 25 size classes, 25 shape index classes, and 25 distance index
classes. As an alternative, the user may want to permanently group
-certain attributes prior to entering the <EM>r.le</EM> programs.
+certain attributes prior to entering the <em>r.le</em> programs.
For example, the user may want to group attributes 1-10, in a map whose
attributes are ages, into a single attribute representing young patches.
-The user can do this using the GRASS <EM>r.reclass</EM> and
-<EM>r.resample</EM> commands, which will create a new map layer that can
+The user can do this using the GRASS <em>r.reclass</em> and
+<em>r.resample</em> commands, which will create a new map layer that can
then be analyzed directly (without setting up group limits) with the
-<P>
+<p>
-<H2>SEE ALSO</H2>
+<h2>SEE ALSO</h2>
-<EM>
+<em>
-<H2>AUTHOR</H2>
+<h2>AUTHOR</h2>
Modified: grass/trunk/raster/r.le/r.le.trace/description.html
--- grass/trunk/raster/r.le/r.le.trace/description.html 2008-05-16 18:39:44 UTC (rev 31375)
+++ grass/trunk/raster/r.le/r.le.trace/description.html 2008-05-16 18:40:49 UTC (rev 31376)
@@ -1,40 +1,40 @@
-The <EM>r.le.trace</EM> module can be used to display the boundary of each
+The <em>r.le.trace</em> module can be used to display the boundary of each
<b>r.le</b> patch and show how the boundary is traced, display the attribute,
size, perimeter, and shape indices for each patch, and save the data in an
output file.
-<H2>NOTES</H2>
+<h2>NOTES</h2>
help page.
-<P>
+<p>
-<H2>SEE ALSO</H2>
+<h2>SEE ALSO</h2>
-<EM>
-<!--<A HREF="r.le.dist.html">r.le.dist</A>,
-</EM>
+<em>
+<!--<a href="r.le.dist.html">r.le.dist</a>,
+</em>
-<H2>AUTHOR</H2>
+<h2>AUTHOR</h2>
Modified: grass/trunk/raster/r.mapcalc/r.mapcalc.html
--- grass/trunk/raster/r.mapcalc/r.mapcalc.html 2008-05-16 18:39:44 UTC (rev 31375)
+++ grass/trunk/raster/r.mapcalc/r.mapcalc.html 2008-05-16 18:40:49 UTC (rev 31376)
@@ -7,41 +7,41 @@
</head>
<body bgcolor="white">
<img src="grass_logo.png" alt="GRASS logo"><hr align=center size=6 noshade>
-<H2>NAME</H2>
-<EM><B>r.mapcalc</B></EM>
-<EM>r.mapcalc</EM> performs arithmetic on raster map layers.
+<h2>NAME</h2>
+<em><b>r.mapcalc</b></em>
+<em>r.mapcalc</em> performs arithmetic on raster map layers.
New raster map layers can be created which are arithmetic expressions
involving existing raster map layers, integer or floating point constants,
and functions.
-<H2>PROGRAM USE</H2>
-If used without command line arguments, <EM>r.mapcalc</EM> will read its
+<h2>PROGRAM USE</h2>
+If used without command line arguments, <em>r.mapcalc</em> will read its
input, one line at a time, from standard input
(which is the keyboard, unless redirected from a file or across a pipe).
Otherwise, the expression on the command line is evaluated.
-<EM>r.mapcalc</EM> expects its input to have the form:
-<P>
-<B>result=</B><EM>expression</EM>
-<P>
-where <EM>result</EM> is the name of a raster map layer
+<em>r.mapcalc</em> expects its input to have the form:
+<p>
+<b>result=</b><em>expression</em>
+<p>
+where <em>result</em> is the name of a raster map layer
to contain the result of the calculation and
-<EM>expression</EM> is any legal arithmetic expression involving existing
+<em>expression</em> is any legal arithmetic expression involving existing
and functions known to the calculator.
Parentheses are allowed in the expression and may be nested to any depth.
-<EM>result</EM> will be created in the user's current mapset.
-<P>
-The formula entered to <EM>r.mapcalc</EM> by the user is recorded both in the
-<EM>result</EM> map title (which appears in the category file for <EM>result</EM>)
-and in the history file for <EM>result</EM>.
-<P>
+<em>result</em> will be created in the user's current mapset.
+<p>
+The formula entered to <em>r.mapcalc</em> by the user is recorded both in the
+<em>result</em> map title (which appears in the category file for <em>result</em>)
+and in the history file for <em>result</em>.
+<p>
Some characters have special meaning to the command shell. If the user
-is entering input to <EM>r.mapcalc</EM> on the command line, expressions
+is entering input to <em>r.mapcalc</em> on the command line, expressions
should be enclosed within single quotes. See NOTES, below.
-<P>
-<H2>OPERATORS AND ORDER OF PRECEDENCE</H2>
+<p>
+<h2>OPERATORS AND ORDER OF PRECEDENCE</h2>
The following operators are supported:
-<div class="code"><PRE>
+<div class="code"><pre>
Operator Meaning Type Precedence
- negation Arithmetic 12
@@ -69,111 +69,111 @@
|| logical or Logical 2
||| logical or[1] Logical 2
?: conditional Logical 1
-</PRE></div>
+</pre></div>
(modulus is the remainder upon division)
-<P>
+<p>
[1] The &&& and ||| operators handle null values differently to other
operators. See the section entitled <b>NULL support</b> below for more
details.
-<P>
+<p>
The operators are applied from left to right, with those of higher precedence
applied before those with lower precedence.
Division by 0 and modulus by 0 are acceptable and give a NULL result.
The logical operators give a 1 result if the comparison is true, 0 otherwise.
-<P>
-<P>
-<H2>RASTER MAP LAYER NAMES</H2>
+<p>
+<p>
+<h2>RASTER MAP LAYER NAMES</h2>
Anything in the expression which is not a number, operator, or function name
is taken to be a raster map layer name.
Examples:
-<P>
+<p>
elevation
x3
3d.his
-</PRE></div>
-<P>
+</pre></div>
+<p>
Most GRASS raster map layers meet this naming convention.
However, if a raster map layer has a name which conflicts with the
above rule, it should be quoted. For example, the expression
-<P>
+<p>
x = a-b
-</PRE></div>
-<P>
+</pre></div>
+<p>
would be interpreted as: x equals a minus b, whereas
-<P>
+<p>
x = "a-b"
-</PRE></div>
-<P>
-would be interpreted as: x equals the raster map layer named <EM>a-b</EM>
-<P>
+</pre></div>
+<p>
+would be interpreted as: x equals the raster map layer named <em>a-b</em>
+<p>
Also
-<P>
+<p>
x = 3107
-</PRE></div>
-<P>
-would create <EM>x</EM> filled with the number 3107, while
-<P>
+</pre></div>
+<p>
+would create <em>x</em> filled with the number 3107, while
+<p>
x = "3107"
-</PRE></div>
-<P>
-would copy the raster map layer <EM>3107</EM> to the raster map layer <EM>x</EM>.
