[GRASS-SVN] r34217 -
grass/branches/develbranch_6/raster/simwe/r.sim.water
svn_grass at osgeo.org
Sun Nov 9 19:57:41 EST 2008
Author: helena
Date: 2008-11-09 19:57:41 -0500 (Sun, 09 Nov 2008)
New Revision: 34217
Removed:
grass/branches/develbranch_6/raster/simwe/r.sim.water/waterglobs.h
extra waterglobs.h removed, merge from trunk 34148
Deleted: grass/branches/develbranch_6/raster/simwe/r.sim.water/waterglobs.h
--- grass/branches/develbranch_6/raster/simwe/r.sim.water/waterglobs.h 2008-11-10 00:53:47 UTC (rev 34216)
+++ grass/branches/develbranch_6/raster/simwe/r.sim.water/waterglobs.h 2008-11-10 00:57:41 UTC (rev 34217)
@@ -1,269 +0,0 @@
-#define EPS 1.e-7
-#define MAXW 7000000
-#define UNDEF -9999
-#ifdef MAIN
-FILE *fdelevin, *fddxin, *fddyin, *fdrain, *fdinfil, *fdtraps, *fdmanin,
- *fddepth, *fddisch, *fderr /*, *fdoutwalk, *fdwalkers*/ ;
-FILE *fdwdepth, *fddetin, *fdtranin, *fdtauin, *fdtc, *fdet, *fdconc, *fdflux,
- *fderdep;
-/* FILE *fdsfile, *fw; */
-char *elevin;
-char *dxin;
-char *dyin;
-char *rain;
-char *infil;
-char *traps;
-char *manin;
-/* char *sfile; */
-char *depth;
-char *disch;
-char *err;
-/* char *outwalk; */
-char *mapset;
-/* Flag */
-char *tserie;
-char *wdepth;
-char *detin;
-char *tranin;
-char *tauin;
-char *tc;
-char *et;
-char *conc;
-char *flux;
-char *erdep;
-/*New Input val */
-char *rainval;
-char *maninval;
-char *infilval;
-/* walkers taken out
-struct
- struct Option *elevin, *dxin, *dyin, *rain, *infil, *traps, *manin,
- *sfile, *depth, *disch, *err, *outwalk, *nwalk, *niter, *outiter,
- *density, *diffc, *hmax, *halpha, *hbeta, *wdepth, *detin, *tranin,
- *tauin, *tc, *et, *conc, *flux, *erdep, *rainval, *maninval,
- *infilval;
-} parm;
-struct
- *depth, *disch, *err, *nwalk, *niter, *outiter,
- *diffc, *hmax, *halpha, *hbeta, *wdepth, *detin, *tranin,
- *infilval;
-} parm;
-struct
- struct Flag *tserie;
-} flag;
-struct
- long int is1, is2;
-} seed;
-struct Cell_head cellhd;
-/* check whether this is the outlet
-struct Point
- double north, east;
- double z1;
-struct Point *points;
-int npoints;
-int npoints_alloc;
-int input_data(void);
-int seeds(long int, long int);
-int seedg(long int, long int);
-int grad_check(void);
-void erod(double **);
-void main_loop(void);
-int output_data(int, double);
-int output_et(void);
-double ulec(void);
-double gasdev(void);
-double amax1(double, double);
-double amin1(double, double);
-int min(int, int);
-int max(int, int);
-double xmin, ymin, xmax, ymax;
-double mayy, miyy, maxx, mixx;
-int mx, my;
-int mx2, my2;
-/*double bxmi,bymi,bxma,byma,bresx,bresy; */
-int maxwab;
-double step, conv;
-double frac;
-double bxmi, bymi;
-float **zz, **cchez;
-double **v1, **v2, **slope;
-double **gama, **gammas, **si, **inf, **sigma;
-float **dc, **tau, **er, **ct, **trap;
-float **dif;
-double vavg[MAXW][2], stack[MAXW][3], w[MAXW][3];
-int iflag[MAXW];
-double hbeta;
-/* int ldemo; */
-double hhmax, sisum, vmean;
-double infsum, infmean;
-int maxw, maxwa, nwalk;
