[GRASS-SVN] r31534 - grass/trunk/gem
Mon May 26 13:08:44 EDT 2008
Author: neteler
Date: 2008-05-26 13:08:44 -0400 (Mon, 26 May 2008)
New Revision: 31534
   grass/trunk/gem/README
   grass/trunk/gem/main.c
boosted to GRASS 7 for parallel installation
Modified: grass/trunk/gem/README
--- grass/trunk/gem/README	2008-05-26 17:07:18 UTC (rev 31533)
+++ grass/trunk/gem/README	2008-05-26 17:08:44 UTC (rev 31534)
@@ -45,10 +45,10 @@
 Usage: start 'gem' w/o parameters for information
 	To install a module into your GRASS installation, in this example
-	/usr/local/grass-6.0.0, simply pass the name of the archive containing
+	/usr/local/grass-7.0.0, simply pass the name of the archive containing
 	the extension or the directory with the unpacked files (e.g. 'cva.tgz'):
-	$ gem --grass=/usr/local/grass-6.0.0 -i cva.tgz
+	$ gem --grass=/usr/local/grass-7.0.0 -i cva.tgz
 	You will be asked for the password of the user owning the GRASS
 	binary files, if required.
Modified: grass/trunk/gem/main.c
--- grass/trunk/gem/main.c	2008-05-26 17:07:18 UTC (rev 31533)
+++ grass/trunk/gem/main.c	2008-05-26 17:08:44 UTC (rev 31534)
@@ -130,9 +130,9 @@
   	- remove cva, install again: WARNING: list item 'cva' exists in index.html (?)
 	- superfluous warning upon uninstall of extension w/o "entries-gisman"
 	- due to bad command line parsing, listing installed extensions only works like this:
-		./gem --grass=/usr/local/grass-6.1.cvs -q
+		./gem --grass=/usr/local/grass-7.0.svn -q
 	  NOT like this:
-	  	./gem -q --grass=/usr/local/grass-6.1.cvs
+	  	./gem -q --grass=/usr/local/grass-7.0.svn
@@ -179,8 +179,8 @@
 	fprintf (stdout, "be installed instead using the -b option. ");
 	fprintf (stdout, "For installation from source code, a C compiler and make tools are needed.\n");
 	fprintf (stdout, "\nExample:\n");
-	fprintf (stdout, "\tgem -b macosx --grass=/usr/local/grass-6.0.0 -i myExtension\n");
-	fprintf (stdout, "Installs the MacOS X binaries for 'myExtension' in /usr/local/grass-6.0.0.\n");
+	fprintf (stdout, "\tgem -b macosx --grass=/usr/local/grass-7.0.0 -i myExtension\n");
+	fprintf (stdout, "Installs the MacOS X binaries for 'myExtension' in /usr/local/grass-7.0.0.\n");
 	exit (0);