+</pre></div>
+<p>
+would copy the raster map layer <em>3107</em> to the raster map layer <em>x</em>.
-<P>
+<p>
Quotes are not required unless the raster map layer names
look like numbers or contain operators, OR unless the program
is run non-interactively. Examples given here assume the
program is run interactively. See NOTES, below.
-<P>
-<EM>r.mapcalc</EM> will look for the raster map layers according to the
+<p>
+<em>r.mapcalc</em> will look for the raster map layers according to the
user's current mapset search path.
It is possible to override the search path and specify the mapset
from which to select the raster map layer.
This is done by specifying the raster map layer name in the form:
-<P>
+<p>
name at mapset
-</PRE></div>
-<P>
+</pre></div>
+<p>
For example, the following is a legal expression:
-<P>
+<p>
result = x at PERMANENT / y at SOILS
-</PRE></div>
-<P>
+</pre></div>
+<p>
The mapset specified does not have to be in the mapset search path.
(This method of overriding the mapset search path is common to all
-GRASS commands, not just <EM>r.mapcalc</EM>.)
-<P>
-<H2>THE NEIGHBORHOOD MODIFIER</H2>
+GRASS commands, not just <em>r.mapcalc</em>.)
+<p>
+<h2>THE NEIGHBORHOOD MODIFIER</h2>
Maps and images are data base files stored in raster format, i.e.,
two-dimensional matrices of integer values.
-In <EM>r.mapcalc</EM>, maps may be followed by a <EM>neighborhood</EM> modifier that
+In <em>r.mapcalc</em>, maps may be followed by a <em>neighborhood</em> modifier that
specifies a relative offset from the current cell being evaluated. The format is
-<EM>map[r,c]</EM>, where <EM>r</EM> is the row offset and <EM>c</EM> is the column offset.
-For example, <EM>map[1,2]</EM> refers to the cell one row below and two columns
-to the right of the current cell, <EM>map[-2,-1]</EM> refers to the cell
+<em>map[r,c]</em>, where <em>r</em> is the row offset and <em>c</em> is the column offset.
+For example, <em>map[1,2]</em> refers to the cell one row below and two columns
+to the right of the current cell, <em>map[-2,-1]</em> refers to the cell
two rows above and one column to the left of the current cell,
-and <EM>map[0,1]</EM> refers to the cell one column to the right of the current cell.
+and <em>map[0,1]</em> refers to the cell one column to the right of the current cell.
This syntax permits the development of neighborhood-type filters within a single
map or across multiple maps.
-<P>
-<H2>RASTER MAP LAYER VALUES FROM THE CATEGORY FILE</H2>
+<p>
+<h2>RASTER MAP LAYER VALUES FROM THE CATEGORY FILE</h2>
Sometimes it is desirable to use a value associated with a category's
-<EM>label</EM> instead of the category value itself. If a raster
-map layer name is preceded by the <B>@</B>
+<em>label</em> instead of the category value itself. If a raster
+map layer name is preceded by the <b>@</b>
operator, then the labels in the category file for the raster map layer
are used in the expression instead of the category value.
-<P>
-For example, suppose that the raster map layer <EM>soil.ph</EM>
+<p>
+For example, suppose that the raster map layer <em>soil.ph</em>
(representing soil pH values) has a category file with labels as follows:
-<P>
+<p>
cat label
0 no data
@@ -184,17 +184,17 @@
5 7.2
6 8.8
7 9.4
-</PRE></div>
-<P>
+</pre></div>
+<p>
Then the expression:
-<P>
+<p>
result = @soils.ph
-</PRE></div>
-<P>
+</pre></div>
+<p>
would produce a result with category values
0, 1.4, 2.4, 3.5, 5.8, 7.2, 8.8 and 9.4.
-<P>
+<p>
Note that this operator may only be applied to raster map layers
and produces a floating point value in the expression.
Therefore, the category label must start with a valid number.
@@ -202,96 +202,96 @@
a floating point number. I the category label does not start
with a number or is missing, it will be represented by NULL
(no data) in the resulting raster map.
-<H2>GREY SCALE EQUIVALENTS AND COLOR SEPARATES</H2>
+<h2>GREY SCALE EQUIVALENTS AND COLOR SEPARATES</h2>
It is often helpful to manipulate the colors assigned to map categories.
This is particularly useful when the spectral properties of cells have meaning
(as with imagery data), or when the map category values represent real
quantities (as when category values reflect true elevation values).
Map color manipulation can also aid visual recognition, and map printing.
-<P>
+<p>
The # operator can be used to either convert map category values to their
grey scale equivalents or to extract the red, green, or blue components
of a raster map layer into separate raster map layers.
-<P>
+<p>
result = #map
-</PRE></div>
-<P>
-converts each category value in <EM>map</EM> to a value in the range 0-255 which
+</pre></div>
+<p>
+converts each category value in <em>map</em> to a value in the range 0-255 which
represents the grey scale level implied by the color for the category.
If the map has a grey scale color table, then the grey level is what
#map evaluates to. Otherwise, it is computed as:
-<P>
+<p>
0.10 * red + 0.81 * green + 0.01 * blue
-</PRE></div>
-<P>
+</pre></div>
+<p>
Alternatively, you can use:
-<P>
+<p>
result = y#map
-</PRE></div>
-<P>
+</pre></div>
+<p>
to use the NTSC weightings:
-<P>
+<p>
0.30 * red + 0.59 * green + 0.11 * blue
-</PRE></div>
-<P>
+</pre></div>
+<p>
Or, you can use:
-<P>
+<p>
result = i#map
-</PRE></div>
-<P>
+</pre></div>
+<p>
to use equal weightings:
-<P>
+<p>
0.33 * red + 0.33 * green + 0.33 * blue
-</PRE></div>
-<P>
+</pre></div>
+<p>
The # operator has three other forms: r#map, g#map, b#map.
These extract the red, green, or blue components in the named raster map,
-respectively. The GRASS shell script <EM><A HREF="r.blend.html">r.blend</A></EM> extracts each of these
+respectively. The GRASS shell script <em><a href="r.blend.html">r.blend</a></em> extracts each of these
components from two raster map layers, and combines them by a user-specified
percentage.
