[GRASS-SVN] r31415 - grass/trunk
svn_grass at osgeo.org
Sun May 18 17:12:26 EDT 2008
Author: neteler
Date: 2008-05-18 17:12:26 -0400 (Sun, 18 May 2008)
New Revision: 31415
grass/trunk/config.guess
grass/trunk/config.sub
Update to current state (from http://git.savannah.gnu.org), see trac #158) (merge from devel_grass6)
Modified: grass/trunk/config.guess
--- grass/trunk/config.guess 2008-05-18 21:12:03 UTC (rev 31414)
+++ grass/trunk/config.guess 2008-05-18 21:12:26 UTC (rev 31415)
@@ -1,9 +1,10 @@
#! /bin/sh
# Attempt to guess a canonical system name.
# Copyright (C) 1992, 1993, 1994, 1995, 1996, 1997, 1998, 1999,
-# 2000, 2001, 2002, 2003, 2004, 2005 Free Software Foundation, Inc.
+# 2000, 2001, 2002, 2003, 2004, 2005, 2006, 2007, 2008
+# Free Software Foundation, Inc.
-timestamp='2005-07-08'
+timestamp='2008-04-14'
# This file is free software; you can redistribute it and/or modify it
# under the terms of the GNU General Public License as published by
@@ -55,8 +56,8 @@
GNU config.guess ($timestamp)
Originally written by Per Bothner.
-Copyright (C) 1992, 1993, 1994, 1995, 1996, 1997, 1998, 1999, 2000, 2001, 2002, 2003, 2004, 2005
-Free Software Foundation, Inc.
+Copyright (C) 1992, 1993, 1994, 1995, 1996, 1997, 1998, 1999, 2000, 2001,
+2002, 2003, 2004, 2005, 2006, 2007, 2008 Free Software Foundation, Inc.
This is free software; see the source for copying conditions. There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE."
@@ -106,7 +107,7 @@
trap "exitcode=\$?; (rm -f \$tmpfiles 2>/dev/null; rmdir \$tmp 2>/dev/null) && exit \$exitcode" 0 ;
trap "rm -f \$tmpfiles 2>/dev/null; rmdir \$tmp 2>/dev/null; exit 1" 1 2 13 15 ;
: ${TMPDIR=/tmp} ;
- { tmp=`(umask 077 && mktemp -d -q "$TMPDIR/cgXXXXXX") 2>/dev/null` && test -n "$tmp" && test -d "$tmp" ; } ||
+ { tmp=`(umask 077 && mktemp -d "$TMPDIR/cgXXXXXX") 2>/dev/null` && test -n "$tmp" && test -d "$tmp" ; } ||
{ test -n "$RANDOM" && tmp=$TMPDIR/cg$$-$RANDOM && (umask 077 && mkdir $tmp) ; } ||
{ tmp=$TMPDIR/cg-$$ && (umask 077 && mkdir $tmp) && echo "Warning: creating insecure temp directory" >&2 ; } ||
{ echo "$me: cannot create a temporary directory in $TMPDIR" >&2 ; exit 1 ; } ;
@@ -160,6 +161,7 @@
arm*) machine=arm-unknown ;;
sh3el) machine=shl-unknown ;;
sh3eb) machine=sh-unknown ;;
+ sh5el) machine=sh5le-unknown ;;
*) machine=${UNAME_MACHINE_ARCH}-unknown ;;
esac
# The Operating System including object format, if it has switched
@@ -206,8 +208,11 @@
*:ekkoBSD:*:*)
echo ${UNAME_MACHINE}-unknown-ekkobsd${UNAME_RELEASE}
exit ;;
+ *:SolidBSD:*:*)
+ echo ${UNAME_MACHINE}-unknown-solidbsd${UNAME_RELEASE}
+ exit ;;
macppc:MirBSD:*:*)
- echo powerppc-unknown-mirbsd${UNAME_RELEASE}
+ echo powerpc-unknown-mirbsd${UNAME_RELEASE}
exit ;;
*:MirBSD:*:*)
echo ${UNAME_MACHINE}-unknown-mirbsd${UNAME_RELEASE}
@@ -325,7 +330,7 @@
sun4*:SunOS:5.*:* | tadpole*:SunOS:5.*:*)
echo sparc-sun-solaris2`echo ${UNAME_RELEASE}|sed -e 's/[^.]*//'`
