[GRASS-SVN] r31390 - grass/branches/develbranch_6/gui/wxpython/docs
svn_grass at osgeo.org
Sat May 17 12:31:40 EDT 2008
Author: martinl
Date: 2008-05-17 12:31:40 -0400 (Sat, 17 May 2008)
New Revision: 31390
Added:
grass/branches/develbranch_6/gui/wxpython/docs/wxGUI.Vector_Digitizing_Tool.html
grass/branches/develbranch_6/gui/wxpython/docs/wxGUI_vector_digitizer_toolbar.jpg
Removed:
grass/branches/develbranch_6/gui/wxpython/docs/wxGUI.Digitization_Tool.html
grass/branches/develbranch_6/gui/wxpython/docs/Makefile
grass/branches/develbranch_6/gui/wxpython/docs/wxGUI.html
grass/branches/develbranch_6/gui/wxpython/docs/wxGUI_layer_manager.jpg
grass/branches/develbranch_6/gui/wxpython/docs/wxGUI_map_display.jpg
wxGUI: initial version of manual page for vector digitizer added
Modified: grass/branches/develbranch_6/gui/wxpython/docs/Makefile
--- grass/branches/develbranch_6/gui/wxpython/docs/Makefile 2008-05-17 15:53:48 UTC (rev 31389)
+++ grass/branches/develbranch_6/gui/wxpython/docs/Makefile 2008-05-17 16:31:40 UTC (rev 31390)
@@ -1,6 +1,6 @@
MODULE_TOPDIR = ../../..
-FILES = wxGUI wxGUI.Digitization_Tool wxGUI.Attribute_Table_Manager
+FILES = wxGUI wxGUI.Vector_Digitizing_Tool wxGUI.Attribute_Table_Manager
include $(MODULE_TOPDIR)/include/Make/Platform.make
include $(MODULE_TOPDIR)/include/Make/Grass.make
Deleted: grass/branches/develbranch_6/gui/wxpython/docs/wxGUI.Digitization_Tool.html
--- grass/branches/develbranch_6/gui/wxpython/docs/wxGUI.Digitization_Tool.html 2008-05-17 15:53:48 UTC (rev 31389)
+++ grass/branches/develbranch_6/gui/wxpython/docs/wxGUI.Digitization_Tool.html 2008-05-17 16:31:40 UTC (rev 31390)
@@ -1,17 +0,0 @@
-<h2>DESCRIPTION</h2>
-Add description here.
-<h2>SEE ALSO</h2>
-<em>
-<a href="v.digit.html">v.digit</a>,
-<a href="v.edit.html">v.edit</a>
-</em>
-<h2>AUTHORS</h2>
-Martin Landa, Czech Technical University in Prague, Czech Republic
-<p>
-<i>$Date$</i>
Copied: grass/branches/develbranch_6/gui/wxpython/docs/wxGUI.Vector_Digitizing_Tool.html (from rev 31371, grass/branches/develbranch_6/gui/wxpython/docs/wxGUI.Digitization_Tool.html)
--- grass/branches/develbranch_6/gui/wxpython/docs/wxGUI.Vector_Digitizing_Tool.html (rev 0)
+++ grass/branches/develbranch_6/gui/wxpython/docs/wxGUI.Vector_Digitizing_Tool.html 2008-05-17 16:31:40 UTC (rev 31390)
@@ -0,0 +1,192 @@
+<h2>DESCRIPTION</h2>
+<i>Vector digitizing tool</i> is
+a <em><a href="wxGUI.html">wxGUI</a></em> component intended for
+interactive editing vector maps
+(see <em><a href="v.edit.html">v.edit</a></em> for non-interactive
+vector editing GRASS capabilities).
+<p>
+Currently, only 2D vector features (points, lines, centroids and
+boundaries) can be edited.
+Vector features can be selected using mouse or by query (e.g. minimal
+vector line length). Vector features can be selected by bounding box
+or simply by mouse click (based on "Settings"->"General"->"Select
+threshold" value).
+<p>
+Vector digitizer can be activated from Main toolbar in Map Display by
+selecting "Digitize" from "Tools" combobox. Vector map to be edited
+can be afterwards selected from digitizer toolbar ("Select vector map"
+combobox, note that only vector maps from the current layer tree in Layer
+Manager are available).
+Vector digitizer can be alternatively also activated from contextual
+menu in Layer Manager by selecting "Start editing" on selected vector
+map in the layer tree.