These forms allow color separates to be made. For example, to
-extract the red component from <EM>map</EM>
-and store it in the new 0-255 map layer <EM>red</EM>,
+extract the red component from <em>map</em>
+and store it in the new 0-255 map layer <em>red</em>,
the user could type:
-<P>
+<p>
red = r#map
-</PRE></div>
-<P>
+</pre></div>
+<p>
To assign this map grey colors type:
-<P>
-<A HREF="r.colors.html">r.colors</A> map=red color=rules
+<p>
+<a href="r.colors.html">r.colors</a> map=red color=rules
black
white
-</PRE></div>
-<P>
+</pre></div>
+<p>
To assign this map red colors type:
-<P>
+<p>
black
red
-</PRE></div>
-<P>
-<H2>FUNCTIONS</H2>
+</pre></div>
+<p>
+<h2>FUNCTIONS</h2>
The functions currently supported are listed in the table below.
The type of the result is indicated in the last column.
-<EM>F</EM>
+<em>F</em>
means that the functions always results in a floating point value,
-<EM>I</EM>
+<em>I</em>
means that the function gives an integer result, and
-<EM>*</EM>
+<em>*</em>
indicates that the result is float if any of the arguments to the function
are floating point values and integer if all arguments are integer.
-<P>
+<p>
function description type
abs(x) return absolute value of x *
@@ -327,8 +327,8 @@
sqrt(x) square root of x F
tan(x) tangent of x (x is in degrees) F
xor(x,y) exclusive-or (XOR) of x and y I
-</PRE></div>
+</pre></div>
Internal variables:
row() current row of moving window
col() current col of moving window
@@ -337,14 +337,14 @@
ewres() current east-west resolution
nsres() current north-south resolution
null() NULL value
-</PRE></div>
+</pre></div>
Note, that the row() and col() indexing starts with 1.
-<H2>FLOATING POINT VALUES IN THE EXPRESSION</H2>
+<h2>FLOATING POINT VALUES IN THE EXPRESSION</h2>
Floating point numbers are allowed in the expression. A floating point
number is a number which contains a decimal point:
2.3 12.0 12. .81
-</PRE></div>
+</pre></div>
Floating point values in the expression are handled in a special way.
With arithmetic and logical operators, if either operand is float,
the other is converted to float and the result of the operation is float.
@@ -352,35 +352,35 @@
(truncated) integer, while division of floats results in an accurate
floating point value. With functions of type * (see table above),
the result is float if any argument is float, integer otherwise.
-<P>
+<p>
Note: If you calculate with integer numbers, the resulting map will
be integer. If you want to get a float result, add the decimal point
to integer number(s).
-<P>
+<p>
If you want floating point division, at least one of the arguments has
to be a floating point value. Multiplying one of them by 1.0 will
produce a floating-point result, as will using float():
r.mapcalc "ndvi=float(lsat.4 - lsat.3) / (lsat.4 + lsat.3)"
-</PRE></div>
-<H2>NULL support</H2>
+</pre></div>
+<h2>NULL support</h2>
<menu>
<li>Division by zero should result in NULL.
<li>Modulus by zero should result in NULL.
<li> NULL-values in any arithmetic or logical operation should result
in NULL. (however, &&& and ||| are treated specially, as described below).
<li> The &&& and ||| operators observe the following axioms even when x is NULL:
x &&& false == false
false &&& x == false
x ||| true == true
true ||| x == true
-</PRE></div>
+</pre></div>
<li> NULL-values in function arguments should result in NULL (however,
if(), eval() and isnull() are treated specially, as described below).
<li> The eval() function always returns its last argument
<li> The situation for if() is:
if(x)
NULL if x is NULL; 0 if x is zero; 1 otherwise
if(x,a)
@@ -390,19 +390,19 @@
if(x,n,z,p)
NULL if x is NULL; n if x is negative;
z if x is zero; p if x is positive
-</PRE></div>
+</pre></div>
<li> The (new) function isnull(x) returns: 1 if x is NULL;
0 otherwise. The (new) function null()
(which has no arguments) returns an integer NULL.
<li>Non-NULL, but invalid, arguments to functions should result in NULL.
Examples:
log(-2)
sqrt(-2)
pow(a,b) where a is negative and b is not an integer
-</PRE></div>
+</pre></div>
</menu>
-<P>
+<p>
NULL support: Please note that any math performed with NULL cells always
results in a NULL value for these cells. If you want to replace a NULL cell
on-the-fly, use the isnull() test function in a if-statement.
@@ -410,40 +410,40 @@
Example: The users wants the NULL-valued cells to be treated like zeros. To
add maps A and B (where B contains NULLs) to get a map C the user can use a
construction like:<p>
C=A + if(isnull(B),0,B)
-</PRE></div>
+</pre></div>
<p>
<b>NULL and conditions:</b>
<p>
For the one argument form:
if(x) = NULL if x is NULL
if(x) = 0 if x = 0
if(x) = 1 otherwise (i.e. x is neither NULL nor 0).
-</PRE></div>
+</pre></div>
<p>
For the two argument form:
if(x,a) = NULL if x is NULL
if(x,a) = 0 if x = 0
if(x,a) = a otherwise (i.e. x is neither NULL nor 0).
-</PRE></div>
+</pre></div>
<p>
For the three argument form:
if(x,a,b) = NULL if x is NULL
if(x,a,b) = b if x = 0
if(x,a,b) = a otherwise (i.e. x is neither NULL nor 0).
-</PRE></div>
+</pre></div>
<p>
For the four argument form:
if(x,a,b,c) = NULL if x is NULL
if(x,a,b,c) = a if x > 0
if(x,a,b,c) = b if x = 0
if(x,a,b,c) = c if x < 0
-</PRE></div>
+</pre></div>
More generally, all operators and most functions return NULL if *any*
of their arguments are NULL.
<br>
@@ -456,7 +456,7 @@
All forms of if() return NULL if the first argument is NULL. The 2, 3
and 4 argument forms of if() return NULL if the "selected" argument is
NULL, e.g.:
if(0,a,b) = b regardless of whether a is NULL
if(1,a,b) = a regardless of whether b is NULL
</pre></div>
@@ -472,31 +472,31 @@
unknown quantity. E.g. if x and y are both unknown, then the values of
"x == y" and "x != y" are also unknown; if they both have unknown
values, the user doesn't know whether or not they both have the same value.
-<H2>EXAMPLES</H2>
+<h2>EXAMPLES</h2>
To compute the average of two raster map layers
-<EM>a</EM> and <EM>b</EM>:
+<em>a</em> and <em>b</em>:
ave = (a + b)/2
</pre></div>
To form a weighted average:
ave = (5*a + 3*b)/8.0
</pre></div>
To produce a binary representation of the raster map layer
-<EM>a</EM> so that category 0 remains 0 and all other categories become 1:
+<em>a</em> so that category 0 remains 0 and all other categories become 1:
mask = a != 0
</pre></div>
This could also be accomplished by:
mask = if(a)
</pre></div>
-To mask raster map layer <EM>b</EM> by raster map layer <EM>a</EM>:
+To mask raster map layer <em>b</em> by raster map layer <em>a</em>:
result = if(a,b)
</pre></div>
To change all values below 5 to NULL:
newmap = if(map<5, null(), 5)
</pre></div>
The graph function allows users to specify a x-y conversion using
@@ -512,11 +512,11 @@
the associated y value returned. Any x value higher than the last
will similarly have the associated y value returned. Consider the
request:
newmap = graph(map, 1,10, 2,25, 3,50)
</pre></div>
X (map) values supplied and y (newmap) values returned:
0, 10
1, 10,
1.5, 16.5
@@ -524,98 +524,98 @@
4, 50
100, 50
</pre></div>
-<H2>NOTES</H2>
+<h2>NOTES</h2>
Extra care must be taken if the expression is given on the command line.
