[GRASS-SVN] r34262 - grass/branches/develbranch_6/vector/v.select
svn_grass at osgeo.org
Wed Nov 12 15:55:40 EST 2008
Author: martinl
Date: 2008-11-12 15:55:40 -0500 (Wed, 12 Nov 2008)
New Revision: 34262
grass/branches/develbranch_6/vector/v.select/main.c
v.select: parameter description & message cosmetics
Modified: grass/branches/develbranch_6/vector/v.select/main.c
--- grass/branches/develbranch_6/vector/v.select/main.c 2008-11-12 16:25:15 UTC (rev 34261)
+++ grass/branches/develbranch_6/vector/v.select/main.c 2008-11-12 20:55:40 UTC (rev 34262)
@@ -5,7 +5,7 @@
* AUTHOR(S): Radim Blazek <radim.blazek gmail.com> (original contributor)
* Glynn Clements <glynn gclements.plus.com>, Markus Neteler <neteler itc.it>
* PURPOSE:
- * COPYRIGHT: (C) 2003-2006 by the GRASS Development Team
+ * COPYRIGHT: (C) 2003-2008 by the GRASS Development Team
* This program is free software under the GNU General Public
* License (>=v2). Read the file COPYING that comes with GRASS
@@ -129,26 +129,32 @@
pre[1] = "b";
module = G_define_module();
- module->keywords = _("vector");
+ module->keywords = _("vector, query");
module->description =
- _("Select features from ainput by features from binput");
+ _("Selects features from vector map (A) by features from other vector map (B).");
in_opt[0] = G_define_standard_option(G_OPT_V_INPUT);
+ in_opt[0]->description = _("Name of input vector map (A)");
in_opt[0]->key = "ainput";
type_opt[0] = G_define_standard_option(G_OPT_V_TYPE);
+ type_opt[0]->label = _("Feature type (vector map A)");
type_opt[0]->key = "atype";
field_opt[0] = G_define_standard_option(G_OPT_V_FIELD);
+ field_opt[0]->label = _("Layer number (vector map A)");
field_opt[0]->key = "alayer";
in_opt[1] = G_define_standard_option(G_OPT_V_INPUT);
+ in_opt[1]->description = _("Name of input vector map (B)");
in_opt[1]->key = "binput";
type_opt[1] = G_define_standard_option(G_OPT_V_TYPE);
+ type_opt[1]->label = _("Feature type (vector map B)");
type_opt[1]->key = "btype";
field_opt[1] = G_define_standard_option(G_OPT_V_FIELD);
+ field_opt[1]->label = _("Layer number (vector map B)");
field_opt[1]->key = "blayer";
out_opt = G_define_standard_option(G_OPT_V_OUTPUT);
@@ -160,11 +166,12 @@
operator_opt->multiple = NO;
operator_opt->options = "overlap";
operator_opt->answer = "overlap";
+ operator_opt->label =
+ _("Operator defines required relation between features");
operator_opt->description =
- _("Operator defines required relation between features. "
- "A feature is written to output if the result of operation 'ainput operator binput' is true. "
- "An input feature is considered to be true, if category of given layer is defined.\n"
- "\t overlap: features partially or completely overlap");
+ _("A feature is written to output if the result of operation 'ainput operator binput' is true. "
+ "An input feature is considered to be true, if category of given layer is defined.");
+ operator_opt->descriptions = _("overlap;features partially or completely overlap");
table_flag = G_define_flag();
table_flag->key = 't';
@@ -219,13 +226,13 @@
/* Lines in A. Go through all lines and mark those that meets condition */
if (type[0] & (GV_POINTS | GV_LINES)) {
- G_message(_("Processing ainput lines ..."));
+ G_message(_("Processing vector features..."));
for (aline = 1; aline <= nalines; aline++) {
BOUND_BOX abox;
G_debug(3, "aline = %d", aline);
- G_percent(aline, nalines, 1); /* must be before any continue */
+ G_percent(aline, nalines, 2); /* must be before any continue */
/* Check category */
if (Vect_get_line_cat(&(In[0]), aline, field[0]) < 0)
@@ -299,8 +306,8 @@
if (type[0] & GV_AREA) {
int aarea, naareas;
- G_message(_("Processing ainput areas ..."));
+ G_message(_("Processing vector areas..."));
naareas = Vect_get_num_areas(&(In[0]));
for (aarea = 1; aarea <= naareas; aarea++) {
@@ -450,7 +457,7 @@
if (!(table_flag->answer)) {
int ttype, ntabs = 0;
- G_message(_("Writing attributes ..."));
+ G_verbose_message(_("Writing attributes..."));
/* Number of output tabs */
for (i = 0; i < Vect_get_num_dblinks(&(In[0])); i++) {
@@ -479,12 +486,10 @@
if (fields[i] == 0)
continue;
- G_message(_("Layer %d"), fields[i]);
/* Make a list of categories */
IFi = Vect_get_field(&(In[0]), fields[i]);
if (!IFi) { /* no table */
- G_message("No table.");
+ G_warning(_("Layer %d - no table"), fields[i]);
continue;
@@ -499,13 +504,12 @@
ncats[i]);
if (ret == DB_FAILED) {
- G_warning(_("Cannot copy table"));
+ G_warning(_("Layer %d - unable to copy table"), fields[i]);
else {
Vect_map_add_dblink(&Out, OFi->number, OFi->name, OFi->table,
IFi->key, OFi->database, OFi->driver);
- G_done_msg("");
@@ -514,5 +518,7 @@
Vect_build(&Out, stderr);
Vect_close(&Out);
+ G_done_msg(" ");
exit(EXIT_SUCCESS);
