[GRASS-SVN] r34360 - grass/branches/develbranch_6/vector/v.overlay
Tue Nov 18 06:26:43 EST 2008
Author: martinl
Date: 2008-11-18 06:26:43 -0500 (Tue, 18 Nov 2008)
New Revision: 34360
   grass/branches/develbranch_6/vector/v.overlay/main.c
v.overlay: don't use standardized parameter description (vector map A/B)
Modified: grass/branches/develbranch_6/vector/v.overlay/main.c
--- grass/branches/develbranch_6/vector/v.overlay/main.c	2008-11-18 11:09:33 UTC (rev 34359)
+++ grass/branches/develbranch_6/vector/v.overlay/main.c	2008-11-18 11:26:43 UTC (rev 34360)
@@ -9,7 +9,7 @@
  *               Markus Neteler <neteler itc.it>,
  *               Paul Kelly <paul-grass stjohnspoint.co.uk>
  * PURPOSE:
- * COPYRIGHT:    (C) 2003-2007 by the GRASS Development Team
+ * COPYRIGHT:    (C) 2003-2008 by the GRASS Development Team
  *               This program is free software under the GNU General Public
  *               License (>=v2). Read the file COPYING that comes with GRASS
@@ -56,25 +56,31 @@
     module->description = _("Overlays two vector maps.");
     in_opt[0] = G_define_standard_option(G_OPT_V_INPUT);
+    in_opt[0]->description = _("Name of input vector map (A)");
     in_opt[0]->key = "ainput";
     type_opt[0] = G_define_standard_option(G_OPT_V_TYPE);
+    type_opt[0]->label = _("Feature type (vector map A)");
     type_opt[0]->key = "atype";
     type_opt[0]->options = "line,area";
     type_opt[0]->answer = "area";
     field_opt[0] = G_define_standard_option(G_OPT_V_FIELD);
+    field_opt[0]->label = _("Layer number (vector map A)");
     field_opt[0]->key = "alayer";
     in_opt[1] = G_define_standard_option(G_OPT_V_INPUT);
+    in_opt[1]->description = _("Name of input vector map (B)");
     in_opt[1]->key = "binput";
     type_opt[1] = G_define_standard_option(G_OPT_V_TYPE);
+    type_opt[1]->label = _("Feature type (vector map B)");
     type_opt[1]->key = "btype";
     type_opt[1]->options = "area";
     type_opt[1]->answer = "area";
     field_opt[1] = G_define_standard_option(G_OPT_V_FIELD);
+    field_opt[1]->label = _("Layer number (vector map B)");
     field_opt[1]->key = "blayer";
     out_opt = G_define_standard_option(G_OPT_V_OUTPUT);
@@ -450,7 +456,7 @@
 	    G_fatal_error(_("Unable to create table: '%s'"),
 			  db_get_string(&stmt));
 	if (db_create_index2(driver, Fi->table, "cat") != DB_OK)
 	    G_warning(_("Unable to create index"));
