[GRASS-SVN] r34338 - grass/branches/develbranch_6/lib/gis
svn_grass at osgeo.org
Mon Nov 17 11:50:33 EST 2008
Author: neteler
Date: 2008-11-17 11:50:33 -0500 (Mon, 17 Nov 2008)
New Revision: 34338
grass/branches/develbranch_6/lib/gis/gislib.dox
function calls simplified to make doxygen happy (as also almost unmaintained and hence outdated)
Modified: grass/branches/develbranch_6/lib/gis/gislib.dox
--- grass/branches/develbranch_6/lib/gis/gislib.dox 2008-11-17 16:50:20 UTC (rev 34337)
+++ grass/branches/develbranch_6/lib/gis/gislib.dox 2008-11-17 16:50:33 UTC (rev 34338)
@@ -56,7 +56,7 @@
writing code using routines from this library:
\verbatim
-#include "gis.h"
+#include <grass/gis.h>
\endverbatim
<b>Note</b>. All routines and global variables in this library,
@@ -72,7 +72,7 @@
library routines are called.
<P>
-int G_gisinit(char *program_name) initialize gis library
+int G_gisinit() initialize gis library
This routine reads the user's GRASS environment file into memory and
makes sure that the user has selected a valid database and mapset. It
@@ -95,11 +95,11 @@
report warning and error messages. They may also be used directly by
GRASS programs.
-<P> int G_fatal_error(char *message, ...) print error message and exit
+<P> int G_fatal_error() print error message and exit
-<P> int G_debug(level, char *message, ...) print debug message
+<P> int G_debug() print debug message
-<P> int G_warning(char *message, ...) print warning message and continue
+<P> int G_warning() print warning message and continue
These routines report errors to the user. The normal mode is to write
the <B>message</B> to the screen (on the standard error output) and
@@ -122,7 +122,7 @@
used to modify the error handling:
<P>
-int G_set_error_routine(int (*handler)()) change error handling
+int G_set_error_routine() change error handling
This routine provides a different error handler for G_fatal_error()
and G_warning(). The <B>handler</B> routine must be defined as follows:
@@ -146,13 +146,13 @@
<I>G_warning()</I> back to the default action.
<P>
-int G_sleep_on_error(int flag) sleep on error?
+int G_sleep_on_error() sleep on error?
If <B>flag</B> is 0, then no pause will occur after printing an error
or warning message. Otherwise the pause will occur.
<P>
-int G_suppress_warnings(int flag) suppress warnings?
+int G_suppress_warnings() suppress warnings?
If <B>flag</B> is 0, then <I>G_warning()</I> will no longer print
warning messages. If <B>flag</B> is 1, then G_warning() will print
@@ -253,10 +253,10 @@
above.</B>
<P>
-int G_getenv(char *name) query GRASS environment variable
+int G_getenv() query GRASS environment variable
<P>
-int G__getenv(char *name) query GRASS environment variable
+int G__getenv() query GRASS environment variable
These routines look up the variable <B>name</B> in the GRASS
environment and return its value (which is a character string). If
@@ -264,11 +264,11 @@
exit(). G__setenv() just returns the NULL pointer.
<P>
-int G_setenv (char *name, char *value) set GRASS environment
+int G_setenv () set GRASS environment
variable
<P>
-int G__setenv(char *name, char *value) set GRASS environment variable
+int G__setenv() set GRASS environment variable
These routines set the the GRASS environment variable <B>name</B>
to <B>value.</B> If <B>value</B> is NULL, the <B>name</B> is unset.
@@ -350,8 +350,7 @@
The last line of the prompt can be modified using G_set_ask_return_msg().
<P>
-char * G_ask_old(char *prompt, char *name, char *element, char *label)
-prompt for existing database file
+char * G_ask_old() prompt for existing database file
The user is asked to enter the name of an existing database file.
@@ -362,8 +361,7 @@
more details about the search path.
<P>
-char * G_ask_new(char *prompt, char *name, char *element, char
- *label) prompt for new database file
+char * G_ask_new() prompt for new database file
The user is asked to enter the name of a new file which does not exist
in the current mapset.
@@ -374,8 +372,7 @@
files are always created in the current mapset.
<P>
-char * G_ask_in_mapset(char *prompt, char *name, char *element, char
- *label) prompt for existing database file
+char * G_ask_in_mapset() prompt for existing database file
The user is asked to enter the name of an file which exists in the
current mapset.
@@ -387,8 +384,7 @@
only permits users to modify files in the current mapset.
