[GRASS-SVN] r34283 - grass/trunk/vector/v.patch
svn_grass at osgeo.org
Fri Nov 14 06:22:33 EST 2008
Author: glynn
Date: 2008-11-14 06:22:33 -0500 (Fri, 14 Nov 2008)
New Revision: 34283
grass/trunk/vector/v.patch/v.patch.html
Fix broken tag
Modified: grass/trunk/vector/v.patch/v.patch.html
--- grass/trunk/vector/v.patch/v.patch.html 2008-11-14 11:21:57 UTC (rev 34282)
+++ grass/trunk/vector/v.patch/v.patch.html 2008-11-14 11:22:33 UTC (rev 34283)
@@ -14,7 +14,13 @@
editing can be done automatically using
<em><a HREF="v.clean.html">v.clean</a></em> (tool=snap,break,rmdupl).
-When using the <em>-a</em< flag, the user has to make sure that the features in the different maps added to the output map do not have overlapping category numbers, unless identical category numbers reflect identical attributes, otherwise the attributes of the added maps are lost. To avoid this, the user can use <em>v.category option=sum</em> to change category values of some of the maps before patching.
+When using the <em>-a</em> flag, the user has to make sure that the
+features in the different maps added to the output map do not have
+overlapping category numbers, unless identical category numbers
+reflect identical attributes, otherwise the attributes of the added
+maps are lost. To avoid this, the user can use <em>v.category
+option=sum</em> to change category values of some of the maps before
+patching.
<h2>EXAMPLES</h2>
