[GRASS-SVN] r31576 - grass-addons/gipe/r.soiltex2prop
svn_grass at osgeo.org
Fri May 30 04:16:56 EDT 2008
Author: ychemin
Date: 2008-05-30 04:16:56 -0400 (Fri, 30 May 2008)
New Revision: 31576
grass-addons/gipe/r.soiltex2prop/main.c
grass-addons/gipe/r.soiltex2prop/prct2porosity.c
bug fixing
Modified: grass-addons/gipe/r.soiltex2prop/main.c
--- grass-addons/gipe/r.soiltex2prop/main.c 2008-05-30 08:03:20 UTC (rev 31575)
+++ grass-addons/gipe/r.soiltex2prop/main.c 2008-05-30 08:16:56 UTC (rev 31576)
@@ -166,11 +166,11 @@
} else {
/* convert to porosity */
- d = prct2porosity(d_sand, d_clay);
+ d = prct2porosity(d_sand*100.0,d_clay*100.0);
outrast1[col] = d;
- d = prct2ksat(d_sand, d_clay);
+ d = prct2ksat(d_sand*100.0,d_clay*100.0);
outrast2[col] = d;
- d = prct2hf(d_sand, d_clay);
+ d = prct2hf(d_sand*100.0, d_clay*100.0);
outrast3[col] = d;
Modified: grass-addons/gipe/r.soiltex2prop/prct2porosity.c
--- grass-addons/gipe/r.soiltex2prop/prct2porosity.c 2008-05-30 08:03:20 UTC (rev 31575)
+++ grass-addons/gipe/r.soiltex2prop/prct2porosity.c 2008-05-30 08:16:56 UTC (rev 31576)
@@ -13,8 +13,6 @@
double temp,porosity;
double silt_input=0.0; //Rawls et al (1990)
//do not have silt input
- // set up mark index for inside/outside polygon check
- double mark[POLYGON_DIMENSION]={0.0};
//printf("in prct2poros(), Volume Fraction\n");
//setup the 3Dvectors and initialize them
struct vector cls[POLYGON_DIMENSION] = {0.0};
@@ -24,65 +22,73 @@
cls[i].clay=0.0;
cls[i].silt=0.0;
- //transform input from [0,1] to [0,100]
- sand_input *= 100.0;
- clay_input *= 100.0;
- //fill up initial polygon points
+ //printf("0=>sand:%.2f\tclay:%.2f\n", sand_input,clay_input);
cls[0].sand=0.0;
cls[0].clay=100.0;
cls[1].sand=10.0;
cls[1].clay=90.0;
cls[2].sand=25.0;
cls[2].clay=75.0;
+ //printf("sand0:%.2f\tclay0:%.2f\tsilt0:%.2f\n",cls[0].sand,cls[0].clay,cls[0].silt);
+ //printf("sand1:%.2f\tclay1:%.2f\tsilt1:%.2f\n",cls[1].sand,cls[1].clay,cls[1].silt);
+ //printf("sand2:%.2f\tclay2:%.2f\tsilt2:%.2f\n",cls[2].sand,cls[2].clay,cls[2].silt);
//Get started
- mark[0]=point_in_triangle(sand_input,clay_input,silt_input,cls[0].sand,cls[0].clay,cls[0].silt,cls[1].sand,cls[1].clay,cls[1].silt,cls[2].sand,cls[2].clay,cls[2].silt);
- if(mark[0]==1){
+ index = point_in_triangle(sand_input,clay_input,silt_input,cls[0].sand,cls[0].clay,cls[0].silt,cls[1].sand,cls[1].clay,cls[1].silt,cls[2].sand,cls[2].clay,cls[2].silt);
+ if(index==1){
porosity=0.575;
- index=1;
//printf("Poros=0.575\n");
if (index==0){// if index not found then continue
+ //printf("1=>sand:%.2f\tclay:%.2f\n",sand_input,clay_input);
cls[0].sand=10.0;
cls[0].clay=0.0;
cls[1].sand=20.0;
cls[1].clay=20.0;
cls[2].sand=50.0;
cls[2].clay=0.0;
- if(mark[0]==1){
- index=1;
+ if(index==1){
porosity=0.575;
