[GRASS-SVN] r31571 - grass-addons/gipe/r.soiltex2prop
svn_grass at osgeo.org
Thu May 29 22:18:04 EDT 2008
Author: ychemin
Date: 2008-05-29 22:18:04 -0400 (Thu, 29 May 2008)
New Revision: 31571
grass-addons/gipe/r.soiltex2prop/main.c
grass-addons/gipe/r.soiltex2prop/prct2hf.c
grass-addons/gipe/r.soiltex2prop/prct2ksat.c
grass-addons/gipe/r.soiltex2prop/prct2porosity.c
bug fixing
Modified: grass-addons/gipe/r.soiltex2prop/main.c
--- grass-addons/gipe/r.soiltex2prop/main.c 2008-05-29 20:58:47 UTC (rev 31570)
+++ grass-addons/gipe/r.soiltex2prop/main.c 2008-05-30 02:18:04 UTC (rev 31571)
@@ -22,9 +22,9 @@
#define POLYGON_DIMENSION 50
double point_in_triangle(double point_x, double point_y, double point_z, double t1_x, double t1_y, double t1_z, double t2_x, double t2_y, double t2_z, double t3_x, double t3_y, double t3_z);
-int prct2porosity(double sand_input, double clay_input);
-int prct2ksat(double sand_input, double clay_input);
-int prct2hf(double sand_input, double clay_input);
+double prct2porosity(double sand_input, double clay_input);
+double prct2ksat(double sand_input, double clay_input);
+double prct2hf(double sand_input, double clay_input);
int main(int argc, char *argv[])
Modified: grass-addons/gipe/r.soiltex2prop/prct2hf.c
--- grass-addons/gipe/r.soiltex2prop/prct2hf.c 2008-05-29 20:58:47 UTC (rev 31570)
+++ grass-addons/gipe/r.soiltex2prop/prct2hf.c 2008-05-30 02:18:04 UTC (rev 31571)
@@ -11,7 +11,7 @@
// HF
-int prct2hf(double sand_input, double clay_input){
+double prct2hf(double sand_input, double clay_input){
int i,index;
double temp, hf;
double silt_input=0.0; //Rawls et al (1990)
@@ -23,9 +23,9 @@
struct vector cls[POLYGON_DIMENSION] = {0.0};
//In case silt is not == 0.0, fill up explicitly
for(i=0;i<POLYGON_DIMENSION;i++){
- cls[0].sand=0.0;
- cls[0].clay=0.0;
- cls[0].silt=0.0;
+ cls[i].sand=0.0;
+ cls[i].clay=0.0;
+ cls[i].silt=0.0;
//transform input from [0,1] to [0,100]
sand_input *= 100.0;
Modified: grass-addons/gipe/r.soiltex2prop/prct2ksat.c
--- grass-addons/gipe/r.soiltex2prop/prct2ksat.c 2008-05-29 20:58:47 UTC (rev 31570)
+++ grass-addons/gipe/r.soiltex2prop/prct2ksat.c 2008-05-30 02:18:04 UTC (rev 31571)
@@ -11,7 +11,7 @@
// KSAT
-int prct2ksat(double sand_input, double clay_input){
+double prct2ksat(double sand_input, double clay_input){
int i,index;
double temp,ksat;
@@ -23,9 +23,9 @@
- cls[0].sand=0.0;
- cls[0].clay=0.0;
- cls[0].silt=0.0;
+ cls[i].sand=0.0;
+ cls[i].clay=0.0;
+ cls[i].silt=0.0;
Modified: grass-addons/gipe/r.soiltex2prop/prct2porosity.c
--- grass-addons/gipe/r.soiltex2prop/prct2porosity.c 2008-05-29 20:58:47 UTC (rev 31570)
+++ grass-addons/gipe/r.soiltex2prop/prct2porosity.c 2008-05-30 02:18:04 UTC (rev 31571)
@@ -8,7 +8,7 @@
double silt;
-int prct2porosity(double sand_input, double clay_input){
+double prct2porosity(double sand_input, double clay_input){
int i,index;
double temp,porosity;
@@ -20,9 +20,9 @@
- cls[0].sand=0.0;
- cls[0].clay=0.0;
- cls[0].silt=0.0;
+ cls[i].sand=0.0;
+ cls[i].clay=0.0;
+ cls[i].silt=0.0;
