[GRASS-SVN] r31483 - in grass-addons/gipe: . i.evapo.SENAY r.soiltex2prop
Thu May 22 09:41:51 EDT 2008
Author: ychemin
Date: 2008-05-22 09:41:51 -0400 (Thu, 22 May 2008)
New Revision: 31483
Added:
   grass-addons/gipe/r.soiltex2prop/
   grass-addons/gipe/r.soiltex2prop/Makefile
   grass-addons/gipe/r.soiltex2prop/description.html
   grass-addons/gipe/r.soiltex2prop/main.c
   grass-addons/gipe/r.soiltex2prop/prct2hf.c
   grass-addons/gipe/r.soiltex2prop/prct2ksat.c
   grass-addons/gipe/r.soiltex2prop/prct2porosity.c
   grass-addons/gipe/r.soiltex2prop/vector_multiplication.c
   grass-addons/gipe/Makefile
   grass-addons/gipe/i.evapo.SENAY/main.c
added new module converting soil texture to porosity (vol. fraction), saturated hydraulic conductivity (cm/h) and wetting front suction (cm), after Rawls et al., 1990.
Modified: grass-addons/gipe/Makefile
--- grass-addons/gipe/Makefile	2008-05-22 11:22:51 UTC (rev 31482)
+++ grass-addons/gipe/Makefile	2008-05-22 13:41:51 UTC (rev 31483)
@@ -85,6 +85,7 @@
 	r.rescale.eq \
 	r.series \
 	r.slope.aspect \
+	r.soiltex2prop \
 	r.statistics \
 	r.stats \
 	r.sum \
Modified: grass-addons/gipe/i.evapo.SENAY/main.c
--- grass-addons/gipe/i.evapo.SENAY/main.c	2008-05-22 11:22:51 UTC (rev 31482)
+++ grass-addons/gipe/i.evapo.SENAY/main.c	2008-05-22 13:41:51 UTC (rev 31483)
@@ -36,7 +36,7 @@
 	struct GModule *module;
 	struct Option *input1, *input2, *input3, *input4;
 	struct Option *input5, *input6, *input7, *input8, *input9;
-	struct Option *input10, *input11, *input12;
+	struct Option *input10, *input11, *input12, *input13;
 	struct Option *output1, *output2;
 	struct Flag *flag2, *flag3;
@@ -51,10 +51,11 @@
 	int infd_lat, infd_doy, infd_tsw;
 	int infd_slope, infd_aspect;
 	int infd_tair, infd_e0;
+	int infd_ndvi;
 	int outfd1, outfd2;
 	char *albedo,*tempk,*dem,*lat,*doy,*tsw;
-	char *slope,*aspect,*tair,*e0;
+	char *slope,*aspect,*tair,*e0, *ndvi;
 	double roh_w, e_atm;
 	int i=0,j=0;
@@ -63,6 +64,7 @@
 	void *inrast_doy, *inrast_tsw;
 	void *inrast_slope, *inrast_aspect;
 	void *inrast_tair, *inrast_e0;
+	void *inrast_ndvi;
 	DCELL *outrast1, *outrast2;
 	RASTER_MAP_TYPE data_type_output=DCELL_TYPE;
@@ -76,6 +78,7 @@
 	RASTER_MAP_TYPE data_type_aspect;
 	RASTER_MAP_TYPE data_type_tair;
 	RASTER_MAP_TYPE data_type_e0;
+	RASTER_MAP_TYPE data_type_ndvi;
 	/* Stats for Senay equation	*/
 	double t0dem_min=400.0,t0dem_max=200.0;
@@ -122,7 +125,6 @@
 	input7->key        =_("roh_w");
 	input7->type       = TYPE_DOUBLE;
 	input7->required   = YES;
-	input7->gisprompt  =_("value, parameter");
 	input7->description=_("Value of the density of fresh water ~[1000-1020]");
 	input7->answer     =_("1005.0");
@@ -142,7 +144,6 @@
 	input10->key        =_("e_atm");
 	input10->type       = TYPE_DOUBLE;
 	input10->required   = NO;
-	input10->gisprompt  =_("value, parameter");
 	input10->description=_("Value of the apparent atmospheric emissivity (Bandara, 1998 used 0.845 for Sri Lanka)");
 	input10->guisection = _("Optional");
@@ -158,6 +159,11 @@
 	input12->description=_("Name of the Surface Emissivity map [-], use with -b");
 	input12->guisection = _("Optional");
+	input13 = G_define_standard_option(G_OPT_R_INPUT) ;
+	input13->key        =_("ndvi");
+	input13->description=_("Name of the NDVI map [-]");
+	input13->answer     =_("ndvi");
 	output1 = G_define_standard_option(G_OPT_R_OUTPUT) ;
 	output1->key        =_("eta");
 	output1->description=_("Name of the output Actual ET layer");
@@ -189,9 +195,12 @@
 	roh_w	 	= atof(input7->answer);
 	slope	 	= input8->answer;
 	aspect	 	= input9->answer;
-	e_atm	 	= atof(input10->answer);
+	if(input10->answer){
+		e_atm 	= atof(input10->answer);
 	tair	 	= input11->answer;
 	e0	 	= input12->answer;
+	ndvi	 	= input13->answer;
 	result1  = output1->answer;
 	result2  = output2->answer;
@@ -314,6 +323,17 @@
 		inrast_e0 = G_allocate_raster_buf(data_type_e0);
+	mapset = G_find_cell2 (ndvi, "");
+	if (mapset == NULL) {
+		G_fatal_error(_("Cell file [%s] not found"), ndvi);
+	data_type_ndvi = G_raster_map_type(ndvi,mapset);
+	if ( (infd_ndvi = G_open_cell_old (ndvi,mapset)) < 0)
+		G_fatal_error(_("Cannot open cell file [%s]"), ndvi);
+	if (G_get_cellhd (ndvi, mapset, &cellhd) < 0)
+		G_fatal_error(_("Cannot read file header of [%s]"), ndvi);
+	inrast_ndvi = G_allocate_raster_buf(data_type_ndvi);
 	G_debug(3, "number of rows %d",cellhd.rows);
 	nrows = G_window_rows();
 	ncols = G_window_cols();
@@ -336,6 +356,7 @@
 		DCELL d_tempk;
 		DCELL d_dem;
 		DCELL d_t0dem;
+		DCELL d_ndvi;
 		G_percent(row,nrows,2);
 		if(G_get_raster_row(infd_albedo,inrast_albedo,row,data_type_albedo)<0)
 			G_fatal_error(_("Could not read from <%s>"),albedo);
@@ -343,6 +364,8 @@
 			G_fatal_error(_("Could not read from <%s>"),tempk);
 		if(G_get_raster_row(infd_dem,inrast_dem,row,data_type_dem)<0)
 			G_fatal_error(_("Could not read from <%s>"),dem);
+		if(G_get_raster_row(infd_ndvi,inrast_ndvi,row,data_type_ndvi)<0)
+			G_fatal_error(_("Could not read from <%s>"),ndvi);
 		/*process the data */
 		for (col=0; col < ncols; col++)
@@ -379,9 +402,21 @@
 					d_dem = (double) ((DCELL *) inrast_dem)[col];
 					break;
+			switch(data_type_ndvi){
+				case CELL_TYPE:
+					d_ndvi = (double) ((CELL *) inrast_ndvi)[col];
+					break;
+				case FCELL_TYPE:
+					d_ndvi = (double) ((FCELL *) inrast_ndvi)[col];
+					break;
+				case DCELL_TYPE:
+					d_ndvi = (double) ((DCELL *) inrast_ndvi)[col];
+					break;
 			if(G_is_d_null_value(&d_albedo)||
 			G_is_d_null_value(&d_tempk)||
-			G_is_d_null_value(&d_dem)){
+			G_is_d_null_value(&d_dem)||
+			G_is_d_null_value(&d_ndvi)){
 				/* do nothing */
 			} else {
 				d_t0dem = d_tempk + 0.00649*d_dem;
@@ -389,7 +424,8 @@
 					/* do nothing */
 				} else {
 					//if(d_t0dem<t0dem_min){
-					if(d_tempk<tempk_min&&d_albedo<0.1){
+					if(d_tempk<tempk_min&&
+					d_albedo<0.1){
 						t0dem_min=d_t0dem;
 						tempk_min=d_tempk;
 					//}else if(d_t0dem>t0dem_max){
@@ -419,6 +455,7 @@
 		DCELL d_aspect;
 		DCELL d_tair;
 		DCELL d_e0;
+		DCELL d_ndvi;
 		DCELL d_etpotd;
 		DCELL d_evapfr;
@@ -557,6 +594,7 @@
 			G_is_d_null_value(&d_lat)||
 			G_is_d_null_value(&d_doy)||
 			G_is_d_null_value(&d_tsw)||
+			G_is_d_null_value(&d_ndvi)||
 			((flag2->answer)&&G_is_d_null_value(&d_slope))||
 			((flag2->answer)&&G_is_d_null_value(&d_aspect))||
 			((flag3->answer)&&G_is_d_null_value(&d_tair))||
@@ -570,7 +608,15 @@
 				} else {
 					d_solar = solar_day(d_lat, d_doy, d_tsw );
-				d_evapfr = evapfr_senay( tempk_max, tempk_min, d_tempk);
+				d_evapfr=evapfr_senay(tempk_max,tempk_min, d_tempk);
+				/*If water then no water stress*/
+				if(d_albedo<=0.1&&d_ndvi<=0.0){
+					d_evapfr=1.0;
+				/*some points are colder than selected low*/
+				if(d_evapfr>1.0){
+					d_evapfr=1.0;
 				if(result2){
 					outrast2[col] = d_evapfr;
@@ -580,7 +626,6 @@
 					d_rnetd = r_net_day(d_albedo,d_solar,d_tsw);
 				d_etpotd = et_pot_day(d_rnetd,d_tempk,roh_w);
-				/*d_etpotd *= d_tsw;*/
 				d = d_etpotd * d_evapfr;
 				outrast1[col] = d;
Added: grass-addons/gipe/r.soiltex2prop/Makefile
--- grass-addons/gipe/r.soiltex2prop/Makefile	                        (rev 0)
+++ grass-addons/gipe/r.soiltex2prop/Makefile	2008-05-22 13:41:51 UTC (rev 31483)
@@ -0,0 +1,10 @@
+MODULE_TOPDIR = ../..