+ //printf("2=>sand:%.2f\tclay:%.2f\n",sand_input,clay_input);
cls[0].sand=100.0;
cls[0].clay=0.0;
cls[1].sand=50.0;
cls[1].clay=50.0;
cls[2].sand=50.0;
cls[2].clay=43.0;
- if(mark[0]==1){
- index=1;
+ if(index==1){
//printf("Poros=0.425\n");
porosity=0.425;
+ //printf("3=>sand:%.2f\tclay:%.2f\n",sand_input,clay_input);
cls[0].sand=100.0;
cls[0].clay=0.0;
cls[1].sand=50.0;
cls[1].clay=43.0;
cls[2].sand=52.0;
cls[2].clay=33.0;
- if(mark[0]==1){
- index=1;
+ ////printf("sand0:%.2f\tclay0:%.2f\tsilt0:%.2f\n",cls[0].sand,cls[0].clay,cls[0].silt);
+ ////printf("sand1:%.2f\tclay1:%.2f\tsilt1:%.2f\n",cls[1].sand,cls[1].clay,cls[1].silt);
+ ////printf("sand2:%.2f\tclay2:%.2f\tsilt2:%.2f\n",cls[2].sand,cls[2].clay,cls[2].silt);
+ if(index==1){
porosity=0.425;
cls[0].sand=100.0;
cls[0].clay=0.0;
@@ -90,9 +96,8 @@
cls[1].clay=33.0;
cls[2].sand=57.0;
cls[2].clay=25.0;
- if(mark[0]==1){
- index=1;
+ if(index==1){
porosity=0.425;
@@ -104,13 +109,12 @@
cls[1].clay=25.0;
cls[2].sand=87.0;
cls[2].clay=0.0;
- if(mark[0]==1){
- index=1;
+ if(index==1){
porosity=0.425;
cls[0].sand=0.0;
cls[0].clay=0.0;
@@ -118,13 +122,12 @@
cls[1].clay=75.0;
cls[2].sand=0.0;
cls[2].clay=90.0;
- if(mark[0]==1){
- index=1;
+ if(index == 1){
//printf("Poros=0.525\n");
porosity=0.525;
cls[0].sand=0.0;
cls[0].clay=0.0;
@@ -132,13 +135,12 @@
cls[1].clay=75.0;
cls[2].sand=10.0;
cls[2].clay=0.0;
- if(mark[0]==1){
- index=1;
+ if(index==1){
porosity=0.525;
cls[0].sand=10.0;
cls[0].clay=0.0;
@@ -146,9 +148,8 @@
cls[1].clay=75.0;
cls[2].sand=20.0;
cls[2].clay=20.0;
- if(mark[0]==1){
- index=1;
+ if(index==1){
porosity=0.525;
@@ -160,9 +161,8 @@
cls[1].clay=75.0;
cls[2].sand=25.0;
cls[2].clay=55.0;
- if(mark[0]==1){
- index=1;
+ if(index==1){
porosity=0.525;
@@ -174,13 +174,12 @@
cls[1].clay=55.0;
cls[2].sand=27.0;
cls[2].clay=45.0;
- if(mark[0]==1){
- index=1;
+ if(index==1){
porosity=0.525;
cls[0].sand=20.0;
cls[0].clay=20.0;
@@ -188,27 +187,25 @@
cls[1].clay=45.0;
cls[2].sand=50.0;
cls[2].clay=0.0;
- if(mark[0]==1){
- index=1;
+ if(index==1){
porosity=0.525;
- if (index==0){// if index not found then continue
+ if (index==0){// if index not found then continue
cls[0].sand=50.0;
cls[0].clay=0.0;
cls[1].sand=70.0;
cls[1].clay=0.0;
cls[2].sand=37.0;
cls[2].clay=25.0;
- if(mark[0]==1){
- index=1;
+ if(index==1){
porosity=0.525;
cls[0].sand=25.0;
cls[0].clay=75.0;
@@ -216,13 +213,12 @@
cls[1].clay=55.0;
cls[2].sand=28.0;
cls[2].clay=61.0;
- if(mark[0]==1){
- index=1;
+ if(index==1){
porosity=0.525;
cls[0].sand=25.0;
cls[0].clay=75.0;
@@ -230,16 +226,14 @@
cls[1].clay=65.0;
cls[2].sand=28.0;
cls[2].clay=61.0;
- if(mark[0]==1){
- index=1;
+ if(index==1){
porosity=0.525;
- index=1;
- //printf("Poros=0.475\n");
+ //printf("Poros=0.475 (final choice...)\n");
porosity=0.475;
return porosity;
