[GRASS-SVN] r34201 - in grass-addons/vector: . v.profile
Sun Nov 9 06:26:58 EST 2008
Author: marisn
Date: 2008-11-09 06:26:58 -0500 (Sun, 09 Nov 2008)
New Revision: 34201
Added:
   grass-addons/vector/v.profile/
   grass-addons/vector/v.profile/Makefile
   grass-addons/vector/v.profile/main.c
   grass-addons/vector/v.profile/v.profile.html
Initial import of vector point/line profiling tool
Added: grass-addons/vector/v.profile/Makefile
--- grass-addons/vector/v.profile/Makefile	                        (rev 0)
+++ grass-addons/vector/v.profile/Makefile	2008-11-09 11:26:58 UTC (rev 34201)
@@ -0,0 +1,14 @@
+# fix this relative to include/
+# or use absolute path to the GRASS source code
+MODULE_TOPDIR = ../../..
+PGM = v.profile
+LIBES = $(VECTLIB) $(GISLIB)
+DEPENDENCIES= $(VECTDEP) $(GISDEP)
+EXTRA_INC = $(VECT_INC)
+EXTRA_CFLAGS = $(VECT_CFLAGS)
+include $(MODULE_TOPDIR)/include/Make/Module.make
+default: cmd
Added: grass-addons/vector/v.profile/main.c
--- grass-addons/vector/v.profile/main.c	                        (rev 0)
+++ grass-addons/vector/v.profile/main.c	2008-11-09 11:26:58 UTC (rev 34201)
@@ -0,0 +1,706 @@
+ * MODULE:     v.profile
+ * AUTHOR(S):  Maris Nartiss <maris.gis at gmail.com>
+ *             with hints from v.out.ascii, v.buffer, v.what
+ *             and other GRASS modules
+ * PURPOSE:    Output vector point/line values along sampling line
+ * COPYRIGHT:  (C) 2008 by the GRASS Development Team
+ *             This program is free software under the
+ *             GNU General Public License (>=v2).
+ *             Read the file COPYING that comes with GRASS
+ *             for details.
+ * TODO:       Attach a centroid to buffer with tolerance value;
+ *             Ability to have "interrupted" profiling line - with holes,
+ *                 that are not counted into whole profile length;
+ *             Implement area sampling by printing out boundary crossing place?
+ *             There is no way how to get CAT values;
+ *             String quoting is unoptimal:
+ *                 * What if delimiter equals string quote character?
+ *                 * Quotes within strings are not escaped
+ *                 * What if user wants to have different quote symbol or no quotes at all?
+#include <stdio.h>
+#include <stdlib.h>
+#include <grass/config.h>
+#include <grass/gis.h>
+#include <grass/Vect.h>
+#include <grass/dbmi.h>
+#include <grass/glocale.h>
+typedef struct
+    double distance;
+    int cat;
+    double z;
+} Result;
+/* Here are stored all profile line matching points */
+static Result *resultset;
+/* Qsort distance comparison function */
+static int compdist(const void *, const void *);
+/* Add point to result data set */
+void add_point(struct line_cats *, const double,
+	       const double, size_t *, const int);
+/* Check if point is on profile line (inside buffer) and calculate distance to it */
+void proc_point(struct line_pnts *, struct line_pnts *,
+		struct line_pnts *, struct line_cats *, size_t *, const int);
+/* Process all two line intersection points */
+void proc_line(struct line_pnts *, struct line_pnts *,
+	       struct line_cats *, size_t *, const int);
+int main(int argc, char *argv[])
+    struct Map_info In, Out, Pro;
+    struct line_pnts *Points, *Profil, *Buffer, *Ipoints;
+    struct line_cats *Cats;
+    struct ilist *Catlist;
+    FILE *ascii;
+    int i, dp, type, otype, id, ncols, nrows, ncats, col, more, open3d,
+	layer, pro_layer, *cats, c, field_index;
+    size_t rescount;
+    double xval, yval, bufsize;
+    char *mapset, *pro_mapset, sql[200], *fs;
+    struct GModule *module;