+PGM = r.soiltex2prop
+LIBES = $(GISLIB)
+DEPENDENCIES = $(GISDEP)
+include $(MODULE_TOPDIR)/include/Make/Module.make
+default: cmd
Added: grass-addons/gipe/r.soiltex2prop/description.html
--- grass-addons/gipe/r.soiltex2prop/description.html	                        (rev 0)
+++ grass-addons/gipe/r.soiltex2prop/description.html	2008-05-22 13:41:51 UTC (rev 31483)
@@ -0,0 +1,24 @@
+<H2>DESCRIPTION</H2>
+<EM>r.soiltex2prop</EM> calculates the soil porosity (volume fraction), saturated hydraulic conductivity (cm/h) and wetting front suction (cm ; Green-Ampt) after Rawls et al, 1990.
+It takes input of soil texture proportions (sand, clay) in range [0.0-100.0].
+<H2>NOTES</H2>
+<H2>TODO</H2>
+<H2>SEE ALSO</H2>
+<em>
+<A HREF="r.uslek.html">r.uslek</A><br>
+</em>
+<H2>AUTHORS</H2>
+Yann Chemin, International Rice Research Institute, The Philippines<BR>
+<p>
+<i>Last changed: $Date: 2006/09/31 15:20:43 $</i>
Added: grass-addons/gipe/r.soiltex2prop/main.c
--- grass-addons/gipe/r.soiltex2prop/main.c	                        (rev 0)
+++ grass-addons/gipe/r.soiltex2prop/main.c	2008-05-22 13:41:51 UTC (rev 31483)
@@ -0,0 +1,209 @@
+ * MODULE:       r.soiltex2prop
+ * AUTHOR(S):    Yann Chemin - ychemin at gmail.com
+ * PURPOSE:      Transforms percentage of texture (sand/clay)
+ *               into USDA 1951 (p209) soil texture classes and then
+ *               into USLE soil erodibility factor (K) as an output
+ * COPYRIGHT:    (C) 2008 by the GRASS Development Team
+ *               This program is free software under the GNU General Public
+ *   	    	 License (>=v2). Read the file COPYING that comes with GRASS
+ *   	    	 for details.
+#include <stdio.h>
+#include <stdlib.h>
+#include <string.h>
+#include <grass/gis.h>
+#include <grass/glocale.h>
+#define POLYGON_DIMENSION 50
+double point_in_triangle(double point_x, double point_y, double point_z, double t1_x, double t1_y, double t1_z, double t2_x, double t2_y, double t2_z, double t3_x, double t3_y, double t3_z);
+int prct2porosity(double sand_input, double clay_input);
+int prct2ksat(double sand_input, double clay_input);
+int prct2hf(double sand_input, double clay_input);
+int main(int argc, char *argv[])
+	struct Cell_head cellhd; //region+header info
+	char *mapset; // mapset name
+	int nrows, ncols;
+	int row,col;
+	struct GModule *module;
+	struct Option *input1, *input2, *input3, *input4;
+	struct Option *output1, *output2, *output3;
+	struct Flag *flag1;
+	struct History history; //metadata
+	/* FMEO Declarations*****************/
+	char *name;   // input raster name
+	char *result1; //output porosity raster name
+	char *result2; //output KSat raster name
+	char *result3; //output Hf raster name
+	//File Descriptors
+	int infd_psand, infd_pclay;
+	int outfd1, outfd2, outfd3;
+	char *psand,*pclay;
+	int i=0,j=0;
+	void *inrast_psand, *inrast_pclay;
+	DCELL *outrast1, *outrast2, *outrast3;
+	RASTER_MAP_TYPE data_type_output=DCELL_TYPE;
+	RASTER_MAP_TYPE data_type_psand;
+	RASTER_MAP_TYPE data_type_pclay;
+	G_gisinit(argv[0]);
+	module = G_define_module();
+	module->keywords = _("soil, texture, porosity, Ksat, Hf");
+	module->description = _("Texture to soil properties (porosity, Ksat,Hf)");
+	/* Define the different options */
+	input1 = G_define_standard_option(G_OPT_R_INPUT) ;
+	input1->key	   = _("psand");
+	input1->description=_("Name of the Soil sand fraction map [0.0-1.0]");
+	input1->answer     =_("psand");
+	input2 = G_define_standard_option(G_OPT_R_INPUT) ;
+	input2->key        =_("pclay");
+	input2->description=_("Name of the Soil clay fraction map [0.0-1.0]");
+	input2->answer     =_("pclay");
+	output1 = G_define_standard_option(G_OPT_R_OUTPUT) ;
+	output1->key        =_("porosity");
+	output1->description=_("Name of the output porosity layer");
+	output1->answer     =_("porosity");
+	output2 = G_define_standard_option(G_OPT_R_OUTPUT) ;
+	output2->key        =_("ksat");
+	output2->description=_("Name of the output Ksat layer");
+	output2->answer     =_("ksat");
+	output3 = G_define_standard_option(G_OPT_R_OUTPUT) ;
+	output3->key        =_("hf");
+	output3->description=_("Name of the output hf layer");
+	output3->answer     =_("hf");
+	if (G_parser(argc, argv))
+		exit (EXIT_FAILURE);
+	psand	 	= input1->answer;
+	pclay	 	= input2->answer;
+	result1  = output1->answer;
+	result2  = output2->answer;
+	result3  = output3->answer;
+	mapset = G_find_cell2(psand, "");
+		G_fatal_error(_("cell file [%s] not found"), psand);
+	data_type_psand = G_raster_map_type(psand,mapset);
+	if ( (infd_psand = G_open_cell_old (psand,mapset)) < 0)
+		G_fatal_error (_("Cannot open cell file [%s]"), psand);
+	if (G_get_cellhd (psand, mapset, &cellhd) < 0)
+		G_fatal_error (_("Cannot read file header of [%s])"), psand);
+	inrast_psand = G_allocate_raster_buf(data_type_psand);
+	mapset = G_find_cell2 (pclay, "");
+		G_fatal_error(_("Cell file [%s] not found"), pclay);
+	data_type_pclay = G_raster_map_type(pclay,mapset);
+	if ( (infd_pclay = G_open_cell_old (pclay,mapset)) < 0)
+		G_fatal_error(_("Cannot open cell file [%s]"), pclay);
+	if (G_get_cellhd (pclay, mapset, &cellhd) < 0)
+		G_fatal_error(_("Cannot read file header of [%s]"), pclay);
+	inrast_pclay = G_allocate_raster_buf(data_type_pclay);