exit ;;
- i86pc:SunOS:5.*:*)
+ i86pc:SunOS:5.*:* | i86xen:SunOS:5.*:*)
echo i386-pc-solaris2`echo ${UNAME_RELEASE}|sed -e 's/[^.]*//'`
exit ;;
sun4*:SunOS:6*:*)
@@ -527,7 +532,7 @@
echo rs6000-ibm-aix3.2
fi
exit ;;
- *:AIX:*:[45])
+ *:AIX:*:[456])
IBM_CPU_ID=`/usr/sbin/lsdev -C -c processor -S available | sed 1q | awk '{ print $1 }'`
if /usr/sbin/lsattr -El ${IBM_CPU_ID} | grep ' POWER' >/dev/null 2>&1; then
IBM_ARCH=rs6000
@@ -764,12 +769,19 @@
echo ${UNAME_MACHINE}-unknown-bsdi${UNAME_RELEASE}
exit ;;
*:FreeBSD:*:*)
- echo ${UNAME_MACHINE}-unknown-freebsd`echo ${UNAME_RELEASE}|sed -e 's/[-(].*//'`
+ case ${UNAME_MACHINE} in
+ pc98)
+ echo i386-unknown-freebsd`echo ${UNAME_RELEASE}|sed -e 's/[-(].*//'` ;;
+ amd64)
+ echo x86_64-unknown-freebsd`echo ${UNAME_RELEASE}|sed -e 's/[-(].*//'` ;;
+ echo ${UNAME_MACHINE}-unknown-freebsd`echo ${UNAME_RELEASE}|sed -e 's/[-(].*//'` ;;
+ esac
exit ;;
i*:CYGWIN*:*)
echo ${UNAME_MACHINE}-pc-cygwin
exit ;;
- i*:MINGW*:*)
+ *:MINGW*:*)
echo ${UNAME_MACHINE}-pc-mingw32
exit ;;
i*:windows32*:*)
@@ -779,9 +791,18 @@
i*:PW*:*)
echo ${UNAME_MACHINE}-pc-pw32
exit ;;
- x86:Interix*:[34]*)
- echo i586-pc-interix${UNAME_RELEASE}|sed -e 's/\..*//'
- exit ;;
+ *:Interix*:[3456]*)
+ x86)
+ echo i586-pc-interix${UNAME_RELEASE}
+ exit ;;
+ EM64T | authenticamd)
+ echo x86_64-unknown-interix${UNAME_RELEASE}
+ exit ;;
+ IA64)
+ echo ia64-unknown-interix${UNAME_RELEASE}
+ exit ;;
+ esac ;;
[345]86:Windows_95:* | [345]86:Windows_98:* | [345]86:Windows_NT:*)
echo i${UNAME_MACHINE}-pc-mks
exit ;;
@@ -794,7 +815,7 @@
i*:UWIN*:*)
echo ${UNAME_MACHINE}-pc-uwin
exit ;;
- amd64:CYGWIN*:*:*)
+ amd64:CYGWIN*:*:* | x86_64:CYGWIN*:*:*)
echo x86_64-unknown-cygwin
exit ;;
p*:CYGWIN*:*)
@@ -815,6 +836,16 @@
echo ${UNAME_MACHINE}-pc-minix
exit ;;
arm*:Linux:*:*)
+ eval $set_cc_for_build
+ if echo __ARM_EABI__ | $CC_FOR_BUILD -E - 2>/dev/null \
+ | grep -q __ARM_EABI__
+ then
+ echo ${UNAME_MACHINE}-unknown-linux-gnu
+ else
+ echo ${UNAME_MACHINE}-unknown-linux-gnueabi
+ fi
+ exit ;;
+ avr32*:Linux:*:*)
exit ;;
cris:Linux:*:*)
@@ -851,7 +882,11 @@
#endif
#endif
EOF
- eval `$CC_FOR_BUILD -E $dummy.c 2>/dev/null | grep ^CPU=`
+ eval "`$CC_FOR_BUILD -E $dummy.c 2>/dev/null | sed -n '
+ /^CPU/{
+ s: ::g
+ p
test x"${CPU}" != x && { echo "${CPU}-unknown-linux-gnu"; exit; }
mips64:Linux:*:*)
@@ -870,7 +905,11 @@
#endif
#endif
EOF
+ /^CPU/{
+ s: ::g
+ p
or32:Linux:*:*)
@@ -919,9 +958,15 @@
sparc:Linux:*:* | sparc64:Linux:*:*)
exit ;;
+ vax:Linux:*:*)
+ echo ${UNAME_MACHINE}-dec-linux-gnu
+ exit ;;
x86_64:Linux:*:*)
echo x86_64-unknown-linux-gnu
exit ;;
+ xtensa*:Linux:*:*)
+ exit ;;
i*86:Linux:*:*)
# The BFD linker knows what the default object file format is, so
# first see if it will tell us. cd to the root directory to prevent
@@ -940,9 +985,6 @@
a.out-i386-linux)
echo "${UNAME_MACHINE}-pc-linux-gnuaout"
exit ;;
- coff-i386)
- echo "${UNAME_MACHINE}-pc-linux-gnucoff"
- exit ;;