+    struct Option *old_map, *new_map, *coords_opt, *buffer_opt, *delim_opt,
+	*dp_opt, *layer_opt, *where_opt, *inline_map, *inline_where,
+	*inline_layer, *type_opt, *file_opt;
+    struct Flag *no_column_flag, *no_z_flag;
+    struct field_info *Fi, *Fpro;
+    dbDriver *driver;
+    dbHandle handle;
+    dbCursor cursor;
+    dbTable *table;
+    dbColumn *column;
+    dbString table_name, dbsql, valstr;
+    /* initialize GIS environment */
+    G_gisinit(argv[0]);
+    /* initialize module */
+    module = G_define_module();
+    module->keywords = _("vector, profile, transect");
+    module->description = _("Vector map profiling tool");
+    old_map = G_define_standard_option(G_OPT_V_INPUT);
+    old_map->guisection = _("Required");
+    type_opt = G_define_standard_option(G_OPT_V_TYPE);
+    type_opt->options = "point,line";
+    type_opt->answer = "point,line";
+    type_opt->guisection = _("Input filter");
+    coords_opt = G_define_option();
+    coords_opt->key = "east_north";
+    coords_opt->type = TYPE_DOUBLE;
+    coords_opt->key_desc = "east,north";
+    coords_opt->required = NO;
+    coords_opt->multiple = YES;
+    coords_opt->label = _("Coordinates for profiling line nodes");
+    coords_opt->description = _("Specify profiling line vertexes and nodes");
+    coords_opt->guisection = _("Profiling line");
+    buffer_opt = G_define_option();
+    buffer_opt->key = "buffer";
+    buffer_opt->type = TYPE_DOUBLE;
+    buffer_opt->required = YES;
+    buffer_opt->answer = "10";
+    buffer_opt->label = _("Buffer (tolerance) for points in map units");
+    buffer_opt->description = _("How far points can be from sampling line");
+    buffer_opt->guisection = _("Required");
+    file_opt = G_define_option();
+    file_opt->key = "out_file";
+    file_opt->type = TYPE_STRING;
+    file_opt->required = NO;
+    file_opt->multiple = NO;
+    file_opt->gisprompt = "new_file,file,output";
+    file_opt->answer = "-";
+    file_opt->description = _("Path to output text file or - for stdout");
+    file_opt->guisection = _("Output formating");
+    delim_opt = G_define_option();
+    delim_opt->key = "fs";
+    delim_opt->type = TYPE_STRING;
+    delim_opt->required = NO;
+    delim_opt->answer = "|";
+    delim_opt->description = _("Field separator");
+    delim_opt->guisection = _("Output formating");
+    dp_opt = G_define_option();
+    dp_opt->key = "dp";
+    dp_opt->type = TYPE_INTEGER;
+    dp_opt->required = NO;
+    dp_opt->options = "0-32";
+    dp_opt->answer = "2";
+    dp_opt->description = _("Number of significant digits");
+    dp_opt->guisection = _("Output formating");
+    where_opt = G_define_standard_option(G_OPT_WHERE);
+    where_opt->guisection = _("Input filter");
+    layer_opt = G_define_standard_option(G_OPT_V_FIELD);
+    layer_opt->answer = "1";
+    layer_opt->description = _("Use features only from specified layer");
+    layer_opt->guisection = _("Input filter");
+    new_map = G_define_option();
+    new_map->key = "map_output";
+    new_map->type = TYPE_STRING;
+    new_map->key_desc = "name";
+    new_map->required = NO;
+    new_map->multiple = NO;
+    new_map->gisprompt = "new,vector,vector";
+    new_map->label = _("Name for profile line and buffer output map");
+    new_map->description =
+	_("Profile line and buffer around it will be written");
+    new_map->guisection = _("Output formating");
+    no_column_flag = G_define_flag();
+    no_column_flag->key = 'c';
+    no_column_flag->description = _("Do not print column names");
+    no_column_flag->guisection = _("Output formating");
+    no_z_flag = G_define_flag();