+	G_debug(3, "number of rows %d",cellhd.rows);
+	nrows = G_window_rows();
+	ncols = G_window_cols();
+	outrast1 = G_allocate_raster_buf(data_type_output);
+	outrast2 = G_allocate_raster_buf(data_type_output);
+	outrast3 = G_allocate_raster_buf(data_type_output);
+	/* Create New raster files */
+	if ( (outfd1 = G_open_raster_new(result1,data_type_output)) < 0)
+		G_fatal_error(_("Could not open <%s>"),result1);
+	if ( (outfd2 = G_open_raster_new(result2,data_type_output)) < 0)
+		G_fatal_error(_("Could not open <%s>"),result2);
+	if ( (outfd3 = G_open_raster_new(result3,data_type_output)) < 0)
+		G_fatal_error(_("Could not open <%s>"),result3);
+	/* Process pixels */
+	for (row = 0; row < nrows; row++)
+		DCELL d;
+		DCELL d_sand;
+		DCELL d_clay;
+		double tex[4] = {0.0,0.0,0.0,0.0};
+		G_percent(row,nrows,2);
+//		printf("row = %i/%i\n",row,nrows);
+		/* read soil input maps */
+		if(G_get_raster_row(infd_psand,inrast_psand,row,data_type_psand)<0)
+			G_fatal_error(_("Could not read from <%s>"),psand);
+		if(G_get_raster_row(infd_pclay,inrast_pclay,row,data_type_pclay)<0)
+			G_fatal_error(_("Could not read from <%s>"),pclay);
+		/*process the data */
+		for (col=0; col < ncols; col++)
+			d_sand = ((DCELL *) inrast_psand)[col];
+			d_clay = ((DCELL *) inrast_pclay)[col];
+			if(G_is_d_null_value(&d_sand)||
+			G_is_d_null_value(&d_clay)){
+				G_set_d_null_value(&outrast1[col],1);
+				G_set_d_null_value(&outrast2[col],1);
+				G_set_d_null_value(&outrast3[col],1);
+			} else {
+				/* convert to porosity		    */
+				d = prct2porosity(d_sand, d_clay);
+				outrast1[col] = d;
+				d = prct2ksat(d_sand, d_clay);
+				outrast2[col] = d;
+				d = prct2hf(d_sand, d_clay);
+				outrast3[col] = d;
+		if (G_put_raster_row (outfd1, outrast1, data_type_output)<0)
+			G_fatal_error(_("Cannot write output raster file1"));
+		if (G_put_raster_row (outfd2, outrast2, data_type_output)<0)
+			G_fatal_error(_("Cannot write output raster file2"));
+		if (G_put_raster_row (outfd3, outrast3, data_type_output)<0)
+			G_fatal_error(_("Cannot write output raster file3"));
+	G_free (inrast_psand);
+	G_free (inrast_pclay);
+	G_close_cell (infd_psand);
+	G_close_cell (infd_pclay);
+	G_free (outrast1);
+	G_close_cell (outfd1);
+	G_free (outrast2);
+	G_close_cell (outfd2);
+	G_free (outrast3);
+	G_close_cell (outfd3);
+	G_short_history(result1, "raster", &history);
+	G_command_history(&history);
+	G_write_history(result1,&history);
+	G_short_history(result2, "raster", &history);
+	G_write_history(result2,&history);
+	G_short_history(result3, "raster", &history);
+	G_write_history(result3,&history);
+	exit(EXIT_SUCCESS);
Added: grass-addons/gipe/r.soiltex2prop/prct2hf.c
--- grass-addons/gipe/r.soiltex2prop/prct2hf.c	                        (rev 0)
+++ grass-addons/gipe/r.soiltex2prop/prct2hf.c	2008-05-22 13:41:51 UTC (rev 31483)
@@ -0,0 +1,716 @@
+#include<stdio.h>
+struct vector{
+	double sand;
+	double clay;
+	double silt;
+// HF
+int prct2hf(double sand_input, double clay_input){
+	int i,index;
+	double temp, hf;
+	double silt_input=0.0; 	//Rawls et al (1990)
+				//do not have silt input
+	// set up mark index for inside/outside polygon check
+	double mark[POLYGON_DIMENSION]={0.0};
+	//printf("in prct2hf(), cm\n");
+	//setup the 3Dvectors and initialize them
+	struct vector cls[POLYGON_DIMENSION] = {0.0};
+	//In case silt is not == 0.0, fill up explicitly
+	for(i=0;i<POLYGON_DIMENSION;i++){
+		cls[0].sand=0.0;
+		cls[0].clay=0.0;
+		cls[0].silt=0.0;
+	cls[0].sand=0.0;
+	cls[0].clay=100.0;
+	cls[1].sand=0.0;
+	cls[1].clay=54.0;
+	cls[2].sand=17.0;
+	cls[2].clay=55.0;
+	//Get started
+	mark[0]=point_in_triangle(sand_input,clay_input,silt_input,cls[0].sand,cls[0].clay,cls[0].silt,cls[1].sand,cls[1].clay,cls[1].silt,cls[2].sand,cls[2].clay,cls[2].silt);
+	if(mark[0]==1){
+		hf=175.0;
+		index=1;
+		//printf("hf=175.0\n");
+	if (index==0){// if index not found then continue
+		cls[0].sand=0.0;
+		cls[1].sand=17.0;
+		cls[1].clay=55.0;
+		cls[2].sand=30.0;
+		cls[2].clay=60.0;
+		if(mark[0]==1){
+			index=1;
+			hf=175.0;
+		cls[0].sand=0.0;
+		cls[1].sand=34.0;
+		cls[1].clay=66.0;
+		cls[2].sand=30.0;
+		cls[2].clay=60.0;
+		if(mark[0]==1){
+			index=1;
+			hf=175.0;
+		cls[0].sand=100.0;
+		cls[0].clay=0.0;
+		cls[1].sand=72.0;
+		cls[1].clay=0.0;
+		cls[2].sand=65.0;
+		cls[2].clay=15.0;
+		if(mark[0]==1){
+			index=1;
+			//printf("hf=5.0\n");
+			hf=5.0;
+		cls[0].clay=0.0;
+		cls[1].sand=65.0;
+		cls[1].clay=30.0;
+		cls[2].sand=65.0;
+		cls[2].clay=15.0;
+		if(mark[0]==1){
+			index=1;
+			hf=5.0;
+		cls[0].clay=0.0;
+		cls[1].sand=65.0;
+		cls[1].clay=30.0;
+		cls[2].sand=67.0;
+		cls[2].clay=33.0;
+		if(mark[0]==1){
+			index=1;
+			hf=5.0;
+		cls[0].sand=58.0;
+		cls[0].clay=42.0;
+		cls[1].sand=65.0;
+		cls[1].clay=30.0;
+		cls[2].sand=67.0;
+		cls[2].clay=33.0;
+		if(mark[0]==1){
+			index=1;
+			//printf("hf=15.0\n");
+			hf=15.0;
+		cls[0].sand=58.0;
+		cls[0].clay=42.0;
+		cls[1].sand=65.0;
+		cls[1].clay=30.0;
+		cls[2].sand=30.0;
+		cls[2].clay=0.0;
+		if(mark[0]==1){
+			index=1;
+			hf=15.0;
+		cls[0].sand=65.0;
+		cls[0].clay=15.0;
+		cls[1].sand=65.0;
+		cls[1].clay=30.0;
+		cls[2].sand=30.0;
+		cls[2].clay=0.0;
+		if(mark[0]==1){
+			index=1;
+			hf=15.0;