# Either a pre-BFD a.out linker (linux-gnuoldld) or
# one that does not give us useful --help.
@@ -964,7 +1006,7 @@
LIBC=gnulibc1
# endif
#else
- #ifdef __INTEL_COMPILER
+ #if defined(__INTEL_COMPILER) || defined(__PGI) || defined(__SUNPRO_C) || defined(__SUNPRO_CC)
LIBC=gnu
#else
LIBC=gnuaout
@@ -974,7 +1016,11 @@
LIBC=dietlibc
#endif
EOF
- eval `$CC_FOR_BUILD -E $dummy.c 2>/dev/null | grep ^LIBC=`
+ /^LIBC/{
+ s: ::g
+ p
test x"${LIBC}" != x && {
echo "${UNAME_MACHINE}-pc-linux-${LIBC}"
exit
@@ -1167,6 +1213,9 @@
BePC:BeOS:*:*) # BeOS running on Intel PC compatible.
echo i586-pc-beos
exit ;;
+ BePC:Haiku:*:*) # Haiku running on Intel PC compatible.
+ echo i586-pc-haiku
+ exit ;;
SX-4:SUPER-UX:*:*)
echo sx4-nec-superux${UNAME_RELEASE}
exit ;;
@@ -1176,6 +1225,15 @@
SX-6:SUPER-UX:*:*)
echo sx6-nec-superux${UNAME_RELEASE}
exit ;;
+ SX-7:SUPER-UX:*:*)
+ echo sx7-nec-superux${UNAME_RELEASE}
+ exit ;;
+ SX-8:SUPER-UX:*:*)
+ echo sx8-nec-superux${UNAME_RELEASE}
+ exit ;;
+ SX-8R:SUPER-UX:*:*)
+ echo sx8r-nec-superux${UNAME_RELEASE}
+ exit ;;
Power*:Rhapsody:*:*)
echo powerpc-apple-rhapsody${UNAME_RELEASE}
exit ;;
@@ -1185,7 +1243,6 @@
*:Darwin:*:*)
UNAME_PROCESSOR=`uname -p` || UNAME_PROCESSOR=unknown
case $UNAME_PROCESSOR in
- *86) UNAME_PROCESSOR=i686 ;;
unknown) UNAME_PROCESSOR=powerpc ;;
esac
echo ${UNAME_PROCESSOR}-apple-darwin${UNAME_RELEASE}
@@ -1264,6 +1321,9 @@
i*86:skyos:*:*)
echo ${UNAME_MACHINE}-pc-skyos`echo ${UNAME_RELEASE}` | sed -e 's/ .*$//'
exit ;;
+ i*86:rdos:*:*)
+ echo ${UNAME_MACHINE}-pc-rdos
+ exit ;;
esac
#echo '(No uname command or uname output not recognized.)' 1>&2
@@ -1424,9 +1484,9 @@
the operating system you are using. It is advised that you
download the most up to date version of the config scripts from
- http://savannah.gnu.org/cgi-bin/viewcvs/*checkout*/config/config/config.guess
+ http://git.savannah.gnu.org/gitweb/?p=config.git;a=blob_plain;f=config.guess;hb=HEAD
and
- http://savannah.gnu.org/cgi-bin/viewcvs/*checkout*/config/config/config.sub
+ http://git.savannah.gnu.org/gitweb/?p=config.git;a=blob_plain;f=config.sub;hb=HEAD
If the version you run ($0) is already up to date, please
send the following data and any information you think might be
Modified: grass/trunk/config.sub
--- grass/trunk/config.sub 2008-05-18 21:12:03 UTC (rev 31414)
+++ grass/trunk/config.sub 2008-05-18 21:12:26 UTC (rev 31415)
