[GRASS-SVN] r31425 - grass-addons/gipe/i.eb.z0m
svn_grass at osgeo.org
Mon May 19 09:08:19 EDT 2008
Author: ychemin
Date: 2008-05-19 09:08:18 -0400 (Mon, 19 May 2008)
New Revision: 31425
grass-addons/gipe/i.eb.z0m/main.c
Bug fixing + standardization of code
Modified: grass-addons/gipe/i.eb.z0m/main.c
--- grass-addons/gipe/i.eb.z0m/main.c 2008-05-19 11:03:40 UTC (rev 31424)
+++ grass-addons/gipe/i.eb.z0m/main.c 2008-05-19 13:08:18 UTC (rev 31425)
@@ -29,7 +29,6 @@
int nrows, ncols;
int row,col;
- int verbose=1;
int heat=0;//Flag for surf. roughness for heat transport output
struct GModule *module;
struct Option *input1, *input2, *output1, *output2;
@@ -51,7 +50,7 @@
int i=0,j=0;
void *inrast_savi;
- unsigned char *outrast1, *outrast2;
+ DCELL *outrast1, *outrast2;
RASTER_MAP_TYPE data_type_output=DCELL_TYPE;
RASTER_MAP_TYPE data_type_savi;
@@ -62,11 +61,8 @@
module->description = _("Momentum roughness length (z0m) and surface roughness for heat transport (z0h) as seen in Pawan (2004)");
/* Define the different options */
- input1 = G_define_option() ;
+ input1 = G_define_standard_option(G_OPT_R_INPUT) ;
input1->key = _("savi");
- input1->type = TYPE_STRING;
- input1->required = YES;
- input1->gisprompt =_("old,cell,raster") ;
input1->description=_("Name of the SAVI map [-1.0;1.0]");
input1->answer =_("savi");
@@ -74,35 +70,24 @@
input2->key =_("coef");
input2->type = TYPE_DOUBLE;
input2->required = NO;
- input2->gisprompt =_("old,cell,raster");
+ input2->gisprompt =_("parameter,value");
input2->description=_("Value of the converion factor from z0m and z0h (Pawan, 2004, used 0.1)");
input2->answer =_("0.1");
- output1 = G_define_option() ;
+ output1 = G_define_standard_option(G_OPT_R_OUTPUT) ;
output1->key =_("z0m");
- output1->type = TYPE_STRING;
- output1->required = YES;
- output1->gisprompt =_("new,cell,raster");
output1->description=_("Name of the output z0m layer");
output1->answer =_("z0m");
- output2 = G_define_option() ;
+ output2 = G_define_standard_option(G_OPT_R_OUTPUT) ;
output2->key =_("z0h");
- output2->type = TYPE_STRING;
output2->required = NO;
- output2->gisprompt =_("new,cell,raster");
output2->description=_("Name of the output z0h layer");
output2->answer =_("z0h");
flag1 = G_define_flag();
flag1->key = 'h';
flag1->description = _("z0h output (You have to input a coef value)");
- flag2 = G_define_flag();
- flag2->key = 'q';
- flag2->description = _("Quiet");
if (G_parser(argc, argv))
exit (EXIT_FAILURE);
@@ -113,7 +98,6 @@
result1 = output1->answer;
result2 = output2->answer;
heat = flag1->answer;
- verbose = (!flag2->answer);
mapset = G_find_cell2(savi, "");
if (mapset == NULL) {
@@ -130,13 +114,13 @@
nrows = G_window_rows();
ncols = G_window_cols();
outrast1 = G_allocate_raster_buf(data_type_output);
- if(heat){
+ if(input2->answer&&output2->answer){
outrast2 = G_allocate_raster_buf(data_type_output);
/* Create New raster files */
if ( (outfd1 = G_open_raster_new (result1,data_type_output)) < 0)
G_fatal_error(_("Could not open <%s>"),result1);
- if(heat){
if ( (outfd2 = G_open_raster_new (result2,data_type_output)) < 0)
G_fatal_error(_("Could not open <%s>"),result2);
@@ -146,9 +130,7 @@
DCELL d;
DCELL d_savi;
DCELL d_z0h;
- if(verbose)
- G_percent(row,nrows,2);
-// printf("row = %i/%i\n",row,nrows);
+ G_percent(row,nrows,2);
/* read soil input maps */
if(G_get_raster_row(infd_savi,inrast_savi,row,data_type_savi)<0)
G_fatal_error(_("Could not read from <%s>"),savi);
@@ -157,25 +139,25 @@
d_savi = ((DCELL *) inrast_savi)[col];
if(G_is_d_null_value(&d_savi)){
- ((DCELL *) outrast1)[col] = -999.99;
- if(heat){
- ((DCELL *) outrast2)[col] = -999.99;
+ G_set_d_null_value(&outrast1[col],1);
+ G_set_d_null_value(&outrast2[col],1);
}else {
/* calculate z0m */
d = z_0m(d_savi);
- ((DCELL *) outrast1)[col] = d;
- if(heat){
- d_z0h = d*coef_z0h;
- ((DCELL *) outrast2)[col] = d;
+ outrast1[col] = d;
+ d_z0h = d * coef_z0h;
+ outrast2[col] = d_z0h;
- if (G_put_raster_row (outfd1, outrast1, data_type_output) < 0)
+ if (G_put_raster_row(outfd1,outrast1,data_type_output)<0)
G_fatal_error(_("Cannot write to output raster file"));
- if(heat){
- if (G_put_raster_row (outfd2, outrast2, data_type_output) < 0)
+ if (G_put_raster_row(outfd2,outrast2,data_type_output)<0)
@@ -186,7 +168,7 @@
G_free (outrast1);
G_close_cell (outfd1);
- if(heat){
G_free (outrast2);
G_close_cell (outfd2);
@@ -195,7 +177,7 @@
G_command_history(&history);
G_write_history(result1,&history);
- if(heat){
G_short_history(result2, "raster", &history);
G_write_history(result2,&history);