<P>
-char * G_ask_any(char *prompt, char *name, char *element, char
- *label, int warn) prompt for any valid file name
+char * G_ask_any() prompt for any valid file name
The user is asked to enter any legal file name. If <B>warn</B> is 1
and the file chosen exists in the current mapset, then the user is
@@ -397,7 +393,7 @@
file exists.
<P>
-int G_set_ask_return_msg(char *msg) set Hit RETURN msg
+int G_set_ask_return_msg() set Hit RETURN msg
The "Hit RETURN to cancel request" part of the prompt in the prompting
routines described above, is modified to "Hit RETURN <B>msg.</B>"
@@ -420,7 +416,7 @@
file name</I> and is built by the following routine:
<P>
-char * G_fully_qualified_name(char *name, char *mapset) fully
+char * G_fully_qualified_name() fully
qualified file name
Returns a fully qualified name for the file <B>name</B> in
@@ -433,7 +429,7 @@
interfaces with the command-line version of <I>d.rast</I>:
\verbatim
-#include "gis.h"
int main(char *argc, char **argv)
char name[GNAME_MAX], *mapset, *fqn;
@@ -463,7 +459,7 @@
The following routines search the database for files:
<P>
-char * G_find_file(char *element, char *name, char *mapset) find a
+char * G_find_file() find a
database file
Look for the file <B>name</B> under the specified <B>element</B> in
@@ -520,7 +516,7 @@
legal. The following routine checks for legal file names:
<P>
-int G_legal_filename(char *name) check for legal database file
+int G_legal_filename() check for legal database file
names
Returns 1 if <B>name</B> is ok, -1 otherwise.
@@ -537,8 +533,7 @@
G_find_file().</I>
<P>
-int G_open_old(char *element, char *name, char *mapset) open a
-database file for reading
+int G_open_old() open a database file for reading
The database file <B>name</B> under the
<B>element</B> in the specified <B>mapset</B> is opened for reading (but
@@ -549,8 +544,7 @@
-1 is returned. Otherwise the file descriptor from the open() is returned.
<P>
-FILE * G_fopen_old(char *element, char *name, char *mapset) open a
- database file for reading
+FILE * G_fopen_old() open a database file for reading
@@ -572,8 +566,7 @@
G_ask_in_mapset(), and noninteractively using G_find_file().</I>
<P>
-int G_open_update(char *element, char *name) open a database file
- for update
+int G_open_update() open a database file for update
The database file <B>name</B> under the <B>element</B> in the
current mapset is opened for reading and writing.
@@ -584,8 +577,7 @@
<P>
-int G_fopen_append(char *element, char *name) open a database file for
-update
+int G_fopen_append() open a database file for update
The database file <B>name</B> under the <B>element</B> in the current
mapset is opened for appending (but not for reading).
@@ -619,7 +611,7 @@
<B>name</B> exists.
<P>
-int G_open_new(char *element, char *name) open a new database file
+int G_open_new() open a new database file
mapset is created and opened for writing (but not reading).
@@ -630,7 +622,7 @@
the file and the file descriptor from the open() is returned.
<P>
-FILE * G_fopen_new(char *element, char *name) open a new database file
+FILE * G_fopen_new() open a new database file
@@ -651,7 +643,7 @@
mapset since GRASS does permit users to modify things in mapsets other
than the current mapset; see \ref Database_Access_Rules).
-int G_rename(char *element, char *old, char *new) rename a database
+int G_rename() rename a database
file
The file or directory <B>old</B> under the database <B>element</B>
@@ -666,7 +658,7 @@
valid database file name.
<P>
-int G_remove(char *element, char *name) remove a database file
+int G_remove() remove a database file
The file or directory <B>name</B> under the database <B>element</B> directory
in the current mapset is removed.
@@ -701,19 +693,19 @@
routines.
<P>
-int G_free(void *buf) free the memory allocated
+int G_free() free the memory allocated
Free the memory allocated by the GRASS malloc routines.
<P>
-void * G_malloc (int size) memory allocation
+void * G_malloc () memory allocation
Allocates a block of memory at least <B>size</B> bytes which is
aligned properly for all data types. A pointer to the aligned block is
returned.
<P>
-void * G_realloc(void *ptr, int size) memory allocation
+void * G_realloc() memory allocation
Changes the <B>size</B> of a previously allocated block of memory at
<B>ptr</B> and returns a pointer to the new block of memory. The
@@ -727,7 +719,7 @@
realloc() routines, which do not handle a NULL <B>ptr.</B>
<P>
-void * G_calloc(int n, int size) memory allocation
+void * G_calloc() memory allocation
Allocates a properly aligned block of memory <B>n</B>*<B>size</B>
bytes in length, initializes the allocated memory to zero, and returns
@@ -738,39 +730,39 @@
discussed in Allocating_Raster_I_O_Buffers.