@@ -1,9 +1,10 @@
#! /bin/sh
# Configuration validation subroutine script.
# This file is (in principle) common to ALL GNU software.
# The presence of a machine in this file suggests that SOME GNU software
@@ -71,8 +72,8 @@
version="\
GNU config.sub ($timestamp)
@@ -119,8 +120,9 @@
# Here we must recognize all the valid KERNEL-OS combinations.
maybe_os=`echo $1 | sed 's/^\(.*\)-\([^-]*-[^-]*\)$/\2/'`
case $maybe_os in
- nto-qnx* | linux-gnu* | linux-dietlibc | linux-uclibc* | uclinux-uclibc* | uclinux-gnu* | \
- kfreebsd*-gnu* | knetbsd*-gnu* | netbsd*-gnu* | storm-chaos* | os2-emx* | rtmk-nova*)
+ nto-qnx* | linux-gnu* | linux-dietlibc | linux-newlib* | linux-uclibc* | \
+ uclinux-uclibc* | uclinux-gnu* | kfreebsd*-gnu* | knetbsd*-gnu* | netbsd*-gnu* | \
+ storm-chaos* | os2-emx* | rtmk-nova*)
os=-$maybe_os
basic_machine=`echo $1 | sed 's/^\(.*\)-\([^-]*-[^-]*\)$/\1/'`
@@ -171,6 +173,10 @@
-hiux*)
os=-hiuxwe2
+ -sco6)
+ os=-sco5v6
+ basic_machine=`echo $1 | sed -e 's/86-.*/86-pc/'`
-sco5)
os=-sco3.2v5
@@ -187,6 +193,10 @@
# Don't forget version if it is 3.2v4 or newer.
+ -sco5v6*)
+ # Don't forget version if it is 3.2v4 or newer.
-sco*)
os=-sco3.2v2
@@ -231,20 +241,23 @@
| alpha | alphaev[4-8] | alphaev56 | alphaev6[78] | alphapca5[67] \
| alpha64 | alpha64ev[4-8] | alpha64ev56 | alpha64ev6[78] | alpha64pca5[67] \
| am33_2.0 \
- | arc | arm | arm[bl]e | arme[lb] | armv[2345] | armv[345][lb] | avr \
+ | arc | arm | arm[bl]e | arme[lb] | armv[2345] | armv[345][lb] | avr | avr32 \
| bfin \
| c4x | clipper \
| d10v | d30v | dlx | dsp16xx \
- | fr30 | frv \
+ | fido | fr30 | frv \
| h8300 | h8500 | hppa | hppa1.[01] | hppa2.0 | hppa2.0[nw] | hppa64 \
| i370 | i860 | i960 | ia64 \
| ip2k | iq2000 \
- | m32r | m32rle | m68000 | m68k | m88k | maxq | mcore \
+ | m32c | m32r | m32rle | m68000 | m68k | m88k \
+ | maxq | mb | microblaze | mcore | mep | metag \
| mips | mipsbe | mipseb | mipsel | mipsle \
| mips16 \
| mips64 | mips64el \
+ | mips64octeon | mips64octeonel \
+ | mips64orion | mips64orionel \
+ | mips64r5900 | mips64r5900el \
| mips64vr | mips64vrel \
- | mips64orion | mips64orionel \
| mips64vr4100 | mips64vr4100el \
| mips64vr4300 | mips64vr4300el \
| mips64vr5000 | mips64vr5000el \
@@ -257,28 +270,27 @@
| mipsisa64sr71k | mipsisa64sr71kel \
| mipstx39 | mipstx39el \
| mn10200 | mn10300 \
- | ms1 \
+ | mt \
| msp430 \
+ | nios | nios2 \
| ns16k | ns32k \
| or32 \
| pdp10 | pdp11 | pj | pjl \
| powerpc | powerpc64 | powerpc64le | powerpcle | ppcbe \
| pyramid \
- | sh | sh[1234] | sh[24]a | sh[23]e | sh[34]eb | shbe | shle | sh[1234]le | sh3ele \
+ | score \
