[GRASS-SVN] r34134 - grass/trunk/scripts/v.out.gps
svn_grass at osgeo.org
Sun Nov 2 05:09:36 EST 2008
Author: hamish
Date: 2008-11-02 05:09:36 -0500 (Sun, 02 Nov 2008)
New Revision: 34134
Removed:
grass/trunk/scripts/v.out.gps/v.out.gpsbabel
* verbose messages
* fix attribute passing: GPX_USE_EXTENSIONS is not a layer creation
option, but a dataset one... (dsco=...). see gdal Rev15656
(merge from devbr6)
* rename from v.out.gpsbabel, part III
Modified: grass/trunk/scripts/v.out.gps/v.out.gps
--- grass/trunk/scripts/v.out.gps/v.out.gps 2008-11-02 10:05:55 UTC (rev 34133)
+++ grass/trunk/scripts/v.out.gps/v.out.gps 2008-11-02 10:09:36 UTC (rev 34134)
@@ -159,7 +159,7 @@
cleanup()
- g.message -d "Cleaning up ..."
+ g.message -v "Cleaning up ..."
\rm -f "$TMP" "$TMP.gpx"
# only try to remove map if it exists to avoid ugly warnings
g.findfile element=vector file="tmp_vogb_epsg4326_$$" > /dev/null
@@ -211,6 +211,7 @@
# SQL extract if needed
if [ -n "$GIS_OPT_WHERE" ] ; then
+ g.message -v "Extracting data ..."
v.extract in="$GIS_OPT_INPUT" out="tmp_vogb_extr_$$" \
type="$GIS_OPT_TYPE" layer="$GIS_OPT_LAYER" \
@@ -224,7 +225,7 @@
eval `v.info -t map="tmp_vogb_extr_$$"`
if [ "$primitives" -eq 0 ] ; then
- g.message -e "SQL query returned an empty map"
+ g.message -e "SQL query returned an empty map (no $GIS_OPT_TYPE features?)"
cleanup
exit 1
fi
@@ -241,8 +242,11 @@
# TODO: multi layer will probably fail badly due to sed 's/^ 1 /'
# output as old GRASS 4 vector ascii and fight with dig_ascii/?
+# Change to s/^ \([0-9] .*\) /# \1/' ??? mmph.
# reproject to lat/lon WGS84
+g.message -v "Reprojecting data ..."
v.out.ascii in="$INMAP" format=standard | \
sed -e 's/^\([PLBCFKA]\)/#\1/' -e 's/^ 1 /# 1 /' | \
tail -n +11 | m.proj -od --quiet | \
@@ -260,19 +264,23 @@
# export as GPX using v.out.ogr
if [ $TRK -eq 1 ] ; then
- LINETYPE="FORCE_GPX_TRACK=YES,"
+ LINETYPE="lco=FORCE_GPX_TRACK=YES"
elif [ $RTE -eq 1 ] ; then
- LINETYPE="FORCE_GPX_ROUTE=YES,"
+ LINETYPE="lco=FORCE_GPX_ROUTE=YES"
else
LINETYPE=""
fi
-# TODO: cat is being reported as evelation? or is <ele>=element??
-# TODO: fix attribute output. ogr2ogr -sql to rename columns?
-# see http://www.gdal.org/ogr/drv_gpx.html
+# BUG: cat is being reported as evelation and attribute output is skipped.
+# (v.out.ogr DB reading bug)
+# v.out.ogr -> shapefile -> GPX works, but we try to avoid that as it's
+# lossy. Also that would allow -a_srs $IN_PROJ -t_srs EPSG:4326 so
+# skip m.proj pains..
+g.message -v "Exporting data ..."
v.out.ogr in=tmp_vogb_epsg4326_$$ dsn="$TMP.gpx" type="$GIS_OPT_TYPE" \
- format=GPX lco="${LINETYPE}GPX_USE_EXTENSIONS=YES" --quiet
+ format=GPX ${LINETYPE} dsco="GPX_USE_EXTENSIONS=YES" --quiet
if [ $? -ne 0 ] ; then
g.message -e "Error exporting data"
@@ -284,7 +292,7 @@
# short circuit, we have what we came for.
mv "$TMP.gpx" "$GIS_OPT_OUTPUT"
cleanup
- g.message -d "Fast exit"
+ g.message -v "Fast exit."
exit 0
fi
@@ -299,6 +307,8 @@
GTYPE="-r"
fi
+g.message -v "Running GpsBabel ..."