+		cls[0].sand=65.0;
+		cls[0].clay=15.0;
+		cls[1].sand=72.0;
+		cls[1].clay=0.0;
+		cls[2].sand=30.0;
+		cls[2].clay=0.0;
+		if(mark[0]==1){
+			index=1;
+			hf=15.0;
+		cls[0].sand=16.0;
+		cls[0].clay=0.0;
+		cls[1].sand=20.0;
+		cls[1].clay=14.0;
+		cls[2].sand=30.0;
+		cls[2].clay=0.0;
+		if(mark[0]==1){
+			index=1;
+			//printf("hf=25.0\n");
+			hf=25.0;
+		cls[0].sand=28.0;
+		cls[0].clay=24.0;
+		cls[1].sand=20.0;
+		cls[1].clay=14.0;
+		cls[2].sand=30.0;
+		cls[2].clay=0.0;
+		if(mark[0]==1){
+			index=1;
+			hf=25.0;
+		cls[0].sand=28.0;
+		cls[0].clay=24.0;
+		cls[1].sand=58.0;
+		cls[1].clay=42.0;
+		cls[2].sand=30.0;
+		cls[2].clay=0.0;
+		if(mark[0]==1){
+			index=1;
+			hf=25.0;
+		cls[0].sand=28.0;
+		cls[0].clay=24.0;
+		cls[1].sand=58.0;
+		cls[1].clay=42.0;
+		cls[2].sand=55.0;
+		cls[2].clay=45.0;
+		if(mark[0]==1){
+			index=1;
+			hf=25.0;
+		cls[0].sand=55.0;
+		cls[0].clay=45.0;
+		cls[1].sand=50.0;
+		cls[1].clay=50.0;
+		cls[2].sand=35.0;
+		cls[2].clay=42.0;
+		if(mark[0]==1){
+			index=1;
+			//printf("hf=35.0\n");
+			hf=35.0;
+		cls[0].sand=55.0;
+		cls[0].clay=45.0;
+		cls[1].sand=28.0;
+		cls[1].clay=24.0;
+		cls[2].sand=35.0;
+		cls[2].clay=42.0;
+		if(mark[0]==1){
+			index=1;
+			hf=35.0;
+		cls[0].sand=20.0;
+		cls[0].clay=28.0;
+		cls[1].sand=28.0;
+		cls[1].clay=24.0;
+		cls[2].sand=35.0;
+		cls[2].clay=42.0;
+		if(mark[0]==1){
+			index=1;
+			hf=35.0;
+		cls[0].sand=20.0;
+		cls[0].clay=28.0;
+		cls[1].sand=28.0;
+		cls[1].clay=24.0;
+		cls[2].sand=20.0;
+		cls[2].clay=14.0;
+		if(mark[0]==1){
+			index=1;
+			hf=35.0;
+		cls[0].sand=20.0;
+		cls[0].clay=28.0;
+		cls[1].sand=10.0;
+		cls[1].clay=14.0;
+		cls[2].sand=20.0;
+		cls[2].clay=14.0;
+		if(mark[0]==1){
+			index=1;
+			hf=35.0;
+		cls[0].sand=16.0;
+		cls[0].clay=0.0;
+		cls[1].sand=10.0;
+		cls[1].clay=14.0;
+		cls[2].sand=20.0;
+		cls[2].clay=14.0;
+		if(mark[0]==1){
+			index=1;
+			hf=35.0;
+		cls[0].sand=16.0;
+		cls[0].clay=0.0;
+		cls[1].sand=10.0;
+		cls[1].clay=14.0;
+		cls[2].sand=7.0;
+		cls[2].clay=3.0;
+		if(mark[0]==1){
+			index=1;
+			hf=35.0;
+		cls[0].sand=16.0;
+		cls[0].clay=0.0;
+		cls[1].sand=0.0;
+		cls[1].clay=0.0;
+		cls[2].sand=7.0;
+		cls[2].clay=3.0;
+		if(mark[0]==1){
+			index=1;
+			hf=35.0;
+		cls[0].sand=3.0;
+		cls[0].clay=3.0;
+		cls[1].sand=0.0;
+		cls[1].clay=0.0;
+		cls[2].sand=7.0;
+		cls[2].clay=3.0;
+		if(mark[0]==1){
+			index=1;
+			hf=35.0;
+		cls[0].sand=3.0;
+		cls[0].clay=3.0;
+		cls[1].sand=0.0;
+		cls[1].clay=0.0;
+		cls[2].sand=0.0;
+		cls[2].clay=9.0;
+		if(mark[0]==1){
+			index=1;
+			hf=35.0;
+		cls[0].sand=3.0;
+		cls[0].clay=3.0;
+		cls[1].sand=0.0;
+		cls[1].clay=28.0;
+		cls[2].sand=0.0;
+		cls[2].clay=9.0;
+		if(mark[0]==1){
+			index=1;
+			//printf("hf=50.0\n");
+			hf=50.0;
+		cls[0].sand=3.0;
+		cls[0].clay=3.0;
+		cls[1].sand=0.0;
+		cls[1].clay=28.0;
+		cls[2].sand=7.0;
+		cls[2].clay=3.0;
+		if(mark[0]==1){
+			index=1;
+			hf=50.0;
+		cls[0].sand=10.0;
+		cls[0].clay=14.0;
+		cls[1].sand=0.0;
+		cls[1].clay=28.0;
+		cls[2].sand=7.0;
+		cls[2].clay=3.0;
+		if(mark[0]==1){
+			index=1;
+			hf=50.0;
+		cls[0].sand=10.0;
+		cls[0].clay=14.0;
+		cls[1].sand=0.0;
+		cls[1].clay=28.0;
+		cls[2].sand=10.0;
+		cls[2].clay=27.0;
+		if(mark[0]==1){
+			index=1;
+			hf=50.0;
+		cls[0].sand=10.0;
+		cls[0].clay=14.0;
+		cls[1].sand=20.0;
+		cls[1].clay=28.0;
+		cls[2].sand=10.0;
+		cls[2].clay=27.0;
+		if(mark[0]==1){
+			index=1;
+			hf=50.0;
+		cls[0].sand=14.0;
+		cls[0].clay=30.0;
+		cls[1].sand=20.0;
+		cls[1].clay=28.0;
+		cls[2].sand=10.0;
+		cls[2].clay=27.0;
+		if(mark[0]==1){
+			index=1;
+			hf=50.0;
+		cls[0].sand=14.0;
+		cls[0].clay=30.0;
+		cls[1].sand=20.0;
+		cls[1].clay=28.0;
+		cls[2].sand=16.0;
+		cls[2].clay=35.0;
+		if(mark[0]==1){
+			index=1;
+			hf=50.0;
+		cls[0].sand=23.0;
+		cls[0].clay=42.0;
+		cls[1].sand=20.0;
+		cls[1].clay=28.0;
+		cls[2].sand=16.0;
+		cls[2].clay=35.0;
+		if(mark[0]==1){
+			index=1;
+			hf=50.0;
+		cls[0].sand=23.0;
+		cls[0].clay=42.0;
+		cls[1].sand=20.0;
+		cls[1].clay=28.0;
+		cls[2].sand=35.0;
+		cls[2].clay=42.0;
+		if(mark[0]==1){
+			index=1;
+			hf=50.0;
+		cls[0].sand=23.0;
+		cls[0].clay=42.0;
+		cls[1].sand=36.0;
+		cls[1].clay=46.0;
+		cls[2].sand=35.0;
+		cls[2].clay=42.0;
+		if(mark[0]==1){
+			index=1;
+			hf=50.0;
+		cls[0].sand=50.0;
+		cls[0].clay=50.0;
+		cls[1].sand=36.0;
+		cls[1].clay=46.0;
+		cls[2].sand=35.0;
+		cls[2].clay=42.0;
+		if(mark[0]==1){
+			index=1;
+			hf=50.0;
+		cls[0].sand=50.0;
+		cls[0].clay=50.0;
+		cls[1].sand=36.0;
+		cls[1].clay=46.0;
+		cls[2].sand=45.0;
+		cls[2].clay=55.0;
+		if(mark[0]==1){
+			index=1;
+			hf=50.0;
+		cls[0].sand=38.0;
+		cls[0].clay=55.0;
+		cls[1].sand=36.0;
+		cls[1].clay=46.0;
+		cls[2].sand=45.0;
+		cls[2].clay=55.0;
+		if(mark[0]==1){
+			index=1;
+			//printf("hf=80.0\n");
+			hf=80.0;
+		cls[0].sand=38.0;
+		cls[0].clay=55.0;
+		cls[1].sand=42.0;
+		cls[1].clay=58.0;
+		cls[2].sand=45.0;
+		cls[2].clay=55.0;
+		if(mark[0]==1){
+			index=1;
+			hf=80.0;
+		cls[0].sand=38.0;
+		cls[0].clay=55.0;
+		cls[1].sand=36.0;
+		cls[1].clay=46.0;
+		cls[2].sand=23.0;
+		cls[2].clay=42.0;
+		if(mark[0]==1){
+			index=1;
+			hf=80.0;
+		cls[0].sand=38.0;
+		cls[0].clay=55.0;
+		cls[1].sand=0.0;