+ | sh | sh[1234] | sh[24]a | sh[23]e | sh[34]eb | sheb | shbe | shle | sh[1234]le | sh3ele \
| sh64 | sh64le \
- | sparc | sparc64 | sparc64b | sparc86x | sparclet | sparclite \
- | sparcv8 | sparcv9 | sparcv9b \
- | strongarm \
+ | sparc | sparc64 | sparc64b | sparc64v | sparc86x | sparclet | sparclite \
+ | sparcv8 | sparcv9 | sparcv9b | sparcv9v \
+ | spu | strongarm \
| tahoe | thumb | tic4x | tic80 | tron \
| v850 | v850e \
| we32k \
- | x86 | xscale | xscalee[bl] | xstormy16 | xtensa \
+ | x86 | xc16x | xscale | xscalee[bl] | xstormy16 | xtensa \
| z8k)
basic_machine=$basic_machine-unknown
- m32c)
- basic_machine=$basic_machine-unknown
m6811 | m68hc11 | m6812 | m68hc12)
# Motorola 68HC11/12.
@@ -286,6 +298,9 @@
m88110 | m680[12346]0 | m683?2 | m68360 | m5200 | v70 | w65 | z8k)
+ ms1)
+ basic_machine=mt-unknown
# We use `pc' rather than `unknown'
# because (1) that's what they normally are, and
@@ -305,25 +320,27 @@
| alpha64-* | alpha64ev[4-8]-* | alpha64ev56-* | alpha64ev6[78]-* \
| alphapca5[67]-* | alpha64pca5[67]-* | arc-* \
| arm-* | armbe-* | armle-* | armeb-* | armv*-* \
- | avr-* \
+ | avr-* | avr32-* \
| bfin-* | bs2000-* \
| c[123]* | c30-* | [cjt]90-* | c4x-* | c54x-* | c55x-* | c6x-* \
| clipper-* | craynv-* | cydra-* \
| d10v-* | d30v-* | dlx-* \
| elxsi-* \
- | f30[01]-* | f700-* | fr30-* | frv-* | fx80-* \
+ | f30[01]-* | f700-* | fido-* | fr30-* | frv-* | fx80-* \
| h8300-* | h8500-* \
| hppa-* | hppa1.[01]-* | hppa2.0-* | hppa2.0[nw]-* | hppa64-* \
| i*86-* | i860-* | i960-* | ia64-* \
| ip2k-* | iq2000-* \
- | m32r-* | m32rle-* \
+ | m32c-* | m32r-* | m32rle-* \
| m68000-* | m680[012346]0-* | m68360-* | m683?2-* | m68k-* \
- | m88110-* | m88k-* | maxq-* | mcore-* \
+ | m88110-* | m88k-* | maxq-* | mcore-* | metag-* \
| mips-* | mipsbe-* | mipseb-* | mipsel-* | mipsle-* \
| mips16-* \
| mips64-* | mips64el-* \
+ | mips64octeon-* | mips64octeonel-* \
+ | mips64orion-* | mips64orionel-* \
+ | mips64r5900-* | mips64r5900el-* \
| mips64vr-* | mips64vrel-* \
- | mips64orion-* | mips64orionel-* \
| mips64vr4100-* | mips64vr4100el-* \
| mips64vr4300-* | mips64vr4300el-* \
| mips64vr5000-* | mips64vr5000el-* \
@@ -336,30 +353,33 @@
| mipsisa64sr71k-* | mipsisa64sr71kel-* \
| mipstx39-* | mipstx39el-* \
| mmix-* \
- | ms1-* \
+ | mt-* \
| msp430-* \
+ | nios-* | nios2-* \
| none-* | np1-* | ns16k-* | ns32k-* \
| orion-* \
| pdp10-* | pdp11-* | pj-* | pjl-* | pn-* | power-* \
| powerpc-* | powerpc64-* | powerpc64le-* | powerpcle-* | ppcbe-* \
| pyramid-* \
| romp-* | rs6000-* \
- | sh-* | sh[1234]-* | sh[24]a-* | sh[23]e-* | sh[34]eb-* | shbe-* \
