[GRASS-SVN] r31530 - grass/trunk/lib/init
Mon May 26 12:43:24 EDT 2008
Author: neteler
Date: 2008-05-26 12:43:23 -0400 (Mon, 26 May 2008)
New Revision: 31530
Added:
   grass/trunk/lib/init/grass7.html
Removed:
   grass/trunk/lib/init/grass6.html
   grass/trunk/lib/init/Makefile
   grass/trunk/lib/init/README
   grass/trunk/lib/init/grass.bat
   grass/trunk/lib/init/helptext.html
   grass/trunk/lib/init/init.bat
   grass/trunk/lib/init/init.sh
   grass/trunk/lib/init/variables.html
boosted to GRASS 7 for parallel installation
Modified: grass/trunk/lib/init/Makefile
--- grass/trunk/lib/init/Makefile	2008-05-26 14:43:08 UTC (rev 31529)
+++ grass/trunk/lib/init/Makefile	2008-05-26 16:43:23 UTC (rev 31530)
@@ -72,7 +72,7 @@
 default: $(FILES)
 	$(MKDIR) $(GISBASE)/docs/html
 	$(INSTALL_DATA) variables.html $(GISBASE)/docs/html/variables.html
-	$(INSTALL_DATA) grass6.html $(GISBASE)/docs/html/grass6.html
+	$(INSTALL_DATA) grass7.html $(GISBASE)/docs/html/grass7.html
 	$(INSTALL_DATA) helptext.html $(GISBASE)/docs/html/helptext.html
 	$(INSTALL_DATA) help_loc_struct.png $(GISBASE)/docs/html/help_loc_struct.png
Modified: grass/trunk/lib/init/README
--- grass/trunk/lib/init/README	2008-05-26 14:43:08 UTC (rev 31529)
+++ grass/trunk/lib/init/README	2008-05-26 16:43:23 UTC (rev 31530)
@@ -1,10 +1,11 @@
 o GRASS text mode startup
-  "grass63" starts up d.m by default (if not first time user).
-  "grass63 -text" will start up in text mode.
-  "grass63 -tcltk" or "grass63 -gui" will start up in tcltk mode.
+  "grass70" starts up d.m by default (if not first time user).
+  "grass70 -text" will start up in text mode.
+  "grass70 -tcltk" or "grass70 -gui" will start up in tcltk mode.
+  "grass70 -wxpython" will start up in wxpython mode.
-  You can use alias "grass63" to "grass63 -text" to use text mode by default.
+  You can use alias "grass70" to "grass70 -text" to use text mode by default.
   Or set env var GRASS_GUI=text.
@@ -25,18 +26,18 @@
 	export LOCATION_NAME=loc1
 	export MAPSET=map1
-	grass63 -	# non-interactive startup using LOCATION location
+	grass70 -	# non-interactive startup using LOCATION location
   ex2)
 	export GISDBASE=/usr/home/grass/usr/data1
 	export MAPSET=map1
 			# GISDBASE/LOCATION_NAME/MAPSET location
-  Also, the first argument of grass63 can override these env vars.
+  Also, the first argument of grass70 can override these env vars.