+		cls[1].clay=44.0;
+		cls[2].sand=23.0;
+		cls[2].clay=42.0;
+		if(mark[0]==1){
+			index=1;
+			hf=80.0;
+		cls[0].sand=16.0;
+		cls[0].clay=35.0;
+		cls[1].sand=0.0;
+		cls[1].clay=44.0;
+		cls[2].sand=23.0;
+		cls[2].clay=42.0;
+		if(mark[0]==1){
+			index=1;
+			hf=80.0;
+		cls[0].sand=16.0;
+		cls[0].clay=35.0;
+		cls[1].sand=0.0;
+		cls[1].clay=44.0;
+		cls[2].sand=14.0;
+		cls[2].clay=30.0;
+		if(mark[0]==1){
+			index=1;
+			hf=80.0;
+		cls[0].sand=10.0;
+		cls[0].clay=27.0;
+		cls[1].sand=0.0;
+		cls[1].clay=44.0;
+		cls[2].sand=14.0;
+		cls[2].clay=30.0;
+		if(mark[0]==1){
+			index=1;
+			hf=80.0;
+		cls[0].sand=10.0;
+		cls[0].clay=27.0;
+		cls[1].sand=0.0;
+		cls[1].clay=44.0;
+		cls[2].sand=0.0;
+		cls[2].clay=28.0;
+		if(mark[0]==1){
+			index=1;
+			hf=80.0;
+		cls[0].sand=17.0;
+		cls[0].clay=55.0;
+		cls[1].sand=0.0;
+		cls[1].clay=44.0;
+		cls[2].sand=0.0;
+		cls[2].clay=54.0;
+		if(mark[0]==1){
+			index=1;
+			//printf("hf=125.0\n");
+			hf=125.0;
+		cls[0].sand=17.0;
+		cls[0].clay=55.0;
+		cls[1].sand=0.0;
+		cls[1].clay=44.0;
+		cls[2].sand=38.0;
+		cls[2].clay=55.0;
+		if(mark[0]==1){
+			index=1;
+			hf=125.0;
+		cls[0].sand=17.0;
+		cls[0].clay=55.0;
+		cls[1].sand=30.0;
+		cls[1].clay=60.0;
+		cls[2].sand=38.0;
+		cls[2].clay=55.0;
+		if(mark[0]==1){
+			index=1;
+			hf=125.0;
+		cls[0].sand=42.0;
+		cls[0].clay=58.0;
+		cls[1].sand=30.0;
+		cls[1].clay=60.0;
+		cls[2].sand=38.0;
+		cls[2].clay=55.0;
+		if(mark[0]==1){
+			index=1;
+			hf=125.0;
+		cls[0].sand=42.0;
+		cls[0].clay=58.0;
+		cls[1].sand=30.0;
+		cls[1].clay=60.0;
+		cls[2].sand=34.0;
+		cls[2].clay=66.0;
+		if(mark[0]==1){
+			index=1;
+			hf=125.0;
+	return hf;
Added: grass-addons/gipe/r.soiltex2prop/prct2ksat.c
--- grass-addons/gipe/r.soiltex2prop/prct2ksat.c	                        (rev 0)
+++ grass-addons/gipe/r.soiltex2prop/prct2ksat.c	2008-05-22 13:41:51 UTC (rev 31483)
@@ -0,0 +1,1038 @@
+#include<stdio.h>
+struct vector{
+	double sand;
+	double clay;
+	double silt;
+// KSAT
+int prct2ksat(double sand_input, double clay_input){
+	int i,index;
+	double temp,ksat;
+	//printf("in prct2ksat(), cm/h\n");
+		cls[0].sand=0.0;
+		cls[0].clay=0.0;
+		cls[0].silt=0.0;
+	cls[0].sand=0.0;
+	cls[1].sand=0.0;
+	cls[1].clay=60.0;
+	cls[2].sand=7.0;
+	cls[2].clay=56.0;
+	//Get started
+	if(mark[0]==1){
+		ksat=0.0025;
+		index=1;
+		//printf("Ksat=0.0025\n");
+		cls[0].sand=0.0;
+		cls[1].sand=7.0;
+		cls[1].clay=56.0;
+		cls[2].sand=30.0;
+		cls[2].clay=56.0;
+		if(mark[0]==1){
+			index=1;
+			ksat=0.0025;
+		cls[0].sand=0.0;
+		cls[1].sand=30.0;
+		cls[1].clay=56.0;
+		cls[2].sand=40.0;
+		cls[2].clay=63.0;
+		if(mark[0]==1){
+			index=1;
+			ksat=0.0025;
+		cls[0].clay=0.0;
+		cls[1].sand=85.0;
+		cls[1].clay=0.0;
+		cls[2].sand=90.0;
+		cls[2].clay=10.0;
+		if(mark[0]==1){
+			index=1;
+			//printf("Ksat=25.0\n");
+			ksat=25.0;
+		cls[0].sand=85.0;
+		cls[0].clay=0.0;
+		cls[1].sand=90.0;
+		cls[1].clay=10.0;
+		cls[2].sand=80.0;
+		cls[2].clay=0.0;
+		if(mark[0]==1){
+			index=1;
+			//printf("Ksat=15.0\n");
+			ksat=15.0;
+		cls[0].sand=80.0;
+		cls[0].clay=0.0;
+		cls[1].sand=90.0;
+		cls[1].clay=10.0;
+		cls[2].sand=85.0;
+		cls[2].clay=15.0;
+		if(mark[0]==1){
+			index=1;
+			ksat=15.0;
+		cls[0].sand=85.0;
+		cls[0].clay=15.0;
+		cls[1].sand=80.0;
+		cls[1].clay=0.0;
+		cls[2].sand=70.0;
+		cls[2].clay=0.0;
+		if(mark[0]==1){
+			index=1;
+			//printf("Ksat=7.5\n");
+			ksat=7.5;
+		cls[0].sand=70.0;
+		cls[0].clay=0.0;
+		cls[1].sand=85.0;
+		cls[1].clay=15.0;
+		cls[2].sand=75.0;
+		cls[2].clay=25.0;
+		if(mark[0]==1){
+			index=1;
+			ksat=7.5;
+		cls[0].sand=70.0;
+		cls[0].clay=0.0;
+		cls[1].sand=75.0;
+		cls[1].clay=25.0;
+		cls[2].sand=68.0;
+		cls[2].clay=23.0;
+		if(mark[0]==1){
+			index=1;
+			//printf("Ksat=2.5\n");
+			ksat=2.5;
+		cls[0].sand=75.0;
+		cls[0].clay=25.0;
+		cls[1].sand=68.0;
+		cls[1].clay=23.0;
+		cls[2].sand=70.0;
+		cls[2].clay=30.0;
+		if(mark[0]==1){
+			index=1;
+			ksat=2.5;
+		cls[0].sand=70.0;
+		cls[0].clay=0.0;
+		cls[1].sand=35.0;
+		cls[1].clay=0.0;
+		cls[2].sand=68.0;
+		cls[2].clay=23.0;
+		if(mark[0]==1){
+			index=1;
+			ksat=2.5;
+		cls[0].sand=17.0;
+		cls[0].clay=0.0;
+		cls[1].sand=35.0;
+		cls[1].clay=0.0;
+		cls[2].sand=22.0;
+		cls[2].clay=5.0;
+		if(mark[0]==1){
+			index=1;
+			//printf("Ksat=1.5\n");
+			ksat=1.5;
+		cls[0].sand=22.0;
+		cls[0].clay=5.0;
+		cls[1].sand=35.0;
+		cls[1].clay=0.0;
+		cls[2].sand=68.0;
+		cls[2].clay=23.0;
+		if(mark[0]==1){
+			index=1;
+			ksat=1.5;
+		cls[0].sand=22.0;
+		cls[0].clay=5.0;
+		cls[1].sand=68.0;
+		cls[1].clay=23.0;
+		cls[2].sand=60.0;
+		cls[2].clay=25.0;
+		if(mark[0]==1){
+			index=1;
+			ksat=1.5;
+		cls[0].sand=60.0;
+		cls[0].clay=25.0;
+		cls[1].sand=68.0;
+		cls[1].clay=23.0;
+		cls[2].sand=70.0;
+		cls[2].clay=30.0;
+		if(mark[0]==1){
+			index=1;
+			ksat=1.5;
+		cls[0].sand=60.0;
+		cls[0].clay=25.0;
+		cls[1].sand=65.0;
+		cls[1].clay=35.0;
+		cls[2].sand=70.0;
+		cls[2].clay=30.0;
+		if(mark[0]==1){
+			index=1;
+			ksat=1.5;
+		cls[0].sand=17.0;
+		cls[0].clay=0.0;
+		cls[1].sand=10.0;
+		cls[1].clay=0.0;
+		cls[2].sand=22.0;
+		cls[2].clay=5.0;
+		if(mark[0]==1){
+			index=1;
+			//printf("Ksat=0.8\n");
+			ksat=0.8;
