[GRASS-SVN] r31449 - grass/branches/develbranch_6/raster/r.in.gdal
svn_grass at osgeo.org
Tue May 20 14:55:00 EDT 2008
Author: epatton
Date: 2008-05-20 14:55:00 -0400 (Tue, 20 May 2008)
New Revision: 31449
grass/branches/develbranch_6/raster/r.in.gdal/description.html
Backported HTML updates from TRUNK: r31448
Modified: grass/branches/develbranch_6/raster/r.in.gdal/description.html
--- grass/branches/develbranch_6/raster/r.in.gdal/description.html 2008-05-20 18:54:27 UTC (rev 31448)
+++ grass/branches/develbranch_6/raster/r.in.gdal/description.html 2008-05-20 18:55:00 UTC (rev 31449)
@@ -1,9 +1,8 @@
<h2>DESCRIPTION</h2>
<em>r.in.gdal</em> allows a user to create a (binary) GRASS raster map layer,
-or imagery group,
-from any GDAL supported raster map format, with an optional title. The
-imported file may also be optionally used to create a new location.
+or imagery group, from any GDAL supported raster map format, with an optional
+title. The imported file may also be optionally used to create a new location.
<!--<h2>OPTIONS</h2>
@@ -18,14 +17,14 @@
PERMANENT mapset.
</dl>-->
-<h2>GDAL supported raster formats</h2>
+<h3>GDAL supported raster formats</h3>
Full details on GDAL supported formats are available at:<p>
<a href="http://www.gdal.org/formats_list.html">http://www.gdal.org/formats_list.html</a><p>
-Selected formats of more than 45 supported formats:
-<pre>
+Selected formats of more than 80 supported formats:
+<div class="code"><pre>
Long Format Name Code Creation Georeferencing Maximum File Size
@@ -77,45 +76,55 @@
SAR CEOS SAR_CEOS No Yes --
USGS ASCII DEM (.dem) USGSDEM No Yes --
X11 Pixmap (.xpm) XPM Yes No
-</pre>
-<h2>Location Creation</h2>
+</pre></div>
-<b>r.in.gdal</b> attempts to preserve projection information when importing
+<h3>Location Creation</h3>
+<em>r.in.gdal</em> attempts to preserve projection information when importing
datasets if the source format includes projection information, and if
the GDAL driver supports it. If the projection of the source dataset does
-not match the projection of the current location <b>r.in.gdal</b> will
+not match the projection of the current location <em>r.in.gdal</em> will
report an error message (<tt>Projection of dataset does not appear to
match current location</tt>) and then report the PROJ_INFO parameters of
-the source dataset.<p>
+the source dataset.
+<p>
If the user wishes to ignore the difference between the apparent coordinate
system of the source data and the current location, they may pass the
-<b>-o</b> flag to override the projection check. <p>
+<b>-o</b> flag to override the projection check.
+<p>
If the user wishes to import the data with the full projection definition,
it is possible to have r.in.gdal automatically create a new location based
on the projection and extents of the file being read. This is accomplished
by passing the name to be used for the new location via the <b>location</b>
parameter. Upon completion of the command, a new location will have been
created (with only a PERMANENT mapset), and the raster will have been
-imported with the indicated <b>output</b> name into the PERMANENT mapset.<p>
+imported with the indicated <b>output</b> name into the PERMANENT mapset.
+<p>
Support for GCPs: In case the image contains GCPs they are written to a
POINTS file within an imagery group. They can directly be used for
-<a href=i.rectify.html>i.rectify</a>. The <em>target</em> option allows to
+<a href=i.rectify.html>i.rectify</a>. The <b>target</b> option allows to
automatically re-project the GCPs from their own projection into another
projection read from the PROJ_INFO file of the location name
-<em>target</em>.
+<b>target</b>.
<h2>NOTES</h2>
-I plan to make a variety of improvements to <b>r.in.gdal</b> in the future
-including support for reporting everything known about a dataset if the
-<b>output</b> parameter is not set.<p>
+Planned improvements to <em>r.in.gdal</em> in the future include support for
+reporting everything known about a dataset if the <b>output</b> parameter is not set.
-The <b>r.in.gdal</b> comand does support the following features, as long as
-the underlying format driver supports it:<p>
+<p>
+The <em>r.in.gdal</em> comand does support the following features, as long as
+the underlying format driver supports it:
+<p>
<dl>
<dt> Color Table
@@ -137,7 +146,7 @@
<dt> Georeferencing
<dd> If the dataset has affine georeferencing information, this will be used
to set the north, south, east and west edges. Rotational coefficients will
-be ignored, resulting in incorrect positioning for rotated datasets. <br>
+be ignored, resulting in incorrect positioning for rotated datasets.<br>
<dt> Projection
<dd> The datasets projection will be used to compare to the current location
@@ -164,6 +173,27 @@
</dl>
+<h3>Error Messages</h3>
+<i>"ERROR: Input map is rotated - cannot import."</i><br>
+In this case the image must be first externally rotated, applying the rotation info stored in
+the metadata field of the raster image file. For example, the
+<a href="http://www.gdal.org/gdal_utilities.html">gdalwarp</a> software can be used
+to transform the map to North-up (note, there are several gdalwarp parameters to select the
+resampling algorithm):
+gdalwarp rotated.tif northup.tif
+</pre></div>
+<p>
+<i>"ERROR: Projection of dataset does not appear to match the current location."</i><br>
+You need to create a location whose projection matches the data you
+wish to import. Try using <b>location</b> parameter to create a new location based
+upon the projection information in the file. If desired, you can then re-project
+it to another location with <em>r.proj</em>.
<h2>EXAMPLES</h2>
<h3>GTOPO30 DEM</h3>
@@ -210,28 +240,6 @@
# ... likewise for other HDF bands in the file.
</pre></div>
-<h2>NOTES</h2>
-<i>"ERROR: Input map is rotated - cannot import."</i><br>
-In this case the image must be first externally rotated, applying the rotation info stored in
-the metadata field of the raster image file. For example, the
-<a href="http://www.gdal.org/gdal_utilities.html">gdalwarp</a> software can be used
-to transform the map to North-up (note, there are several gdalwarp parameters to select the
-resampling algorithm):
-<div class="code"><pre>
-gdalwarp rotated.tif northup.tif
-</pre></div>
-<p>
-<i>"ERROR: Projection of dataset does not appear to match the current location."</i><br>
-You need to create a location whose projection matches the data you
-wish to import. Try using <em>location</em> parameter to create a new location based
-upon the projection information in the file. If desired, you can then re-project
-it to another location with <em>r.proj</em>.
<h2>SEE ALSO</h2>
<em>
<a href="r.colors.html">r.colors</a>,
@@ -249,4 +257,4 @@
<a href="http://home.gdal.org/warmerda/">Frank Warmerdam</a> (<a href="mailto:warmerdam AT pobox dot com">email</a>).
-<p><i>Last changed: $Date$</i>
+<p><i>Last changed: $Date$</i>I