   ex3)
   	export LOCATION=/usr/home/grass/usr/data1/loc1/map1
@@ -44,7 +45,7 @@
 	export MAPSET=map1
-	grass63 /usr/home/grass/usr/data2/loc2-1/map1-1
+	grass70 /usr/home/grass/usr/data2/loc2-1/map1-1
 			# /usr/home/grass/usr/data2/loc2-1/map1-1 location
@@ -53,7 +54,7 @@
 	export MAPSET=map1
@@ -63,7 +64,7 @@
 	export MAPSET=map1
-	grass63 map1-1	# non-interactive startup using
+	grass70 map1-1	# non-interactive startup using
 			# GISDBASE/LOCATION_NAME/map1-1 location
   ex6)
@@ -72,7 +73,7 @@
 	export MAPSET=map1
-	grass63 loc2-1/map1-1
+	grass70 loc2-1/map1-1
 			# GISDBASE/loc2-1/map1-1 location
Modified: grass/trunk/lib/init/grass.bat
--- grass/trunk/lib/init/grass.bat	2008-05-26 14:43:08 UTC (rev 31529)
+++ grass/trunk/lib/init/grass.bat	2008-05-26 16:43:23 UTC (rev 31530)
@@ -8,7 +8,7 @@
 rem *******Environment variables***********
 rem Uncomment and set the following values if they differ from the indicated default
-rem Directory where your .grassrc6 file will be stored
+rem Directory where your .grassrc7 file will be stored
 rem set HOME=%USERPROFILE%
 rem Name of the wish (Tk) executable
Deleted: grass/trunk/lib/init/grass6.html
--- grass/trunk/lib/init/grass6.html	2008-05-26 14:43:08 UTC (rev 31529)
+++ grass/trunk/lib/init/grass6.html	2008-05-26 16:43:23 UTC (rev 31530)
@@ -1,373 +0,0 @@
-<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN">
-<html>
-<head>
- <TITLE>GRASS 6</TITLE>
- <meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1">
- <link rel="stylesheet" href="grassdocs.css" type="text/css">
-</head>
-<body bgcolor="white">
-<img src="grass_logo.png" alt="GRASS logo"><hr align=center size=6 noshade>
-<H2>NAME</H2>
-<EM><B>grass63</B></EM>  - The GRASS startup program<BR>
-<H2>SYNOPSIS</H2>
-<B>grass63</B> [<B>-</B>] [<B>-v</B>] [<B>-h | -help | --help</B>]
-    [<B>-text | -gui | -tcltk | -wx]</B>]
-    [[[<B>&lt;GISDBASE&gt;/</B>]<B>&lt;LOCATION_NAME&gt;/</B>]
-    	<B>&lt;MAPSET&gt;</B>]
-<BR>
-<H2>DESCRIPTION</H2>
-<P>
-This program is used to start GRASS. It will parse the command line arguments
-and then initialize GRASS for the user. Since GRASS programs require a
-specific environment, this program must be called before any other GRASS
-program can run. The command line arguments are optional and provide the user
-with a method to indicate the desired user interface, as well as the desired
-mapset to work on.
-<H2>FEATURES</H2>
-<P>
-The GRASS program will save both the desired user interface and mapset.
-Thus, the next time the user runs GRASS, typing <EM>grass63</EM> (without any
-options) will start grass with the previous settings for the user interface
-and mapset.
-<P>
-If you specify a graphical user interface (Tcl/Tk or wxPython), the <EM>grass63</EM>
-program will try to verify that the system you specified exists and that you
-can access it successfully. If any of these checks fail, then <EM>grass63</EM>
-will automatically switch back to the text user interface mode.
-<H2>OPTIONS</H2>
-<P>
-All command line options are optional.
-<H3>Flags:</H3>
-<DL>
-<DT><B>-</B>
-<DD> Tries to start GRASS using location environment variables (see below)
-<DT><B>-h</B> <B>-help</B> <B>--help</B>
-<DD> Prints a brief usage message
-<DT><B>-text</B>
-<DD> Indicates that the text based user interface should be used
-<DT><B>-gui</B> (or <B>-tcltk</B>)
-<DD> Indicates that the Tcl/Tk based graphical user interface should be used
-<DT><B>-wx</B>
-<DD> Indicates that the new Python based graphical user interface should be used (wxgrass)
-<DT><B>-v</B> <B>--version</B>
-<DD> Prints the version for GRASS
-</DL>
-<H3>Parameters:</H3>
-<DL>
-<DT><B>GISDBASE</B>
-<DD> Initial database directory which should be a fully qualified path
-    (e.g., /usr/local/share/grassdata)
-<DT><B>LOCATION_NAME</B>
-<DD> Initial location directory which is a subdirectory of GISDBASE
-<DT><B>MAPSET</B>
-<DD> Initial mapset directory which is a subdirectory of LOCATION_NAME
-<DT><B>Note</B>
-<DD> You must specify one of the following<BR><BR>
-    MAPSET<BR>
-    LOCATION_NAME/MAPSET<BR>
-    GISDBASE/LOCATION_NAME/MAPSET<BR>
-</DL>
-<H2>ENVIRONMENT VARIABLES</H2>
-<H3>User Interface Environment Variable</H3>
-<P>
-The <EM>grass63</EM> program will check for the existence of an environment
-variable called GRASS_GUI which indicates the type of user interface for
-GRASS to use. If this variable is not set when <EM>grass63</EM> is run, then
-it will be created and then saved in the $HOME/.grassrc6 file for the next
-time GRASS is run. In addition to "text", "tcltk" or "wx", the GRASS_GUI variable
-can be set to the name of the GUI to use, for example "gis.m" or "wxgrass".