+		cls[0].sand=20.0;
+		cls[0].clay=12.0;
+		cls[1].sand=10.0;
+		cls[1].clay=0.0;
+		cls[2].sand=22.0;
+		cls[2].clay=5.0;
+		if(mark[0]==1){
+			index=1;
+			ksat=0.8;
+		cls[0].sand=20.0;
+		cls[0].clay=12.0;
+		cls[1].sand=42.0;
+		cls[1].clay=20.0;
+		cls[2].sand=22.0;
+		cls[2].clay=5.0;
+		if(mark[0]==1){
+			index=1;
+			ksat=0.8;
+		cls[0].sand=60.0;
+		cls[0].clay=25.0;
+		cls[1].sand=42.0;
+		cls[1].clay=20.0;
+		cls[2].sand=22.0;
+		cls[2].clay=5.0;
+		if(mark[0]==1){
+			index=1;
+			ksat=0.8;
+		cls[0].sand=60.0;
+		cls[0].clay=25.0;
+		cls[1].sand=42.0;
+		cls[1].clay=20.0;
+		cls[2].sand=57.0;
+		cls[2].clay=30.0;
+		if(mark[0]==1){
+			index=1;
+			ksat=0.8;
+		cls[0].sand=60.0;
+		cls[0].clay=25.0;
+		cls[1].sand=65.0;
+		cls[1].clay=35.0;
+		cls[2].sand=57.0;
+		cls[2].clay=30.0;
+		if(mark[0]==1){
+			index=1;
+			ksat=0.8;
+		cls[0].sand=63.0;
+		cls[0].clay=38.0;
+		cls[1].sand=65.0;
+		cls[1].clay=35.0;
+		cls[2].sand=57.0;
+		cls[2].clay=30.0;
+		if(mark[0]==1){
+			index=1;
+			ksat=0.8;
+		cls[0].sand=55.0;
+		cls[0].clay=35.0;
+		cls[1].sand=60.0;
+		cls[1].clay=40.0;
+		cls[2].sand=63.0;
+		cls[2].clay=38.0;
+		if(mark[0]==1){
+			index=1;
+			//printf("Ksat=0.5\n");
+			ksat=0.5;
+		cls[0].sand=55.0;
+		cls[0].clay=35.0;
+		cls[1].sand=57.0;
+		cls[1].clay=30.0;
+		cls[2].sand=63.0;
+		cls[2].clay=38.0;
+		if(mark[0]==1){
+			index=1;
+			ksat=0.5;
+		cls[0].sand=55.0;
+		cls[0].clay=35.0;
+		cls[1].sand=57.0;
+		cls[1].clay=30.0;
+		cls[2].sand=38.0;
+		cls[2].clay=23.0;
+		if(mark[0]==1){
+			index=1;
+			ksat=0.5;
+		cls[0].sand=42.0;
+		cls[0].clay=20.0;
+		cls[1].sand=57.0;
+		cls[1].clay=30.0;
+		cls[2].sand=38.0;
+		cls[2].clay=23.0;
+		if(mark[0]==1){
+			index=1;
+			ksat=0.5;
+		cls[0].sand=42.0;
+		cls[0].clay=20.0;
+		cls[1].sand=23.0;
+		cls[1].clay=20.0;
+		cls[2].sand=20.0;
+		cls[2].clay=12.0;
+		if(mark[0]==1){
+			index=1;
+			ksat=0.5;
+		cls[0].sand=7.0;
+		cls[0].clay=3.0;
+		cls[1].sand=23.0;
+		cls[1].clay=20.0;
+		cls[2].sand=20.0;
+		cls[2].clay=12.0;
+		if(mark[0]==1){
+			index=1;
+			ksat=0.5;
+		cls[0].sand=7.0;
+		cls[0].clay=3.0;
+		cls[1].sand=10.0;
+		cls[1].clay=0.0;
+		cls[2].sand=20.0;
+		cls[2].clay=12.0;
+		if(mark[0]==1){
+			index=1;
+			ksat=0.5;
+		cls[0].sand=7.0;
+		cls[0].clay=3.0;
+		cls[1].sand=10.0;
+		cls[1].clay=0.0;
+		cls[2].sand=0.0;
+		cls[2].clay=0.0;
+		if(mark[0]==1){
+			index=1;
+			ksat=0.5;
+		cls[0].sand=7.0;
+		cls[0].clay=3.0;
+		cls[1].sand=0.0;
+		cls[1].clay=3.0;
+		cls[2].sand=0.0;
+		cls[2].clay=0.0;
+		if(mark[0]==1){
+			index=1;
+			ksat=0.5;
+		cls[0].sand=7.0;
+		cls[0].clay=3.0;
+		cls[1].sand=0.0;
+		cls[1].clay=3.0;
+		cls[2].sand=9.0;
+		cls[2].clay=18.0;
+		if(mark[0]==1){
+			index=1;
+			//printf("Ksat=0.3\n");
+			ksat=0.3;
+		cls[0].sand=0.0;
+		cls[0].clay=16.0;
+		cls[1].sand=0.0;
+		cls[1].clay=3.0;
+		cls[2].sand=9.0;
+		cls[2].clay=18.0;
+		if(mark[0]==1){
+			index=1;
+			ksat=0.3;
+		cls[0].sand=7.0;
+		cls[0].clay=3.0;
+		cls[1].sand=23.0;
+		cls[1].clay=20.0;
+		cls[2].sand=9.0;
+		cls[2].clay=18.0;
+		if(mark[0]==1){
+			index=1;
+			ksat=0.3;
+		cls[0].sand=22.0;
+		cls[0].clay=29.0;
+		cls[1].sand=23.0;
+		cls[1].clay=20.0;
+		cls[2].sand=9.0;
+		cls[2].clay=18.0;
+		if(mark[0]==1){
+			index=1;
+			ksat=0.3;
+		cls[0].sand=22.0;
+		cls[0].clay=29.0;
+		cls[1].sand=23.0;
+		cls[1].clay=20.0;
+		cls[2].sand=33.0;
+		cls[2].clay=29.0;
+		if(mark[0]==1){
+			index=1;
+			ksat=0.3;
+		cls[0].sand=38.0;
+		cls[0].clay=23.0;
+		cls[1].sand=23.0;
+		cls[1].clay=20.0;
+		cls[2].sand=33.0;
+		cls[2].clay=29.0;
+		if(mark[0]==1){
+			index=1;
+			ksat=0.3;
+		cls[0].sand=38.0;
+		cls[0].clay=23.0;
+		cls[1].sand=50.0;
+		cls[1].clay=35.0;
+		cls[2].sand=33.0;
+		cls[2].clay=29.0;
+		if(mark[0]==1){
+			index=1;
+			ksat=0.3;
+		cls[0].sand=38.0;
+		cls[0].clay=23.0;
+		cls[1].sand=50.0;
+		cls[1].clay=35.0;
+		cls[2].sand=55.0;
+		cls[2].clay=35.0;
+		if(mark[0]==1){
+			index=1;
+			ksat=0.3;
+		cls[0].sand=60.0;
+		cls[0].clay=40.0;
+		cls[1].sand=50.0;
+		cls[1].clay=35.0;
+		cls[2].sand=55.0;
+		cls[2].clay=35.0;
+		if(mark[0]==1){
+			index=1;
+			ksat=0.3;
+		cls[0].sand=60.0;
+		cls[0].clay=40.0;
+		cls[1].sand=50.0;
+		cls[1].clay=35.0;
+		cls[2].sand=57.0;
+		cls[2].clay=44.0;
+		if(mark[0]==1){
+			index=1;
+			ksat=0.3;
+		cls[0].sand=40.0;
+		cls[0].clay=38.0;
+		cls[1].sand=50.0;
+		cls[1].clay=35.0;
+		cls[2].sand=57.0;
+		cls[2].clay=44.0;
+		if(mark[0]==1){
+			index=1;
+			//printf("Ksat=0.15\n");
+			ksat=0.15;
+		cls[0].sand=40.0;
+		cls[0].clay=38.0;
+		cls[1].sand=55.0;
+		cls[1].clay=45.0;
+		cls[2].sand=57.0;
+		cls[2].clay=44.0;
+		if(mark[0]==1){
+			index=1;
+			ksat=0.15;
+		cls[0].sand=40.0;
+		cls[0].clay=38.0;
+		cls[1].sand=50.0;
+		cls[1].clay=35.0;
+		cls[2].sand=33.0;
+		cls[2].clay=29.0;
+		if(mark[0]==1){
+			index=1;
+			ksat=0.15;
+		cls[0].sand=40.0;
+		cls[0].clay=38.0;
+		cls[1].sand=30.0;
+		cls[1].clay=38.0;
+		cls[2].sand=33.0;
+		cls[2].clay=29.0;
+		if(mark[0]==1){
+			index=1;
+			ksat=0.15;
+		cls[0].sand=22.0;
+		cls[0].clay=29.0;
+		cls[1].sand=30.0;
+		cls[1].clay=38.0;
+		cls[2].sand=33.0;
+		cls[2].clay=29.0;
+		if(mark[0]==1){
+			index=1;
+			ksat=0.15;
+		cls[0].sand=22.0;
+		cls[0].clay=29.0;