gpsbabel $GTYPE -i gpx -f "$TMP.gpx" \
-o "$GIS_OPT_FORMAT" -F "$GIS_OPT_OUTPUT"
Deleted: grass/trunk/scripts/v.out.gps/v.out.gpsbabel
--- grass/trunk/scripts/v.out.gps/v.out.gpsbabel 2008-11-02 10:05:55 UTC (rev 34133)
+++ grass/trunk/scripts/v.out.gps/v.out.gpsbabel 2008-11-02 10:09:36 UTC (rev 34134)
@@ -1,314 +0,0 @@
-#!/bin/sh
-# MODULE: v.out.gps
-# PURPOSE: Exports a GRASS vector map to a GPS receiver
-# or data file using GpsBabel
-# COPYRIGHT: (c) 2008 Hamish Bowman, and the GRASS Development Team
-# This program is free software under the GNU General Public
-# License (>=v2). Read the file COPYING that comes with GRASS
-# for details.
-# AUTHOR: Hamish Bowman, Dunedin, New Zealand
-# REQUIREMENTS:
-# - GpsBabel from http://gpsbabel.sourceforge.net
-# - cs2cs from PROJ.4 (for m.proj) http://proj.osgeo.org
-# - report supported GpsBabel formats:
-# gpsbabel -^2 | tr '\t' ';' | sort -t';' -k3
-# How to do it
-# http://www.gdal.org/ogr/drv_gpx.html
-# gpsbabel [options] -i INTYPE -f INFILE -o OUTTYPE -F OUTFILE
-#%Module
-#% description: Exports a vector map to a GPS receiver or file format supported by GpsBabel.
-#% keywords: vector, export, GPS
-#%End
-#%flag
-#% key: w
-#% description: Export as waypoints
-#%end
-#%flag
-#% key: r
-#% description: Export as routes
-#%end
-#%flag
-#% key: t
-#% description: Export as tracks
-#%end
-############ TODO:
-##%flag
-##% key: z
-##% description: Export altitude from 3D vector's z-coordinate
-##%end
-#%option
-#% key: input
-#% type: string
-#% description: Name of input vector map
-#% gisprompt: old,vector,vector
-#% required: yes
-#%end
-#%option
-#% key: type
-#% type: string
-#% description: Feature type(s)
-#% options: point,centroid,line,boundary
-#% multiple: yes
-#%end
-#%option
-#% key: output
-#% type: string
-#% description: Name for output file or GPS device
-#% gisprompt: new_file,file,output
-#% key_desc: name
-#% required: yes
-#%end
-#%option
-#% key: format
-#% type: string
-#% description: GpsBabel supported output format
-#% answer: gpx
-#%end
-#%option
-#% key: layer
-#% type: integer
-#% label: Layer number
-#% description: A single vector map can be connected to multiple database tables. This number determines which table to use.
-#% answer: 1
-#% required : no
-#% guisection: Subset
-#%end
-#%option
-#% key: where
-#% type: string
-#% label: WHERE conditions of SQL statement without 'where' keyword
-#% description: Example: income < 1000 and inhab >= 10000
-#% required : no
-#%end
-if [ -z "$GISBASE" ] ; then
- echo "You must be in GRASS GIS to run this program." 1>&2
- exit 1
-fi
-if [ "$1" != "@ARGS_PARSED@" ] ; then
- # save command line
- CMDLINE="`basename $0`"
- for arg in "$@" ; do
- CMDLINE="$CMDLINE \"$arg\""
- done
- export CMDLINE
- exec g.parser "$0" "$@"
-fi
-# set environment so that awk works properly in all languages
-unset LC_ALL
-LC_NUMERIC=C
-export LC_NUMERIC
-eval `g.gisenv`
-: ${GISBASE?} ${GISDBASE?} ${LOCATION_NAME?} ${MAPSET?}
-LOCATION="$GISDBASE"/"$LOCATION_NAME"/"$MAPSET"
-PROG=`basename $0`
-#### check for gpsbabel
-if [ ! -x "`which gpsbabel`" ] ; then
- g.message -e "The gpsbabel program was not found, please install it first.
- http://gpsbabel.sourceforge.net"
- exit 1
-fi
-#### check for cs2cs
-if [ ! -x "`which cs2cs`" ] ; then
- g.message -e "The cs2cs program was not found, please install it first.
- http://proj.osgeo.org"
- exit 1
-fi
-# check if we will overwrite data
-if [ -e "$GIS_OPT_OUTPUT" ] ; then
- if [ -z "$GRASS_OVERWRITE" ] || [ "$GRASS_OVERWRITE" -ne 1 ] ; then
- g.message -e "Output file already exists."
