[GRASS-SVN] r31590 - grass/branches/develbranch_6/tools
svn_grass at osgeo.org
Fri May 30 17:25:43 EDT 2008
Author: neteler
Date: 2008-05-30 17:25:43 -0400 (Fri, 30 May 2008)
New Revision: 31590
grass/branches/develbranch_6/tools/build_html_index.sh
use table for more compact help main page (merge from trunk)
Modified: grass/branches/develbranch_6/tools/build_html_index.sh
--- grass/branches/develbranch_6/tools/build_html_index.sh 2008-05-30 21:24:39 UTC (rev 31589)
+++ grass/branches/develbranch_6/tools/build_html_index.sh 2008-05-30 21:25:43 UTC (rev 31590)
@@ -77,6 +77,9 @@
Geographic Resources Analysis Support System (GRASS), an open source (GNU
GPL'ed), image processing and geographic information system (GIS).</p>
+<table>
+<tr>
+<td valign=\"top\">
<h3>Quick Introduction</h3>
<!-- the files grass6.html & helptext.html file live in lib/init/ -->
@@ -267,6 +270,8 @@
write_html_header $FILENAME "GRASS GIS $GRASSVERSION Reference Manual" 1
#modules:
+echo "</td>" >> $FILENAME
+echo "<td valign=\"top\">" >> $FILENAME
echo "<h3>Manual sections:</h3>" >> $FILENAME
echo "<ul>" >> $FILENAME
#for all module groups:
@@ -283,6 +288,8 @@
echo "<li><a href=\"xganim.html\">xganim</a> tool for animating a raster map series</li>" >> $FILENAME
echo "</ul>" >> $FILENAME
+echo "</td></tr>" >> $FILENAME
+echo "</table>" >> $FILENAME
#insert a special comment so that GEM will know where to merge docs of extensions
echo >> "$FILENAME"
