[GRASS-SVN] r31429 - grass-web/trunk/grass63/binary/mswindows/native
svn_grass at osgeo.org
Mon May 19 12:25:48 EDT 2008
Author: marcopx
Date: 2008-05-19 12:25:48 -0400 (Mon, 19 May 2008)
New Revision: 31429
grass-web/trunk/grass63/binary/mswindows/native/README.html
Updated README.html to reflect changes in WinGRASS-6.3.0-3 binary update
Modified: grass-web/trunk/grass63/binary/mswindows/native/README.html
--- grass-web/trunk/grass63/binary/mswindows/native/README.html 2008-05-19 15:29:28 UTC (rev 31428)
+++ grass-web/trunk/grass63/binary/mswindows/native/README.html 2008-05-19 16:25:48 UTC (rev 31429)
@@ -171,7 +171,7 @@
<p>GRASS is released under the GNU General Public License (GPL).</p>
-<p>Visit the GRASS GIS main web site at <a href="http://grass.osgeo.org/">http://grass.osgeo.org/</a></p>
+<p>Visit the GRASS GIS main web site at <a target="_blank" href="http://grass.osgeo.org/">http://grass.osgeo.org/</a></p>
</div>
@@ -188,10 +188,10 @@
features may not work.</p>
<p>If you need a robust, bug-free release of GRASS on Windows you should install the Cygwin version of
-GRASS 6.3.0, available at <a href="http://grass.osgeo.org/grass63/binary/mswindows/cygwin/">
+GRASS 6.3.0, available at <a target="_blank" href="http://grass.osgeo.org/grass63/binary/mswindows/cygwin/">
http://grass.osgeo.org/grass63/binary/mswindows/cygwin/</a>.<p>
-<p>See also <a href="http://grass.osgeo.org/wiki/WinGRASS_Current_Status">
+<p>See also <a target="_blank" href="http://grass.osgeo.org/wiki/WinGRASS_Current_Status">
http://grass.osgeo.org/wiki/WinGRASS_Current_Status</a>.</p>
<p>The current release of WinGRASS, based on GRASS 6.3.0, has been built on a i686 machine in the MinGW environment
@@ -226,9 +226,9 @@
<p> All the above softwares and libraries have been built from sources on a i686 machine in the MinGW environment,
with the exception of MSYS, provided by MinGW Project on SourceForge.NET
-(<a href="http://www.mingw.org/msys.shtml">http://www.mingw.org/msys.shtml</a>),
+(<a target="_blank" href="http://www.mingw.org/msys.shtml">http://www.mingw.org/msys.shtml</a>),
Flex and Bison, provided by GnuWin32 Project on SourceForge.NET
-(<a href="http://gnuwin32.sourceforge.net/">http://gnuwin32.sourceforge.net/</a>).</p>
+(<a target="_blank" href="http://gnuwin32.sourceforge.net/">http://gnuwin32.sourceforge.net/</a>).</p>
<p>The current release of GRASS 6.3.0 has been built with the following configuration:</p>
@@ -282,21 +282,15 @@
<p><h3>Install GRASS</h3></p>
-<p>If you had already installed a previous release of WinGRASS (6.3.0RC5 or 6.3.0RC6), please uninstall it before to install the
-current WinGRASS release. Open the Add/Remove Programs application from the Windows Control Panel, select GRASS and remove it.</p>
+<p>To install GRASS launch WinGRASS-6.3.0-3-Setup.exe and follow the instructions in it.</p>
-<p>Please, note that the uninstall procedure will erase the whole GRASS install direcory. Because of that we strongly
-recommend you to backup all your personal data stored in it before to uninstall GRASS.</p>
-<p>To install GRASS launch WinGRASS-6.3.0-Setup.exe and follow the instructions in it.</p>
<p>If installed into a directory that has spaces in either its name or the path of directories leading up to it,
some functionalities of GRASS might be hampered. We would highly appreciate if you tried and reported any problems,
so that we can fix them. However, if you want to avoid any such issues, we recommend that you choose a simple
installation path without spaces, such as <code>C:\GRASS</code>.</p>
<p>The WinGRASS Installer has been made using the OpenSource NSIS (Nullsoft Scriptable Install System) software, available at:
-<a href="http://nsis.sourceforge.net">http://nsis.sourceforge.net</a></p>
+<a target="_blank" href="http://nsis.sourceforge.net">http://nsis.sourceforge.net</a></p>
</div>
@@ -314,7 +308,7 @@
<p>Used as sample data in the book "Open Source GIS: A GRASS GIS Approach", 3rd edition, this data set is a comprehensive
collection of raster, vector and imagery data covering parts of North Carolina (NC), USA (map), prepared from public data
sources provided by the North Carolina state and local government agencies and Global Land Cover Facility (GLCF).</p>
-<p>See also <a href="http://www.grassbook.org/data_menu3rd.php">http://www.grassbook.org/data_menu3rd.php</a></p>
+<p>See also <a target="_blank" href="http://www.grassbook.org/data_menu3rd.php">http://www.grassbook.org/data_menu3rd.php</a></p>
</td>
</tr></table>
@@ -323,7 +317,7 @@
<td align="left">
<p>Also known as Spearfish data set, it contains raster, vector and point data of South Dakota, USA