Some characters have special meaning to the UNIX shell.
These include, among others:
-<P>
+<p>
-<P>
+<p>
It is advisable to put single quotes around the expression; e.g.:
result = 'elevation * 2'
</pre></div>
Without the quotes, the *, which has special meaning to the UNIX shell,
-would be altered and <EM>r.mapcalc</EM> would see something other than the *.
-<P>
-If the input comes directly from the keyboard and the <EM>result</EM> raster
+would be altered and <em>r.mapcalc</em> would see something other than the *.
+<p>
+If the input comes directly from the keyboard and the <em>result</em> raster
map layer exists, the user will be asked if it can be overwritten.
-Otherwise, the <EM>result</EM> raster map layer will automatically be
+Otherwise, the <em>result</em> raster map layer will automatically be
overwritten if it exists.
-<P>
-Quoting <EM>result</EM> is not allowed.
-However, it is never necessary to quote <EM>result</EM> since
+<p>
+Quoting <em>result</em> is not allowed.
+However, it is never necessary to quote <em>result</em> since
it is always taken to be a raster map layer name.
-<P>
+<p>
For formulas that the user enters from standard input
(rather than from the command line), a line continuation feature now exists.
-If the user adds \e to the end of an input line, <EM>r.mapcalc</EM> assumes that
+If the user adds \e to the end of an input line, <em>r.mapcalc</em> assumes that
the formula being entered by the user continues on to the next input line.
There is no limit to the possible number of input lines
or to the length of a formula.
-<P>
-If the <EM>r.mapcalc</EM> formula entered by the user is very long,
+<p>
+If the <em>r.mapcalc</em> formula entered by the user is very long,
the map title will contain only some of it, but most (if not all) of
-the formula will be placed into the history file for the <EM>result</EM> map.
-<P>
-When the user enters input to <EM>r.mapcalc</EM> non-interactively on
+the formula will be placed into the history file for the <em>result</em> map.
+<p>
+When the user enters input to <em>r.mapcalc</em> non-interactively on
the command line, the program will not warn the user not to overwrite
existing map layers. Users should therefore take care to assign program
outputs raster map names that do not yet exist in their current mapsets.
-<P>
+<p>
The environment variable GRASS_RND_SEED is read to initialise the
random number generator.
-<H2>BUGS</H2>
+<h2>BUGS</h2>
Continuation lines must end with a \ and have NO trailing white space
(blanks or tabs). If the user does leave white space at the end of
-continuation lines, the error messages produced by <EM>r.mapcalc</EM> will
+continuation lines, the error messages produced by <em>r.mapcalc</em> will
be meaningless and the equation will not work as the user intended.
This is important for the eval() function.
-<P>
-Error messages produced by <EM>r.mapcalc</EM> are almost useless.
-In future, <EM>r.mapcalc</EM> should make some attempt
+<p>
+Error messages produced by <em>r.mapcalc</em> are almost useless.
+In future, <em>r.mapcalc</em> should make some attempt
to point the user to the offending section of the equation, e.g.:
x = a * b ++ c
ERROR: somewhere in line 1: ... b ++ c ...
</pre></div>
-<P>
-Currently, there is no comment mechanism in <EM>r.mapcalc</EM>.
+<p>
+Currently, there is no comment mechanism in <em>r.mapcalc</em>.
Perhaps adding a capability that would cause the entire line to be
ignored when the user inserted a # at the start of a line
as if it were not present, would do the trick.
-<P>
+<p>
The function should require the user to type "end" or "exit" instead
of simply a blank line. This would make separation of multiple scripts
separable by white space.
-<P>
+<p>
r.mapcalc does not print a warning in case of operations on NULL cells.
It is left to the user to utilize the isnull() function.
-<H2>SEE ALSO</H2>
-<B><A HREF="http://grass.itc.it/gdp/raster/mapcalc-algebra.pdf">r.mapcalc: An Algebra for GIS and Image
-Processing</A></B>, by Michael Shapiro and Jim Westervelt, U.S. Army
+<h2>SEE ALSO</h2>
+<b><a href="http://grass.itc.it/gdp/raster/mapcalc-algebra.pdf">r.mapcalc: An Algebra for GIS and Image
+Processing</a></b>, by Michael Shapiro and Jim Westervelt, U.S. Army
Construction Engineering Research Laboratory (March/1991).
-<P>
-<B><A HREF="http://grass.itc.it/gdp/raster/mapcalc.pdf">Performing Map Calculations on GRASS Data:
-r.mapcalc Program Tutorial</A></B>, by Marji Larson, Michael Shapiro and Scott
+<p>
+<b><a href="http://grass.itc.it/gdp/raster/mapcalc.pdf">Performing Map Calculations on GRASS Data:
+r.mapcalc Program Tutorial</a></b>, by Marji Larson, Michael Shapiro and Scott
Tweddale, U.S. Army Construction Engineering Research Laboratory (December
1991)
<p>
Grey scale conversion is based on the C.I.E. x,y,z system where y represents
luminance. See "Fundamentals of Digital Image Processing,"
by Anil K. Jain (Prentice Hall, NJ, 1989; p 67).
-<P>
-<EM>
-<A HREF="g.region.html">g.region</A>,
-<A HREF="r.bitpattern.html">r.bitpattern</A>,
-<A HREF="r.blend.html">r.blend</A>,
-<A HREF="r.colors.html">r.colors</A>,
-<A HREF="r.fillnulls.html">r.fillnulls</A>
-</EM>
-<H2>AUTHORS</H2>
+<p>
+<em>
+<a href="g.region.html">g.region</a>,
+<a href="r.bitpattern.html">r.bitpattern</a>,
+<a href="r.blend.html">r.blend</a>,
+<a href="r.colors.html">r.colors</a>,
+<a href="r.fillnulls.html">r.fillnulls</a>
+</em>
+<h2>AUTHORS</h2>
Michael Shapiro, U.S.Army Construction Engineering
Research Laboratory
-<P>
+<p>
Glynn Clements
<p><i>Last changed: $Date$</i>
</body>
Modified: grass/trunk/raster/r.support/front/description.html
--- grass/trunk/raster/r.support/front/description.html 2008-05-16 18:39:44 UTC (rev 31375)
+++ grass/trunk/raster/r.support/front/description.html 2008-05-16 18:40:49 UTC (rev 31376)
@@ -11,7 +11,7 @@
module will run non-interactively. If only the map name is given
<em>r.support</em> will run interactively within a terminal shell and the
user with be prompted for input.