+		cls[1].sand=30.0;
+		cls[1].clay=38.0;
+		cls[2].sand=13.0;
+		cls[2].clay=29.0;
+		if(mark[0]==1){
+			index=1;
+			ksat=0.15;
+		cls[0].sand=22.0;
+		cls[0].clay=29.0;
+		cls[1].sand=9.0;
+		cls[1].clay=18.0;
+		cls[2].sand=13.0;
+		cls[2].clay=29.0;
+		if(mark[0]==1){
+			index=1;
+			ksat=0.15;
+		cls[0].sand=0.0;
+		cls[0].clay=16.0;
+		cls[1].sand=9.0;
+		cls[1].clay=18.0;
+		cls[2].sand=13.0;
+		cls[2].clay=29.0;
+		if(mark[0]==1){
+			index=1;
+			ksat=0.15;
+		cls[0].sand=0.0;
+		cls[0].clay=16.0;
+		cls[1].sand=0.0;
+		cls[1].clay=25.0;
+		cls[2].sand=13.0;
+		cls[2].clay=29.0;
+		if(mark[0]==1){
+			index=1;
+			ksat=0.15;
+		cls[0].sand=0.0;
+		cls[0].clay=33.0;
+		cls[1].sand=0.0;
+		cls[1].clay=25.0;
+		cls[2].sand=15.0;
+		cls[2].clay=38.0;
+		if(mark[0]==1){
+			index=1;
+			//printf("Ksat=0.075\n");
+			ksat=0.075;
+		cls[0].sand=13.0;
+		cls[0].clay=29.0;
+		cls[1].sand=0.0;
+		cls[1].clay=25.0;
+		cls[2].sand=15.0;
+		cls[2].clay=38.0;
+		if(mark[0]==1){
+			index=1;
+			ksat=0.075;
+		cls[0].sand=13.0;
+		cls[0].clay=29.0;
+		cls[1].sand=30.0;
+		cls[1].clay=38.0;
+		cls[2].sand=15.0;
+		cls[2].clay=38.0;
+		if(mark[0]==1){
+			index=1;
+			ksat=0.075;
+		cls[0].sand=20.0;
+		cls[0].clay=41.0;
+		cls[1].sand=30.0;
+		cls[1].clay=38.0;
+		cls[2].sand=15.0;
+		cls[2].clay=38.0;
+		if(mark[0]==1){
+			index=1;
+			ksat=0.075;
+		cls[0].sand=20.0;
+		cls[0].clay=41.0;
+		cls[1].sand=30.0;
+		cls[1].clay=38.0;
+		cls[2].sand=50.0;
+		cls[2].clay=50.0;
+		if(mark[0]==1){
+			index=1;
+			ksat=0.075;
+		cls[0].sand=40.0;
+		cls[0].clay=38.0;
+		cls[1].sand=30.0;
+		cls[1].clay=38.0;
+		cls[2].sand=50.0;
+		cls[2].clay=50.0;
+		if(mark[0]==1){
+			index=1;
+			ksat=0.075;
+		cls[0].sand=40.0;
+		cls[0].clay=38.0;
+		cls[1].sand=55.0;
+		cls[1].clay=45.0;
+		cls[2].sand=50.0;
+		cls[2].clay=50.0;
+		if(mark[0]==1){
+			index=1;
+			ksat=0.075;
+		cls[0].sand=13.0;
+		cls[0].clay=50.0;
+		cls[1].sand=20.0;
+		cls[1].clay=41.0;
+		cls[2].sand=50.0;
+		cls[2].clay=50.0;
+		if(mark[0]==1){
+			index=1;
+			//printf("Ksat=0.025\n");
+			ksat=0.025;
+		cls[0].sand=13.0;
+		cls[0].clay=50.0;
+		cls[1].sand=18.0;
+		cls[1].clay=53.0;
+		cls[2].sand=50.0;
+		cls[2].clay=50.0;
+		if(mark[0]==1){
+			index=1;
+			ksat=0.025;
+		cls[0].sand=35.0;
+		cls[0].clay=55.0;
+		cls[1].sand=18.0;
+		cls[1].clay=53.0;
+		cls[2].sand=50.0;
+		cls[2].clay=50.0;
+		if(mark[0]==1){
+			index=1;
+			ksat=0.025;
+		cls[0].sand=35.0;
+		cls[0].clay=55.0;
+		cls[1].sand=43.0;
+		cls[1].clay=58.0;
+		cls[2].sand=50.0;
+		cls[2].clay=50.0;
+		if(mark[0]==1){
+			index=1;
+			ksat=0.025;
+		cls[0].sand=13.0;
+		cls[0].clay=50.0;
+		cls[1].sand=20.0;
+		cls[1].clay=41.0;
+		cls[2].sand=15.0;
+		cls[2].clay=38.0;
+		if(mark[0]==1){
+			index=1;
+			ksat=0.025;
+		cls[0].sand=13.0;
+		cls[0].clay=50.0;
+		cls[1].sand=0.0;
+		cls[1].clay=33.0;
+		cls[2].sand=15.0;
+		cls[2].clay=38.0;
+		if(mark[0]==1){
+			index=1;
+			ksat=0.025;
+		cls[0].sand=13.0;
+		cls[0].clay=50.0;
+		cls[1].sand=0.0;
+		cls[1].clay=33.0;
+		cls[2].sand=0.0;
+		cls[2].clay=51.0;
+		if(mark[0]==1){
+			index=1;
+			ksat=0.025;
+		cls[0].sand=8.0;
+		cls[0].clay=56.0;
+		cls[1].sand=0.0;
+		cls[1].clay=60.0;
+		cls[2].sand=0.0;
+		cls[2].clay=51.0;
+		if(mark[0]==1){
+			index=1;
+			//printf("Ksat=0.0075\n");
+			ksat=0.0075;
+		cls[0].sand=8.0;
+		cls[0].clay=56.0;
+		cls[1].sand=13.0;
+		cls[1].clay=50.0;
+		cls[2].sand=0.0;
+		cls[2].clay=51.0;
+		if(mark[0]==1){
+			index=1;
+			ksat=0.0075;
+		cls[0].sand=8.0;
+		cls[0].clay=56.0;
+		cls[1].sand=13.0;
+		cls[1].clay=50.0;
+		cls[2].sand=18.0;
+		cls[2].clay=53.0;
+		if(mark[0]==1){
+			index=1;
+			ksat=0.0075;
+		cls[0].sand=8.0;
+		cls[0].clay=56.0;
+		cls[1].sand=30.0;
+		cls[1].clay=56.0;
+		cls[2].sand=18.0;
+		cls[2].clay=53.0;
+		if(mark[0]==1){
+			index=1;
+			ksat=0.0075;
+		cls[0].sand=35.0;
+		cls[0].clay=55.0;
+		cls[1].sand=30.0;
+		cls[1].clay=56.0;
+		cls[2].sand=18.0;
+		cls[2].clay=53.0;
+		if(mark[0]==1){
+			index=1;
+			ksat=0.0075;
+		cls[0].sand=35.0;
+		cls[0].clay=55.0;
+		cls[1].sand=30.0;
+		cls[1].clay=56.0;
+		cls[2].sand=43.0;
+		cls[2].clay=58.0;
+		if(mark[0]==1){
+			index=1;
+			ksat=0.0075;
+		cls[0].sand=40.0;
+		cls[0].clay=63.0;
+		cls[1].sand=30.0;
+		cls[1].clay=56.0;
+		cls[2].sand=43.0;
+		cls[2].clay=58.0;
+		if(mark[0]==1){
+			index=1;
+			ksat=0.0075;
+	return ksat;
Added: grass-addons/gipe/r.soiltex2prop/prct2porosity.c
--- grass-addons/gipe/r.soiltex2prop/prct2porosity.c	                        (rev 0)
+++ grass-addons/gipe/r.soiltex2prop/prct2porosity.c	2008-05-22 13:41:51 UTC (rev 31483)
@@ -0,0 +1,244 @@
+#include<stdio.h>
+struct vector{
+	double sand;
+	double clay;
+	double silt;
+int prct2porosity(double sand_input, double clay_input){
+	int i,index;
+	double temp,porosity;
+	//printf("in prct2poros(), Volume Fraction\n");
+		cls[0].sand=0.0;
+		cls[0].clay=0.0;
+		cls[0].silt=0.0;
+	cls[0].sand=0.0;
+	cls[1].sand=10.0;
+	cls[1].clay=90.0;
+	cls[2].sand=25.0;
+	cls[2].clay=75.0;
+	//Get started
+	if(mark[0]==1){
+		porosity=0.575;
+		index=1;
+		//printf("Poros=0.575\n");
+		cls[0].sand=10.0;
+		cls[0].clay=0.0;
+		cls[1].sand=20.0;
+		cls[1].clay=20.0;
+		cls[2].sand=50.0;