+    no_z_flag->key = 'z';
+    no_z_flag->label = _("Do not print 3D vector data (z values)");
+    no_z_flag->description = _("Only affects 3D vectors");
+    no_z_flag->guisection = _("Output formating");
+    /* Options that allow to input profiling line from vector map */
+    inline_map = G_define_option();
+    inline_map->key = "profile_map";
+    inline_map->type = TYPE_STRING;
+    inline_map->key_desc = "name";
+    inline_map->required = NO;
+    inline_map->multiple = NO;
+    inline_map->gisprompt = "old,vector,vector";
+    inline_map->label = _("Profiling line map");
+    inline_map->description = _("Vector map containing profiling line");
+    inline_map->guisection = _("Profiling line");
+    inline_where = G_define_option();
+    inline_where->key = "profile_where";
+    inline_where->type = TYPE_STRING;
+    inline_where->key_desc = "sql_query";
+    inline_where->required = NO;
+    inline_where->multiple = NO;
+    inline_where->label = _("WHERE conditions for input profile line map");
+    inline_where->description =
+	_("Use to select only one line from profiling line map");
+    inline_where->guisection = _("Profiling line");
+    inline_layer = G_define_option();
+    inline_layer->key = "profile_layer";
+    inline_layer->type = TYPE_INTEGER;
+    inline_layer->required = NO;
+    inline_layer->answer = "1";
+    inline_layer->description = _("Profiling line map layer");
+    inline_layer->guisection = _("Profiling line");
+    if (G_parser(argc, argv))
+	exit(EXIT_FAILURE);
+    /* Start with simple input validation and then move to more complex ones */
+    otype = Vect_option_to_types(type_opt);
+    layer = atoi(layer_opt->answer);
+    pro_layer = atoi(inline_layer->answer);
+    if (layer < 1 || pro_layer < 1)
+	G_fatal_error(_("Layer 0 not supported"));
+    /* The precision of the output */
+    if (dp_opt->answer) {
+	if (sscanf(dp_opt->answer, "%d", &dp) != 1)
+	    G_fatal_error(_("Failed to interpreter 'dp' parameter as an integer"));
+    /* Get buffer size */
+    bufsize = fabs(atof(buffer_opt->answer));
+    if (bufsize < 0)
+	G_fatal_error(_("Tolerance value can not be less than 0"));
+    /* If new map name is provided, it has to be useable */
+    if (new_map->answer != NULL)
+	if (Vect_legal_filename(new_map->answer) < 1)
+	    G_fatal_error(_("<%s> is not a valid vector map name"),
+			  new_map->answer);
+    /* inline_where has no use if inline_map has been not provided */
+    if (inline_where->answer != NULL && inline_map->answer == NULL)
+	G_fatal_error(_("No input profile map name provided, but WHERE conditions for it have been set"));
+    /* Currently only one profile input method is supported */
+    if (inline_map->answer != NULL && coords_opt->answer != NULL)
+	G_fatal_error(_("Profile input coordinates and vector map are provided. "
+		       "Please provide only one of them"));
+    if (inline_map->answer == NULL && coords_opt->answer == NULL)
+	G_fatal_error(_("No profile input coordinates nor vector map are provided. "
+		       "Please provide one of them"));
+    /* Where to put module output */
+    if (file_opt->answer) {
+	if (strcmp(file_opt->answer, "-") == 0) {
+	    ascii = stdout;
+	else {
+	    ascii = fopen(file_opt->answer, "w");
+	if (ascii == NULL) {
+	    G_fatal_error(_("Unable to open file <%s>"), file_opt->answer);
+    else {
+	ascii = stdout;
+    /* Create and initialize struct's where to store points/lines and categories */
+    Points = Vect_new_line_struct();
+    Profil = Vect_new_line_struct();
+    Buffer = Vect_new_line_struct();
+    Ipoints = Vect_new_line_struct();
