[GRASS-SVN] r31506 - in grass/branches/develbranch_6: include
lib/bitmap lib/ogsf
svn_grass at osgeo.org
Sat May 24 04:24:16 EDT 2008
Author: martinl
Date: 2008-05-24 04:24:16 -0400 (Sat, 24 May 2008)
New Revision: 31506
grass/branches/develbranch_6/include/gsurf.h
grass/branches/develbranch_6/lib/bitmap/bitmap.c
grass/branches/develbranch_6/lib/ogsf/GS2.c
grass/branches/develbranch_6/lib/ogsf/Gs3.c
grass/branches/develbranch_6/lib/ogsf/gs.c
grass/branches/develbranch_6/lib/ogsf/gsds.c
ogsflib: doxygen strings/debug messages updated
Modified: grass/branches/develbranch_6/include/gsurf.h
--- grass/branches/develbranch_6/include/gsurf.h 2008-05-24 05:44:09 UTC (rev 31505)
+++ grass/branches/develbranch_6/include/gsurf.h 2008-05-24 08:24:16 UTC (rev 31506)
@@ -1,12 +1,20 @@
-* $Id$
+ \file gsurf.h
+ \brief OGSF library - main header
+ GRASS OpenGL gsurf OGSF Library
+ (C) 1999-2008 by the GRASS Development Team
+ This program is free software under the
+ GNU General Public License (>=v2).
+ Read the file COPYING that comes with GRASS
+ for details.
+ \author Bill Brown USACERL (January 1993)
-/* gsurf.h
- Bill Brown, USACERL
- January 1993
#ifndef _GSURF_H
#define _GSURF_H
@@ -69,17 +77,17 @@
#define LEGAL_SRC(s) (s==NOTSET_ATT||s==MAP_ATT||s==CONST_ATT||s==FUNC_ATT)
/* site markers */
-#define ST_X 1
+#define ST_X 1
#define ST_BOX 2
-#define ST_SPHERE 3
+#define ST_SPHERE 3
#define ST_CUBE 4
-#define ST_DIAMOND 5
-#define ST_DEC_TREE 6
-#define ST_CON_TREE 7
-#define ST_ASTER 8
-#define ST_GYRO 9
+#define ST_DIAMOND 5
+#define ST_DEC_TREE 6
+#define ST_CON_TREE 7
+#define ST_ASTER 8
+#define ST_GYRO 9
/* ACS_MODIFY_One Line site_attr management ***************************************/
-#define ST_HISTOGRAM 10
+#define ST_HISTOGRAM 10
/* site attribute modes (what attribute of marker category is used for) */
/* TODO: may want to make these OR'able */
Modified: grass/branches/develbranch_6/lib/bitmap/bitmap.c
--- grass/branches/develbranch_6/lib/bitmap/bitmap.c 2008-05-24 05:44:09 UTC (rev 31505)
+++ grass/branches/develbranch_6/lib/bitmap/bitmap.c 2008-05-24 08:24:16 UTC (rev 31506)
@@ -47,11 +47,14 @@
* \brief Create bitmap of dimension x/y and return structure token.
* Bitmap is initialized to all zeros
- * \param int x
- * \param int y
- * \return struct BM or NULL on error
+ * \param x x dimension
+ * \param y y dimension
+ * \return pointer to struct BM
+ * \return NULL on error
struct BM *BM_create (int x, int y)
Modified: grass/branches/develbranch_6/lib/ogsf/GS2.c
--- grass/branches/develbranch_6/lib/ogsf/GS2.c 2008-05-24 05:44:09 UTC (rev 31505)
+++ grass/branches/develbranch_6/lib/ogsf/GS2.c 2008-05-24 08:24:16 UTC (rev 31506)
@@ -83,10 +83,11 @@
- \brief Library initialization
+ \brief Initialize OGSF library
- Get region settings - wind, Region (NSWE array)
- Compute scale
+ Get region settings - wind
+ Set Region (NSWE array) and compute scale
void GS_libinit(void)
@@ -213,8 +214,6 @@
geosurf *ns;
- G_debug(3, "GS_new_surface");
if (Next_surf < MAX_SURFS) {
ns = gs_get_new_surface();
gs_init_surf(ns, wind.west + wind.ew_res / 2.,
@@ -228,9 +227,13 @@
Surf_ID[Next_surf] = ns->gsurf_id;
++Next_surf;
+ G_debug(3, "GS_new_surface(): id=%d", ns->gsurf_id);
return (ns->gsurf_id);
return (-1);
@@ -1569,11 +1572,11 @@
- \brief Load attribute map
+ \brief Load raster map as attribute
\param id surface id
\param filename filename
- \param att attribute id
+ \param att attribute descriptor
\return -1 on error (invalid surface id)
\return ?
