[GRASS-SVN] r31517 - in grass/trunk/gui/wxpython: . gui_modules
svn_grass at osgeo.org
Sat May 24 17:03:23 EDT 2008
Author: martinl
Date: 2008-05-24 17:03:23 -0400 (Sat, 24 May 2008)
New Revision: 31517
grass/trunk/gui/wxpython/gui_modules/menuform.py
grass/trunk/gui/wxpython/wxgui.py
wxGUI: check for input/map parameter type when calling module for menu, trac #177) [merge devbr r31516]
Modified: grass/trunk/gui/wxpython/gui_modules/menuform.py
--- grass/trunk/gui/wxpython/gui_modules/menuform.py 2008-05-24 21:00:30 UTC (rev 31516)
+++ grass/trunk/gui/wxpython/gui_modules/menuform.py 2008-05-24 21:03:23 UTC (rev 31517)
@@ -1348,6 +1348,7 @@
def __init__(self, parent=-1):
self.parent = parent
+ self.grass_task = None
def ParseCommand(self, cmd, gmpath=None, completed=None, parentframe=-1, show=True, modal=False):
@@ -1435,6 +1436,31 @@
# print >> sys.stderr, time.time() - start
return cmd
+ def GetCommandInputMapParamKey(self, cmd):
+ """Get parameter key for input raster/vector map
+ @param cmd module name
+ @return parameter key
+ @return None on failure
+ # parse the interface decription
+ if not self.grass_task:
+ self.grass_task = grassTask()
+ handler = processTask(self.grass_task)
+ xml.sax.parseString(getInterfaceDescription(cmd), handler)
+ for p in self.grass_task.params:
+ if p.get('name', '') in ('input', 'map'):
+ age = p.get('age', '')
+ prompt = p.get('prompt', '')
+ element = p.get('element', '')
+ if age == 'old' and \
+ element in ('cell', 'grid3', 'vector') and \
+ prompt in ('raster', '3d-raster', 'vector'):
+ return p.get('name', None)
+ return None
class StaticWrapText(wx.StaticText):
A Static Text field that wraps its text to fit its width, enlarging its height if necessary.
Modified: grass/trunk/gui/wxpython/wxgui.py
--- grass/trunk/gui/wxpython/wxgui.py 2008-05-24 21:00:30 UTC (rev 31516)
+++ grass/trunk/gui/wxpython/wxgui.py 2008-05-24 21:03:23 UTC (rev 31517)
@@ -432,10 +432,11 @@
except:
layer = None
if layer and len(cmdlist) == 1: # only if no paramaters given
- if type == 'raster' and cmdlist[0][0] == 'r' and cmdlist[0][1] != '3':
- cmdlist.append(name) # TODO map/input=
- elif type == 'vector' and cmdlist[0][0] == 'v':
+ if (type == 'raster' and cmdlist[0][0] == 'r' and cmdlist[0][1] != '3') or \
+ (type == 'vector' and cmdlist[0][0] == 'v'):
+ input = menuform.GUI().GetCommandInputMapParamKey(cmdlist[0])
+ if input:
+ cmdlist.append("%s=%s" % (input, name))
return cmdlist