+    Cats = Vect_new_cats_struct();
+    /* Construct profile line from user supplied points */
+    if (inline_map->answer == NULL) {
+	for (i = 0; coords_opt->answers[i] != NULL; i += 2) {
+	    xval = atof(coords_opt->answers[i]);
+	    yval = atof(coords_opt->answers[i + 1]);
+	    Vect_append_point(Profil, xval, yval, 0);
+	/* Line is built from two coordinates */
+	if (i == 2)
+	    G_fatal_error(_("At least profile start and end coordinates are required!"));
+    else {
+	/* Check provided profile map name validity */
+	if ((pro_mapset = G_find_vector2(inline_map->answer, "")) == NULL)
+	    G_fatal_error(_("Vector map <%s> not found"), inline_map->answer);
+    if ((mapset = G_find_vector2(old_map->answer, "")) == NULL)
+	G_fatal_error(_("Vector map <%s> not found"), old_map->answer);
+    if (Vect_set_open_level(2))
+	G_fatal_error(_("Unable to set predetermined vector open level"));
+    /* Open existing vector for reading */
+    if (1 > Vect_open_old(&In, old_map->answer, mapset))
+	G_fatal_error(_("Unable to open vector map <%s>"), old_map->answer);
+    /* Process input as 3D only if it's required */
+    if (!no_z_flag->answer && Vect_is_3d(&In))
+	open3d = WITH_Z;
+    else
+	open3d = WITHOUT_Z;
+    /* the field separator */
+    fs = delim_opt->answer;
+    if (strcmp(fs, "\\t") == 0)
+	fs = "\t";
+    if (strcmp(fs, "tab") == 0)
+	fs = "\t";
+    if (strcmp(fs, "space") == 0)
+	fs = " ";
+    /* Let's get vector layers db connections information */
+    Fi = Vect_get_field(&In, layer);
+    if (!Fi && where_opt->answer != NULL) {
+	Vect_close(&In);
+	G_fatal_error(_("No database connection defined for map <%s> layer %d, "
+		       "but WHERE condition is provided"), old_map->answer,
+		      layer);
+    /* Get profile line from existing vector map */
+    if (inline_map->answer != NULL) {
+	if (1 > Vect_open_old(&Pro, inline_map->answer, pro_mapset))
+			  inline_map->answer);
+	if (inline_where->answer != NULL) {
+	    Fpro = Vect_get_field(&Pro, pro_layer);
+	    if (!Fpro) {
+		Vect_close(&In);
+		Vect_close(&Pro);
+			      inline_map->answer, pro_layer);
+	    /* Prepeare strings for use in db_* calls */
+	    db_init_string(&dbsql);
+	    db_init_string(&valstr);
+	    db_init_string(&table_name);
+	    db_init_handle(&handle);
+	    G_debug(1,
+		    "Field number:%d; Name:<%s>; Driver:<%s>; Database:<%s>; Table:<%s>; Key:<%s>",
+		    Fpro->number, Fpro->name, Fpro->driver, Fpro->database,
+		    Fpro->table, Fpro->key);
+	    /* Prepearing database for use */
+	    driver = db_start_driver(Fpro->driver);
+	    if (driver == NULL) {
+		Vect_close(&In);
+		Vect_close(&Pro);
+		G_fatal_error(_("Unable to start driver <%s>"), Fpro->driver);
+	    db_set_handle(&handle, Fpro->database, NULL);
+	    if (db_open_database(driver, &handle) != DB_OK) {
+		Vect_close(&In);
+		Vect_close(&Pro);
+		G_fatal_error(_("Unable to open database <%s> by driver <%s>"),
+			      Fpro->database, driver);
+	    db_set_string(&table_name, Fpro->table);
+	    if (db_describe_table(driver, &table_name, &table) != DB_OK) {
+		Vect_close(&In);
+		Vect_close(&Pro);
+		G_fatal_error(_("Unable to describe table <%s>"),
+			      Fpro->table);
+	    ncols = db_get_table_number_of_columns(table);
+	    ncats =
+		db_select_int(driver, Fpro->table, Fpro->key,
+			      inline_where->answer, &cats);
+	    if (ncats < 1) {
+		Vect_close(&In);
+		Vect_close(&Pro);
+		G_fatal_error(_("No features match Your query"));
+	    if (ncats > 1) {
+		Vect_close(&In);
+		Vect_close(&Pro);
+		G_fatal_error(_("Your query matches more than one record in input profiling map. "