@@ -1588,7 +1591,7 @@
int reuse = 0, begin, hdata, ret, neg = 0, has_null = 0;
typbuff *tbuff;
- G_debug (3, "GS_load_att_map(): att_map: %s", filename);
+ G_debug (3, "GS_load_att_map(): map=%s", filename);
gs = gs_get_surf(id);
@@ -1747,8 +1750,6 @@
tbuff->nm, &has_null);
filename = G_fully_qualified_name(filename, mapset);
- G_debug(3, "HAS-NULL = %d", has_null);
break;
case ATTY_INT:
default:
@@ -1769,7 +1770,7 @@
return (-1);
+ G_debug(4, " has_null=%d", has_null);
if (!has_null) {
gsds_free_data_buff(gs->att[att].hdata, ATTY_NULL);
@@ -1843,9 +1844,6 @@
G_warning(_("Error finding range"));
- G_debug (3, "Range Updated: %f %f",
- gs->zmin, gs->zmax);
return (ret);
@@ -2068,7 +2066,7 @@
\brief Set draw mode
- \param mode mode id
+ \param mode mode type(s)
\return 0 on success
@@ -2077,7 +2075,8 @@
geosurf *gs;
- G_debug(3, "GS_set_drawmode");
+ G_debug(3, "GS_set_drawmode(): id=%d mode=%d",
+ id, mode);
@@ -2215,7 +2214,8 @@
geosurf *gs;
- G_debug(3, "GS_set_drawres");
+ G_debug(3, "GS_set_drawres() id=%d xyres=%d/%d xywire=%d/%d",
+ id, xres, yres, xwire, ywire);
if (xres < 1 || yres < 1 || xwire < 1 || ywire < 1) {
return (-1);
@@ -2272,8 +2272,6 @@
geosurf *gs;
- G_debug(3, "GS_get_dims");
if (gs) {
Modified: grass/branches/develbranch_6/lib/ogsf/Gs3.c
--- grass/branches/develbranch_6/lib/ogsf/Gs3.c 2008-05-24 05:44:09 UTC (rev 31505)
+++ grass/branches/develbranch_6/lib/ogsf/Gs3.c 2008-05-24 08:24:16 UTC (rev 31506)
@@ -130,7 +130,7 @@
char *map_set, *nullflags;
int offset, row, col;
- G_debug(3, "Gs_loadmap_as_float");
+ G_debug(3, "Gs_loadmap_as_float(): name=%s", map_name);
map_set = G_find_cell2(map_name, "");
if (!map_set) {
@@ -167,7 +167,7 @@
- G_debug(3, "_HAS-NULL_ = %d", *has_null);
+ G_debug(4, " has_null=%d", *has_null);
G_close_cell(cellfile);
@@ -1132,10 +1132,10 @@
- \brief Update no_zero ranges for att (actually no_null now)
+ \brief Update no_zero ranges for attribute (actually no_null now)
\param gs pointer to geosurf struct
- \param desc attribute id
+ \param desc attribute id (descriptor)
\return -1 on error
\return 1 on success
@@ -1246,5 +1246,8 @@
gs->zrange_nz = gs->zmax_nz - gs->zmin_nz;
+ G_debug (3, "Gs_update_attrange(): min=%f max=%f",
+ gs->zmin, gs->zmax);
return (1);
Modified: grass/branches/develbranch_6/lib/ogsf/gs.c
--- grass/branches/develbranch_6/lib/ogsf/gs.c 2008-05-24 05:44:09 UTC (rev 31505)
+++ grass/branches/develbranch_6/lib/ogsf/gs.c 2008-05-24 08:24:16 UTC (rev 31506)
@@ -39,7 +39,7 @@
+ \brief Initialize library
Still need to take care of library initialization,
probably want to define a Surf_top of constant value (i.e., 0)
@@ -63,10 +63,11 @@
geosurf *gs;
- G_debug(3, "gs_get_surf");
+ G_debug(4, "gs_get_surf():");
for (gs = Surf_top; gs; gs = gs->next) {
if (gs->gsurf_id == id) {
+ G_debug(4, " id=%d", id);
return (gs);
@@ -86,7 +87,7 @@
geosurf *ps;
- G_debug(3, "gs_get_prev_surface");
+ G_debug(4, "gs_get_prev_surface");
for (ps = Surf_top; ps; ps = ps->next) {
if (ps->gsurf_id == id - 1) {
@@ -113,7 +114,7 @@
gsurfs[i] = gs;
- G_debug(3, "gs_num_surfaces(): num=%d", i);
+ G_debug(4, "gs_num_surfaces(): num=%d", i);
return (i);
@@ -130,7 +131,7 @@
for (i = 0, gs = Surf_top; gs; gs = gs->next, i++);
return (i);
@@ -164,7 +165,7 @@
- \brief Get last geosurf struct