<P>
-double * G_alloc_vector(int n) memory allocation
+double * G_alloc_vector() memory allocation
Allocate a vector (array) of <B>n</B> doubles initialized to zero.
<P>
-float * G_alloc_fvector(int n) memory allocation
+float * G_alloc_fvector() memory allocation
Allocate a vector (array) of <B>n</B> floats initialized to zero.
<P>
-double ** G_alloc_matrix(int rows, int cols) memory allocation
+double ** G_alloc_matrix() memory allocation
Allocate a matrix of <B>rows</B> by <B>cols</B> doubles initialized to
zero.
<P>
-float ** G_alloc_fmatrix(int rows, int cols) memory allocation
+float ** G_alloc_fmatrix() memory allocation
Allocate a matrix of <B>rows</B> by <B>cols</B> floats initialized to
zero.
<P>
-int G_free_vector(double *v) memory deallocation
+int G_free_vector() memory deallocation
Deallocate a vector (array) of doubles or floats.
<P>
-int G_free_matrix(double **m) memory deallocation
+int G_free_matrix() memory deallocation
Deallocate a matrix of doubles.
<P>
-int G_free_fmatrix(float **m) memory deallocation
+int G_free_fmatrix() memory deallocation
Deallocate a matrix of floats.
@@ -808,7 +800,7 @@
probably be used instead.)]
<P>
-int G_get_window(struct Cell_head *region) read the database region
+int G_get_window() read the database region
Reads the database region as stored in the WIND file in the user's
current mapset <B>into region.</B>
@@ -825,7 +817,7 @@
G_window_rows() and G_window_cols().</I>
<P>
-int G_put_window(struct Cell_head *region) write the database region
+int G_put_window() write the database region
Writes the database region file (WIND) in the user's current mapset
from <B>region.</B> Returns 1 if the region is written ok. Returns -1
if not (no diagnostic message is printed).
@@ -847,7 +839,7 @@
following routine reads this region:
<P>
-int G_get_default_window(struct Cell_head *region) read the default
+int G_get_default_window() read the default
region
Reads the default region for the location into <B>region.</B>
@@ -895,7 +887,7 @@
\endverbatim
<P>
-int G_set_window(struct Cell_head *region) set the active region
+int G_set_window() set the active region
This routine sets the active region from <B>region.</B> Setting the
active region does not change the WIND file in the database. It simply
@@ -927,8 +919,7 @@
files.
<P>
-int G_get_set_window(struct Cell_head *region) get the active
- region
+int G_get_set_window() get the active region
Gets the values of the currently active region into <B>region.</B> If
<I>G_set_window()</I> has been called, then the values set by that call
@@ -943,8 +934,7 @@
is really needed before using this routine.
<P>
-char * G_align_window(struct Cell_head *region, struct Cell_head *ref)
-align two regions
+char * G_align_window() align two regions
Modifies the input <B>region</B> to align to the <B>ref</B>
region. The resolutions in <B>region</B> are set to match those in
@@ -960,8 +950,7 @@
This routine returns NULL if ok, otherwise it returns an error message.
<P>
-double G_col_to_easting(double col, struct Cell_head *region) column
-to easting
+double G_col_to_easting() column to easting
Converts a <B>col</B>umn relative to a <B>region</B> to an easting;
@@ -972,8 +961,7 @@
eastern edge of the column.
<P>
-double G_row_to_northing(double row, struct Cell_head *region) row to
-northing
+double G_row_to_northing() row to northing
Converts a <B>row</B> relative to a <B>region</B> to a northing;
@@ -983,8 +971,7 @@
edge of the row; and row+1.0 will return the northing for the southern
edge of the row.
-double G_easting_to_col(double east, struct Cell_head *region) easting
-to column
+double G_easting_to_col() easting to column
<P>
Converts an <B>east</B>ing relative to a <B>region</B> to a column.
@@ -994,8 +981,7 @@
give the column number.
<P>
-double G_northing_to_row(double north, struct Cell_head *region)
-northing to row
+double G_northing_to_row() northing to row
Converts a <B>north</B>ing relative to a <B>region</B> to a row.
@@ -1029,15 +1015,14 @@
99 Other (more than 121 projections are supported)
<P>
-char * G_database_projection_name(int proj) query cartographic
-projection
+char * G_database_projection_name() query cartographic projection
Returns a pointer to a string which is a printable name for projection
code <B>proj</B> (as returned by <I>G_projection()</I>). Returns NULL if
<B>proj</B> is not a valid projection.