+			       "Currently it's not supported. Enhance WHERE conditions to get only one line."));
+	    if (!(Catlist = Vect_new_list())) {
+		Vect_close(&In);
+		Vect_close(&Pro);
+		G_fatal_error(_("Error while initialising line list"));
+	    /* Get all features matching specified CAT value */
+	    Vect_cidx_find_all(&Pro, pro_layer, GV_LINE, cats[0], Catlist);
+	    if (Catlist->n_values > 1) {
+		Vect_close(&In);
+		Vect_close(&Pro);
+	    if (Vect_read_line(&Pro, Profil, NULL, Catlist->value[0]) !=
+		GV_LINE) {
+		G_fatal_error(_("Error while reading vector feature from profile line map"));
+	else {
+	    /* WHERE not provided -> assuming profiling line map contains only one line */
+	    c = 0;
+	    while ((type = Vect_read_next_line(&Pro, Profil, NULL)) > 0) {
+		if (type & GV_LINE)
+		    c++;
+	    /* Currently we support only one SINGLE input line */
+	    if (c > 1) {
+		Vect_close(&In);
+		Vect_close(&Pro);
+		G_fatal_error(_("Your input profile map contains more than one line. "
+			       "Currently it's not supported. Provide WHERE conditions to get only one line."));
+    /* Create a buffer around profile line for point sampling
+       Tolerance is calculated in such way that buffer will have flat end and no cap. */
+    Vect_line_buffer(Profil, bufsize, 1 - (bufsize * cos((2 * M_PI) / 2)),
+		     Buffer);
+    Vect_cat_set(Cats, 1, 1);
+    if (new_map->answer != NULL) {
+	/* Open new vector for reading/writing */
+	if (0 > Vect_open_new(&Out, new_map->answer, WITHOUT_Z)) {
+	    Vect_close(&In);
+	    G_fatal_error(_("Unable to create vector map <%s>"),
+			  new_map->answer);
+	/* Write profile line and it's buffer into new vector map */
+	Vect_write_line(&Out, GV_LINE, Profil, Cats);
+	/* No category for boundary */
+	Vect_reset_cats(Cats);
+	Vect_write_line(&Out, GV_BOUNDARY, Buffer, Cats);
+    rescount = 0;
+    resultset = NULL;
+    /* If input vector has a database connection... */
+    if (Fi != NULL) {
+	G_debug(1,
+		Fi->number, Fi->name, Fi->driver, Fi->database, Fi->table,
+		Fi->key);
+	driver = db_start_driver(Fi->driver);
+	    Vect_close(&In);
+	    G_fatal_error(_("Unable to start driver <%s>"), Fi->driver);
+	db_set_handle(&handle, Fi->database, NULL);
+	    Vect_close(&In);
+			  Fi->database, driver);
+	db_set_string(&table_name, Fi->table);
+	    Vect_close(&In);
+	    G_fatal_error(_("Unable to describe table <%s>"), Fi->table);
+	/* Create vector feature list for future processing by applying SQL WHERE conditions... */
+	if (where_opt->answer != NULL) {
+	    ncats =
+		db_select_int(driver, Fi->table, Fi->key, where_opt->answer,
+			      &cats);
+	    if (ncats < 1)
+	    field_index = Vect_cidx_get_field_index(&In, layer);
+	    for (i = 0; i < ncats; i++) {
+		c = Vect_cidx_find_next(&In, field_index, cats[i],
+					otype, 0, &type, &id);
+		/* Crunch over all lines, that match specified CAT */
+		while (c >= 0) {
+		    c++;
+		    if (type & otype) {
+			switch (Vect_read_line(&In, Points, Cats, id)) {
+			case GV_POINT:
+			    proc_point(Points, Profil, Buffer, Cats,
+				       &rescount, open3d);
+			    break;
+			case GV_LINE:
+			    Vect_reset_line(Ipoints);
+			    if (Vect_line_get_intersections
+				(Profil, Points, Ipoints, open3d) > 0)
+				proc_line(Ipoints, Profil, Cats, &rescount,
+					  open3d);
+			    break;
+		    else
+			G_fatal_error
+			    ("Error in Vect_cidx_find_next function! Report a bug.");
+		    c = Vect_cidx_find_next(&In, field_index, cats[i], otype,
+					    c, &type, &id);
+    /* Process all lines IF no database exists or WHERE was not provided.