-double rwalk, bresx, bresy, xrand, yrand;
-double stepx, stepy, xp0, yp0;
-double chmean, si0, deltap, deldif, cch, hhc, halpha;
-double eps;
-int maxwab, nstack;
-int iterout, mx2o, my2o;
-int miter, nwalka, lwwfin;
-double timec;
-int ts, timesec;
-double rain_val;
-double manin_val;
-double infil_val;
-#else
-/* extern FILE *fdelevin, *fddxin, *fddyin, *fdrain, *fdinfil, *fdtraps,
- *fdmanin, *fddepth, *fddisch, *fderr, *fdoutwalk, *fdwalkers; */
-extern FILE *fdelevin, *fddxin, *fddyin, *fdrain, *fdinfil, *fdtraps,
- *fdmanin, *fddepth, *fddisch, *fderr;
-extern FILE *fdwdepth, *fddetin, *fdtranin, *fdtauin, *fdtc, *fdet, *fdconc,
- *fdflux, *fderdep;
-extern FILE *fdsfile, *fw;
-extern char *elevin;
-extern char *dxin;
-extern char *dyin;
-extern char *rain;
-extern char *infil;
-extern char *traps;
-extern char *manin;
-extern char *sfile;
-extern char *depth;
-extern char *disch;
-extern char *err;
-/* extern char *outwalk; */
-extern char *mapset;
-extern char *tserie;
-extern char *wdepth;
-extern char *detin;
-extern char *tranin;
-extern char *tauin;
-extern char *tc;
-extern char *et;
-extern char *conc;
-extern char *flux;
-extern char *erdep;
-extern char *rainval;
-extern char *maninval;
-extern char *infilval;
-extern struct
- *infilval;
-} parm;
-extern struct
-} flag;
-extern struct
-} seed;
-extern struct Cell_head cellhd;
-extern struct Point
- double z1;
-extern struct Point *points;
-extern int npoints;
-extern int npoints_alloc;
-extern int input_data(void);
-extern int seeds(long int, long int);
-extern int seedg(long int, long int);
-extern int grad_check(void);
-extern void erod(double **);
-extern void main_loop(void);
-extern int output_data(int, double);
-extern int output_et(void);
-extern double ulec(void);
-extern double gasdev(void);
-extern double amax1(double, double);
-extern double amin1(double, double);
-extern int min(int, int);
-extern int max(int, int);
-extern double xmin, ymin, xmax, ymax;
-extern double mayy, miyy, maxx, mixx;
-extern int mx, my;
-extern int mx2, my2;
-/*extern double bxmi,bymi,bxma,byma,bresx,bresy; */
-extern int maxwab;
-extern double step, conv;
-extern double frac;
-extern double bxmi, bymi;
-extern float **zz, **cchez;
-extern double **v1, **v2, **slope;
-extern double **gama, **gammas, **si, **inf, **sigma;
-extern float **dc, **tau, **er, **ct, **trap;
-extern float **dif;
-extern double vavg[MAXW][2], stack[MAXW][3], w[MAXW][3];
-extern int iflag[MAXW];
-extern double hbeta;
-extern int ldemo;
-extern double hhmax, sisum, vmean;
-extern double infsum, infmean;
-extern int maxw, maxwa, nwalk;
-extern double rwalk, bresx, bresy, xrand, yrand;
-extern double stepx, stepy, xp0, yp0;
-extern double chmean, si0, deltap, deldif, cch, hhc, halpha;
-extern double eps;
-extern int maxwab, nstack;
-extern int iterout, mx2o, my2o;
-extern int miter, nwalka, lwwfin;
-extern double timec;
-extern int ts, timesec;
-extern double rain_val;
-extern double manin_val;
-extern double infil_val;
-#endif