-<P>
+<p>
Freeform metadata information is stored in a "<tt>hist</tt>" file which may be
appended to by using the <b>history</b> option. Currently this is limited to
50 lines of text with a maximum line length of 78 characters. Any input
@@ -32,8 +32,8 @@
<h2>AUTHORS</h2>
-Micharl Shapiro, CERL: Original author<BR>
-<a href="MAILTO:rez at touchofmadness.com">Brad Douglas</a>: GRASS 6 Port<BR>
+Micharl Shapiro, CERL: Original author<br>
+<a href="MAILTO:rez at touchofmadness.com">Brad Douglas</a>: GRASS 6 Port<br>
M. Hamish Bowman: command line enhancements<br>
Markus Neteler: category copy from other map
Modified: grass/trunk/raster/r.univar2/r.univar.html
--- grass/trunk/raster/r.univar2/r.univar.html 2008-05-16 18:39:44 UTC (rev 31375)
+++ grass/trunk/raster/r.univar2/r.univar.html 2008-05-16 18:40:49 UTC (rev 31376)
@@ -1,6 +1,6 @@
-<EM>r.univar</EM> calculates the univariate statistics of a raster map.
+<em>r.univar</em> calculates the univariate statistics of a raster map.
This includes the number of cells counted, minimum and maximum cell values,
range, arithmetic mean, population variance, standard deviation, and
coefficient of variation.
@@ -9,45 +9,45 @@
If the <b>-g</b> flag is given the results are presented in a format suitable
for use in a shell script.
-<H2>NOTES</H2>
+<h2>NOTES</h2>
-As with most GRASS raster modules, <EM>r.univar</EM> operates on the cell
+As with most GRASS raster modules, <em>r.univar</em> operates on the cell
array defined by the current region settings, not the original extent and
-resolution of the input map. See <em><A HREF="g.region.html">g.region</A></em>.
-<P>
+resolution of the input map. See <em><a href="g.region.html">g.region</a></em>.
+<p>
This module can use large amounts of system memory when the <b>-e</b>
extended statistics flag is used with a very large region setting. If the
region is too large the module should exit gracefully with a memory allocation
error. Basic statistics can be calculated using any size input region.
-<H2>TODO</H2>
+<h2>TODO</h2>
<i>mode, skewness, kurtosis</i>
-<H2>SEE ALSO</H2>
+<h2>SEE ALSO</h2>
<em>
-<A HREF="g.region.html">g.region</A><br>
-<A HREF="r3.univar.html">r3.univar</A><br>
-<A HREF="r.univar.sh.html">r.univar.sh</A><br>
-<A HREF="r.average.html">r.average</A><br>
-<A HREF="r.median.html">r.median</A><br>
-<A HREF="r.mode.html">r.mode</A><br>
-<A HREF="r.sum.html">r.sum</A><br>
-<A HREF="r.series.html">r.series</A><br>
-<A HREF="r.stats.html">r.stats</A><br>
-<A HREF="r.statistics.html">r.statistics</A><br>
-<A HREF="v.univar.html">v.univar</A><br>
-<A HREF="v.univar.sh.html">v.univar.sh</A><br>
+<a href="g.region.html">g.region</a><br>
+<a href="r3.univar.html">r3.univar</a><br>
+<a href="r.univar.sh.html">r.univar.sh</a><br>
+<a href="r.average.html">r.average</a><br>
+<a href="r.median.html">r.median</a><br>
+<a href="r.mode.html">r.mode</a><br>
+<a href="r.sum.html">r.sum</a><br>
+<a href="r.series.html">r.series</a><br>
+<a href="r.stats.html">r.stats</a><br>
+<a href="r.statistics.html">r.statistics</a><br>
+<a href="v.univar.html">v.univar</a><br>
+<a href="v.univar.sh.html">v.univar.sh</a><br>
</em>
-<H2>AUTHORS</H2>
+<h2>AUTHORS</h2>
-Hamish Bowman, Otago University, New Zealand<BR>
+Hamish Bowman, Otago University, New Zealand<br>
Extended statistics by Martin Landa
<p>
Modified: grass/trunk/raster/r.univar2/r3.univar.html
--- grass/trunk/raster/r.univar2/r3.univar.html 2008-05-16 18:39:44 UTC (rev 31375)
+++ grass/trunk/raster/r.univar2/r3.univar.html 2008-05-16 18:40:49 UTC (rev 31376)
@@ -1,6 +1,6 @@
-<EM>r3.univar</EM> calculates the univariate statistics for raster3d maps.
+<em>r3.univar</em> calculates the univariate statistics for raster3d maps.
@@ -9,47 +9,47 @@
-<H2>NOTES</H2>
+<h2>NOTES</h2>
-As with most GRASS raster3d modules, <EM>r3.univar</EM> operates on the cell
+As with most GRASS raster3d modules, <em>r3.univar</em> operates on the cell
array defined by the current 3d region settings, not the original extent and
-<P>
+<p>
-<H2>TODO</H2>
+<h2>TODO</h2>
-<H2>SEE ALSO</H2>
+<h2>SEE ALSO</h2>
<em>
-<A HREF="r.univar.html">r.univar</A><br>
+<a href="r.univar.html">r.univar</a><br>
</em>
-<H2>AUTHORS</H2>
+<h2>AUTHORS</h2>
Soeren Gebbert<br>
Code is based on r.univar from<br>
and Martin Landa
Modified: grass/trunk/raster/r.watershed/front/description.html
--- grass/trunk/raster/r.watershed/front/description.html 2008-05-16 18:39:44 UTC (rev 31375)
+++ grass/trunk/raster/r.watershed/front/description.html 2008-05-16 18:40:49 UTC (rev 31376)
@@ -1,107 +1,107 @@
-<EM>r.watershed</EM> generates a set of maps indicating:
+<em>r.watershed</em> generates a set of maps indicating:
1) the location of watershed basins, and
2) the LS and S factors of the Revised Universal Soil Loss Equation (RUSLE).
-<P>
+<p>
<!-- Interactive mode not activated in GRASS 6.
-<EM>r.watershed</EM> can be run either interactively or non-interactively.
+<em>r.watershed</em> can be run either interactively or non-interactively.
If the user types <tt>r.watershed</tt>
on the command line without program arguments, the program will prompt the user
with a verbose description of the input maps. The interactive version of
-<EM>r.watershed</EM> can prepare inputs to lumped-parameter hydrologic models.