<P>
-char * G_database_unit_name(int plural) database units
+char * G_database_unit_name() database units
Returns a string describing the database grid units. It returns a
plural form (eg. feet) if <B>plural</B> is true. Otherwise it returns
@@ -1110,43 +1095,37 @@
Otherwise, a standard floating-point to ASCII conversion is made.
<P>
-int G_format_easting(double east, char *buf, int projection) easting
-to ASCII
+int G_format_easting() easting to ASCII
Converts the double representation of the <B>east</B> coordinate to
its ASCII representation (into <B>buf</B>).
<P>
-int G_format_northing(double north, char *buf, int projection)
-northing to ASCII
+int G_format_northing() northing to ASCII
Converts the double representation of the <B>north</B> coordinate to
<P>
-int G_format_resolution(double resolution, char *buf, int projection)
-resolution to ASCII
+int G_format_resolution() resolution to ASCII
Converts the double representation of the <B>resolution</B> to its
<P>
-int G_scan_easting(char *buf, double *easting, int projection) ASCII
-easting to double
+int G_scan_easting() ASCII easting to double
Converts the ASCII "easting" coordinate string in <B>buf</B> to its
double representation (into <B>easting</B>).
<P>
-int G_scan_northing(char *buf, double *northing, int projection) ASCII
-northing to double
+int G_scan_northing() ASCII northing to double
Converts the ASCII "northing" coordinate string in <B>buf</B> to its
double representation (into <B>northing</B>).
<P>
-int G_scan_resolution(char *buf, double *resolution, int projection)
-ASCII resolution to double
+int G_scan_resolution() ASCII resolution to double
Converts the ASCII "resolution" string in <B>buf</B> to its double
representation (into resolution).
@@ -1188,15 +1167,14 @@
area. Otherwise the area of a grid cell varies with the row.
<P>
-double G_area_of_cell_at_row(int row) cell area in specified row
+double G_area_of_cell_at_row() cell area in specified row
This routine returns the area in square meters of a cell in the
specified <B>row.</B> This value is constant for planimetric grids and
varies with the row if the projection is latitude-longitude.
<P>
-int G_begin_zone_area_on_ellipsoid(double a, double e2, double s)
-begin area calculations for ellipsoid
+int G_begin_zone_area_on_ellipsoid() begin area calculations for ellipsoid
Initializes raster area calculations for an ellipsoid, where <B>a</B>
is the semi-major axis of the ellipse (in meters), <B>e2</B> is the
@@ -1210,15 +1188,14 @@
zero implies a sphere.
<P>
-double G_area_for_zone_on_ellipsoid(double north, double south) area
-between latitudes
+double G_area_for_zone_on_ellipsoid() area between latitudes
Returns the area between latitudes <B>north</B> and <B>south</B>
scaled by the factor <B>s</B> passed to
<I>G_begin_zone_area_on_ellipsoid().</I>
<P>
-int G_begin_zone_area_on_sphere(double r, double s) initialize
+int G_begin_zone_area_on_sphere() initialize
calculations for sphere
Initializes raster area calculations for a sphere. The radius of the
@@ -1227,8 +1204,7 @@
<I>G_begin_zone_area_on_ellipsoid()</I>).
<P>
-double G_area_for_zone_on_sphere(double north, double south) area
-between latitudes
+double G_area_for_zone_on_sphere() area between latitudes
@@ -1271,8 +1247,7 @@
metric (e.g. imagery.)
<P>
-double G_area_of_polygon(double *x, double *y, int n) area in square
-meters of polygon
+double G_area_of_polygon() area in square meters of polygon
Returns the area in square meters of the polygon described by the
<B>n</B> pairs of <B>x,y</B> coordinate vertices. It is used both for
@@ -1292,16 +1267,14 @@
feet, and so on.
<P>
-int G_begin_ellipsoid_polygon_area (double a, double e2) begin area
-calculations
+int G_begin_ellipsoid_polygon_area () begin area calculations
This initializes the polygon area calculations for the ellipsoid with
semi-major axis <B>a</B> (in meters) and ellipsoid eccentricity
squared <B>e2.</B>
<P>
-double G_ellipsoid_polygon_area(double *lon, double *lat, int n) area
-of lat-long polygon
+double G_ellipsoid_polygon_area() area of lat-long polygon
<B>n</B> pairs of <B>lat,long</B> vertices for latitude-longitude
@@ -1329,7 +1302,7 @@
metric (e.g. imagery).