+ \brief Get last allocated geosurf struct from list
\return pointer to geosurf struct
@@ -172,22 +173,21 @@
geosurf *ls;
- G_debug(3, "gs_get_last_surface():");
if (!Surf_top) {
return (NULL);
for (ls = Surf_top; ls->next; ls = ls->next);
- G_debug(3, " last surface id: %d", ls->gsurf_id);
+ G_debug(4, "gs_get_last_surface(): last surface id=%d",
+ ls->gsurf_id);
return (ls);
- \brief Get new geosurf struct
+ \brief Allocate new geosurf struct
@@ -195,8 +195,6 @@
geosurf *ns, *ls;
- G_debug(3, "gs_get_new_surface");
ns = (geosurf *) G_malloc(sizeof(geosurf)); /* G_fatal_error */
if (!ns) {
return (NULL);
@@ -213,13 +211,15 @@
ns->next = NULL;
+ G_debug(4, "gs_get_new_surface(): id=%d", ns->gsurf_id);
return (ns);
- \brief Init geosurf struct
+ \brief Initialize allocated geosurf struct
- Now xmin & ox are the same, right? - get rid of ox, oy in geosurf struct?
+ \todo Now xmin & ox are the same, right? - get rid of ox, oy in geosurf struct?
\param ox,oy x/y origin coordinates
@@ -236,7 +236,7 @@
geosurf *ps;
int i;
- G_debug(3, "gs_init_surf");
+ G_debug(4, "gs_init_surf() id=%d", gs->gsurf_id);
if (!gs) {
return (-1);
@@ -422,17 +422,17 @@
- \brief Set default attributes
+ \brief Set default attribute values
- \param defs array of default values
- \param null_defs array of null default values
+ \param defs array of default values (dim MAX_ATTRS)
+ \param null_defs array of null default values (dim MAX_ATTRS)
void gs_set_defaults(geosurf * gs, float *defs, float *null_defs)
int i;
- G_debug(3, "gs_set_defaults");
+ G_debug(4, "gs_set_defaults(): id=%d", gs->gsurf_id);
for (i = 0; i < MAX_ATTS; i++) {
gs->att[i].constant = defs[i];
@@ -454,7 +454,7 @@
geosurf *fs;
- G_debug(3, "gs_delete_surf");
+ G_debug(4, "gs_delete_surf");
fs = gs_get_surf(id);
@@ -479,7 +479,7 @@
geosurf *gs;
int found = 0;
- G_debug(3, "gs_free_surf");
+ G_debug(4, "gs_free_surf");
if (Surf_top) {
if (fs == Surf_top) {
@@ -550,7 +550,7 @@
int i, j, same;
int old_datah;
- G_debug(3, "gs_free_unshared_buffs");
+ G_debug(4, "gs_free_unshared_buffs");
/* for each attribute
if !same, free buff
@@ -589,7 +589,7 @@
geosurf *gs;
int ref, j;
- G_debug(3, "gs_num_datah_reused");
+ G_debug(4, "gs_num_datah_reused");
if same, ++reference
@@ -619,7 +619,7 @@
int gs_get_att_type(geosurf * gs, int desc)
- G_debug(3, "gs_get_att_type");
+ G_debug(4, "gs_get_att_type");
if (!LEGAL_ATT(desc)) {
return (-1);
@@ -645,7 +645,7 @@
int gs_get_att_src(geosurf * gs, int desc)
- G_debug(3, "gs_get_att_src");
+ G_debug(4, "gs_get_att_src(): id=%d desc=%d", gs->gsurf_id, desc);
return (-1);
@@ -662,8 +662,8 @@
\brief Get attribute typbuff
- \param to_write
+ \param to_write non-zero value for 'write'
\return pointer to typbuff
@@ -673,6 +673,9 @@
typbuff *tb;
geosurf *gsref;
+ G_debug(4, "gs_get_att_typbuff(): id=%d desc=%d to_write=%d",
+ gs->gsurf_id, desc, to_write);
if (gs) {
if ((tb = gsds_get_typbuff(gs->att[desc].hdata, to_write))) {
tb->tfunc = NULL;
@@ -696,8 +699,8 @@
\brief Allocate attribute buffer
- \param type buffer type
+ \param type buffer type (based on raster map type)
\return -1 on error
\return pointer to typbuff (casted)
@@ -706,7 +709,7 @@
int hdata, dims[2], ndims;
- G_debug(3, "gs_malloc_att_buff");
+ G_debug(4, "gs_malloc_att_buff");
if (gs) {
