[GRASS-SVN] r34136 - grass/trunk/scripts/v.out.gps
svn_grass at osgeo.org
Sun Nov 2 05:12:05 EST 2008
Author: hamish
Date: 2008-11-02 05:12:05 -0500 (Sun, 02 Nov 2008)
New Revision: 34136
Removed:
grass/trunk/scripts/v.out.gps/v.out.gpsbabel.html
rename from v.out.gpsbabel, part V
Deleted: grass/trunk/scripts/v.out.gps/v.out.gpsbabel.html
--- grass/trunk/scripts/v.out.gps/v.out.gpsbabel.html 2008-11-02 10:10:50 UTC (rev 34135)
+++ grass/trunk/scripts/v.out.gps/v.out.gpsbabel.html 2008-11-02 10:12:05 UTC (rev 34136)
@@ -1,63 +0,0 @@
-<H2>DESCRIPTION</H2>
-<EM>v.out.gps</EM> allows the user to export waypoint, route, and track
-data from a vector map into a locally connected GPS receiver or as a file in
-many common GPS data formats. Translation is done via the
-<EM><A HREF="http://www.gpsbabel.org">GpsBabel</a></EM> program.
-<P>
-Do not use as a primary means of navigation.
-<H2>NOTES</H2>
-<em>v.out.gps</em> automatically reprojects data from the
-projection settings of the current location to Lat/Lon WGS84.
-<p>
-GPX format is used for data interchange between GRASS and GpsBabel.
-If the requested output is GPX, then <tt>gpsbabel</tt> is never run.
-<P>
-The <b>layer</b> option is only used in conjunction with the
-<b>where</b> SQL query option.
-<H2>EXAMPLES</H2>
-<h3>GPX Export</h3>
-Export a vector lines map to a GPX track file:
-<div class="code"><pre>
-v.out.gps -t input=trail output=trail.gpx
-</pre></div>
-<h3>GPS device connected via USB adapter</h3>
-Export vector maps named <i>waypoints, tracks, routes</i> to a Garmin GPS
-connected to /dev/ttyUSB0:
-v.out.gps -w input=waypoints format=garmin output=/dev/ttyUSB0
-v.out.gps -t input=tracks format=garmin output=/dev/ttyUSB0
-v.out.gps -r input=routes format=garmin output=/dev/ttyUSB0
-</pre></div>
-<H2>SEE ALSO</H2>
-<EM><A HREF="m.proj.html">m.proj</A></EM><BR>
-<EM><A HREF="v.in.ascii.html">v.in.ascii</A></EM><BR>
-<EM><A HREF="v.out.ascii.html">v.out.ascii</A></EM><BR>
-<EM><A HREF="v.in.garmin.html">v.in.garmin</A></EM><BR>
-<EM><A HREF="v.in.gpsbabel.html">v.in.gpsbabel</A></EM><BR>
-<EM><A HREF="v.extract.html">v.extract</A></EM><BR>
-<BR>
-<A HREF="http://www.gpsbabel.org">GpsBabel.org</a><BR>
-The <A HREF="http://www.gdal.org/ogr/drv_gpx.html">GDAL/OGR GPX format page</a><BR>
-cs2cs from <A HREF="http://proj.osgeo.org">PROJ.4</a><BR>
-<H2>AUTHOR</H2>
-Hamish Bowman, Dunedin New Zealand
-<p>
-<i>Last changed: $Date$</i>