<P>
-double G_distance(double x1, y1, x2, y2) distance in meters
+double G_distance() distance in meters
This routine computes the distance, in meters, from <B>x1,y1</B> to
<B>x2,y2.</B> If the projection is latitude-longitude, this distance
@@ -1337,8 +1310,7 @@
calculations.
<P>
-int G_begin_geodesic_distance(double a, double e2) begin geodesic
-distance
+int G_begin_geodesic_distance() begin geodesic distance
Initializes the distance calculations for the ellipsoid with
@@ -1346,8 +1318,7 @@
projection.
<P>
-double G_geodesic_distance(double lon1, double lat1, double lon2,
-double lat2) geodesic distance
+double G_geodesic_distance() geodesic distance
Calculates the geodesic distance from <B>lon1,lat1</B> to
<B>lon2,lat2</B> in meters.
@@ -1358,20 +1329,17 @@
fixed latitudes and varying longitude separation.
<P>
-int G_set_geodesic_distance_lat1(double lat1) set geodesic
- distance lat1
+int G_set_geodesic_distance_lat1() set geodesic distance lat1
Set the first latitude.
<P>
-int G_set_geodesic_distance_lat2(double lat2) set geodesic
- distance lat2
+int G_set_geodesic_distance_lat2() set geodesic distance lat2
Set the second latitude.
<P>
-double G_geodesic_distance_lon_to_lon(double lon1, double lon2)
-geodesic distance
+double G_geodesic_distance_lon_to_lon() geodesic distance
<B>lon2,lat2</B> in meters, where <B>lat1</B> was the latitude passed
@@ -1389,8 +1357,7 @@
some adjustment of coordinates is necessary.
<P>
-double G_adjust_easting(double east, struct Cell_head *region) returns
-east larger than west
+double G_adjust_easting() returns east larger than west
If the region projection is PROJECTION_LL, then this routine returns
an equivalent <B>east</B> that is larger, but no more than 360 degrees
@@ -1399,7 +1366,7 @@
is returned.
<P>
-double G_adjust_east_longitude(double east, double west) adjust east
+double G_adjust_east_longitude() adjust east
longitude
This routine returns an equivalent <B>east</B> that is larger, but no
@@ -1409,8 +1376,7 @@
This routine should be used only with latitude-longitude coordinates.
<P>
-int G_shortest_way(double *east1, double *east2) shortest way between
-eastings
+int G_shortest_way() shortest way between eastings
If the database projection is PROJECTION_LL, then <B>east1,east2</B>
are changed so that they are no more than 180 degrees apart. Their
@@ -1421,7 +1387,7 @@
\subsection Miscellaneous Miscellaneous
-char * G_ellipsoid_name(int n) return ellipsoid name
+char * G_ellipsoid_name() return ellipsoid name
This routine returns a pointer to a string containing the name for the
<B>n</B><I>th</I> ellipsoid in the GRASS ellipsoid table; NULL when
@@ -1436,16 +1402,14 @@
\endverbatim
<P>
-int G_get_ellipsoid_by_name(char *name, double *a, double *e2) get
-ellipsoid by name
+int G_get_ellipsoid_by_name() get ellipsoid by name
This routine returns the semi-major axis <B>a</B> (in meters) and
eccentricity squared <B>e2</B> for the named ellipsoid. Returns 1 if
<B>name</B> is a known ellipsoid, 0 otherwise.
<P>
-int G_get_ellipsoid_parameters(double *a, double *e2) get ellipsoid
-parameters
+int G_get_ellipsoid_parameters() get ellipsoid parameters
This routine returns the semi-major axis <B>a</B> (in meters) and the
eccentricity squared <B>e2</B> for the ellipsoid associated with the
@@ -1453,8 +1417,7 @@
database, it returns the values for the WGS 84 ellipsoid.
<P>
-double G_meridional_radius_of_curvature(double lon, double a, double
-e2) meridional radius of curvature
+double G_meridional_radius_of_curvature() meridional radius of curvature
Returns the meridional radius of curvature at a given longitude:
@@ -1464,8 +1427,7 @@
<P>
-double G_transverse_radius_of_curvature(double lon, double a, double
-e2) transverse radius of curvature
+double G_transverse_radius_of_curvature() transverse radius of curvature
Returns the transverse radius of curvature at a given longitude:
@@ -1474,8 +1436,7 @@
\f$
<P>
-double G_radius_of_conformal_tangent_sphere(double lon, double a,
-double e2) radius of conformal tangent sphere
+double G_radius_of_conformal_tangent_sphere() radius of conformal tangent sphere
Returns the radius of the conformal sphere tangent to ellipsoid at a
given longitude:
@@ -1485,7 +1446,7 @@
\f$
<P>
-int G_pole_in_polygon(double *x, double *y, int n) pole in polygon
+int G_pole_in_polygon() pole in polygon
For latitude-longitude coordinates, this routine determines if the
polygon defined by the <B>n</B> coordinate vertices <B>x,y</B>
@@ -1518,8 +1479,7 @@
and polygon plotting capability.