-After a verbose interactive session, <EM>r.watershed</EM> will query the user
+<em>r.watershed</em> can prepare inputs to lumped-parameter hydrologic models.
+After a verbose interactive session, <em>r.watershed</em> will query the user
for a number of
map layers. Each map layer's values will be tabulated by watershed basin and sent
to an output file. This output file is organized to ease data entry into a
lumped-parameter hydrologic model program. The non-interactive version of
-<EM>r.watershed</EM> cannot create this file.
+<em>r.watershed</em> cannot create this file.
-<P>
+<p>
The user can run the program non-interactively, by specifying input map names
on the command line. Parameter names may be specified by their
full names, or by any initial string that distinguish them from other parameter names.
-In <EM>r.watershed</EM>'s case, the first two letters of each name sufficiently
+In <em>r.watershed</em>'s case, the first two letters of each name sufficiently
distinguishes parameter names.
-For example, the two expressions below are equivalent inputs to <EM>r.watershed</EM>:
-<P>
-<PRE>
+For example, the two expressions below are equivalent inputs to <em>r.watershed</em>:
+<p>
+<pre>
el=elev.map th=100 st=stream.map ba=basin.map
elevation=elev.map threshold=100 stream=stream.map basin=basin.map
-</PRE>
+</pre>
-<H2>OPTIONS</H2>
+<h2>OPTIONS</h2>
<dl>
-<DT><EM>-m</EM>
+<dt><em>-m</em>
-<DD>Without this flag set, the entire analysis is run in memory
+<dd>Without this flag set, the entire analysis is run in memory
maintained by the operating system. This can be limiting, but is
relatively fast. Setting the flag causes the program to manage memory
on disk which allows larger maps to be processes but is considerably
slower.
-<DT><EM>-4</EM>
+<dt><em>-4</em>
-<DD>Allow only horizontal and vertical flow of water.
+<dd>Allow only horizontal and vertical flow of water.
Stream and slope lengths are approximately the same as outputs from default surface
flow (allows horizontal, vertical, and diagonal flow of water).
This flag will also make the drainage basins look more homogeneous.
-<DT><EM>elevation</EM>
+<dt><em>elevation</em>
-<DD>Input map: Elevation on which entire analysis is based.
+<dd>Input map: Elevation on which entire analysis is based.
-<DT><EM>depression</EM>
+<dt><em>depression</em>
-<DD>Input map: Map layer of actual depressions or sinkholes in the
+<dd>Input map: Map layer of actual depressions or sinkholes in the
landscape that are large enough to slow and store surface runoff from
a storm event. Any non-zero values indicate depressions.
-<DT><EM>flow</EM>
+<dt><em>flow</em>
-<DD>Input map: amount of overland flow per cell. This map indicates the
+<dd>Input map: amount of overland flow per cell. This map indicates the
amount of overland flow units that each cell will contribute to the
watershed basin model. Overland flow units represent the amount of
overland flow each cell contributes to surface flow. If omitted, a
value of one (1) is assumed. The algorithm is D8 flow accumulation.
-<DT><EM>disturbed.land</EM>
+<dt><em>disturbed.land</em>
-<DD>Raster map input layer or value containing the percent of disturbed
+<dd>Raster map input layer or value containing the percent of disturbed
land (i.e., croplands, and construction sites) where the raster or input
-value of 17 equals 17%. If no map or value is given, <EM>r.watershed</EM>
+value of 17 equals 17%. If no map or value is given, <em>r.watershed</em>
assumes no disturbed land. This input is used for the RUSLE calculations.
-<DT><EM>blocking</EM>
+<dt><em>blocking</em>
-<DD>Input map: terrain that will block overland surface flow. Terrain
+<dd>Input map: terrain that will block overland surface flow. Terrain
that will block overland surface flow and restart the slope length
for the RUSLE. Any non-zero values indicate blocking terrain.
-<DT><EM>threshold</EM>
+<dt><em>threshold</em>
-<DD>The minimum size of an exterior watershed basin in cells, if no flow
+<dd>The minimum size of an exterior watershed basin in cells, if no flow
map is input, or overland flow units when a flow map is given.
Warning: low threshold values will dramactically increase run time and
generate difficult too read basin and half.basin results.
This parameter also controls the level of detail in the <em>stream</em>
segments map.
-<DT><EM>max.slope.length</EM>
+<dt><em>max.slope.length</em>
-<DD>Input value indicating the maximum length of overland surface flow
+<dd>Input value indicating the maximum length of overland surface flow
in meters. If overland flow travels greater than the maximum length,
the program assumes the maximum length (it assumes that landscape
characteristics not discernible in the digital elevation model exist
that maximize the slope length). This input is used for the RUSLE calculations
and is a sensitive parameter.
-<DT><EM>accumulation</EM>
+<dt><em>accumulation</em>
-<DD>Output map: The absolute value of each cell in this output map layer is
+<dd>Output map: The absolute value of each cell in this output map layer is
the amount of overland flow that traverses the cell. This value will be
the number of upland cells plus one if no overland flow map is given. If
the overland flow map is given, the value will be in overland flow units.
@@ -110,9 +110,9 @@
negative values cannot have their surface runoff and sedimentation yields
calculated accurately.
-<DT><EM>drainage</EM>
+<dt><em>drainage</em>
-<DD>Output map: drainage direction. Provides the "aspect" for each
+<dd>Output map: drainage direction. Provides the "aspect" for each
cell. Multiplying positive values by 45 will give the direction in
degrees that the surface runoff will travel from that cell. The
value -1 indicates that the cell is a depression area (defined by
@@ -121,124 +121,124 @@
region. The absolute value of these negative cells indicates the
direction of flow.
-<DT><EM>basin</EM>
+<dt><em>basin</em>
-<DD>Output map: Unique label for each watershed basin. Each basin will
+<dd>Output map: Unique label for each watershed basin. Each basin will
be given a unique positive even integer. Areas along edges may not
be large enough to create an exterior watershed basin. 0 values
indicate that the cell is not part of a complete watershed basin
in the current geographic region.
-<DT><EM>stream</EM>
+<dt><em>stream</em>
-<DD>Output map: stream segments. Values correspond to the watershed
+<dd>Output map: stream segments. Values correspond to the watershed
basin values.
-<DT><EM>half.basin</EM>
+<dt><em>half.basin</em>
-<DD>Output map: each half-basin is given a unique value. Watershed
+<dd>Output map: each half-basin is given a unique value. Watershed
basins are divided into left and right sides. The right-hand side
cell of the watershed basin (looking upstream) are given even values
corresponding to the values in basin. The left-hand side
cells of the watershed basin are given odd values which are one less
than the value of the watershed basin.
