[GRASS-SVN] r34244 - in grass/branches/develbranch_6: . doc
imagery/i.rectify
svn_grass at osgeo.org
Tue Nov 11 05:22:38 EST 2008
Author: msieczka
Date: 2008-11-11 05:22:38 -0500 (Tue, 11 Nov 2008)
New Revision: 34244
grass/branches/develbranch_6/AUTHORS
grass/branches/develbranch_6/contributors.csv
grass/branches/develbranch_6/doc/infrastructure.txt
grass/branches/develbranch_6/imagery/i.rectify/description.html
Info about me updated.
Modified: grass/branches/develbranch_6/AUTHORS
--- grass/branches/develbranch_6/AUTHORS 2008-11-11 10:07:41 UTC (rev 34243)
+++ grass/branches/develbranch_6/AUTHORS 2008-11-11 10:22:38 UTC (rev 34244)
@@ -64,11 +64,8 @@
http://www.grass-gis.org/mailman/listinfo/grass-qa
-Bugtracker maintainer:
- Maciej "Maciek" Sieczka <werchowyna at epf.pl>
Power user tester:
+ Maciej "Maciek" Sieczka <msieczka at sieczka.org>
Modified: grass/branches/develbranch_6/contributors.csv
--- grass/branches/develbranch_6/contributors.csv 2008-11-11 10:07:41 UTC (rev 34243)
+++ grass/branches/develbranch_6/contributors.csv 2008-11-11 10:22:38 UTC (rev 34244)
@@ -33,7 +33,7 @@
michael,Michael Barton,<michael.barton asu.edu>,USA,cmbarton,yes
mike,Mike Thomas,<miketh brisbane.paradigmgeo.com>,Australia,-,-
moritz,Moritz Lennert,<mlennert club.worldonline.be>,Belgium,mlennert,yes
-msieczka,Maciek Sieczka,<tutey o2.pl>,Poland,msieczka,yes
+msieczka,Maciej Sieczka,<msieczka sieczka.org>,Poland,msieczka,yes
paul,Paul Kelly,<paul-grass stjohnspoint.co.uk>,UK,pkelly,yes
paulo,Paulo Marcondes,<pmarc.debian gmail.com>,Brazil,pmarcondes,-
pallech,Serena Pallecchi,<pallecch cli.di.unipi.it>,Italy,-,-
Modified: grass/branches/develbranch_6/doc/infrastructure.txt
--- grass/branches/develbranch_6/doc/infrastructure.txt 2008-11-11 10:07:41 UTC (rev 34243)
+++ grass/branches/develbranch_6/doc/infrastructure.txt 2008-11-11 10:22:38 UTC (rev 34244)
@@ -171,12 +171,6 @@
== GRASS Bugtracker ==
-Maintainer: Bernhard Reiter, Jan-Oliver Wagner (gforce)
- Maciej Sieczka (bugs generally), with help from
- - Jachym Cepicky - code patches,
- - Scott Mitchell - website patches,
- - Martin Landa - doc patches
Very old bugtracker (Dec 2000 - Dec 2006):
* https://intevation.de/rt/webrt?q_queue=grass
* webRT, sponsored by Intevation GmbH, Germany
Modified: grass/branches/develbranch_6/imagery/i.rectify/description.html
--- grass/branches/develbranch_6/imagery/i.rectify/description.html 2008-11-11 10:07:41 UTC (rev 34243)
+++ grass/branches/develbranch_6/imagery/i.rectify/description.html 2008-11-11 10:22:38 UTC (rev 34244)
@@ -1,36 +1,31 @@
<H2>DESCRIPTION</H2>
-<EM>i.rectify</EM> uses the control
-points identified in
+<EM>i.rectify</EM> uses the control points (GCPs) identified with
<EM><A HREF="i.points.html">i.points</A></EM>
or
<EM><A HREF="i.vpoints.html">i.vpoints</A></EM>
-to calculate a transformation matrix based on a first,
-second, or third order polynomial and then converts x,y
-cell coordinates to standard map coordinates for each pixel
-in the image. The result is a planimetric image with a
-transformed coordinate system (i.e., a different coordinate
-system than before it was rectified).
+to calculate a transformation matrix based on a 1st, 2nd, or 3rd order
+polynomial, and then converts x,y cell coordinates of raster map(s) in the input
+imagery group, created with <EM><A HREF="i.group.html">i.group</A></EM>, to
+target coordinates for each cell in each input raster map. The <em>output</em>
+is a raster map, or a set of them with a transformed coordinate system (i.e., a
+different coordinate system than before it was rectified).
<P>
+Upon completion of <EM>i.rectify</EM>, the rectified image is deposited in the
+target LOCATION, which was selected using
+<EM><A HREF="i.target.html">i.target</A></EM> prior to running
or
-<EM><A HREF="i.vpoints.html">i.vpoints</A></EM>
+<EM><A HREF="i.vpoints.html">i.vpoints</A></EM>.
-must be run before <EM>i.rectify</EM>, and both programs
-are required to rectify an image. An image must be
-rectified before it can reside in a standard coordinate
-LOCATION, and therefore be analyzed with the other map
-layers in the standard coordinate LOCATION. Upon
-completion of <EM>i.rectify</EM>, the rectified image is
-deposited in the target standard coordinate LOCATION. This
-LOCATION is selected using
+<p>
+By default
-<EM><A HREF="i.target.html">i.target</A></EM>.
<H2>Program Prompts</H2>
The first prompt in the program asks for the name of
@@ -172,6 +167,8 @@
or removed.
<P>
Note: In interactive mode it is possible to define a new file name
for the target images. This is (currently) not provided in command line