<P>
-int G_bresenham_line(int x1, int y1, int x2, int y2, int (*point)())
-Bresenham line algorithm
+int G_bresenham_line() Bresenham line algorithm
Draws a line from <B>x1,y1</B> to <B>x2,y2</B> using Bresenham's
algorithm. A routine to plot points must be provided, as is defined
@@ -1533,8 +1493,7 @@
function correctly, and is independent of all following routines.
<P>
-int G_setup_plot(double t, double b, double l, double r, nt (*Move)(),
- int (*Cont)()) initialize plotting routines
+int G_setup_plot() initialize plotting routines
Initializes the plotting capability. This routine must be called once
before calling the <B>G_plot_*()</B> routines described below.
@@ -1561,8 +1520,7 @@
to x,y. Cont() is responsible for clipping
<P>
-int G_plot_line(double east1, double north1, double east2, double
-north2) plot line between latlon coordinates
+int G_plot_line() plot line between latlon coordinates
A line from <B>east1,north1</B> to <B>east2,north2</B> is plotted in
output x,y coordinates (e.g. pixels for graphics.) This routine
@@ -1573,7 +1531,7 @@
procedure.
<P>
-int G_plot_polygon(double *east, double *north, int n) plot filled
+int G_plot_polygon() plot filled
polygon with n vertices
The polygon, described by the <B>n</B> vertices <B>east,north</B>, is
@@ -1584,8 +1542,7 @@
procedure.
<P>
-int G_plot_area(double **xs, double **ys, int *npts, int rings) plot
-multiple polygons
+int G_plot_area() plot multiple polygons
Like G_plot_polygon(), except it takes a set of polygons, each with
<B>npts[<I>i</I>]</B> vertices, where the number of polygons is
@@ -1593,8 +1550,7 @@
plotting vector areas with interior islands.
<P>
-int G_plot_where_en(int x, int y, double *east, double *north) x,y
-to east,north
+int G_plot_where_en() x,y to east,north
The pixel coordinates <B>x,y</B> are converted to map coordinates
<B>east,north.</B>
@@ -1604,8 +1560,7 @@
procedure.
<P>
-int G_plot_where_xy(double *east, double *north, int *x, int *y)
-east,north to x,y
+int G_plot_where_xy() east,north to x,y
The map coordinates <B>east,north</B> are converted to pixel
coordinates <B>x,y.</B>
@@ -1615,8 +1570,7 @@
procedure.
<P>
-int G_plot_fx(double (*f)(), double east1, double east2) plot
- f(east1) to f(east2)
+int G_plot_fx() plot f(east1) to f(east2)
The function <B>f(east)</B> is plotted from <B>east1</B> to
<B>east2.</B> The function <B>f(east)</B> must return the map northing
@@ -1797,7 +1751,7 @@
memory (of <I>type struct Flag *).</I>
<P>
-int G_parser(int argc, char *argv[]) parse command line
+int G_parser() parse command line
The command line parameters <B>argv</B> and the number of parameters
<B>argc</B> from the main() routine are passed directly to
@@ -1879,7 +1833,7 @@
defined in Parser_Routines.
\verbatim
-#include "gis.h" ; /* The standard GRASS include file */
+#include <grass/gis.h> ; /* The standard GRASS include file */
struct Option *opt ; /* Establish an Option pointer for each option */
struct Flag *flag ; /* Establish a Flag pointer for each option */
@@ -2061,7 +2015,7 @@
\verbatim
#include <stdlib.h>
#include <string.h>
-#include "gis.h"
#include "glocale.h"
int
@@ -2766,13 +2720,13 @@
These next 3 routines copy characters from one string to another.
<P>
-char * G_strcpy(char *dst, char *src)copy strings
+char * G_strcpy()copy strings
Copies the <B>src</B> string to <B>dst</B> up to and including the
NULL which terminates the <B>src</B> string. Returns <B>dst.</B>
<P>
-char * G_strncpy(char *dst, char *src, int n) copy strings
+char * G_strncpy() copy strings
Copies at most <B>n</B> characters from the <B>src</B> string to
<B>dst.</B> If <B>src</B> contains less than <B>n</B> characters, then
@@ -2783,7 +2737,7 @@
terminated, while strncpy() does not.