if (0 < (hdata = gs->att[desc].hdata)) {
@@ -735,7 +738,7 @@
int size;
- G_debug(3, "gs_malloc_lookup");
+ G_debug(4, "gs_malloc_lookup");
if (gs) {
if (gs->att[desc].lookup) {
@@ -791,7 +794,7 @@
int gs_set_att_type(geosurf * gs, int desc, int type)
- G_debug(3, "gs_set_att_type(): desc=%d, type=%d",
+ G_debug(4, "gs_set_att_type(): desc=%d, type=%d",
desc, type);
if (gs && LEGAL_TYPE(type)) {
@@ -807,7 +810,7 @@
\brief Set attribute source
\param src source id
\return -1 on error
@@ -815,7 +818,8 @@
int gs_set_att_src(geosurf * gs, int desc, int src)
- G_debug(3, "gs_set_att_src");
+ G_debug(4, "gs_set_att_src(): id=%d desc=%d src=%d",
+ gs->gsurf_id, desc, src);
/* check if old source was MAP_ATT, free buff */
if (MAP_ATT == gs_get_att_src(gs, desc)) {
@@ -858,7 +862,7 @@
int gs_set_att_const(geosurf * gs, int desc, float constant)
- G_debug(3, "gs_set_att_const");
+ G_debug(4, "gs_set_att_const");
if (gs) {
gs->att[desc].constant = constant;
Modified: grass/branches/develbranch_6/lib/ogsf/gsds.c
--- grass/branches/develbranch_6/lib/ogsf/gsds.c 2008-05-24 05:44:09 UTC (rev 31505)
+++ grass/branches/develbranch_6/lib/ogsf/gsds.c 2008-05-24 08:24:16 UTC (rev 31506)
@@ -1,7 +1,7 @@
\file gsds.c
- \brief OGSF library - ? (lower level functions)
+ \brief OGSF library - dataset loading and management (lower level functions)
@@ -79,7 +79,7 @@
static int Tot_mem = 0;
- \brief Initialize
+ \brief Initialize gsds
static int init_gsds(void)
@@ -211,7 +211,7 @@
\brief Get handle to gsds
- \param name
+ \param name raster map name
\return -1 on failure
\return data id
@@ -266,16 +266,14 @@
- \brief Get typbuff
+ \brief Get data buffer
- change_flag just tells us to set changed flag
+ Doesn't prevent writing a buff thats's been gotten with change_flag
+ == 0 (could return a copy, but willing to trust calling func for
+ now)
- Doesn't prevent
- writing a buff thats's been gotten with change_flag == 0 (could return a
- copy, but willing to trust calling func for now)
- \param id
- \param change_flag
+ \param id dataset id
+ \param change_flag set changed flag
\return pointer to typbuff struct
\return NULL on failure
@@ -359,10 +357,10 @@
- \brief ADD
+ \brief Free allocated buffer
- \param id
- \param typ
+ \param typ data type
\return 0 not found
\return 1 found
@@ -384,12 +382,12 @@
- \brief ADD
+ \brief Free data buffer
- \param ds
- \param typ
+ \param ds pointer to dataset struct
- \return
+ \return freed size
int free_data_buffs(dataset * ds, int typ)
@@ -457,8 +455,8 @@
ds->numbytes -= freed;
if (freed) {
- G_debug (3, "freed data from id no. %d", ds->data_id);
- G_debug (3, "%.3f Kbytes freed, current total = %.3f",
+ G_debug (5, "free_data_buffs(): freed data from id no. %d", ds->data_id);
+ G_debug (5, "free_data_buffs(): %.3f Kbytes freed, current total = %.3f",
freed / 1000., Tot_mem / 1000.);
@@ -470,10 +468,10 @@
\todo add ATTY_CONST
- \param id
- \param dims
- \param ndims
- \param type
+ \param dims array of dimensions
+ \param ndims number of dimensions
+ \param type data type
\return
@@ -590,7 +588,7 @@
ds->ndims = ndims;
Tot_mem += siz;
- G_debug (3, "%f Kbytes allocated, current total = %f",
+ G_debug (5, "gsds_alloc_typbuff(): %f Kbytes allocated, current total = %f",
siz / 1000., Tot_mem / 1000.);
return (siz);
