[GRASS-SVN] r34347 - grass/branches/develbranch_6/lib/imagery
svn_grass at osgeo.org
Mon Nov 17 16:54:15 EST 2008
Author: neteler
Date: 2008-11-17 16:54:15 -0500 (Mon, 17 Nov 2008)
New Revision: 34347
grass/branches/develbranch_6/lib/imagery/Makefile
grass/branches/develbranch_6/lib/imagery/imagerylib.dox
doxygen updated
Modified: grass/branches/develbranch_6/lib/imagery/Makefile
--- grass/branches/develbranch_6/lib/imagery/Makefile 2008-11-17 21:54:08 UTC (rev 34346)
+++ grass/branches/develbranch_6/lib/imagery/Makefile 2008-11-17 21:54:15 UTC (rev 34347)
@@ -3,8 +3,11 @@
LIB_NAME = $(IMAGERY_LIBNAME)
include $(MODULE_TOPDIR)/include/Make/Lib.make
+include $(MODULE_TOPDIR)/include/Make/Doxygen.make
EXTRA_LIBS = $(GMATHLIB) $(GISLIB)
default: lib
+#doxygen:
+DOXNAME=imagery
Modified: grass/branches/develbranch_6/lib/imagery/imagerylib.dox
--- grass/branches/develbranch_6/lib/imagery/imagerylib.dox 2008-11-17 21:54:08 UTC (rev 34346)
+++ grass/branches/develbranch_6/lib/imagery/imagerylib.dox 2008-11-17 21:54:15 UTC (rev 34347)
@@ -10,38 +10,31 @@
routines that provide access to the <I>group</I> database structure
which was also introduced in GRASS 3.0 for the same purpose. It is
assumed that the reader has read Database_Structure for a general
-description of GRASS databases, Image_Data_Groups for a description of
-imagery groups, and Raster_Maps for details about map layers in
-GRASS. The routines in the Imagery_Library are presented in functional
+description of GRASS databases, \ref Image_Data_Groups for a description of
+imagery groups, and \ref Raster_Maps for details about map layers in
+GRASS. The routines in the \ref Imagery_Library are presented in functional
groupings, rather than in alphabetical order. The order of
presentation will, it is hoped, provide a better understanding of how
the library is to be used, as well as show the interrelationships
among the various routines. Note that a good way to understand how to
use these routines is to look at the source code for GRASS modules
which use them. Most routines in this library require that the header
-file "imagery.h" be included in any code using these
+file <grass/imagery.h> be included in any code using these
routines. Therefore, programmers should always include this file when
writing code using routines from this library:
\verbatim
-#include "imagery.h"
+#include <grass/imagery.h>
\endverbatim
<P>
-This header file includes the "gis.h" header file as well.
-<P>
<B>Note.</B> All routines and global variables in this library,
documented or undocumented, start with the prefix <B>I_.</B> To avoid
name conflicts, programmers should not create variables or routines in
their own modules which use this prefix.
-<P>
-An alphabetic index is provided in Appendix_E_Index_to_Imagery_Library
\subsection Group_Processing Group Processing
The group is the key database structure which permits integration of
image processing in GRASS.
@@ -69,28 +62,14 @@
user cancels the request, 0 is returned; otherwise, 1 is returned.
<P>
-int I_ask_group_old(char *prompt, char *group) prompt for an existing
-group
+int I_ask_group_old() prompt for an existing group
Asks the user to enter the name of an existing <B>group</B> in the
current mapset.
<P>
-int I_ask_group_new(char *prompt, char *group) prompt for new group
-Asks the user to enter a name for a <B>group</B> which does not exist
-in the current mapset.
-<P>
-int I_ask_group_any(char *prompt, char *group) prompt for any
-valid group name
-Asks the user to enter a valid <B>group</B> name. The <B>group</B> may
-or may not exist in the current mapset.
-<P>
<B>Note.</B> The user is not warned if the <B>group</B> exists. The
-programmer should use <I>I_find_group</I> to determine if the
+programmer should use <I>I_find_group()</I> to determine if the
<P>
@@ -99,7 +78,7 @@
\verbatim
char group[INAME_LEN];
-\par
if ( ! I_ask_group_any ("Enter group to be processed", group))
exit(0);
\endverbatim
@@ -113,7 +92,7 @@
exists. The following routine provides this service:
<P>
-int I_find_group(char *group)does group exist?
+int I_find_group() does group exist?
Returns 1 if the specified <B>group</B> exists in the current mapset;
0 otherwise.
@@ -125,15 +104,14 @@
These routines provide access to the information contained in the REF
file for groups and subgroups, as well as routines to update this
information. They use the <I>Ref</I> structure, which is defined in
-the "imagery.h" header file; see \ref Imagery_Library_Data_Structures.
+the <grass/imagery.h> header file; see \ref Imagery_Library_Data_Structures.