<P>
-char * G_strcat(char *dst, char *src) concatenate strings
+char * G_strcat() concatenate strings
Appends the <B>src</B> string to the end of the <B>dst</B> string,
which is then NULL terminated. Returns <B>dst.</B>
@@ -2792,7 +2746,7 @@
These next 3 routines remove unwanted white space from a single string.
<P>
-char * G_squeeze(char *s) remove unnecessary white space
+char * G_squeeze() remove unnecessary white space
Leading and trailing white space is removed from the string <B>s</B>
and internal white space which is more than one character is reduced
@@ -2800,21 +2754,20 @@
linefeeds, newlines, and formfeeds. Returns <B>s.</B>
<P>
-void G_strip(char *s) remove leading/training white space
+void G_strip() remove leading/training white space
Leading and trailing white space is removed from the string <B>s.</B>
White space here means only spaces and tabs. There is no return value.
<P>
-char * G_chop(char *s) Chop leading and trailing white spaces:
+char * G_chop() Chop leading and trailing white spaces:
space, \f, \n, \r, \t, \v - returns pointer to string
<P>
The next routines replaces character(s) from string.
<P>
-char * G_strchg(char *bug, char character, char new) replace
-character(s)
+char * G_strchg() replace character(s)
Replace all occurencies of character in string bug with new. Returns
changed string
@@ -2823,7 +2776,7 @@
This next routine copies a string to allocated memory.
<P>
-char * G_store(char *s) copy string to allocated memory
+char * G_store() copy string to allocated memory
This routine allocates enough memory to hold the string <B>s</B>,
copies <B>s</B> to the allocated memory, and returns a pointer to the
@@ -2833,13 +2786,13 @@
The next 2 routines convert between upper and lower case.
<P>
-char * G_tolcase(char *s) convert string to lower case
+char * G_tolcase() convert string to lower case
Upper case letters in the string <B>s</B> are converted to their lower
case equivalent. Returns <B>s.</B>
<P>
-char * G_toucase(char *s) convert string to upper case
+char * G_toucase() convert string to upper case
Lower case letters in the string <B>s</B> are converted to their upper
@@ -2848,7 +2801,7 @@
And finally a routine which gives a printable version of control characters.
<P>
-char * G_unctrl(unsigned char c) printable version of control
+char * G_unctrl() printable version of control
character
This routine returns a pointer to a string which contains an
@@ -2879,18 +2832,18 @@
<I>FOLLOWING new FUNCTIONS need to be merged into the flow of this text:</I>
<P>
-int G_trim_decimal(char *buf) trim
+int G_trim_decimal() trim
This routine remove trailing zeros from decimal number for example:
23.45000 would come back as 23.45
<P>
-char * G_index(str, delim) delimiter
+char * G_index() delimiter
Position of delimiter
<P>
-char * G_rindex (str, delim) ??????
+char * G_rindex () ??????
<P>
int G_strcasecmp(char *a, char *b) string compare ignoring case (upper or lower)
@@ -2901,12 +2854,12 @@
1 if a>b
<P>
-char * G_strstr(char *mainString, char *subString)Return a pointer
+char * G_strstr() Return a pointer
to the first occurrence of subString in mainString, or NULL if no occurrences
are found
<P>
-char * G_strdup(char *string) Return a pointer to a string that is a
+char * G_strdup() Return a pointer to a string that is a
duplicate of the string given to G_strdup. The duplicate is created
using malloc. If unable to allocate the required space, NULL is
returned.
@@ -2998,7 +2951,7 @@
allows this.
<P>
-int G_system(command) run a shell level command
+int G_system() run a shell level command
The shell level <B>command</B> is executed. Interrupt signals for the
parent module are ignored during the call. Interrupt signals for the
@@ -3056,7 +3009,7 @@
Volume 1, 2nd edition. Prentice Hall).
<P>
-char * G_sock_get_fname(char *name) makes full socket path
+char * G_sock_get_fname() makes full socket path
Takes a simple <B>name</B> for a communication channel and builds the
full path for a sockets file with that <B>name</B>. The path as of
@@ -3067,7 +3020,7 @@
string when it is no longer needed.
<P>
-int G_sock_exists(char *name) does the socket exist
+int G_sock_exists() does the socket exist
Takes the full path to a unix socket; determines if the file exists;
and if the file exists whether it is a socket file or not. Returns a
@@ -3075,7 +3028,7 @@
returns zero.
