[GRASS-SVN] r34290 - grass/branches/develbranch_6/general/manage/lib
Fri Nov 14 10:36:25 EST 2008
Author: neteler
Date: 2008-11-14 10:36:25 -0500 (Fri, 14 Nov 2008)
New Revision: 34290
   grass/branches/develbranch_6/general/manage/lib/do_copy.c
   grass/branches/develbranch_6/general/manage/lib/do_rename.c
fix
Modified: grass/branches/develbranch_6/general/manage/lib/do_copy.c
--- grass/branches/develbranch_6/general/manage/lib/do_copy.c	2008-11-14 15:34:06 UTC (rev 34289)
+++ grass/branches/develbranch_6/general/manage/lib/do_copy.c	2008-11-14 15:36:25 UTC (rev 34290)
@@ -24,7 +24,7 @@
     hold_signals(1);
     if (G_strcasecmp(list[n].alias, "vect") == 0) {
-	ret = Vect_copy(old, mapset, new, stderr);
+	ret = Vect_copy(old, mapset, new);
 	if (ret == -1) {
 	    G_warning("Cannot copy <%s> to current mapset as <%s>",
 		      G_fully_qualified_name(old, mapset), new);
Modified: grass/branches/develbranch_6/general/manage/lib/do_rename.c
--- grass/branches/develbranch_6/general/manage/lib/do_rename.c	2008-11-14 15:34:06 UTC (rev 34289)
+++ grass/branches/develbranch_6/general/manage/lib/do_rename.c	2008-11-14 15:36:25 UTC (rev 34290)
@@ -37,7 +37,7 @@
 	    G_warning(_("Vector map <%s> not found"), old);
 	else {
-	    ret = Vect_rename(old, new, stderr);
+	    ret = Vect_rename(old, new);
 	    if (ret != -1) {
 		renamed = 1;