(UTM projection, Clarke66 ellipsoid, NAD27 conus)</p>
-<p>See also <a href="http://grass.osgeo.org/download/data6.php">http://grass.osgeo.org/download/data6.php</a></p>
+<p>See also <a target="_blank" href="http://grass.osgeo.org/download/data6.php">http://grass.osgeo.org/download/data6.php</a></p>
</td>
</tr></table>
@@ -363,7 +357,7 @@
<table><tr>
<td width="100" align="left" valign="top"><p><h4>Python</h4></p></td>
<td align="left">
-<p>Download the <a href="http://www.python.org/ftp/python/2.5.2/python-2.5.2.msi">Python installer</a></p>
+<p>Download the <a target="_blank" href="http://www.python.org/ftp/python/2.5.2/python-2.5.2.msi">Python installer</a></p>
<p>Install to <code>%PROGRAMFILES%\Python</code></p>
<p>Add <code>%PROGRAMFILES%\Python</code> to your <code>PATH</code> system variable.</p>
</td>
@@ -372,7 +366,7 @@
<table><tr>
<td width="100" align="left" valign="top"><p><h4>Python Extensions</h4></p></td>
<td align="left">
-<p>Download the <a href="http://downloads.sourceforge.net/pywin32/pywin32-210.win32-py2.5.exe">
+<p>Download the <a target="_blank" href="http://downloads.sourceforge.net/pywin32/pywin32-210.win32-py2.5.exe">
Python Extensions installer</a></p>
<p>Just launch the installer, it will automatically set the correct install path.</p>
</td>
@@ -381,7 +375,7 @@
<table><tr>
<td width="100" align="left" valign="top"><p><h4>wxPython</h4></p></td>
<td align="left">
-<p>Download the <a href="http://downloads.sourceforge.net/wxpython/wxPython2.8-win32-unicode-2.8.7.1-py25.exe">
+<p>Download the <a target="_blank" href="http://downloads.sourceforge.net/wxpython/wxPython2.8-win32-unicode-2.8.7.1-py25.exe">
wxPython installer</a></p>
<p>Install to <code>%PROGRAMFILES%\Python\Lib\site-packages</code></p>
</td>
@@ -390,7 +384,7 @@
<table><tr>
<td width="100" align="left" valign="top"><p><h4>NumPy</h4></p></td>
<td align="left">
-<p>Download <a href="http://downloads.sourceforge.net/numpy/numpy-1.0.4.win32-py2.5.msi">
+<p>Download <a target="_blank" href="http://downloads.sourceforge.net/numpy/numpy-1.0.4.win32-py2.5.msi">
NumPy installer</a></p>
</td>
@@ -401,7 +395,7 @@
<p>Please, note that the new GRASS Python GUI is still at a highly experimental stage, and that the
vector digitizer is disabled in it.</p>
-<p>See also <a href="http://grass.osgeo.org/wiki/WxPython-based_GUI_for_GRASS">
+<p>See also <a target="_blank" href="http://grass.osgeo.org/wiki/WxPython-based_GUI_for_GRASS">
http://grass.osgeo.org/wiki/WxPython-based_GUI_for_GRASS</a></p>
</div>
@@ -438,7 +432,7 @@
<p><h3>Known Issues</h3></p>
-<p>See <a href="http://grass.osgeo.org/wiki/WinGRASS_Current_Status#Known_Issues">
+<p>See <a target="_blank" href="http://grass.osgeo.org/wiki/WinGRASS_Current_Status#Known_Issues">
http://grass.osgeo.org/wiki/WinGRASS_Current_Status#Known_Issues</a></p>
</div>
@@ -450,7 +444,7 @@
<p><h3>How to Submit Bugs</h3></p>
<p>We would highly appreciate if you contributed to WinGRASS project by submitting bugs to
-<a href="http://trac.osgeo.org/grass/">http://trac.osgeo.org/grass/</a> or informing us about them through the
+<a target="_blank" href="http://trac.osgeo.org/grass/">http://trac.osgeo.org/grass/</a> or informing us about them through the
Windows GRASS Mailing List (<a target="_blank"
href="http://lists.osgeo.org/mailman/listinfo/grass-windows">http://lists.osgeo.org/mailman/listinfo/grass-windows</a>).</p>
@@ -463,7 +457,7 @@
<p><h3>Build GRASS From Source</h3></p>
<p>Information on how to build GRASS from source code on Windows in a MinGW environment are available at
-<a href="http://trac.osgeo.org/grass/wiki/BuildingOnWindows">http://trac.osgeo.org/grass/wiki/BuildingOnWindows</a></p>
+<a target="_blank" href="http://trac.osgeo.org/grass/wiki/BuildingOnWindows">http://trac.osgeo.org/grass/wiki/BuildingOnWindows</a></p>
</div>
@@ -475,7 +469,7 @@
<p>The GRASS Development Team is a multi-national group consisting of scientists and developers participating from various fields.</p>
-<p>For more information, see <a href="http://grass.osgeo.org/community/team.php">
+<p>For more information, see <a target="_blank" href="http://grass.osgeo.org/community/team.php">
http://grass.osgeo.org/community/team.php</a></p>
</div>
@@ -493,7 +487,7 @@
<p>This document has been written by Marco Pasetti, in agreement with the GRASS Development Team.</p>
<p>To contact them, e-mail to: GRASS Development Mailing List
-(<a href="http://lists.osgeo.org/mailman/listinfo/grass-dev">http://lists.osgeo.org/mailman/listinfo/grass-dev</a>).</p>
+(<a target="_blank" href="http://lists.osgeo.org/mailman/listinfo/grass-dev">http://lists.osgeo.org/mailman/listinfo/grass-dev</a>).</p>
</div>