+ | sh-* | sh[1234]-* | sh[24]a-* | sh[23]e-* | sh[34]eb-* | sheb-* | shbe-* \
| shle-* | sh[1234]le-* | sh3ele-* | sh64-* | sh64le-* \
- | sparc-* | sparc64-* | sparc64b-* | sparc86x-* | sparclet-* \
+ | sparc-* | sparc64-* | sparc64b-* | sparc64v-* | sparc86x-* | sparclet-* \
| sparclite-* \
- | sparcv8-* | sparcv9-* | sparcv9b-* | strongarm-* | sv1-* | sx?-* \
+ | sparcv8-* | sparcv9-* | sparcv9b-* | sparcv9v-* | strongarm-* | sv1-* | sx?-* \
| tahoe-* | thumb-* \
- | tic30-* | tic4x-* | tic54x-* | tic55x-* | tic6x-* | tic80-* \
+ | tic30-* | tic4x-* | tic54x-* | tic55x-* | tic6x-* | tic80-* | tile-* \
| tron-* \
| v850-* | v850e-* | vax-* \
| we32k-* \
- | x86-* | x86_64-* | xps100-* | xscale-* | xscalee[bl]-* \
- | xstormy16-* | xtensa-* \
+ | x86-* | x86_64-* | xc16x-* | xps100-* | xscale-* | xscalee[bl]-* \
+ | xstormy16-* | xtensa*-* \
| ymp-* \
| z8k-*)
- m32c-*)
+ # Recognize the basic CPU types without company name, with glob match.
+ xtensa*)
+ basic_machine=$basic_machine-unknown
# Recognize the various machine names and aliases which stand
# for a CPU type and a company and sometimes even an OS.
@@ -431,6 +451,14 @@
basic_machine=ns32k-sequent
os=-dynix
+ blackfin)
+ basic_machine=bfin-unknown
+ os=-linux
+ blackfin-*)
+ basic_machine=bfin-`echo $basic_machine | sed 's/^[^-]*-//'`
+ os=-linux
c90)
basic_machine=c90-cray
os=-unicos
@@ -463,8 +491,8 @@
basic_machine=craynv-cray
os=-unicosmp
- cr16c)
- basic_machine=cr16c-unknown
+ cr16)
+ basic_machine=cr16-unknown
os=-elf
crds | unos)
@@ -502,6 +530,10 @@
basic_machine=m88k-motorola
os=-sysv3
+ dicos)
+ basic_machine=i686-pc
+ os=-dicos
djgpp)
basic_machine=i586-pc
os=-msdosdjgpp
@@ -656,6 +688,14 @@
basic_machine=m68k-isi
os=-sysv
+ m68knommu)
+ basic_machine=m68k-unknown
+ os=-linux
+ m68knommu-*)
+ basic_machine=m68k-`echo $basic_machine | sed 's/^[^-]*-//'`
+ os=-linux
m88k-omron*)
basic_machine=m88k-omron
@@ -671,6 +711,10 @@
basic_machine=i386-pc
os=-mingw32
+ mingw32ce)
+ basic_machine=arm-unknown
+ os=-mingw32ce
miniframe)
basic_machine=m68000-convergent
@@ -696,6 +740,9 @@
os=-msdos
+ ms1-*)
+ basic_machine=`echo $basic_machine | sed -e 's/ms1-/mt-/'`
mvs)
basic_machine=i370-ibm
os=-mvs
@@ -794,6 +841,14 @@
basic_machine=i860-intel
os=-osf
+ parisc)
+ basic_machine=hppa-unknown
+ os=-linux
+ parisc-*)
+ basic_machine=hppa-`echo $basic_machine | sed 's/^[^-]*-//'`
+ os=-linux
pbd)
basic_machine=sparc-tti
@@ -803,6 +858,12 @@
pc532 | pc532-*)
basic_machine=ns32k-pc532
+ pc98)
+ basic_machine=i386-pc
+ pc98-*)
+ basic_machine=i386-`echo $basic_machine | sed 's/^[^-]*-//'`