-<P>
-There is an order of precedence in the way <EM>grass63</EM> determines the user
-interface to use. The following is the hierarchy from highest precedence to
-lowest.
-<P>
-The user may add own environment variable settings to $HOME/.grassrc6 file
-which are used during next startup of GRASS (list of
-<a href=variables.html>implemented environment variables</a>).
-<DL>
-<DT><B>Interface precedence</B>
-<DD>Command line argument<BR>
-    Environment variable GRASS_GUI<BR>
-    Value set in $HOME/.grassrc6<BR>
-    Default value - currently gis.m
-</DL>
-<H3>Tcl/Tk Environment Variables</H3>
-<P>
-If you choose to use the Tcl/Tk graphical user interface, then the following
-environment variables can be used to override your system default tclsh and
-wish commands. See the section immediately following the variable descriptions
-for an example.
-<DL>
-<DT><B>GRASS_TCLSH</B>
-<DD> Command to use to override tclsh
-<DT><B>GRASS_WISH</B>
-<DD> Command to use to override wish
-<DT><B>GRASS_PYTHON</B>
-<DD> Command to use to override python
-</DL>
-<H4>Example Use of GRASS Tcl/Tk Environment Variables</H4>
-<P>
-Suppose your system has Tcl/Tk 8.0 installed and you install your personal
-version of Tcl/Tk 8.3 binaries installed under $HOME/bin. You can use the
-above variables to have GRASS use the Tcl/Tk 8.3 binaries instead.
-<P>
-GRASS_TCLSH = $HOME/bin/tclsh8.3<BR>
-GRASS_WISH  = $HOME/bin/wish8.3
-<H3>Addon path to extra local GRASS modules</H3>
-This environment variables allows to extend the GRASS paths to locally
-developed/installed modules which are not distributes through the standard
-release of GRASS.
-<P>
-GRASS_ADDON_PATH=/usr/mytools<BR>
-GRASS_ADDON_PATH=/usr/mytools:/usr/local/othertools
-<P>
-In this example above path(s) would be added to the standard GRASS path
-environment.
-<H3>Location Environment Variables</H3>
-<P>
-The Synopsis and Options sections above describe options that can be used to
-set the location and mapset that GRASS will use. These values can also be set
-with environment variables. However, specifying the location and mapset
-variables on the command line will override these environment variables. The
-available variables are as follows:
-<DL>
-<DT><B>LOCATION</B>
-<DD> A fully qualified path to a mapset
-    (eg /usr/local/share/grassdata/spearfish60/PERMANENT). This environment variable
-    overrides the GISDBASE, LOCATION_NAME, and MAPSET variables.
-    (eg /usr/local/share/grassdata)
-<DT><B>MAPSET</B>
-</DL>
-<P>
-There are a variety of ways in which these variables can be used to specify
-the mapset to use. The following are some possible examples.
