[GRASS-SVN] r34220 -
grass/branches/develbranch_6/vector/v.db.connect
svn_grass at osgeo.org
Mon Nov 10 01:51:52 EST 2008
Author: hamish
Date: 2008-11-10 01:51:52 -0500 (Mon, 10 Nov 2008)
New Revision: 34220
grass/branches/develbranch_6/vector/v.db.connect/main.c
pass correct variable form to %s
Modified: grass/branches/develbranch_6/vector/v.db.connect/main.c
--- grass/branches/develbranch_6/vector/v.db.connect/main.c 2008-11-10 05:20:45 UTC (rev 34219)
+++ grass/branches/develbranch_6/vector/v.db.connect/main.c 2008-11-10 06:51:52 UTC (rev 34220)
@@ -253,7 +253,7 @@
&Map));
if (!driver)
G_fatal_error(_("Unable to start driver <%s>"),
- dbdriver);
+ dbdriver->answer);
db_get_column(driver, dbtable->answer, dbkey->answer,
&column);