+		cls[2].clay=0.0;
+		if(mark[0]==1){
+			index=1;
+			porosity=0.575;
+		cls[0].clay=0.0;
+		cls[1].sand=50.0;
+		cls[1].clay=50.0;
+		cls[2].sand=50.0;
+		cls[2].clay=43.0;
+		if(mark[0]==1){
+			index=1;
+			//printf("Poros=0.425\n");
+			porosity=0.425;
+		cls[0].clay=0.0;
+		cls[1].sand=50.0;
+		cls[1].clay=43.0;
+		cls[2].sand=52.0;
+		cls[2].clay=33.0;
+		if(mark[0]==1){
+			index=1;
+			porosity=0.425;
+		cls[0].clay=0.0;
+		cls[1].sand=52.0;
+		cls[1].clay=33.0;
+		cls[2].sand=57.0;
+		cls[2].clay=25.0;
+		if(mark[0]==1){
+			index=1;
+			porosity=0.425;
+		cls[0].clay=0.0;
+		cls[1].sand=57.0;
+		cls[1].clay=25.0;
+		cls[2].sand=87.0;
+		cls[2].clay=0.0;
+		if(mark[0]==1){
+			index=1;
+			porosity=0.425;
+		cls[0].sand=0.0;
+		cls[0].clay=0.0;
+		cls[1].sand=25.0;
+		cls[1].clay=75.0;
+		cls[2].sand=0.0;
+		cls[2].clay=90.0;
+		if(mark[0]==1){
+			index=1;
+			//printf("Poros=0.525\n");
+			porosity=0.525;
+		cls[0].sand=0.0;
+		cls[0].clay=0.0;
+		cls[1].sand=25.0;
+		cls[1].clay=75.0;
+		cls[2].sand=10.0;
+		cls[2].clay=0.0;
+		if(mark[0]==1){
+			index=1;
+			porosity=0.525;
+		cls[0].sand=10.0;
+		cls[0].clay=0.0;
+		cls[1].sand=25.0;
+		cls[1].clay=75.0;
+		cls[2].sand=20.0;
+		cls[2].clay=20.0;
+		if(mark[0]==1){
+			index=1;
+			porosity=0.525;
+		cls[0].sand=20.0;
+		cls[0].clay=20.0;
+		cls[1].sand=25.0;
+		cls[1].clay=75.0;
+		cls[2].sand=25.0;
+		cls[2].clay=55.0;
+		if(mark[0]==1){
+			index=1;
+			porosity=0.525;
+		cls[0].sand=20.0;
+		cls[0].clay=20.0;
+		cls[1].sand=25.0;
+		cls[1].clay=55.0;
+		cls[2].sand=27.0;
+		cls[2].clay=45.0;
+		if(mark[0]==1){
+			index=1;
+			porosity=0.525;
+		cls[0].sand=20.0;
+		cls[0].clay=20.0;
+		cls[1].sand=27.0;
+		cls[1].clay=45.0;
+		cls[2].sand=50.0;
+		cls[2].clay=0.0;
+		if(mark[0]==1){
+			index=1;
+			porosity=0.525;
+		cls[0].sand=50.0;
+		cls[0].clay=0.0;
+		cls[1].sand=70.0;
+		cls[1].clay=0.0;
+		cls[2].sand=37.0;
+		cls[2].clay=25.0;
+		if(mark[0]==1){
+			index=1;
+			porosity=0.525;
+		cls[0].sand=25.0;
+		cls[0].clay=75.0;
+		cls[1].sand=25.0;
+		cls[1].clay=55.0;
+		cls[2].sand=28.0;
+		cls[2].clay=61.0;
+		if(mark[0]==1){
+			index=1;
+			porosity=0.525;
+		cls[0].sand=25.0;
+		cls[0].clay=75.0;
+		cls[1].sand=37.0;
+		cls[1].clay=65.0;
+		cls[2].sand=28.0;
+		cls[2].clay=61.0;
+		if(mark[0]==1){
+			index=1;
+			porosity=0.525;
+		index=1;
+		//printf("Poros=0.475\n");
+		porosity=0.475;
+	return porosity;
Added: grass-addons/gipe/r.soiltex2prop/vector_multiplication.c
--- grass-addons/gipe/r.soiltex2prop/vector_multiplication.c	                        (rev 0)
+++ grass-addons/gipe/r.soiltex2prop/vector_multiplication.c	2008-05-22 13:41:51 UTC (rev 31483)
@@ -0,0 +1,85 @@
+#include<stdio.h>
+struct vector{
+	double sand;
+	double clay;
+	double silt;
+double point_in_triangle(double point_x, double point_y, double point_z, double t1_x, double t1_y, double t1_z, double t2_x, double t2_y, double t2_z, double t3_x, double t3_y, double t3_z){
+	//printf("in function: sand=%5.3f clay=%5.3f silt=%5.3f\n",point_x,point_y,point_z);
+	double answer;
+	double answer1_x, answer1_y, answer1_z;
+	double answer2_x, answer2_y, answer2_z;
+	double answer3_x, answer3_y, answer3_z;
+	// Consider three points forming a trinagle from a given soil class boundary ABC
+	// Consider F an additional point in space
+	double af1, af2, af3; //Points for vector AF
+	double bf1, bf2, bf3; //Points for vector BF
+	double cf1, cf2, cf3; //Points for vector CF
+	double ab1, ab2, ab3; //Points for vector AB
+	double bc1, bc2, bc3; //Points for vector BC
+	double ca1, ca2, ca3; //Points for vector CA
+	// Create vectors AB, BC and CA
+	ab1=(t2_x-t1_x);
+	ab2=(t2_y-t1_y);
+	ab3=(t2_z-t1_z);
+	bc1=(t3_x-t2_x);
+	bc2=(t3_y-t2_y);
+	bc3=(t3_z-t2_z);
+	ca1=(t1_x-t3_x);
+	ca2=(t1_y-t3_y);
+	ca3=(t1_z-t3_z);
+	// Create vectors AF, BF and CF
+	af1=(point_x-t1_x);
+	af2=(point_y-t1_y);
+	af3=(point_z-t1_z);
+	bf1=(point_x-t2_x);
+	bf2=(point_y-t2_y);
+	bf3=(point_z-t2_z);
+	cf1=(point_x-t3_x);
+	cf2=(point_y-t3_y);
+	cf3=(point_z-t3_z);
+	// Calculate the following CrossProducts:
+	// AFxAB
+	answer1_x=(af2*ab3)-(af3*ab2);
+	answer1_y=(af3*ab1)-(af1*ab3);
+	answer1_z=(af1*ab2)-(af2*ab1);
+//	printf("answer(AFxAB)= %f %f %f\n",answer1_x, answer1_y, answer1_z);
+	//BFxBC
+	answer2_x=(bf2*bc3)-(bf3*bc2);
+	answer2_y=(bf3*bc1)-(bf1*bc3);
+	answer2_z=(bf1*bc2)-(bf2*bc1);
+//	printf("answer(BFxBC)= %f %f %f\n",answer2_x, answer2_y, answer2_z);
+	//CFxCA
+	answer3_x=(cf2*ca3)-(cf3*ca2);
+	answer3_y=(cf3*ca1)-(cf1*ca3);
+	answer3_z=(cf1*ca2)-(cf2*ca1);
+//	printf("answer(CFxCA)= %f %f %f\n",answer3_x, answer3_y, answer3_z);
+	answer=0.0;//initialize value
+	if((int)answer1_x>=0&&(int)answer2_x>=0&&(int)answer3_x>=0){
+		answer+=1.0;
+	} else if((int)answer1_x<=0&&(int)answer2_x<=0&&(int)answer3_x<=0){
+		answer-=1.0;
+	if((int)answer1_y>=0&&(int)answer2_y>=0&&(int)answer3_y>=0){
+		answer+=1.0;
+	} else if((int)answer1_y<=0&&(int)answer2_y<=0&&(int)answer3_y<=0){
+		answer-=1.0;
+	if((int)answer1_z>=0&&(int)answer2_z>=0&&(int)answer3_z>=0){
+		answer+=1.0;
+	} else if((int)answer1_z<=0&&(int)answer2_z<=0&&(int)answer3_z<=0){
+		answer-=1.0;
+	if(answer==3||answer==-3){
+		answer=1;
+	} else {
+		answer=0;
+	return answer;
