[GRASS-SVN] r34309 - grass/trunk/lib/vector/Vlib
svn_grass at osgeo.org
Sat Nov 15 15:42:52 EST 2008
Author: neteler
Date: 2008-11-15 15:42:52 -0500 (Sat, 15 Nov 2008)
New Revision: 34309
grass/trunk/lib/vector/Vlib/intersect.c
marisn: Add Vect_line_get_intersection() function (merge from develbranch_6, r34306)
Modified: grass/trunk/lib/vector/Vlib/intersect.c
--- grass/trunk/lib/vector/Vlib/intersect.c 2008-11-15 20:41:51 UTC (rev 34308)
+++ grass/trunk/lib/vector/Vlib/intersect.c 2008-11-15 20:42:52 UTC (rev 34309)
@@ -1065,7 +1065,7 @@
return 1;
-static struct line_pnts *APnts, *BPnts;
+static struct line_pnts *APnts, *BPnts, *IPnts;
static int cross_found; /* set by find_cross() */
@@ -1087,6 +1087,23 @@
BPnts->y[j + 1], BPnts->z[j + 1], &x1,
&y1, &z1, &x2, &y2, &z2, 0);
+ switch (ret) {
+ case 0:
+ case 5:
+ break;
+ case 1:
+ if (0 > Vect_copy_xyz_to_pnts(IPnts, &x1, &y1, &z1, 1))
+ G_warning(_("Error while adding point to array. Out of memory"));
+ break;
+ case 2:
+ case 3:
+ case 4:
+ if (0 > Vect_copy_xyz_to_pnts(IPnts, &x2, &y2, &z2, 1))
+ break;
/* add ALL (including end points and duplicates), clean later */
if (ret > 0) {
cross_found = 1;
@@ -1126,11 +1143,21 @@
if (APoints->n_points == 1 && BPoints->n_points == 1) {
if (APoints->x[0] == BPoints->x[0] && APoints->y[0] == BPoints->y[0]) {
if (!with_z) {
+ if (0 >
+ Vect_copy_xyz_to_pnts(IPnts, &APoints->x[0],
+ &APoints->y[0], NULL, 1))
return 1;
else {
- if (APoints->z[0] == BPoints->z[0])
+ if (APoints->z[0] == BPoints->z[0]) {
+ if (0 >
+ &APoints->y[0], &APoints->z[0],
+ 1))
return 1;
else
return 0;
@@ -1146,6 +1173,10 @@
NULL, NULL);
if (dist <= rethresh) {
+ if (0 >
+ Vect_copy_xyz_to_pnts(IPnts, &APoints->x[0], &APoints->y[0],
+ &APoints->z[0], 1))
return 1;
else {
@@ -1158,8 +1189,13 @@
BPoints->z[0], with_z, NULL, NULL, NULL, &dist,
NULL, NULL);
- if (dist <= rethresh)
+ if (dist <= rethresh) {
+ if (0 >
+ Vect_copy_xyz_to_pnts(IPnts, &BPoints->x[0], &BPoints->y[0],
+ &BPoints->z[0], 1))
return 1;
else
return 0;
@@ -1246,3 +1282,29 @@
return cross_found;
+ * \brief Get 2 lines intersection points.
+ * A wrapper around Vect_line_check_intersection() function.
+ * \param[in] APoints first input line
+ * \param[in] BPoints second input line
+ * \param[out] IPoints output with intersection points
+ * \param[in] with_z 3D, not supported (only if one or both are points)!
+ * \return 0 no intersection
+ * \return 1 intersection found
+int
+Vect_line_get_intersections(struct line_pnts *APoints,
+ struct line_pnts *BPoints,
+ struct line_pnts *IPoints, int with_z)
+ int ret;
+ IPnts = IPoints;
+ ret = Vect_line_check_intersection(APoints, BPoints, with_z);
+ return ret;