+<p>
+New vector map can be easily created from digitizer toolbar by
+selecting "New vector map" in "Select vector map" combobox. A new
+vector map is created, added to the current layer tree in Layer
+Manager and opened for editing. "Select vector map" combobox in
+digitizer toolbar also allows switching easily between vector maps to be
+edited.
+<h2>NOTES</h2>
+<i>Dead (deleted)</i> are internally only marked in the geometry file
+as 'dead' but it remains there and occupies space. Any vector module
+used afterwards on this vector map which really reads and writes
+vector geometry (so not <em><a href="g.copy.html">g.copy</a></em>)
+will writes only features which are 'alive'.
+<p>
+<i>Added or modified</i> vector features are <i>snapped</i> to
+existing vector features ("Settings"->"General"->"Snapping", nodes or vertices)
+based on "Settings"->"General"->"Snapping threshold" value. To
+disable snapping set up snapping threshold to '0'.
+<h2>Digitizer toolbar</h2>
+<center>
+<br><img src="wxGUI_vector_digitizer_toolbar.jpg" border="1"><br><br>
+</center>
+<dl>
+ <dt><img src="icons/silk/bullet_add.png"> Digitize new point</dt>
+ <dd>Add new point to vector map and optionally define its
+ attributes.</dd>
+ <dt><img src="icons/silk/vector_add.png"> Digitize new line</dt>
+ <dd>Add new line to vector map and optionally define its
+ attributes.</dd>
+ <dt><img src="icons/silk/shape_handles.png"> Digitize new boundary</dt>
+ <dd>Add new boundary to vector map and optionally define its
+ attributes.</dd>
+ <dt><img src="icons/silk/shape_square_add.png"> Digitize new centroid</dt>
+ <dd>Add new centroid to vector map and optionally define its
+ attributes.</dd>
+ <dt><img src="icons/silk/chart_line.png"> Move vertex</dt>
+ <dd>Move selected vertex of linear feature. Thus shape of linear
+ feature is changed.</dd>
+ <dt><img src="icons/silk/chart_line_add.png"> Add vertex</dt>
+ <dd>Add new vertex to selected linear feature (shape not
+ changed).</dd>
+ <dt><img src="icons/silk/chart_line_delete.png"> Remove vertex</dt>
+ <dd>Remove selected vertex from linear feature. Thus shape of selected
+ feature can be changed.</dd>
+ <dt><img src="icons/silk/chart_line_link.png"> Split line/boundary</dt>
+ <dd>Split selected linear feature on given position to separate
+ vector features.</dd>
+ <dt><img src="icons/silk/chart_line_edit.png"> Edit line/boundary</dt>
+ <dd>Edit selected linear feature, add new segments or remove
+ existing segments of linear feature.</dd>
+ <dt><img src="icons/silk/bullet_go.png"> Move feature(s)</dt>
+ <dd>Move selected vector features. Selection can be done by mouse or
+ by query.</dd>
+ <dt><img src="icons/silk/vector_delete.png"> Delete feature(s)</dt>
+ <dd>Delete selected vector features. Selection can be done by mouse
+ or by query.</dd>
+ <dt><img src="icons/silk/chart_organisation.png"> Display/update categories</dt>
+ <dd>Display categories of selected vector feature. Category settings
+ can be modified, new layer/category pairs added or already defined pairs
+ removed.</dd>
+ <dt><img src="icons/silk/chart_organisation_add.png"> Copy categories</dt>
+ <dd>Copy category settings of selected vector feature to other
+ vector features. Layer/category pairs of source vector features are
+ appended to the target feature category settings. Existing
+ layer/category pairs are not removed from category settings of the
+ target features.</dd>
+ <dt><img src="icons/silk/table.png"> Display/update attributes</dt>
+ <dd>Display attributes of selected vector feature (based on its
+ category settings). Attributes can be also modified. Same
+ functionality is accessible from Main toolbar "Query vector map
+ (editable mode)".</dd>
+ <dt><img src="icons/silk/plugin.png"> Additional tools</dt>
+ <dd>
+ <ul>
+ <li>Copy features from (background) map<br> Make identical copy of