- exit 1
- fi
-fi
-#### set temporary files
-TMP="`g.tempfile pid=$$`"
-if [ $? -ne 0 ] || [ -z "$TMP" ] ; then
- g.message -e "Unable to create temporary files"
- exit 1
-fi
-cleanup()
- \rm -f "$TMP" "$TMP.gpx"
- # only try to remove map if it exists to avoid ugly warnings
- g.findfile element=vector file="tmp_vogb_epsg4326_$$" > /dev/null
- if [ $? -eq 0 ] ; then
- g.remove vect="tmp_vogb_epsg4326_$$" --quiet
- fi
- g.findfile element=vector file="tmp_vogb_extr_$$" > /dev/null
- g.remove vect="tmp_vogb_extr_$$" --quiet
- fi
-#### trap ctrl-c so that we can clean up tmp
-trap 'cleanup' 2 3 15
-#### process command line arguments
-WPT=$GIS_FLAG_W ; RTE=$GIS_FLAG_R ; TRK=$GIS_FLAG_T
-if [ $WPT -eq 1 ] && ([ $RTE -eq 1 ] || [ $TRK -eq 1 ]) ; then
- g.message -e "One feature at a time please."
- rm -f "${TMP}"
- exit 1
-fi
-# logic eludes me at pressent.. [combine with above]
-if [ $RTE -eq 1 ] && [ $TRK -eq 1 ] ; then
- rm -f "${TMP}"
- exit 1
-fi
-if [ $WPT -eq 0 ] && [ $RTE -eq 0 ] && [ $TRK -eq 0 ] ; then
- g.message -e "No features requested for export."
- cleanup
- exit 1
-fi
-# set some reasonable defaults
-if [ $WPT -eq 1 ] ; then
- if [ -z "$GIS_OPT_TYPE" ] ; then
- GIS_OPT_TYPE="point"
- fi
-else
- GIS_OPT_TYPE="line"
- fi
-fi
-# SQL extract if needed
-if [ -n "$GIS_OPT_WHERE" ] ; then
- v.extract in="$GIS_OPT_INPUT" out="tmp_vogb_extr_$$" \
- type="$GIS_OPT_TYPE" layer="$GIS_OPT_LAYER" \
- where="$GIS_OPT_WHERE" --quiet
- if [ $? -ne 0 ] ; then
- g.message -e "Error executing SQL query"
- cleanup
- exit 1
- fi
- eval `v.info -t map="tmp_vogb_extr_$$"`
- if [ "$primitives" -eq 0 ] ; then
- cleanup
- exit 1
- fi
- INMAP="tmp_vogb_extr_$$"
-else
- INMAP="$GIS_OPT_INPUT"
-fi
-#### set up projection info
-# TODO: check if we are already in ll/WGS84. If so skip m.proj step.
-# TODO: multi layer will probably fail badly due to sed 's/^ 1 /'
-# output as old GRASS 4 vector ascii and fight with dig_ascii/?
-# reproject to lat/lon WGS84
-v.out.ascii in="$INMAP" format=standard | \
- sed -e 's/^\([PLBCFKA]\)/#\1/' -e 's/^ 1 /# 1 /' | \
- tail -n +11 | m.proj -od --quiet | \
- sed -e 's/\t\([-\.0-9]*\) .*/ \1/' \
- -e 's/^\([-\.0-9]\)/ \1/' \
- -e 's/^#//' | \
- v.in.ascii out=tmp_vogb_epsg4326_$$ -n format=standard --quiet
-if [ $? -ne 0 ] ; then
- g.message -e "Error reprojecting data"
- cleanup
- exit 1
-fi
-# export as GPX using v.out.ogr
-if [ $TRK -eq 1 ] ; then
-elif [ $RTE -eq 1 ] ; then
-else
- LINETYPE=""
-fi
-v.out.ogr in=tmp_vogb_epsg4326_$$ dsn="$TMP.gpx" type="$GIS_OPT_TYPE" \
- g.message -e "Error exporting data"
- cleanup
- exit 1
-fi
-if [ "$GIS_OPT_FORMAT" = gpx ] ; then
- # short circuit, we have what we came for.
- mv "$TMP.gpx" "$GIS_OPT_OUTPUT"
- cleanup
- exit 0
-fi
-# run gpsbabel
-GTYPE=""
- GTYPE="-w"
-elif [ $TRK -eq 1 ] ; then
- GTYPE="-t"
- GTYPE="-r"
-fi
-gpsbabel $GTYPE -i gpx -f "$TMP.gpx" \
- -o "$GIS_OPT_FORMAT" -F "$GIS_OPT_OUTPUT"
- g.message -e "Error running GpsBabel"
- cleanup
- exit 1
-fi
-cleanup
-g.message -v "Done."
-exit
