[GRASS-SVN] r34311 - grass/branches/develbranch_6/ps/ps.map
svn_grass at osgeo.org
Sat Nov 15 15:52:45 EST 2008
Author: neteler
Date: 2008-11-15 15:52:45 -0500 (Sat, 15 Nov 2008)
New Revision: 34311
grass/branches/develbranch_6/ps/ps.map/description.html
example polished to fix trac #362 (merge from trunk)
Modified: grass/branches/develbranch_6/ps/ps.map/description.html
--- grass/branches/develbranch_6/ps/ps.map/description.html 2008-11-15 20:51:59 UTC (rev 34310)
+++ grass/branches/develbranch_6/ps/ps.map/description.html 2008-11-15 20:52:45 UTC (rev 34311)
@@ -1522,14 +1522,9 @@
<H2>EXAMPLE ps.map INPUT FILE</H2>
The following is an example of a <EM>ps.map</EM> script file. The file has been
-named <EM>spear.soils</EM>.
-This script file can be entered at the command line:
+named <EM>spear.soils</EM>:
<PRE>
- <B>ps.map input=</B><EM>spear.soils</EM> <B>output=</B><EM>soils.ps</EM>
-</PRE>
-<PRE>
# this ps.map example draws a map of Spearfish, SD
<B>raster</B> soils
<B>outline</B>
@@ -1594,9 +1589,21 @@
<B>paper</B> a4
<B>end</B>
<B>end</B>
</PRE>
+This script file can be entered at the command line:
+<div class="code"><pre>
+ # First set the region
+ g.region rast=soils
+ # Generate comment file (or use text editor)
+ echo "Spearfish (SD) soils" > soil.cmt
+ # Generate map as Postsript file
+ ps.map input=spear.soils output=soils.ps
+</pre></div>
<P>
More examples can be found on the
<a href="http://grass.osgeo.org/wiki/Ps.map_scripts">GRASS Wiki</a>