-<DL>
-<DT><B>Example 1</B>
-<DD> The environment variables are defined as follows:<BR><BR>
-    LOCATION = /usr/local/share/grassdata/spearfish60/PERMANENT<BR>
-    GISDBASE = /usr/local/share/grassdata<BR>
-    LOCATION_NAME = spearfish60<BR>
-    MAPSET = PERMANENT<BR><BR>
-    Start GRASS with the following command:<BR><BR>
-    grass63 -<BR><BR>
-    GRASS will start with the mapset defined by LOCATION since the LOCATION
-    variable overrides the other variables.<BR><BR>
-<DT><B>Example 2</B>
-    grass63 -<BR><BR>
-    GISDBASE/LOCATION_NAME/MAPSET.<BR><BR>
-<DT><B>Example 3</B>
-    grass63 /usr/home/grass/data/thailand/forests<BR><BR>
-    GRASS will start with the mapset /home/grass/data/thailand/forests which
-    overrides the environment variables.<BR><BR>
-<DT><B>Example 4</B>
-    grass63 swamps<BR><BR>
-    GRASS will start with the mapset defined by GISDBASE/LOCATION_NAME/swamps
-    since the command line argument for the mapset overrides the environment
-    variable MAPSET.<BR><BR>
-<DT><B>Example 5</B>
-    grass63 thailand/forests<BR><BR>
-    GRASS will start with the mapset defined by GISDBASE/thailand/forests
-    since the command line arguments for the location and mapset overrides
-    the environment variables LOCATION_NAME and MAPSET.<BR><BR>
-</DL>
-<H3>Note</H3>
-<P>
-Note that you will need to set these variables using the appropriate method
-required for the UNIX shell that you use.
-<H2>EXAMPLES</H2>
-<P>
-The following are some examples of how you could start GRASS
-<DL>
-<DT><B>grass63</B>
-<DD> Start GRASS using the default user interface. The user will be prompted
-    to choose the appropriate location and mapset.
-<DT><B>grass63 -gui</B>
-<DD> Start GRASS using the Tcl/Tk based user interface. The user will be
-    prompted to choose the appropriate location and mapset.
-<DT><B>grass63 -text</B>
-<DD> Start GRASS using the text based user interface. The user will be
-<DT><B>grass63 -gui -</B>
-<DD> Start GRASS using the Tcl/Tk based user interface and try to obtain
-    the location and mapset from environment variables.
-<DT><B>Other examples</B>
-<DD> See the <B>Location Environment Variables</B> section for further
-    examples.
-</DL>
-<H2>BUGS AND CAVEAT</H2>
-<P>
-If you start GRASS using the Tcl/Tk interface you must have a <EM>wish</EM>
-command in your $PATH variable. That is, the command must be named
-<EM>wish</EM> and not something like <EM>wish8.3</EM>. By default, a Tcl/Tk
-installation does not create a <EM>wish</EM> command. Thus, the system
-administrator must create an appropriate link to the actual wish program.
-<P>
-For example, suppose Tcl/Tk 8.3 programs are installed in /usr/local/bin. Then
-the system administrator should go to the /usr/local/bin directory and run the
-commands <EM>ln -s wish8.3 wish</EM> and <EM>ln -s tclsh8.3 tclsh</EM> to
-properly install Tcl/Tk for use with GRASS.
-<P>
-Furthermore, if you have more than one version of Tcl/Tk installed, make sure
-that the version you want to use with GRASS is the first version found in
-your $PATH variable. GRASS searches your $PATH variable until it finds the
-first version of <EM>wish</EM>.
-<H2>FILES</H2>
-<EM>$UNIX_BIN/grass63</EM> - GRASS startup program (Linux, MacOSX etc.)<BR><BR>
-<EM>$WINDOWS_BIN/grass63.bat</EM> - GRASS startup program (MS-Windows)<BR><BR>
-<EM>$GISBASE/etc/Init.sh</EM> - GRASS initialization script called by
-    <EM>grass63</EM><BR><BR>
-<EM>$GISBASE/etc/gis_set.tcl</EM> - Tcl/Tk script to set the
-    location and mapset to use. Called by <EM>Init.sh</EM><BR><BR>
-<H2>SEE ALSO</H2>
-List of <a href=variables.html>implemented GRASS environment variables</a>.