+ selected vector features. If background vector map
+ ("Settings"->"General"->"Background map") is given copy
+ features from background vector map, not from currently
+ modified vector map.</li>
+ <li>Flip selected lines/boundaries<br> Flip direction of
+ selected linear features (lines or boundaries).</li>
+ <li>Merge selected lines/boundaries<br> Merge (at least two)
+ selected vector lines or boundaries. The geometry of the
+ merged vector lines can be changed. If the second line from
+ two selected lines is in opposite direction to the first, it
+ will be flipped. See also
+ module <em><a href="v.build.polylines.html">v.build.polylines</a></em>.</li>
+ <li>Break selected lines/boundaries at intersection<br> Split
+ given vector line or boundary into two lines on given position
+ (based on <em><a href="v.clean.html">v.clean</a></em>,
+ tool=break).</li>
+ <li>Snap selected lines/boundaries (only to nodes)<br> Snap
+ vector features in given threshold. See also
+ module <em><a href="v.clean.html">v.clean</a></em>. Note that
+ this tool supports only snapping to nodes. Snapping to vector
+ features from background vector map is not currently
+ supported.</li>
+ <li>Connect two selected lines/boundaries<br> Connect selected
+ lines or boundaries, the first given line is connected to the
+ second one. The second line is broken if necessary. The lines
+ are connected only if distance between them is not greater
+ than snapping threshold value.</li>
+ <li>Query tool<br>Select vector features by min/max length value
+ (linear features or dangles).</li>
+ <li>Z-bulk labeling of 3D lines<br> Assign z coordinate to 3D
+ vector lines in bounding box.</li>
+ <li>Feature type conversion<br> Change feature type of selected
+ geometry features. Points are converted to centroids,
+ centroids to points, lines to boundaries and boundaries to
+ lines.</li>
+ </ul>
+ </dd>
+ <dt><img src="icons/silk/arrow_undo.png"> Undo</dt>
+ <dd>Undo previous operations.</dd>
+ <dt><img src="icons/silk/color_swatch.png"> Settings</dt>
+ <dd>Dialog for vector digitizer settings.</dd>
+ <dt><img src="icons/silk/door_in.png"> Quit digitizing tool</dt>
+ <dd>Changes in vector map can be optionally discarded when
+ digitizing session is quited.</dd>
+</dl>
+<h2>SEE ALSO</h2>
+<em>
+<a href="v.edit.html">v.edit</a>,
+<a href="v.category.html">v.category</a>
+</em>
+<p>
+See also <a href="http://grass.osgeo.org/wiki/WxPython-based_GUI_for_GRASS#Vector_digitizer">Wiki</a> page.
+<p>
+TCL/TK-based <a href="v.digit.html">v.digit</a>.
+<h2>AUTHORS</h2>
+Martin Landa, FBK-irst, Trento, Italy
+<p>
+<i>$Date$</i>
Modified: grass/branches/develbranch_6/gui/wxpython/docs/wxGUI.html
--- grass/branches/develbranch_6/gui/wxpython/docs/wxGUI.html 2008-05-17 15:53:48 UTC (rev 31389)
+++ grass/branches/develbranch_6/gui/wxpython/docs/wxGUI.html 2008-05-17 16:31:40 UTC (rev 31390)
@@ -398,14 +398,12 @@
<h2>SEE ALSO</h2>
<em>
-<a href="wxGUI.Digitization_Tool.html">Digitization tool</a>,
+<a href="wxGUI.Vector_Digitizing_Tool.html">Vector digitizing tool</a>,
<a href="wxGUI.Attribute_Table_Manager.html">Attribute Table Manager</a>
</em>
<p>
-<em>
-<a href="http://grass.osgeo.org/wiki/WxPython-based_GUI_for_GRASS">Wiki page</a>
-</em>
+See also <a href="http://grass.osgeo.org/wiki/WxPython-based_GUI_for_GRASS">Wiki</a> page.
<p>
<em>
Property changes on: grass/branches/develbranch_6/gui/wxpython/docs/wxGUI_layer_manager.jpg
___________________________________________________________________
- application/octet-stream
+ image/jpg
Property changes on: grass/branches/develbranch_6/gui/wxpython/docs/wxGUI_map_display.jpg
+ image/jpg
Added: grass/branches/develbranch_6/gui/wxpython/docs/wxGUI_vector_digitizer_toolbar.jpg
(Binary files differ)
Property changes on: grass/branches/develbranch_6/gui/wxpython/docs/wxGUI_vector_digitizer_toolbar.jpg
+ image/jpg
