[GRASS-SVN] r34182 - grass/branches/develbranch_6/scripts/v.db.join
svn_grass at osgeo.org
Fri Nov 7 12:44:12 EST 2008
Author: martinl
Date: 2008-11-07 12:44:12 -0500 (Fri, 07 Nov 2008)
New Revision: 34182
grass/branches/develbranch_6/scripts/v.db.join/v.db.join
v.db.join: remove extra space
add gisprompts
undefined cleanup() commented
Modified: grass/branches/develbranch_6/scripts/v.db.join/v.db.join
--- grass/branches/develbranch_6/scripts/v.db.join/v.db.join 2008-11-07 13:57:53 UTC (rev 34181)
+++ grass/branches/develbranch_6/scripts/v.db.join/v.db.join 2008-11-07 17:44:12 UTC (rev 34182)
@@ -5,7 +5,7 @@
# MODULE: v.db.join
# AUTHOR(S): Markus Neteler
# PURPOSE: Join a table to a map table
-# COPYRIGHT: (C) 2007 by Markus Neteler and the GRASS Development Team
+# COPYRIGHT: (C) 2007-2008 by Markus Neteler and the GRASS Development Team
# This program is free software under the GNU General Public
# License (>=v2). Read the file COPYING that comes with GRASS
@@ -33,6 +33,7 @@
#% description: Layer where to join
#% answer: 1
#% required : no
+#% gisprompt: old_layer,layer,layer
#%end
#%option
@@ -40,6 +41,7 @@
#% type: string
#% description: Join column in map table
#% required : yes
+#% gisprompt: old_dbcolumn,dbcolumn,dbcolumn
#%end
#%option
@@ -47,6 +49,7 @@
#% type: string
#% description: Other table name
#% required : yes
+#% gisprompt: old_dbtable,dbtable,dbtable
#%end
#%option
@@ -54,6 +57,7 @@
#% type: string
#% description: Join column in other table
#% required : yes
#%end
if [ -z "$GISBASE" ] ; then
@@ -73,23 +77,24 @@
PROG=`basename $0`
-driver=`v.db.connect -g map="$GIS_OPT_MAP" fs=";" | grep "^$GIS_OPT_LAYER " | cut -d';' -f5`
-database=`v.db.connect -g map="$GIS_OPT_MAP" fs=";" | grep "^$GIS_OPT_LAYER " | cut -d';' -f4`
+driver=`v.db.connect -g map="$GIS_OPT_MAP" fs=";" | grep "^$GIS_OPT_LAYER" | cut -d';' -f5`
+database=`v.db.connect -g map="$GIS_OPT_MAP" fs=";" | grep "^$GIS_OPT_LAYER" | cut -d';' -f4`
if [ "$driver" = "dbf" ] ; then
g.message -e "JOIN is not supported for tables stored in DBF format."
exit 1
fi
-maptable=`v.db.connect -g map="$GIS_OPT_MAP" fs=";" | grep "^$GIS_OPT_LAYER " | cut -d';' -f2`
+maptable=`v.db.connect -g map="$GIS_OPT_MAP" fs=";" | grep "^$GIS_OPT_LAYER" | cut -d';' -f2`
if [ -z "$maptable" ] ; then
g.message 'There is no table connected to this map! Cannot join any column.'
- cleanup
+ ### cleanup
exit 1
fi
v.info --quiet -c "$GIS_OPT_MAP" layer="$GIS_OPT_LAYER" | \
- cut -d'|' -f1,2 | grep "|${GIS_OPT_COLUMN}$" 2>&1 >/dev/null
+ cut -d'|' -f1,2 | grep "|${GIS_OPT_COLUMN}$" 2>&1 >/dev/null
if [ $? -ne 0 ] ; then
g.message -e "Column <$GIS_OPT_COLUMN> not found in table <$GIS_OPT_MAP> at layer $GIS_OPT_LAYER"