<P>
-int G_sock_bind(char *name) binds the socket
+int G_sock_bind() binds the socket
Takes the full path to a unix socket and attempts to bind a file
descriptor to the path <B>name</B>. If successful it will return the
@@ -3095,8 +3048,7 @@
<B>G_sock_listen()</B> and <B>G_sock_accept()</B>.
<P>
-int G_sock_listen(int fd, unsigned int queue) listen on a
-socket
+int G_sock_listen() listen on a socket
Takes the file descriptor returned by a successful call to
<B>G_sock_bind()</B> and the length of the the listen queue. A
@@ -3111,7 +3063,7 @@
wrapper around the system <B>listen()</B> function.
<P>
-int G_sock_accept(int fd) accept a connection on the listening
+int G_sock_accept() accept a connection on the listening
socket
@@ -3131,8 +3083,7 @@
second and third arguments being <B>NULL</B>.
<P>
-int G_sock_connect(char *name) make a connection to a
-server process
+int G_sock_connect() make a connection to a server process
Takes the full path to a socket file and attempts to make a connection
to a server listening for connections. If successful, the file
@@ -3152,7 +3103,7 @@
#include <stdio.h>
#include <stdlib.h>
#include <errno.h>
-#include "gis.h"
int main (int argc, char *argv[])
@@ -3235,7 +3186,7 @@
format is the same as that produced by the UNIX <I>date</I> command.
<P>
-char * G_gets(char *buf) get a line of input (detect ctrl-z)
+char * G_gets() get a line of input (detect ctrl-z)
This routine does a <I>gets()</I> from stdin into <B>buf.</B> It exits
if end-of-file is detected. If stdin is a tty (i.e., not a pipe or
@@ -3313,7 +3264,7 @@
Returns a pointer to a string which is the user's login name.
<P>
-int G_yes(char *question, int default) ask a yes/no question
+int G_yes() ask a yes/no question
This routine prints a <B>question</B> to the user, and expects the
user to respond either yes or no. (Invalid responses are rejected and
@@ -3524,7 +3475,7 @@
\section TimeStamp_functions Timestamp functions
\verbatim
- #include "gis.h"
+ #include <grass/gis.h>
\endverbatim
@@ -3583,21 +3534,21 @@
<P>
-int G_init_timestamp(struct TimeStamp *ts)
+int G_init_timestamp()
Sets ts->count = 0, to indicate no valid DateTimes are in TimeStamp.
<P>
-int G_set_timestamp(struct TimeStamp *ts, DateTime *dt) Copies a
+int G_set_timestamp() Copies a
single DateTime to a TimeStamp in preparation for writing. (overwrites any
existing information in TimeStamp)
<P>
-int G_set_timestamp_range(struct TimeStamp *ts, DateTime *dt1, DateTime *dt2)
+int G_set_timestamp_range()
Copies two DateTimes (a range) to a TimeStamp in preparation for writing.
(overwrites any existing information in TimeStamp)
<P>
-int G_write_raster_timestamp(char *name, struct TimeStamp *ts)
+int G_write_raster_timestamp()
Returns:
<br>
@@ -3611,7 +3562,7 @@
<P>
-int G_write_vector_timestamp(char *name, struct TimeStamp *ts)
+int G_write_vector_timestamp()
Returns:
<br>
@@ -3625,7 +3576,7 @@
<P>
-int G_format_timestamp(struct TimeStamp *ts, char *buf)
+int G_format_timestamp()
Returns:
<br>
@@ -3636,7 +3587,7 @@
<P>
-int G_scan_timestamp(struct TimeStamp *ts, char *buf)
+int G_scan_timestamp()
Returns:
<br>
@@ -3647,7 +3598,7 @@
<P>
-int G_remove_raster_timestamp(char *name)
+int G_remove_raster_timestamp()
Only timestamp files in current mapset can be removed
<P>
@@ -3664,7 +3615,7 @@
<P>
-int G_remove_vector_timestamp(char *name)
+int G_remove_vector_timestamp()
<P>
@@ -3681,13 +3632,12 @@
<P>
-int G_read_grid3_timestamp(char *name,char *mapset, struct
- TimeStamp *ts) read grid3 timestamp
+int G_read_grid3_timestamp() read grid3 timestamp
Returns 1 on success. 0 or negative on error.
<P>
-int G_remove_grid3_timestamp(char *name) remove grid3
+int G_remove_grid3_timestamp() remove grid3
timestamp
@@ -3706,8 +3656,7 @@
<P>
-int G_write_grid3_timestamp(char *name,
- struct TimeStamp *ts) write grid3 timestamp
+int G_write_grid3_timestamp() write grid3 timestamp
Returns:
