[GRASS-SVN] r31497 - in grass/trunk/gui/wxpython: . gui_modules
svn_grass at osgeo.org
Fri May 23 11:28:58 EDT 2008
Author: martinl
Date: 2008-05-23 11:28:58 -0400 (Fri, 23 May 2008)
New Revision: 31497
grass/trunk/gui/wxpython/gis_set.py
grass/trunk/gui/wxpython/gui_modules/dbm.py
grass/trunk/gui/wxpython/wxgui.py
wxGUI: wrong indentation fixed (wxgui)
better mapset checking (gis_set)
default connection settings include 'schema/group' (dbm)
[sync'ed with devbr6, r31496]
Modified: grass/trunk/gui/wxpython/gis_set.py
--- grass/trunk/gui/wxpython/gis_set.py 2008-05-23 15:24:36 UTC (rev 31496)
+++ grass/trunk/gui/wxpython/gis_set.py 2008-05-23 15:28:58 UTC (rev 31497)
@@ -541,7 +541,9 @@
self.listOfMapsetsSelectable = []
for mapset in glob.glob(os.path.join(self.gisdbase, location, "*")):
- if os.path.isdir(mapset) and os.path.basename(mapset) != 'PERMANENT':
+ if os.path.isdir(mapset) and \
+ os.path.isfile(os.path.join(self.gisdbase, location, mapset, "WIND")) and \
+ os.path.basename(mapset) != 'PERMANENT':
self.listOfMapsets.append(os.path.basename(mapset))
utils.ListSortLower(self.listOfMapsets)
Modified: grass/trunk/gui/wxpython/gui_modules/dbm.py
--- grass/trunk/gui/wxpython/gui_modules/dbm.py 2008-05-23 15:24:36 UTC (rev 31496)
+++ grass/trunk/gui/wxpython/gui_modules/dbm.py 2008-05-23 15:28:58 UTC (rev 31497)
@@ -147,6 +147,8 @@
@return -1 if key column is not displayed
+ self.log.write(_("Loading data..."))
# These two should probably be passed to init more cleanly
# setting the numbers of items = number of elements in the dictionary
self.itemDataMap = {}
@@ -2022,26 +2024,24 @@
# get default values
+ self.defaultConnect = {}
cmdConnect = gcmd.Command(['db.connect',
'-p',
'--q'])
for line in cmdConnect.ReadStdOutput():
item, value = line.split(':')
- item = item.strip()
- value = value.strip()
- if item == 'driver':
- self.defaultDriver = value
- elif item == 'database':
- self.defaultDatabase = value
+ self.defaultConnect[item.strip()] = value.strip()
- if len(self.defaultDriver) == 0 or \
- len(self.defaultDatabase) == 0:
+ if len(self.defaultConnect['driver']) == 0 or \
+ len(self.defaultConnect['database']) == 0:
raise gcmd.DBMError(_('Unable to determine default DB connection settings. '
'Please define DB connection using db.connect module.'))
- self.defaultTables = self.__getTables(self.defaultDriver, self.defaultDatabase)
+ self.defaultTables = self.__getTables(self.defaultConnect['driver'],
+ self.defaultConnect['database'])
try:
- self.defaultColumns = self.__getColumns(self.defaultDriver, self.defaultDatabase,
+ self.defaultColumns = self.__getColumns(self.defaultConnect['driver'],
+ self.defaultConnect['database'],
self.defaultTables[0])
except IndexError:
self.defaultColumns = []
@@ -2091,8 +2091,8 @@
choices=self.defaultColumns))}
# set default values for widgets
- self.addLayerWidgets['driver'][1].SetStringSelection(self.defaultDriver)
- self.addLayerWidgets['database'][1].SetValue(self.defaultDatabase)
+ self.addLayerWidgets['driver'][1].SetStringSelection(self.defaultConnect['driver'])
+ self.addLayerWidgets['database'][1].SetValue(self.defaultConnect['database'])
self.addLayerWidgets['table'][1].SetSelection(0)
self.addLayerWidgets['key'][1].SetSelection(0)
# events
@@ -2343,10 +2343,18 @@
driver = self.mapDBInfo.layers[layer]['driver']
database = self.mapDBInfo.layers[layer]['database']
table = self.mapDBInfo.layers[layer]['table']
listOfColumns = self.__getColumns(driver, database, table)
self.modifyLayerWidgets['driver'][1].SetStringSelection(driver)
self.modifyLayerWidgets['database'][1].SetValue(database)
- self.modifyLayerWidgets['table'][1].SetStringSelection(table)
+ if table in self.modifyLayerWidgets['table'][1].GetItems():
+ self.modifyLayerWidgets['table'][1].SetStringSelection(table)
+ else:
+ if self.defaultConnect['schema'] != '':
+ table = self.defaultConnect['schema'] + table # try with default schema
+ else:
+ table = 'public.' + table # try with 'public' schema
self.modifyLayerWidgets['key'][1].SetItems(listOfColumns)
self.modifyLayerWidgets['key'][1].SetSelection(0)
@@ -2461,15 +2469,18 @@
table = self.addLayerWidgets['table'][1]
key = self.addLayerWidgets['key'][1]
- driver.SetStringSelection(self.defaultDriver)
- database.SetValue(self.defaultDatabase)
- tables = self.__getTables(self.defaultDriver, self.defaultDatabase)
+ driver.SetStringSelection(self.defaultConnect['driver'])
+ database.SetValue(self.defaultConnect['database'])
+ tables = self.__getTables(self.defaultConnect['driver'],
table.SetItems(tables)
table.SetSelection(0)
if len(tables) == 0:
key.SetItems([])
else:
- cols = self.__getColumns(self.defaultDriver, self.defaultDatabase, tables[0])
+ cols = self.__getColumns(self.defaultConnect['driver'],
+ tables[0])
key.SetItems(cols)
key.SetSelection(0)
Modified: grass/trunk/gui/wxpython/wxgui.py
--- grass/trunk/gui/wxpython/wxgui.py 2008-05-23 15:24:36 UTC (rev 31496)
+++ grass/trunk/gui/wxpython/wxgui.py 2008-05-23 15:28:58 UTC (rev 31497)
@@ -1162,7 +1162,7 @@
busy = wx.BusyInfo(message=_("Please wait, loading attribute data..."),
parent=self)
wx.Yield()
self.dbmanager = dbm.AttributeManager(parent=self, id=wx.ID_ANY,
title="%s - <%s>" % (_("GRASS GIS Attribute Table Manager"),
mapname),
