[GRASS-SVN] r31523 - in grass/trunk/raster/r.watershed: ram seg
Mon May 26 02:52:09 EDT 2008
Author: hamish
Date: 2008-05-26 02:52:09 -0400 (Mon, 26 May 2008)
New Revision: 31523
   grass/trunk/raster/r.watershed/ram/close_maps2.c
   grass/trunk/raster/r.watershed/seg/close_maps2.c
tweak comments (merge from dvbr6 with minor clarification)
Modified: grass/trunk/raster/r.watershed/ram/close_maps2.c
--- grass/trunk/raster/r.watershed/ram/close_maps2.c	2008-05-26 06:45:01 UTC (rev 31522)
+++ grass/trunk/raster/r.watershed/ram/close_maps2.c	2008-05-26 06:52:09 UTC (rev 31523)
@@ -46,7 +46,9 @@
 		        flag = 1;
 		        while (flag) {
 			    G_get_color(r,&red,&green,&blue, &colors);
-			    if((blue*.11 + red*.30 + green*.59) < 100) {
+			    /* if existing rule is too dark then append a new
+					rule to override it */
+			    if((blue*.11 + red*.30 + green*.59) < 100) {
 				G_set_color(r, rd, gr, bl, &colors);
 			        flag = 0;
@@ -69,7 +71,8 @@
 	G_percent(r-1,max,3); /* finish it */
-      else G_debug(1, "Too many subbasins to reasonably check neighboring color spread");
+      else G_debug(1, "Too many subbasins to reasonably check for color brightness");
+        /* using the existing stack of while/for/for/for/while loops ... */
     /* stream segments map */
Modified: grass/trunk/raster/r.watershed/seg/close_maps2.c
--- grass/trunk/raster/r.watershed/seg/close_maps2.c	2008-05-26 06:45:01 UTC (rev 31522)
+++ grass/trunk/raster/r.watershed/seg/close_maps2.c	2008-05-26 06:52:09 UTC (rev 31523)
@@ -38,7 +38,9 @@
 		        flag = 1;
 		        while (flag) {
 			        flag = 0;
@@ -59,7 +61,8 @@