-<DT><EM>visual</EM>
+<dt><em>visual</em>
-<DD>Output map: useful for visual display of results.
+<dd>Output map: useful for visual display of results.
Surface runoff accumulation with the values
modified to provide for easy display. All negative accumulation values
are changed to zero. All positive values above the basin threshold
are given the value of the <em>threshold</em> parameter.
-<DT><EM>length.slope</EM>
+<dt><em>length.slope</em>
-<DD>Output map: slope length and steepness (LS) factor. Contains the LS
+<dd>Output map: slope length and steepness (LS) factor. Contains the LS
factor for the Revised Universal Soil Loss Equation. Equations taken
-from <EM>Revised Universal Soil Loss Equation for Western Rangelands</EM>
+from <em>Revised Universal Soil Loss Equation for Western Rangelands</em>
(Weltz et al. 1987).
Since the LS factor is a small number, it is multiplied by 100 for the
GRASS output map.
-<DT><EM>slope.steepness</EM>
+<dt><em>slope.steepness</em>
-<DD>Output map: slope steepness (S) factor for RUSLE.
+<dd>Output map: slope steepness (S) factor for RUSLE.
Contains the revised S factor for the Universal Soil
Loss Equation. Equations taken from article entitled
-<EM>Revised Slope Steepness Factor for the Universal Soil
-Loss Equation</EM> (McCool et al. 1987). Since the S factor
+<em>Revised Slope Steepness Factor for the Universal Soil
+Loss Equation</em> (McCool et al. 1987). Since the S factor
is a small number (usually less than one), it is multiplied
by 100 for the GRASS output map layer.
</dd>
</dl>
-<H2>NOTES</H2>
+<h2>NOTES</h2>
-<EM>r.watershed</EM> uses an algorithm designed to minimize the impact of
-DEM data errors. This algorithm works slower than <EM>r.terraflow</EM> but
+<em>r.watershed</em> uses an algorithm designed to minimize the impact of
+DEM data errors. This algorithm works slower than <em>r.terraflow</em> but
provides more accurate results in areas of low slope as well as DEMs
constructed with techniques that mistake canopy tops as the ground elevation.
Kinner et al. (2005), for example, used SRTM and IFSAR DEMs to compare
-<EM>r.watershed</EM> against <EM>r.terraflow</EM> results in Panama.
-<EM>r.terraflow</EM> was unable to replicate stream locations in the larger
-valleys while <EM>r.watershed</EM> performed much better. Thus, if forest
+<em>r.watershed</em> against <em>r.terraflow</em> results in Panama.
+<em>r.terraflow</em> was unable to replicate stream locations in the larger
+valleys while <em>r.watershed</em> performed much better. Thus, if forest
canopy exists in valleys, SRTM, IFSAR, and similar data products will cause
-major errors in <EM>r.terraflow</EM> stream output. Under similar conditions,
-<EM>r.watershed</EM> will generate better <b>stream</b> and <b>half.basin</b>
-results. If watershed divides contain flat to low slope, <EM>r.watershed</EM>
-will generate better basin results than <EM>r.terraflow</EM>.
-(<EM>r.terraflow</EM> uses the same type of algorithm as ESRI's ArcGIS
+major errors in <em>r.terraflow</em> stream output. Under similar conditions,
+<em>r.watershed</em> will generate better <b>stream</b> and <b>half.basin</b>
+results. If watershed divides contain flat to low slope, <em>r.watershed</em>
+will generate better basin results than <em>r.terraflow</em>.
+(<em>r.terraflow</em> uses the same type of algorithm as ESRI's ArcGIS
watershed software which fails under these conditions.) Also, if watershed
divides contain forest canopy mixed with uncanopied areas using SRTM, IFSAR,
-and similar data products, <EM>r.watershed</EM> will generate better basin
-results than <EM>r.terraflow</EM>.
+and similar data products, <em>r.watershed</em> will generate better basin
+results than <em>r.terraflow</em>.
-<P>
-There are two versions of this program: <EM>ram</EM> and <EM>seg</EM>.
-Which is version is run depends on whether the <EM>-m</EM> flag is set.
-<BR>
-The <EM>ram</EM> version uses virtual memory managed by the operating
-system to store all the data structures and is faster than the <EM>seg</EM>
+<p>
+There are two versions of this program: <em>ram</em> and <em>seg</em>.
+Which is version is run depends on whether the <em>-m</em> flag is set.
+<br>
+The <em>ram</em> version uses virtual memory managed by the operating
+system to store all the data structures and is faster than the <em>seg</em>
version;
-<EM>seg</EM> uses the GRASS segmentation library which manages data in disk
-files. Thus <EM>seg</EM> uses much less system memory (RAM) allowing other
+<em>seg</em> uses the GRASS segmentation library which manages data in disk
+files. Thus <em>seg</em> uses much less system memory (RAM) allowing other
processes to operate on the same CPU, even when the current geographic
region is huge.
-<BR>
+<br>
Due to memory requirements of both programs, it is quite easy to run out of
-memory when working with huge map regions. If the <EM>ram</EM> version runs
+memory when working with huge map regions. If the <em>ram</em> version runs
out of memory and the resolution size of the current geographic region
cannot be increased, either more memory needs to be added to the computer,
-or the swap space size needs to be increased. If <EM>seg</EM> runs out of
+or the swap space size needs to be increased. If <em>seg</em> runs out of
memory, additional disk space needs to be freed up for the program to run.
-<P>
+<p>
Both versions use the A<sup>T</sup> least-cost search algorithm to determine
the flow of water over the landscape (see <a href="#seealso">SEE ALSO</a>
section).
The algorithm produces results similar to those obtained when running
-<EM><A HREF="r.cost.html">r.cost</A></EM> and
-<EM><A HREF="r.drain.html">r.drain</A></EM> on every cell on the map.
+<em><a href="r.cost.html">r.cost</a></em> and
+<em><a href="r.drain.html">r.drain</a></em> on every cell on the map.
-<P>
+<p>
In many situations, the elevation data will be too finely detailed for
-the amount of time or memory available. Running <EM>r.watershed</EM> may
+the amount of time or memory available. Running <em>r.watershed</em> may
require use of a coarser resolution. To make the results more closely
resemble the finer terrain data, create a map layer containing the
lowest elevation values at the coarser resolution. This is done by:
1) Setting the current geographic region equal to the elevation map
-layer with <EM>g.region</EM>, and 2) Use the <EM>r.neighbors</EM> or
-<EM>r.resamp.stats</EM> command to find the lowest value for an area
+layer with <em>g.region</em>, and 2) Use the <em>r.neighbors</em> or
+<em>r.resamp.stats</em> command to find the lowest value for an area
equal in size to the desired resolution. For example, if the resolution
of the elevation data is 30 meters and the resolution of the geographic
-region for <EM>r.watershed</EM> will be 90 meters: use the minimum
+region for <em>r.watershed</em> will be 90 meters: use the minimum
function for a 3 by 3 neighborhood. After changing to the resolution at
-which <EM>r.watershed</EM> will be run, <EM>r.watershed</EM> should be run
-using the values from the <EM>neighborhood</EM> output map layer that
+which <em>r.watershed</em> will be run, <em>r.watershed</em> should be run
+using the values from the <em>neighborhood</em> output map layer that
represents the minimum elevation within the region of the coarser cell.