<P>
The contents of the REF file are read or updated by the following
routines:
<P>
-int I_get_group_ref(char *group, struct Ref *ref) read group REF
- file
+int I_get_group_ref() read group REF file
Reads the contents of the REF file for the specified <B>group</B> into
the <B>ref</B> structure.
@@ -142,8 +120,7 @@
Returns 1 if successful; 0 otherwise (but no error messages are printed).
<P>
-int I_put_group_ref(char *group, struct Ref *ref) write group REF
-file
+int I_put_group_ref() write group REF file
Writes the contents of the <B>ref</B> structure to the REF file for
the specified <B>group.</B>
@@ -156,8 +133,7 @@
already exist.
<P>
-int I_get_subgroup_ref(char *group, char *subgroup, struct Ref
- *ref) read subgroup REF file
+int I_get_subgroup_ref() read subgroup REF file
Reads the contents of the REF file for the specified <B>subgroup</B>
of the specified <B>group</B> into the <B>ref</B> structure.
@@ -166,8 +142,7 @@
<P>
-int I_put_subgroup_ref(char *group, char *subgroup, struct Ref *ref)
-write subgroup REF file
+int I_put_subgroup_ref() write subgroup REF file
Writes the contents of the <B>ref</B> structure into the REF file for
the specified <B>subgroup</B> of the specified <B>group.</B>
@@ -183,19 +158,18 @@
These next routines manipulate the <I>Ref</I> structure:
<P>
-int I_init_group_ref(struct Ref *ref) initialize Ref structure
+int I_init_group_ref() initialize Ref structure
This routine initializes the <B>ref</B> structure for other library
calls which require a <I>Ref</I> structure. This routine must be
called before any use of the structure can be made.
<P>
-<B>Note.</B> The routines I_get_group_ref and I_get_subgroup_ref call
+<B>Note.</B> The routines I_get_group_ref() and I_get_subgroup_ref() call
this routine automatically.
<P>
-int I_add_file_to_group_ref(char *name, char *mapset, struct Ref *ref)
-add file name to Ref structure
+int I_add_file_to_group_ref() add file name to Ref structure
This routine adds the file <B>name</B> and <B>mapset</B> to the list
contained in the <B>ref</B> structure, if it is not already in the
@@ -206,12 +180,11 @@
<P>
Returns the index into the <I>file</I> array within the <B>ref</B>
-structure for the file after insertion; see
+structure for the file after insertion; see \ref
<P>
-int I_transfer_group_ref_file(struct Ref *src, int n, struct Ref
- *dst)copy Ref lists
+int I_transfer_group_ref_file() copy Ref lists
This routine is used to copy file names from one <I>Ref</I> structure
to another. The name and mapset for file <B>n</B> from the <B>src</B>
@@ -241,7 +214,7 @@
subgroup.
<P>
-int I_free_group_ref(struct Ref *ref) free Ref structure
+int I_free_group_ref() free Ref structure
This routine frees memory allocated to the <B>ref</B> structure.
@@ -251,8 +224,7 @@
The following two routines read and write the TARGET file.
<P>
-int I_get_target(char *group, char *location, char *mapset) read
-target information
+int I_get_target() read target information
Reads the target <B>location</B> and <B>mapset</B> from the TARGET
file for the specified group. Returns 1 if successful; 0 otherwise
@@ -264,8 +236,7 @@
<B>Note.</B> This routine does <B>not</B> validate the target information.
<P>
-int I_put_target(char *group, char *location, char *mapset) write
-target information
+int I_put_target() write target information
Writes the target <B>location</B> and <B>mapset</B> to the TARGET file
for the specified <B>group.</B> Returns 1 if successful; 0 otherwise
@@ -289,7 +260,7 @@
<P>
These routines use the <I>Control_Points</I> structure, which is
-defined in the "imagery.h" <I>header file</I>; see
+defined in the <grass/imagery.h> <I>header file</I>; see \ref
<P>
@@ -298,8 +269,7 @@
the structure is needed.
<P>
-int I_get_control_points(char *group, struct Control_Points *cp) read
-group control points
+int I_get_control_points() read group control points
Reads the control points from the POINTS file for the <B>group</B>
into the <B>cp</B> structure. Returns 1 if successful; 0 otherwise
@@ -310,8 +280,7 @@
invalid, or does not exist.
<P>
-int I_new_control_point(struct Control_Points *cp, double e1,
- double n1, double e2, double n2, int status) add new control point
+int I_new_control_point() add new control point
Once the control points have been read into the <B>cp</B> structure,
this routine adds new points to it. The new control point is given by
@@ -323,8 +292,7 @@
<P>
-int I_put_control_points(char *group, struct Control_Points *cp) write
+int I_put_control_points() write group control points
Writes the control points from the <B>cp</B> structure to the POINTS
@@ -365,7 +333,7 @@
\section Imagery_Library_Data_Structures Imagery Library Data Structures
-Some of the data structures in the "imagery.h" header file are
+Some of the data structures in the <grass/imagery.h> header file are
described below.
\subsection struct_Ref struct Ref
