[GRASS-SVN] r31387 - grass/branches/develbranch_6/display/d.vect
svn_grass at osgeo.org
Sat May 17 09:25:44 EDT 2008
Author: neteler
Date: 2008-05-17 09:25:44 -0400 (Sat, 17 May 2008)
New Revision: 31387
grass/branches/develbranch_6/display/d.vect/area.c
grass/branches/develbranch_6/display/d.vect/description.html
grass/branches/develbranch_6/display/d.vect/local_proto.h
grass/branches/develbranch_6/display/d.vect/main.c
grass/branches/develbranch_6/display/d.vect/plot1.c
support for z height (geometry) colors added
Modified: grass/branches/develbranch_6/display/d.vect/area.c
--- grass/branches/develbranch_6/display/d.vect/area.c 2008-05-17 09:31:46 UTC (rev 31386)
+++ grass/branches/develbranch_6/display/d.vect/area.c 2008-05-17 13:25:44 UTC (rev 31387)
@@ -17,7 +17,7 @@
const struct color_rgb *bcolor, const struct color_rgb *fcolor,
int chcat, int id_flag, int table_colors_flag, int cats_color_flag,
struct Cell_head *window, char *rgb_column, int default_width,
- char *width_column, double width_scale) {
+ char *width_column, double width_scale, int z_color_flag, char *style) {
int num, area, isle, n_isles, n_points;
double xl, yl;
@@ -211,6 +211,23 @@
continue;
+ /* z height colors */
+ if( z_color_flag && Vect_is_3d (Map)) {
+ BOUND_BOX box;
+ double zval;
+ struct Colors colors;
+ Vect_get_map_box (Map, &box );
+ zval = Points->z[0];
+ G_debug (3, "display area %d, centroid %d, cat %d, x: %f, y: %f, z: %f", area, centroid,
+ cat, Points->x[0], Points->y[0], Points->z[0]);
+ rgb = 1;
+ G_make_fp_colors(&colors, style, box.B, box.T);
+ G_get_raster_color(&zval, &red, &grn, &blu, &colors, DCELL_TYPE);
+ G_debug (3, "b %d, g: %d, r %d", blu, grn, red);
if( table_colors_flag ) {
centroid = Vect_get_area_centroid ( Map, area );
if( cat >= 0 ) {
@@ -249,7 +266,7 @@
rgb = 0;
} /* end if table_colors_flag */
/* random colors */
if( cats_color_flag ) {
rgb = 0;
@@ -305,8 +322,8 @@
D_line_width(width);
} /* end if nrec_width */
- if ( fcolor ) {
- if (!table_colors_flag && !cats_color_flag) {
+ if ( fcolor || (z_color_flag && Vect_is_3d (Map)) ) {
+ if (!table_colors_flag && !cats_color_flag && !z_color_flag) {
R_RGB_color(fcolor->r, fcolor->g, fcolor->b);
plot_polygon ( Points->x, Points->y, Points->n_points);
Modified: grass/branches/develbranch_6/display/d.vect/description.html
--- grass/branches/develbranch_6/display/d.vect/description.html 2008-05-17 09:31:46 UTC (rev 31386)
+++ grass/branches/develbranch_6/display/d.vect/description.html 2008-05-17 13:25:44 UTC (rev 31387)
@@ -66,6 +66,27 @@
d.vect -c soils where="label='VBF'" display=shape,attr attrcol=label
</pre></div>
+<p>
+3D points, 3D lines and 3D polygons colorized according to z height:
+<div class="code"><pre>
+g.region rast=elevation.10m
+r.random elevation.10m n=5000 vector=random3d -d
+d.mon x0
+# display as black points
+d.vect random3d
+# display 3D points colorized according to z height
+d.vect -z random3d zcol=gyr
+# 3D contour lines
+r.contour elevation.10m out=contour20m step=20
+d.vect -z contour20m zcol=gyr
+# generate 3D triangles
+v.delaunay random3d out=random3d_del
+# display 3D polygons colorized according to z height
+d.vect -z random3d_del type=area zcol=gyr
+</pre></div>
<h2>SEE ALSO</h2>
<em>
@@ -78,8 +99,10 @@
<a HREF="sql.html">GRASS SQL interface</a>
</em>
-<h2>AUTHOR</h2>
+<h2>AUTHORS</h2>
-Radim Blazek, ITC-Irst, Trento, Italy
+CERL<br>
+Radim Blazek, ITC-Irst, Trento, Italy<br>
+other GRASS developers
<p><i>Last changed: $Date$</i><p>
Modified: grass/branches/develbranch_6/display/d.vect/local_proto.h
--- grass/branches/develbranch_6/display/d.vect/local_proto.h 2008-05-17 09:31:46 UTC (rev 31386)
+++ grass/branches/develbranch_6/display/d.vect/local_proto.h 2008-05-17 13:25:44 UTC (rev 31387)
@@ -3,11 +3,11 @@
FILE *open_vect(char *, char *);
int close_vect(FILE *);
-int plot1(struct Map_info *, int, int, struct cat_list *, const struct color_rgb *, const struct color_rgb *, int, SYMBOL *, int, int, int, int, char *, int, char *, double);
+int plot1(struct Map_info *, int, int, struct cat_list *, const struct color_rgb *, const struct color_rgb *, int, SYMBOL *, int, int, int, int, char *, int, char *, double, int, char *);
int label(struct Map_info *, int, int, struct cat_list *, LATTR *, int);
int topo(struct Map_info *, int, int, LATTR *);
int dir(struct Map_info *, int, struct cat_list *, int);
-int darea(struct Map_info *, struct cat_list *, const struct color_rgb *, const struct color_rgb *, int, int, int, int, struct Cell_head *, char *, int, char *, double);
+int darea(struct Map_info *, struct cat_list *, const struct color_rgb *, const struct color_rgb *, int, int, int, int, struct Cell_head *, char *, int, char *, double, int, char *);
int attr(struct Map_info *, int, char *, struct cat_list *, LATTR *, int);
int zcoor(struct Map_info *, int, LATTR *);
int test_bg_color (const char*);
Modified: grass/branches/develbranch_6/display/d.vect/main.c
--- grass/branches/develbranch_6/display/d.vect/main.c 2008-05-17 09:31:46 UTC (rev 31386)
+++ grass/branches/develbranch_6/display/d.vect/main.c 2008-05-17 13:25:44 UTC (rev 31387)
@@ -3,9 +3,9 @@
* MODULE: d.vect
* AUTHOR(S): CERL, Radim Blazek, others
- * PURPOSE: Display the binary vector (dig) file that the user wants displayed
+ * PURPOSE: Display the binary vector file that the user wants displayed
* on top of the current image.