-<P>
+<p>
The minimum size of drainage basins, defined by the <em>threshold</em>
parameter, is only relevant for those watersheds with a single stream
having at least the <em>threshold</em> of cells flowing into it.
@@ -248,8 +248,8 @@
an interior stream segment is determined by the distance between the
tributaries flowing into it.
-<P>
-The <EM>r.watershed</EM> program does not require the user to have the
+<p>
+The <em>r.watershed</em> program does not require the user to have the
current geographic region filled with elevation values. Areas without
elevation data MUST be masked out, by creating a raster map (or raster
reclassification) named <tt>MASK</tt>. Areas
@@ -258,33 +258,33 @@
unimportant areas can significantly reduce processing time if the watersheds
of interest occupy a small percentage of the overall area.
-<P>
+<p>
Zero data values will be treated as elevation data (not no_data).
-<P>
+<p>
To isolate an individual river network using the output of this module,
a number of approaches may be considered.
-<OL>
-<LI>Use a resample of the basins catchment raster map as a MASK.<BR>
+<ol>
+<li>Use a resample of the basins catchment raster map as a MASK.<br>
The equivalent vector map method is similar using <em>v.select</em> or
<em>v.overlay</em>.
-<LI>Use the <em>r.cost</em> module with a point in the river as a starting
+<li>Use the <em>r.cost</em> module with a point in the river as a starting
point.
-<LI>Use the <em>v.net.iso</em> module with a node in the river as a
+<li>Use the <em>v.net.iso</em> module with a node in the river as a
starting point.
-</OL>
+</ol>
-<P>
+<p>
To create <i>river mile</i> segmentation from a vectorized streams map,
try the <em>v.net.iso</em> or <em>v.lrs.segment</em> modules.
-<H2>EXAMPLES</H2>
+<h2>EXAMPLES</h2>
<i>These examples use the Spearfish sample dataset.</i>
-<P>
+<p>
Convert <em>r.watershed</em> streams map output to a vector layer.
-<P>
+<p>
If you want a detailed stream network, set the threshold option
small to create lots of catchment basins, as only one stream is
presented per catchment. The r.to.vect -v flag preserves the
@@ -294,9 +294,9 @@
r.watershed elev=elevation.dem stream=rwater.stream
r.to.vect -v in=rwater.stream out=rwater_stream
</pre></div>
-<BR>
+<br>
-<P>
+<p>
Set a nice color table for the accumulation map:
MAP=rwater.accum
@@ -320,10 +320,10 @@
100% red
EOF
</pre></div>
-<BR>
+<br>
-<P>
+<p>
Create a more detailed stream map using the accumulation map and convert
it to a vector output map. The accumulation cut-off, and therefore fractal
dimension, is arbitrary; in this example we use the map's mean number of
@@ -351,9 +351,9 @@
points map and upload to that ?? -->
<!-- Note value column containing accumulation cells in output vector
may not necessarily reference the downstream end of the line! drop it? -->
-<BR>
+<br>
-<P>
+<p>
Create watershed basins map and convert to a vector polygon map
r.watershed elev=elevation.dem basin=rwater.basin thresh=15000
@@ -361,50 +361,50 @@
v.db.dropcol map=rwater_basins column=label
v.db.renamecol map=rwater_basins column=value,catchment
</pre></div>
-<BR>
+<br>
-<P>
+<p>
Display output in a nice way
r.shaded.relief map=elevation.dem
d.shadedmap rel=elevation.dem.shade drape=rwater.basin bright=40
d.vect rwater_course color=orange
</pre></div>
-<BR>
+<br>
<a name="references"></a>
-<H2>REFERENCES</H2>
+<h2>REFERENCES</h2>
Ehlschlaeger, C. (1989). <i>Using the A<sup>T</sup> Search Algorithm
to Develop Hydrologic Models from Digital Elevation Data</i>,
<b>Proceedings of International Geographic Information Systems (IGIS)
-Symposium '89</b>, pp 275-281 (Baltimore, MD, 18-19 March 1989).<BR>
+Symposium '89</b>, pp 275-281 (Baltimore, MD, 18-19 March 1989).<br>
URL: <a href="http://faculty.wiu.edu/CR-Ehlschlaeger2/older/IGIS/paper.html">
http://faculty.wiu.edu/CR-Ehlschlaeger2/older/IGIS/paper.html</a>
-<P>
+<p>
Kinner D., H. Mitasova, R. Harmon, L. Toma, R., Stallard. (2005).
<i>GIS-based Stream Network Analysis for The Chagres River Basin,
Republic of Panama</i>. <b>The Rio Chagres: A Multidisciplinary Profile of
-a Tropical Watershed</b>, R. Harmon (Ed.), Springer/Kluwer, p.83-95.<BR>
+a Tropical Watershed</b>, R. Harmon (Ed.), Springer/Kluwer, p.83-95.<br>
URL: <a href="http://skagit.meas.ncsu.edu/%7Ehelena/measwork/panama/panama.html">
http://skagit.meas.ncsu.edu/~helena/measwork/panama/panama.html</a>
-<P>
+<p>
McCool et al. (1987). <i>Revised Slope Steepness Factor for the Universal
Soil Loss Equation</i>, <b>Transactions of the ASAE</b> Vol 30(5).
-<P>
+<p>
Weltz M. A., K. G. Renard, J. R. Simanton (1987). <i>Revised Universal Soil
Loss Equation for Western Rangelands</i>, <b>U.S.A./Mexico Symposium of
Strategies for Classification and Management of Native Vegetation for
Food Production In Arid Zones</b> (Tucson, AZ, 12-16 Oct. 1987).
<a name="seealso"></a>
-<H2>SEE ALSO</H2>
+<h2>SEE ALSO</h2>
-<EM>
+<em>
<a href="r.cost.html">r.cost</a>,
<a href="r.drain.html">r.drain</a>,
@@ -416,10 +416,10 @@
<a href="r.terraflow.html">r.terraflow</a>,
<a href="r.topidx.html">r.topidx</a>,
<a href="r.water.outlet.html">r.water.outlet</a>
-</EM>
+</em>
-<H2>AUTHOR</H2>
+<h2>AUTHOR</h2>
Charles Ehlschlaeger, U.S. Army Construction Engineering Research Laboratory
<p>
