[GRASS-SVN] r31472 - grass/branches/develbranch_6/general/g.gisenv
svn_grass at osgeo.org
Thu May 22 03:51:37 EDT 2008
Author: glynn
Date: 2008-05-22 03:51:37 -0400 (Thu, 22 May 2008)
New Revision: 31472
grass/branches/develbranch_6/general/g.gisenv/main.c
Remove bogus quotes from example usage of set= option (merge r31471 from trunk)
Modified: grass/branches/develbranch_6/general/g.gisenv/main.c
--- grass/branches/develbranch_6/general/g.gisenv/main.c 2008-05-22 07:49:49 UTC (rev 31471)
+++ grass/branches/develbranch_6/general/g.gisenv/main.c 2008-05-22 07:51:37 UTC (rev 31472)
@@ -48,7 +48,7 @@
set->key = "set" ;
set->type = TYPE_STRING ;
set->description = _("GRASS variable to set") ;
- set->key_desc = "\"VARIABLE=value\"" ;
+ set->key_desc = "VARIABLE=value" ;
set->required = NO;
store_opt = G_define_option() ;
