[GRASS-SVN] r31441 - grass-addons/gipe/i.evapo.SENAY
svn_grass at osgeo.org
Tue May 20 07:30:16 EDT 2008
Author: ychemin
Date: 2008-05-20 07:30:15 -0400 (Tue, 20 May 2008)
New Revision: 31441
grass-addons/gipe/i.evapo.SENAY/main.c
bug fix
Modified: grass-addons/gipe/i.evapo.SENAY/main.c
--- grass-addons/gipe/i.evapo.SENAY/main.c 2008-05-20 07:18:04 UTC (rev 31440)
+++ grass-addons/gipe/i.evapo.SENAY/main.c 2008-05-20 11:30:15 UTC (rev 31441)
@@ -92,37 +92,31 @@
input1->key = _("albedo");
input1->description=_("Name of the Albedo map [0.0-1.0]");
input1->answer =_("albedo");
- input1->guisection = _("Required");
input2 = G_define_standard_option(G_OPT_R_INPUT) ;
input2->key =_("tempk");
input2->description=_("Name of the temperature map [Degree Kelvin]");
input2->answer =_("tempk");
- input2->guisection = _("Required");
input3 = G_define_standard_option(G_OPT_R_INPUT) ;
input3->key =_("dem");
input3->description=_("Name of the elevation map [m]");
input3->answer =_("dem");
- input3->guisection = _("Required");
input4 = G_define_standard_option(G_OPT_R_INPUT) ;
input4->key =_("lat");
input4->description=_("Name of the degree latitude map [dd.ddd]");
input4->answer =_("lat");
- input4->guisection = _("Required");
input5 = G_define_standard_option(G_OPT_R_INPUT) ;
input5->key =_("doy");
input5->description=_("Name of the Day of Year map [0.0-366.0]");
input5->answer =_("doy");
- input5->guisection = _("Required");
input6 = G_define_standard_option(G_OPT_R_INPUT) ;
input6->key =_("tsw");
input6->description=_("Name of the single-way transmissivity map [0.0-1.0]");
input6->answer =_("tsw");
- input6->guisection = _("Required");
input7 = G_define_option() ;
input7->key =_("roh_w");
@@ -131,7 +125,6 @@
input7->gisprompt =_("value, parameter");
input7->description=_("Value of the density of fresh water ~[1000-1020]");
input7->answer =_("1005.0");
- input7->guisection = _("Required");
input8 = G_define_standard_option(G_OPT_R_INPUT) ;
input8->key =_("slope");
@@ -151,7 +144,6 @@
input10->required = NO;
input10->gisprompt =_("value, parameter");
input10->description=_("Value of the apparent atmospheric emissivity (Bandara, 1998 used 0.845 for Sri Lanka)");
- input10->answer =_("0.845");
input10->guisection = _("Optional");
input11 = G_define_standard_option(G_OPT_R_INPUT) ;
@@ -170,7 +162,6 @@
output1->key =_("eta");
output1->description=_("Name of the output Actual ET layer");
output1->answer =_("eta");
- output1->guisection = _("Required");
output2 = G_define_standard_option(G_OPT_R_OUTPUT) ;
output2->key =_("evapfr");
@@ -388,8 +379,9 @@
d_dem = (double) ((DCELL *) inrast_dem)[col];
break;
- if(G_is_d_null_value(&d_albedo)||G_is_d_null_value(&d_tempk)
- ||G_is_d_null_value(&d_dem)){
+ if(G_is_d_null_value(&d_albedo)||
+ G_is_d_null_value(&d_tempk)||
+ G_is_d_null_value(&d_dem)){
/* do nothing */
} else {
d_t0dem = d_tempk + 0.00649*d_dem;
@@ -401,7 +393,8 @@
t0dem_min=d_t0dem;
tempk_min=d_tempk;
//}else if(d_t0dem>t0dem_max){
- }else if(d_tempk>tempk_max){
+ }else if(d_tempk>tempk_max&&
+ d_albedo>0.3){
t0dem_max=d_t0dem;
tempk_max=d_tempk;
@@ -558,9 +551,12 @@
break;
- ||d_tempk<10.0||G_is_d_null_value(&d_lat)||
- G_is_d_null_value(&d_doy)||G_is_d_null_value(&d_tsw)||
+ d_tempk<10.0||
+ G_is_d_null_value(&d_lat)||
+ G_is_d_null_value(&d_doy)||
+ G_is_d_null_value(&d_tsw)||
((flag2->answer)&&G_is_d_null_value(&d_slope))||
((flag2->answer)&&G_is_d_null_value(&d_aspect))||
((flag3->answer)&&G_is_d_null_value(&d_tair))||
@@ -568,10 +564,10 @@
G_set_d_null_value(&outrast1[col],1);
if (result2)
G_set_d_null_value(&outrast2[col],1);
- }else {
+ } else {
if(flag2->answer){
d_solar = solar_day_3d(d_lat,d_doy,d_tsw,d_slope,d_aspect);
- }else {
+ } else {
d_solar = solar_day(d_lat, d_doy, d_tsw );
d_evapfr = evapfr_senay( tempk_max, tempk_min, d_tempk);
@@ -584,7 +580,7 @@
d_rnetd = r_net_day(d_albedo,d_solar,d_tsw);
d_etpotd = et_pot_day(d_rnetd,d_tempk,roh_w);
- d_etpotd *= d_tsw;
+ /*d_etpotd *= d_tsw;*/
d = d_etpotd * d_evapfr;
outrast1[col] = d;
@@ -620,11 +616,11 @@
G_free (outrast1);
G_close_cell (outfd1);
if (result2){
+ G_free (outrast2);
+ G_close_cell (outfd2);
/* Color table for evaporative fraction */
G_init_colors(&colors);
G_add_color_rule(0,0,0,0,1,255,255,255,&colors);
- G_free (outrast2);
- G_close_cell (outfd2);
G_short_history(result2, "raster", &history);
G_command_history(&history);
G_write_history(result2,&history);