-<p>
-<a href="http://grass.osgeo.org">GRASS Web site</a>
-<p>
-<a href="http://download.osgeo.org/grass/grass6_progman/">GRASS 6 Programmer's Manual</a>
-<H2>AUTHORS (of this page)</H2>
-Justin Hickey<br>
-Markus Neteler
-<p><i>Last changed: $Date$</i>
-<HR>
-<P><a href=index.html>Help Index</a>
-</body>
-</html>
Copied: grass/trunk/lib/init/grass7.html (from rev 31487, grass/trunk/lib/init/grass6.html)
--- grass/trunk/lib/init/grass7.html	                        (rev 0)
+++ grass/trunk/lib/init/grass7.html	2008-05-26 16:43:23 UTC (rev 31530)
@@ -0,0 +1,373 @@
+<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN">
+<html>
+<head>
+ <TITLE>GRASS 7</TITLE>
+ <meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1">
+ <link rel="stylesheet" href="grassdocs.css" type="text/css">
+</head>
+<body bgcolor="white">
+<img src="grass_logo.png" alt="GRASS logo"><hr align=center size=6 noshade>
+<H2>NAME</H2>
+<EM><B>grass70</B></EM>  - The GRASS startup program<BR>
+<H2>SYNOPSIS</H2>
+<B>grass70</B> [<B>-</B>] [<B>-v</B>] [<B>-h | -help | --help</B>]
+    [<B>-text | -gui | -tcltk | -wx]</B>]
+    [[[<B>&lt;GISDBASE&gt;/</B>]<B>&lt;LOCATION_NAME&gt;/</B>]
+    	<B>&lt;MAPSET&gt;</B>]
+<BR>
+<H2>DESCRIPTION</H2>
+<P>
+This program is used to start GRASS. It will parse the command line arguments
+and then initialize GRASS for the user. Since GRASS programs require a
+specific environment, this program must be called before any other GRASS
+program can run. The command line arguments are optional and provide the user
+with a method to indicate the desired user interface, as well as the desired
+mapset to work on.
+<H2>FEATURES</H2>
+<P>
+The GRASS program will save both the desired user interface and mapset.
+Thus, the next time the user runs GRASS, typing <EM>grass70</EM> (without any
+options) will start grass with the previous settings for the user interface
+and mapset.
+<P>
+If you specify a graphical user interface (Tcl/Tk or wxPython), the <EM>grass70</EM>
+program will try to verify that the system you specified exists and that you
+can access it successfully. If any of these checks fail, then <EM>grass70</EM>
+will automatically switch back to the text user interface mode.
+<H2>OPTIONS</H2>
+<P>
+All command line options are optional.
+<H3>Flags:</H3>
+<DL>
+<DT><B>-</B>
+<DD> Tries to start GRASS using location environment variables (see below)
+<DT><B>-h</B> <B>-help</B> <B>--help</B>
+<DD> Prints a brief usage message
+<DT><B>-text</B>
+<DD> Indicates that the text based user interface should be used
+<DT><B>-gui</B> (or <B>-tcltk</B>)
+<DD> Indicates that the Tcl/Tk based graphical user interface should be used
+<DT><B>-wx</B>
+<DD> Indicates that the new Python based graphical user interface should be used (wxgrass)
+<DT><B>-v</B> <B>--version</B>
+<DD> Prints the version for GRASS
+</DL>
+<H3>Parameters:</H3>
+<DL>
+<DT><B>GISDBASE</B>
+<DD> Initial database directory which should be a fully qualified path
+    (e.g., /usr/local/share/grassdata)
+<DT><B>LOCATION_NAME</B>
+<DD> Initial location directory which is a subdirectory of GISDBASE
+<DT><B>MAPSET</B>
+<DD> Initial mapset directory which is a subdirectory of LOCATION_NAME
+<DT><B>Note</B>
+<DD> You must specify one of the following<BR><BR>
+    MAPSET<BR>
+    LOCATION_NAME/MAPSET<BR>
+    GISDBASE/LOCATION_NAME/MAPSET<BR>
+</DL>
+<H2>ENVIRONMENT VARIABLES</H2>
+<H3>User Interface Environment Variable</H3>
+<P>
+The <EM>grass70</EM> program will check for the existence of an environment
+variable called GRASS_GUI which indicates the type of user interface for
+GRASS to use. If this variable is not set when <EM>grass70</EM> is run, then
+it will be created and then saved in the $HOME/.grassrc7 file for the next
+time GRASS is run. In addition to "text", "tcltk" or "wx", the GRASS_GUI variable
+can be set to the name of the GUI to use, for example "gis.m" or "wxgrass".