pentium | p5 | k5 | k6 | nexgen | viac3)
@@ -859,6 +920,10 @@
basic_machine=i586-unknown
os=-pw32
+ rdos)
+ os=-rdos
rom68k)
basic_machine=m68k-rom68k
os=-coff
@@ -885,6 +950,10 @@
sb1el)
basic_machine=mipsisa64sb1el-unknown
+ sde)
+ basic_machine=mipsisa32-sde
+ os=-elf
sei)
basic_machine=mips-sei
os=-seiux
@@ -896,6 +965,9 @@
basic_machine=sh-hitachi
os=-hms
+ sh5el)
+ basic_machine=sh5le-unknown
sh64)
basic_machine=sh64-unknown
@@ -985,6 +1057,10 @@
basic_machine=tic6x-unknown
os=-coff
+ tile*)
+ basic_machine=tile-unknown
+ os=-linux-gnu
tx39)
basic_machine=mipstx39-unknown
@@ -1101,7 +1177,7 @@
sh[1234] | sh[24]a | sh[34]eb | sh[1234]le | sh[23]ele)
basic_machine=sh-unknown
- sparc | sparcv8 | sparcv9 | sparcv9b)
+ sparc | sparcv8 | sparcv9 | sparcv9b | sparcv9v)
basic_machine=sparc-sun
cydra)
@@ -1174,21 +1250,23 @@
| -aos* \
| -nindy* | -vxsim* | -vxworks* | -ebmon* | -hms* | -mvs* \
| -clix* | -riscos* | -uniplus* | -iris* | -rtu* | -xenix* \
- | -hiux* | -386bsd* | -knetbsd* | -mirbsd* | -netbsd* | -openbsd* \
+ | -hiux* | -386bsd* | -knetbsd* | -mirbsd* | -netbsd* \
+ | -openbsd* | -solidbsd* \
| -ekkobsd* | -kfreebsd* | -freebsd* | -riscix* | -lynxos* \
| -bosx* | -nextstep* | -cxux* | -aout* | -elf* | -oabi* \
| -ptx* | -coff* | -ecoff* | -winnt* | -domain* | -vsta* \
| -udi* | -eabi* | -lites* | -ieee* | -go32* | -aux* \
| -chorusos* | -chorusrdb* \
| -cygwin* | -pe* | -psos* | -moss* | -proelf* | -rtems* \
- | -mingw32* | -linux-gnu* | -linux-uclibc* | -uxpv* | -beos* | -mpeix* | -udk* \
+ | -mingw32* | -linux-gnu* | -linux-newlib* | -linux-uclibc* \
+ | -uxpv* | -beos* | -mpeix* | -udk* \
| -interix* | -uwin* | -mks* | -rhapsody* | -darwin* | -opened* \
| -openstep* | -oskit* | -conix* | -pw32* | -nonstopux* \
| -storm-chaos* | -tops10* | -tenex* | -tops20* | -its* \
| -os2* | -vos* | -palmos* | -uclinux* | -nucleus* \
| -morphos* | -superux* | -rtmk* | -rtmk-nova* | -windiss* \
| -powermax* | -dnix* | -nx6 | -nx7 | -sei* | -dragonfly* \
- | -skyos* | -haiku*)
+ | -skyos* | -haiku* | -rdos* | -toppers* | -drops*)
# Remember, each alternative MUST END IN *, to match a version number.
-qnx*)
@@ -1318,6 +1396,9 @@
-zvmoe)
os=-zvmoe
+ -dicos*)
+ os=-dicos
-none)
@@ -1340,6 +1421,12 @@
# system, and we'll never get to this point.
case $basic_machine in
+ score-*)
+ os=-elf
+ spu-*)
+ os=-elf
*-acorn)
os=-riscix1.2
@@ -1349,9 +1436,9 @@
arm*-semi)
os=-aout
- c4x-* | tic4x-*)
- os=-coff
+ c4x-* | tic4x-*)
+ os=-coff
# This must come before the *-dec entry.
pdp10-*)
os=-tops20
@@ -1377,6 +1464,9 @@
m68*-cisco)
os=-aout
+ mep-*)
+ os=-elf
mips*-cisco)
os=-elf