+       Read in single line and get it's type */
+    if (Fi == NULL || (where_opt->answer == NULL && Fi != NULL)) {
+	while ((type = Vect_read_next_line(&In, Points, Cats)) > 0) {
+	    if (type & GV_POINT)
+		proc_point(Points, Profil, Buffer, Cats, &rescount, open3d);
+	    if (type & GV_LINE) {
+		    proc_line(Ipoints, Profil, Cats, &rescount, open3d);
+    /* We don't need input vector anymore */
+    Vect_close(&In);
+    G_debug(1, "There are %d features matching profile line", rescount);
+    /* Sort results by distance, cat */
+    qsort(&resultset[0], rescount, sizeof(Result), compdist);
+    /* Print out column names */
+    if (!no_column_flag->answer) {
+	fprintf(ascii, "Number%sDistance", fs);
+	if (open3d == WITH_Z)
+	    fprintf(ascii, "%sZ", fs);
+	if (Fi != NULL) {
+	    for (col = 0; col < ncols; col++) {
+		column = db_get_table_column(table, col);
+		fprintf(ascii, "%s%s", fs, db_get_column_name(column));
+	fprintf(ascii, "\n");
+    /* Print out result */
+    for (i = 0; i < rescount; i++) {
+	fprintf(ascii, "%d%s%.*f", i + 1, fs, dp, resultset[i].distance);
+	    fprintf(ascii, "%s%.*f", fs, dp, resultset[i].z);
+	if (Fi != NULL) {
+	    sprintf(sql, "select * from %s where %s=%d", Fi->table, Fi->key,
+		    resultset[i].cat);
+	    G_debug(1, "SQL: \"%s\"", sql);
+	    db_set_string(&dbsql, sql);
+	    if (db_open_select_cursor(driver, &dbsql, &cursor, DB_SEQUENTIAL)
+		!= DB_OK)
+		G_warning(_("Unabale to get attribute data for cat %d"),
+	    else {
+		nrows = db_get_num_rows(&cursor);
+		G_debug(1, "Result count: %d", nrows);
+		table = db_get_cursor_table(&cursor);
+		if (nrows > 0) {
+		    if (db_fetch(&cursor, DB_NEXT, &more) != DB_OK) {
+			G_warning(_("Error while retreiving database record for cat %d"),
+		    else {
+			    /* Column description retreiving is fast, as they live in provided table structure */
+			    db_convert_column_value_to_string(column,
+							      &valstr);
+			    type = db_get_column_sqltype(column);
+			    /* Those values should be quoted */
+			    if (type == DB_SQL_TYPE_CHARACTER ||
+				type == DB_SQL_TYPE_DATE ||
+				type == DB_SQL_TYPE_TIME ||
+				type == DB_SQL_TYPE_TIMESTAMP ||
+				type == DB_SQL_TYPE_INTERVAL ||
+				type == DB_SQL_TYPE_TEXT ||
+				type == DB_SQL_TYPE_SERIAL)
+				fprintf(ascii, "%s\"%s\"", fs,
+					db_get_string(&valstr));
+			    else
+		else {
+			fprintf(ascii, "%s", fs);
+	    db_close_cursor(&cursor);
+	/* Terminate attribute data line and flush data to provided output (file/stdout) */
+	if (fflush(ascii))
+            G_fatal_error(_("Can not write data portion to provided output"));
+    /* Build topology for vector map and close them */
+	Vect_build(&Out, stdout);
+	Vect_close(&Out);
+    if (Fi != NULL)
+	db_close_database_shutdown_driver(driver);
+    if (ascii != NULL)
+	fclose(ascii);
+    /* Don't forget to report to caller sucessfull end of data processing :) */
+    exit(EXIT_SUCCESS);
+static int compdist(const void *d1, const void *d2)
+    Result *r1 = (Result *) d1, *r2 = (Result *) d2;
+    G_debug(5, "Comparing %f with %f", r1->distance, r2->distance);
+    if (r1->distance == r2->distance) {
+	if (r1->cat > r2->cat)
+	    return 1;
+	else
+	    return -1;
+    if (r1->distance > r2->distance)
+	return 1;
+    else
+	return -1;
+void add_point(struct line_cats *Cats, const double dist,
+	       const double z, size_t *rescount, const int open3d)
+    Result *tmp;
+    tmp =
+	(Result *) G_realloc(resultset, sizeof(Result) * (*rescount + 1));
+    /* Don't leak memory if realloc fails */
+    if (!tmp) {
+        G_free(resultset);
+        G_fatal_error(_("Out of memory"));
+    else
+        resultset = tmp;
+    resultset[*rescount].distance = dist;
+    Vect_cat_get(Cats, 1, &resultset[*rescount].cat);
+	resultset[*rescount].z = z;
+    (*rescount)++;
+    G_debug(3, "Distance of point %d is %f", *rescount,
+	    resultset[*rescount - 1].distance);