+<P>
+There is an order of precedence in the way <EM>grass70</EM> determines the user
+interface to use. The following is the hierarchy from highest precedence to
+lowest.
+<P>
+The user may add own environment variable settings to $HOME/.grassrc7 file
+which are used during next startup of GRASS (list of
+<a href=variables.html>implemented environment variables</a>).
+<DL>
+<DT><B>Interface precedence</B>
+<DD>Command line argument<BR>
+    Environment variable GRASS_GUI<BR>
+    Value set in $HOME/.grassrc7<BR>
+    Default value - currently gis.m
+</DL>
+<H3>Tcl/Tk Environment Variables</H3>
+<P>
+If you choose to use the Tcl/Tk graphical user interface, then the following
+environment variables can be used to override your system default tclsh and
+wish commands. See the section immediately following the variable descriptions
+for an example.
+<DL>
+<DT><B>GRASS_TCLSH</B>
+<DD> Command to use to override tclsh
+<DT><B>GRASS_WISH</B>
+<DD> Command to use to override wish
+<DT><B>GRASS_PYTHON</B>
+<DD> Command to use to override python
+</DL>
+<H4>Example Use of GRASS Tcl/Tk Environment Variables</H4>
+<P>
+Suppose your system has Tcl/Tk 8.0 installed and you install your personal
+version of Tcl/Tk 8.3 binaries installed under $HOME/bin. You can use the
+above variables to have GRASS use the Tcl/Tk 8.3 binaries instead.
+<P>
+GRASS_TCLSH = $HOME/bin/tclsh8.3<BR>
+GRASS_WISH  = $HOME/bin/wish8.3
+<H3>Addon path to extra local GRASS modules</H3>
+This environment variables allows to extend the GRASS paths to locally
+developed/installed modules which are not distributes through the standard
+release of GRASS.
+<P>
+GRASS_ADDON_PATH=/usr/mytools<BR>
+GRASS_ADDON_PATH=/usr/mytools:/usr/local/othertools
+<P>
+In this example above path(s) would be added to the standard GRASS path
+environment.
+<H3>Location Environment Variables</H3>
+<P>
+The Synopsis and Options sections above describe options that can be used to
+set the location and mapset that GRASS will use. These values can also be set
+with environment variables. However, specifying the location and mapset
+variables on the command line will override these environment variables. The
+available variables are as follows:
+<DL>
+<DT><B>LOCATION</B>
+<DD> A fully qualified path to a mapset
+    (eg /usr/local/share/grassdata/spearfish60/PERMANENT). This environment variable
+    overrides the GISDBASE, LOCATION_NAME, and MAPSET variables.
+    (eg /usr/local/share/grassdata)
+<DT><B>MAPSET</B>
+</DL>
+<P>
+There are a variety of ways in which these variables can be used to specify
+the mapset to use. The following are some possible examples.
+<DL>
+<DT><B>Example 1</B>
+<DD> The environment variables are defined as follows:<BR><BR>
+    LOCATION = /usr/local/share/grassdata/spearfish60/PERMANENT<BR>
+    GISDBASE = /usr/local/share/grassdata<BR>
+    LOCATION_NAME = spearfish60<BR>
+    MAPSET = PERMANENT<BR><BR>
+    Start GRASS with the following command:<BR><BR>
+    grass70 -<BR><BR>
+    GRASS will start with the mapset defined by LOCATION since the LOCATION
+    variable overrides the other variables.<BR><BR>
+<DT><B>Example 2</B>
+    grass70 -<BR><BR>
+    GISDBASE/LOCATION_NAME/MAPSET.<BR><BR>
+<DT><B>Example 3</B>
+    grass70 /usr/home/grass/data/thailand/forests<BR><BR>
+    GRASS will start with the mapset /home/grass/data/thailand/forests which
+    overrides the environment variables.<BR><BR>
+<DT><B>Example 4</B>
+    grass70 swamps<BR><BR>
+    GRASS will start with the mapset defined by GISDBASE/LOCATION_NAME/swamps
+    since the command line argument for the mapset overrides the environment
+    variable MAPSET.<BR><BR>
+<DT><B>Example 5</B>
+    grass70 thailand/forests<BR><BR>
+    GRASS will start with the mapset defined by GISDBASE/thailand/forests
+    since the command line arguments for the location and mapset overrides
+    the environment variables LOCATION_NAME and MAPSET.<BR><BR>
+</DL>
+<H3>Note</H3>
+<P>
+Note that you will need to set these variables using the appropriate method
+required for the UNIX shell that you use.
