[GRASS-SVN] r34276 - grass/branches/develbranch_6/vector/v.category
svn_grass at osgeo.org
Thu Nov 13 11:31:06 EST 2008
Author: epatton
Date: 2008-11-13 11:31:06 -0500 (Thu, 13 Nov 2008)
New Revision: 34276
grass/branches/develbranch_6/vector/v.category/description.html
Added notes about ID parameter
Modified: grass/branches/develbranch_6/vector/v.category/description.html
--- grass/branches/develbranch_6/vector/v.category/description.html 2008-11-13 16:29:38 UTC (rev 34275)
+++ grass/branches/develbranch_6/vector/v.category/description.html 2008-11-13 16:31:06 UTC (rev 34276)
@@ -2,7 +2,7 @@
<em>v.category</em> attaches, deletes or reports vector categories to
map geometry. These categories (IDs) are used to link geometry
-object(s) to attribute record (from attribute table linked to vector map).
+object(s) to attribute records (from attribute table linked to vector map).
<h2>NOTES</h2>
@@ -28,7 +28,11 @@
<p>
The <b>id</b> parameter specifies the list of feature ids to which the
-operation is performed. By default all vector features are processed.
+operation is performed; by default, all vector feature ids are processed.
+The <b>id</b> is an internal (unique) geometry id that all vector primitives possess,
+and is separate from any category the feature may also possess.
+Use <div class="code"><pre><em><a href="v.edit.html">v.edit</a></em> map=inputname tool=select</pre></div>
+to find out the geometry ids of certain features.
<h2>EXAMPLES</h2>
