[GRASS-SVN] r34222 - grass/trunk/vector/v.db.connect
svn_grass at osgeo.org
Mon Nov 10 02:13:38 EST 2008
Author: hamish
Date: 2008-11-10 02:13:33 -0500 (Mon, 10 Nov 2008)
New Revision: 34222
grass/trunk/vector/v.db.connect/main.c
pass correct variable form to %s
Modified: grass/trunk/vector/v.db.connect/main.c
--- grass/trunk/vector/v.db.connect/main.c 2008-11-10 06:52:35 UTC (rev 34221)
+++ grass/trunk/vector/v.db.connect/main.c 2008-11-10 07:13:33 UTC (rev 34222)
@@ -248,7 +248,7 @@
&Map));
if (!driver)
G_fatal_error(_("Unable to start driver <%s>"),
- dbdriver);
+ dbdriver->answer);
db_get_column(driver, dbtable->answer, dbkey->answer,
&column);