+<H2>EXAMPLES</H2>
+<P>
+The following are some examples of how you could start GRASS
+<DL>
+<DT><B>grass70</B>
+<DD> Start GRASS using the default user interface. The user will be prompted
+    to choose the appropriate location and mapset.
+<DT><B>grass70 -gui</B>
+<DD> Start GRASS using the Tcl/Tk based user interface. The user will be
+    prompted to choose the appropriate location and mapset.
+<DT><B>grass70 -text</B>
+<DD> Start GRASS using the text based user interface. The user will be
+<DT><B>grass70 -gui -</B>
+<DD> Start GRASS using the Tcl/Tk based user interface and try to obtain
+    the location and mapset from environment variables.
+<DT><B>Other examples</B>
+<DD> See the <B>Location Environment Variables</B> section for further
+    examples.
+</DL>
+<H2>BUGS AND CAVEAT</H2>
+<P>
+If you start GRASS using the Tcl/Tk interface you must have a <EM>wish</EM>
+command in your $PATH variable. That is, the command must be named
+<EM>wish</EM> and not something like <EM>wish8.3</EM>. By default, a Tcl/Tk
+installation does not create a <EM>wish</EM> command. Thus, the system
+administrator must create an appropriate link to the actual wish program.
+<P>
+For example, suppose Tcl/Tk 8.3 programs are installed in /usr/local/bin. Then
+the system administrator should go to the /usr/local/bin directory and run the
+commands <EM>ln -s wish8.3 wish</EM> and <EM>ln -s tclsh8.3 tclsh</EM> to
+properly install Tcl/Tk for use with GRASS.
+<P>
+Furthermore, if you have more than one version of Tcl/Tk installed, make sure
+that the version you want to use with GRASS is the first version found in
+your $PATH variable. GRASS searches your $PATH variable until it finds the
+first version of <EM>wish</EM>.
+<H2>FILES</H2>
+<EM>$UNIX_BIN/grass70</EM> - GRASS startup program (Linux, MacOSX etc.)<BR><BR>
+<EM>$WINDOWS_BIN/grass70.bat</EM> - GRASS startup program (MS-Windows)<BR><BR>
+<EM>$GISBASE/etc/Init.sh</EM> - GRASS initialization script called by
+    <EM>grass70</EM><BR><BR>
+<EM>$GISBASE/etc/gis_set.tcl</EM> - Tcl/Tk script to set the
+    location and mapset to use. Called by <EM>Init.sh</EM><BR><BR>
+<H2>SEE ALSO</H2>
+List of <a href=variables.html>implemented GRASS environment variables</a>.
+<p>
+<a href="http://grass.osgeo.org">GRASS Web site</a>
+<p>
+<a href="http://download.osgeo.org/grass/grass6_progman/">GRASS 6 Programmer's Manual</a>
+<H2>AUTHORS (of this page)</H2>
+Justin Hickey<br>
+Markus Neteler
+<p><i>Last changed: $Date$</i>
+<HR>
+<P><a href=index.html>Help Index</a>
+</body>
+</html>
Modified: grass/trunk/lib/init/helptext.html
--- grass/trunk/lib/init/helptext.html	2008-05-26 14:43:08 UTC (rev 31529)
+++ grass/trunk/lib/init/helptext.html	2008-05-26 16:43:23 UTC (rev 31530)
@@ -174,9 +174,9 @@
 <H2>See also</H2>
-<a href="grass6.html">GRASS 6 launch manual page</a>
+<a href="grass7.html">GRASS 7 launch manual page</a>
 <br>
-<a href="index.html">GRASS 6 Reference Manual</a>
+<a href="index.html">GRASS 7 Reference Manual</a>
 <HR>
Modified: grass/trunk/lib/init/init.bat
--- grass/trunk/lib/init/init.bat	2008-05-26 14:43:08 UTC (rev 31529)
+++ grass/trunk/lib/init/init.bat	2008-05-26 16:43:23 UTC (rev 31530)
@@ -14,7 +14,7 @@
 rem             and does not expect or provide an interactive terminal
 rem             running in addition to the GUI display.
 rem
-rem  COPYRIGHT: (C) 2006 by the GRASS Development Team
+rem  COPYRIGHT: (C) 2006, 2008 by the GRASS Development Team
 rem
 rem             This program is free software under the GNU General Public
 rem   	    	License (>=v2). Read the file COPYING that comes with GRASS
@@ -30,7 +30,7 @@
 set GRASS_VERSION=GRASS_VERSION_NUMBER
 if "%HOME%"=="" set HOME=%USERPROFILE%
-set WINGISRC=%HOME%\.grassrc6
+set WINGISRC=%HOME%\.grassrc7
 rem Make sure %GISRC% is set so g.dirseps will work
 rem (not actually used)
 set GISRC=junk
Modified: grass/trunk/lib/init/init.sh
--- grass/trunk/lib/init/init.sh	2008-05-26 14:43:08 UTC (rev 31529)
+++ grass/trunk/lib/init/init.sh	2008-05-26 16:43:23 UTC (rev 31530)
@@ -159,7 +159,7 @@
 export GIS_LOCK
 # Set the global grassrc file
-GISRCRC="$HOME/.grassrc6"
+GISRCRC="$HOME/.grassrc7"
 # Set the session grassrc file
 if [ "$MINGW" ] ; then
@@ -187,8 +187,8 @@
 ## use TMPDIR if it exists, otherwise /tmp
 #tmp=${TMPDIR-/tmp}
-#tmp="$tmp/grass6-$USER-$GIS_LOCK"
-tmp=/tmp/grass6-$USER-$GIS_LOCK
+#tmp="$tmp/grass7-$USER-$GIS_LOCK"
+tmp=/tmp/grass7-$USER-$GIS_LOCK
 (umask 077 && mkdir "$tmp") || {
     echo "Cannot create temporary directory! Exiting." 1>&2
     exit 1
Modified: grass/trunk/lib/init/variables.html
--- grass/trunk/lib/init/variables.html	2008-05-26 14:43:08 UTC (rev 31529)
+++ grass/trunk/lib/init/variables.html	2008-05-26 16:43:23 UTC (rev 31530)
@@ -75,7 +75,7 @@
 <h2>Setting GRASS variables</h2>
 Use <em><a href="g.gisenv.html">g.gisenv</a></em> within GRASS. This permanently
-predefines GRASS variables in the <tt>.grassrc6</tt> file.
+predefines GRASS variables in the <tt>.grassrc7</tt> file.
 <br><br>
 Usage:
 <div class="code"><pre>
@@ -107,7 +107,7 @@
   <br>
   <dt>GISRC</dt>
-  <dd>name of <tt>.grassrc6</tt> file. Defines the system wide value
+  <dd>name of <tt>.grassrc7</tt> file. Defines the system wide value
     while in a GRASS session.</dd>
   <br>
@@ -559,11 +559,11 @@
 <h2>GRASS-related Files</h2>
 <dl>
-  <dt>$HOME/.grassrc6</dt>
+  <dt>$HOME/.grassrc7</dt>
   <dd>stores the GRASS variables (but not environment variables)</dd>
   <br>
-  <dt>$HOME/.grasslogin6</dt>
+  <dt>$HOME/.grasslogin7</dt>
   <dd>stores the DBMI passwords in this hidden file.
     Only the file owner can access this file.</dd>
