[GRASS-SVN] r34279 - grass/trunk/raster/r.terraflow
Fri Nov 14 04:20:08 EST 2008
Author: neteler
Date: 2008-11-14 04:20:07 -0500 (Fri, 14 Nov 2008)
New Revision: 34279
   grass/trunk/raster/r.terraflow/r.terraflow.html
less nonsense example
Modified: grass/trunk/raster/r.terraflow/r.terraflow.html
--- grass/trunk/raster/r.terraflow/r.terraflow.html	2008-11-14 03:19:59 UTC (rev 34278)
+++ grass/trunk/raster/r.terraflow/r.terraflow.html	2008-11-14 09:20:07 UTC (rev 34279)
@@ -162,17 +162,21 @@
 <h2>EXAMPLES</h2>
+Spearfish sample data set:
 <div class="code"><pre>
- r.terraflow elev=spearfish filled=spearfish-filled \
-    dir=spearfish-mfdir swatershed=spearfish-watershed \
-    accumulation=spearfish-accu tci=spearfish-tci
+g.region rast=elevation.10m -p
+r.terraflow elev=elevation.10m filled=elevation10m.filled \
+    dir=elevation10m.mfdir swatershed=elevation10m.watershed \
+    accumulation=elevation10m.accu tci=elevation10m.tci
 </pre></div>
-    accumulation=spearfish-accu tci=spearfish-tci d8cut=500 memory=800 \
-    STREAM-DIR=/var/tmp/ stats=spearfish-stats.txt
+    accumulation=elevation10m.accu tci=elevation10m.tci d8cut=500 memory=800 \
+    STREAM-DIR=/var/tmp/ stats=elevation10mstats.txt
 </pre></div>
