[GRASS-SVN] r34191 - grass/branches/develbranch_6/vector/v.in.ascii
svn_grass at osgeo.org
Sat Nov 8 03:53:50 EST 2008
Author: neteler
Date: 2008-11-08 03:53:50 -0500 (Sat, 08 Nov 2008)
New Revision: 34191
grass/branches/develbranch_6/vector/v.in.ascii/description.html
standard mode -> standard format mode
Modified: grass/branches/develbranch_6/vector/v.in.ascii/description.html
--- grass/branches/develbranch_6/vector/v.in.ascii/description.html 2008-11-08 08:53:06 UTC (rev 34190)
+++ grass/branches/develbranch_6/vector/v.in.ascii/description.html 2008-11-08 08:53:50 UTC (rev 34191)
@@ -69,7 +69,7 @@
disabling of topology.
<p>
-A GRASS ASCII vector map (in <B>standard</B> mode) may contain a mix
+A GRASS ASCII vector map (in <B>standard format</B> mode) may contain a mix
of primitives including points, lines, boundaries, centroids, areas,
faces, and kernels.
<!--This format is described in the
@@ -191,8 +191,8 @@
<h2>EXAMPLES</h2>
-<h3>Example 1a) - standard mode</h3>
-Sample ASCII polygon vector map for 'standard' mode.
+<h3>Example 1a) - standard format mode</h3>
+Sample ASCII polygon vector map for 'standard' format mode.
The two areas will be assigned categories 20 and 21.
The example can be tested in the Spearfish sample dataset:
<p>
@@ -227,8 +227,8 @@
1 21
</pre></div>
-<h3>Example 1b) - standard mode</h3>
-Sample ASCII 3D line vector map for 'standard' mode with simplified input
+<h3>Example 1b) - standard format mode</h3>
+Sample ASCII 3D line vector map for 'standard' format mode with simplified input
(no header). The example can be tested in the Spearfish sample dataset:
<div class="code"><pre>