- * COPYRIGHT: (C) 2004-2006 by the GRASS Development Team
+ * COPYRIGHT: (C) 2004-2008 by the GRASS Development Team
* This program is free software under the GNU General Public
* License (>=v2). Read the file COPYING that comes with GRASS
@@ -95,7 +95,7 @@
char map_name[128] ;
struct GModule *module;
struct Option *map_opt;
- struct Option *color_opt, *fcolor_opt, *rgbcol_opt;
+ struct Option *color_opt, *fcolor_opt, *rgbcol_opt, *zcol_opt;
struct Option *type_opt, *display_opt;
struct Option *icon_opt, *size_opt;
struct Option *where_opt;
@@ -106,7 +106,7 @@
struct Option *width_opt, *wcolumn_opt, *wscale_opt;
struct Option *render_opt;
struct Flag *verbose_flag; /* please remove before GRASS 7 released */
- struct Flag *id_flag, *table_acolors_flag, *cats_acolors_flag, *x_flag;
+ struct Flag *id_flag, *table_acolors_flag, *cats_acolors_flag, *x_flag, *zcol_flag;
struct cat_list *Clist;
int *cats, ncat;
LATTR lattr;
@@ -182,6 +182,15 @@
_("Name of color definition column (for use with -a flag)");
rgbcol_opt->answer = "GRASSRGB" ;
+ zcol_opt = G_define_option();
+ zcol_opt->key = "zcolor";
+ zcol_opt->key_desc = "style";
+ zcol_opt->type = TYPE_STRING;
+ zcol_opt->required = NO;
+ zcol_opt->description = _("Type of color table (for use with -z flag)");
+ zcol_opt->answer = "terrain";
+ zcol_opt->guisection = _("Colors");
/* Lines */
width_opt = G_define_option() ;
width_opt->key = "width";
@@ -352,6 +361,11 @@
_("Don't add to list of vectors and commands in monitor "
"(it won't be drawn if the monitor is refreshed)");
+ zcol_flag = G_define_flag ();
+ zcol_flag->key = 'z';
+ zcol_flag->description =
+ _("Colorize polygons according to z height)");
/* Check command line */
if (G_parser(argc, argv))
exit(EXIT_FAILURE);
@@ -650,7 +664,8 @@
has_color ? &color : NULL, has_fcolor ? &fcolor : NULL, chcat,
(int) id_flag->answer, table_acolors_flag->answer,
cats_acolors_flag->answer, &window, rgbcol_opt->answer,
- default_width, wcolumn_opt->answer, width_scale );
+ default_width, wcolumn_opt->answer, width_scale,
+ zcol_flag->answer, zcol_opt->answer );
if ( wcolumn_opt->answer )
D_line_width(default_width);
@@ -666,7 +681,7 @@
has_color ? &color : NULL, has_fcolor ? &fcolor : NULL, chcat, Symb,
size, (int) id_flag->answer, table_acolors_flag->answer,
cats_acolors_flag->answer, rgbcol_opt->answer, default_width,
- wcolumn_opt->answer, width_scale) ;
+ wcolumn_opt->answer, width_scale, zcol_flag->answer, zcol_opt->answer) ;
Modified: grass/branches/develbranch_6/display/d.vect/plot1.c
--- grass/branches/develbranch_6/display/d.vect/plot1.c 2008-05-17 09:31:46 UTC (rev 31386)
+++ grass/branches/develbranch_6/display/d.vect/plot1.c 2008-05-17 13:25:44 UTC (rev 31387)
@@ -135,7 +135,7 @@
const struct color_rgb *color, const struct color_rgb *fcolor,
int chcat, SYMBOL *Symb, int size, int id_flag,
int table_colors_flag, int cats_color_flag, char *rgb_column,
- int default_width, char *width_column, double width_scale)
+ int default_width, char *width_column, double width_scale, int z_color_flag, char *style)
int i, ltype, nlines = 0, line, cat = -1;
double *x, *y;
@@ -323,7 +323,22 @@
if (Cats->n_cats > 0 && !found) continue;
+ BOUND_BOX box;
+ double zval;
+ G_debug (3, "display line %d, cat %d, x: %f, y: %f, z: %f", line,
+ custom_rgb = TRUE;
/* only first category */
@@ -461,8 +476,8 @@
D_symbol(Symb, x0, y0, line_color, fill_color);
- } else if (color || custom_rgb) {
+ } else if (color || custom_rgb || (z_color_flag && Vect_is_3d (Map))) {
R_RGB_color(color->r, color->g, color->b);
else {
if (custom_rgb)
