[GRASS-SVN] r31433 - grass/branches/develbranch_6/win32/Extras
svn_grass at osgeo.org
Mon May 19 15:32:19 EDT 2008
Author: marcopx
Date: 2008-05-19 15:32:19 -0400 (Mon, 19 May 2008)
New Revision: 31433
grass/branches/develbranch_6/win32/Extras/README.html
Updates according to the WinGRASS-6.3.0-3 installer update
Modified: grass/branches/develbranch_6/win32/Extras/README.html
--- grass/branches/develbranch_6/win32/Extras/README.html 2008-05-19 19:29:26 UTC (rev 31432)
+++ grass/branches/develbranch_6/win32/Extras/README.html 2008-05-19 19:32:19 UTC (rev 31433)
@@ -282,14 +282,8 @@
<p><h3>Install GRASS</h3></p>
-<p>If you had already installed a previous release of WinGRASS (6.3.0RC5 or 6.3.0RC6), please uninstall it before to install the
-current WinGRASS release. Open the Add/Remove Programs application from the Windows Control Panel, select GRASS and remove it.</p>
+<p>To install GRASS launch WinGRASS-6.3.0-3-Setup.exe and follow the instructions in it.</p>
-<p>Please, note that the uninstall procedure will erase the whole GRASS install direcory. Because of that we strongly
-recommend you to backup all your personal data stored in it before to uninstall GRASS.</p>
-<p>To install GRASS launch WinGRASS-6.3.0-Setup.exe and follow the instructions in it.</p>
<p>If installed into a directory that has spaces in either its name or the path of directories leading up to it,
some functionalities of GRASS might be hampered. We would highly appreciate if you tried and reported any problems,
so that we can fix them. However, if you want to avoid any such issues, we recommend that you choose a simple