+void proc_point(struct line_pnts *Points, struct line_pnts *Profil,
+		struct line_pnts *Buffer, struct line_cats *Cats,
+		size_t *rescount, const int open3d)
+    double dist;
+    if (Vect_point_in_poly(*Points->x, *Points->y, Buffer) > 0) {
+	Vect_line_distance(Profil, *Points->x, *Points->y, *Points->z,
+			   open3d, NULL, NULL, NULL, NULL, NULL, &dist);
+	add_point(Cats, dist, *Points->z, rescount, open3d);
+/* Process all line intersection points */
+void proc_line(struct line_pnts *Ipoints, struct line_pnts *Profil,
+	       struct line_cats *Cats, size_t *rescount, const int open3d)
+    int i;
+    double dist;
+    /* Add all line and profile intersection points to resultset */
+    for (i = 0; i < Ipoints->n_points; i++) {
+	Vect_line_distance(Profil, Ipoints->x[i], Ipoints->y[i],
+			   Ipoints->z[i], open3d, NULL, NULL, NULL, NULL,
+			   NULL, &dist);
+	add_point(Cats, dist, Ipoints->z[i], rescount, open3d);
Added: grass-addons/vector/v.profile/v.profile.html
--- grass-addons/vector/v.profile/v.profile.html	                        (rev 0)
+++ grass-addons/vector/v.profile/v.profile.html	2008-11-09 11:26:58 UTC (rev 34201)
@@ -0,0 +1,52 @@
+<h2>DESCRIPTION</h2>
+<p>This module will print out distance and attributes to points/lines along profiling
+line. Distance is calculated from first profiling line coordinate pair or from the
+beginning of vector line (use "Line directions" feature in gis.m to see distance calculation
+direction). Output can go to file or stdout. Output file will be overwritten without warning.
+Buffer (tolerance) parameter sets how far point
+can be located from profiling line and still be included in output data set. Output map
+option can be used to visualy check which points are profiled. Buffer (tolerance) setting
+does not affect lines. Lines are sampled at their crossing point with profiling line.
+By default Z values are printed if input vector is a 3D map. It can be disabled with -z
+flag. Profiling line can be provided as N,E coordinate pairs or can come from input vector
+map. As currently profiling line must be single line, one should use profile_where parameter
+to select single line from profile input map if it contains multiple features.</p>
+<h2>NOTE</h2>
+<p>Currently module can profile only points and lines (including 3D ones). Areas and other
+complex features are not supported. If one can provide reasonable examples how area
+sampling should work and why it's important, area (or any other feature type) sampling can
+be added.</p>
+<h2>EXAMPLES</h2>
+<p>
+Get point values and distance from the city and save into file for later usage. Will use
+; as delimiter and three numbers after decimal separator for distance. Output file will contain
+data for all points, that are within 100m range to profiling line.
+<div class="code"><pre>
+v.profile input=archsites at PERMANENT map_output=profiling_line buffer=100 \
+east_north=591518.55,4925722.38,592110.14,4920989.67 out_file=/home/user/archsites.distance dp=3 fs=';'
+# Now let's see output:
+$cat archsites.distance
+Number;Distance;cat;str1
+1;446.958;24;"Hanson Ranch"
+2;1386.149;11;"No Name"
+3;2754.872;2;"No Name"
+4;4559.578;13;"No Name"
+</pre></div>
+</p>
+<p>Create river valley crossection and provide river marker
+# Take elevation samples
+r.profile input=elevation.dem at PERMANENT output=/home/user/elevation.profile \
+profile=600570.27364,4920613.41838,600348.034348,4920840.38617
+# Now get distance to place where river marker should be set
+v.profile input=streams at PERMANENT out_file=/home/user/river.profile \
+east_north=600570.27364,4920613.41838,600348.034348,4920840.38617
+</pre></div>
+</p>
+<h2>BUGS</h2>
+<p>Strings are enclosed in double quotes ", still quotes within string are not escaped.</p>
+<p>Vector CAT values are not outputed. Only way how to get CAT value is from attribute table.</p>
+<h2>SEE ALSO</h2>
+<p><a href="r.profile.html">r.profile</a></p>
+<h2>AUTHOR</h2>
+<p>Maris Nartiss</p>
