[GRASS-SVN] r34365 - grass/trunk/gui/wxpython/gui_modules
svn_grass at osgeo.org
Tue Nov 18 08:19:01 EST 2008
Author: martinl
Date: 2008-11-18 08:19:01 -0500 (Tue, 18 Nov 2008)
New Revision: 34365
grass/trunk/gui/wxpython/gui_modules/goutput.py
grass/trunk/gui/wxpython/gui_modules/menuform.py
grass/trunk/gui/wxpython/gui_modules/wxgui_utils.py
wxGUI: fix multiple layer/dbtable/dbcolumn
background map available from layer contextual menu
(merge from devbr6, r34364)
Modified: grass/trunk/gui/wxpython/gui_modules/goutput.py
--- grass/trunk/gui/wxpython/gui_modules/goutput.py 2008-11-18 13:17:43 UTC (rev 34364)
+++ grass/trunk/gui/wxpython/gui_modules/goutput.py 2008-11-18 13:19:01 UTC (rev 34365)
@@ -476,8 +476,9 @@
# Thread aborted (using our convention of None return)
self.WriteLog(_('Please note that the data are left in incosistent stage '
'and can be corrupted'), self.cmd_output.StyleWarning)
- self.WriteCmdLog('(%s) %s' % (str(time.ctime()),
- _('Command aborted')))
+ self.WriteCmdLog('(%s) %s (%d sec)' % (str(time.ctime()),
+ _('Command aborted'),
+ (time.time() - event.time)))
# pid=self.cmdThread.requestId)
else:
try:
Modified: grass/trunk/gui/wxpython/gui_modules/menuform.py
--- grass/trunk/gui/wxpython/gui_modules/menuform.py 2008-11-18 13:17:43 UTC (rev 34364)
+++ grass/trunk/gui/wxpython/gui_modules/menuform.py 2008-11-18 13:19:01 UTC (rev 34365)
@@ -1185,44 +1185,48 @@
'dbcolumn',
'layer',
'layer_all'):
- if p.get('prompt', '') in ('layer',
- 'layer_all'):
- if p.get('prompt', '') == 'layer_all':
- all = True
- else:
- all = False
- if p.get('age', 'old_layer') == 'old_layer':
- win = gselect.LayerSelect(parent=which_panel,
- all=all)
+ if p.get('multiple', 'no') == 'yes':
+ win = wx.TextCtrl(parent=which_panel, value = p.get('default',''),
+ size=globalvar.DIALOG_TEXTCTRL_SIZE)
+ else:
+ if p.get('prompt', '') in ('layer',
+ 'layer_all'):
+ if p.get('prompt', '') == 'layer_all':
+ all = True
+ else:
+ all = False
+ if p.get('age', 'old_layer') == 'old_layer':
+ win = gselect.LayerSelect(parent=which_panel,
+ all=all)
+ p['wxGetValue'] = win.GetStringSelection
+ win.Bind(wx.EVT_CHOICE, self.OnUpdateSelection)
+ win.Bind(wx.EVT_CHOICE, self.OnSetValue)
+ else:
+ win = wx.SpinCtrl(parent=which_panel, id=wx.ID_ANY,
+ min=1, max=100, initial=1)
+ win.Bind(wx.EVT_SPINCTRL, self.OnSetValue)
+ elif p.get('prompt', '') == 'dbdriver':
+ win = gselect.DriverSelect(parent=which_panel,
+ choices=p['values'],
+ value=p['default'])
- win.Bind(wx.EVT_CHOICE, self.OnUpdateSelection)
- win.Bind(wx.EVT_CHOICE, self.OnSetValue)
- else:
- win = wx.SpinCtrl(parent=which_panel, id=wx.ID_ANY,
- min=1, max=100, initial=1)
- win.Bind(wx.EVT_SPINCTRL, self.OnSetValue)
- elif p.get('prompt', '') == 'dbdriver':
- win = gselect.DriverSelect(parent=which_panel,
- choices=p['values'],
- value=p['default'])
- p['wxGetValue'] = win.GetStringSelection
- win.Bind(wx.EVT_COMBOBOX, self.OnUpdateSelection)
- win.Bind(wx.EVT_COMBOBOX, self.OnSetValue)
- elif p.get('prompt', '') == 'dbname':
- win = gselect.DatabaseSelect(parent=which_panel,
- win.Bind(wx.EVT_TEXT, self.OnUpdateSelection)
- win.Bind(wx.EVT_TEXT, self.OnSetValue)
- elif p.get('prompt', '') == 'dbtable':
- win = gselect.TableSelect(parent=which_panel)
- elif p.get('prompt', '') == 'dbcolumn':
- win = gselect.ColumnSelect(parent=which_panel)
+ win.Bind(wx.EVT_COMBOBOX, self.OnUpdateSelection)
+ win.Bind(wx.EVT_COMBOBOX, self.OnSetValue)
+ elif p.get('prompt', '') == 'dbname':
+ win = gselect.DatabaseSelect(parent=which_panel,
+ win.Bind(wx.EVT_TEXT, self.OnUpdateSelection)
+ win.Bind(wx.EVT_TEXT, self.OnSetValue)
+ elif p.get('prompt', '') == 'dbtable':
+ win = gselect.TableSelect(parent=which_panel)
+ elif p.get('prompt', '') == 'dbcolumn':
+ win = gselect.ColumnSelect(parent=which_panel)
p['wxId'] = win.GetId()
which_sizer.Add(item=win, proportion=0,
Modified: grass/trunk/gui/wxpython/gui_modules/wxgui_utils.py
--- grass/trunk/gui/wxpython/gui_modules/wxgui_utils.py 2008-11-18 13:17:43 UTC (rev 34364)
+++ grass/trunk/gui/wxpython/gui_modules/wxgui_utils.py 2008-11-18 13:19:01 UTC (rev 34365)
@@ -291,17 +291,21 @@
layer = self.GetPyData(self.layer_selected)[0]['maplayer']
# enable editing only for vector map layers available in the current mapset
digitToolbar = self.mapdisplay.toolbars['vdigit']
+ if digitToolbar:
+ # background vector map
+ self.popupMenu.Append(self.popupID14,
+ text=_("Use as background vector map"),
+ kind=wx.ITEM_CHECK)
+ self.Bind(wx.EVT_MENU, self.OnSetBgMap, id=self.popupID14)
+ if UserSettings.Get(group='vdigit', key='bgmap', subkey='value',
+ internal=True) == layer.GetName():
+ self.popupMenu.Check(self.popupID14, True)
if layer.GetMapset() != grassenv.GetGRASSVariable("MAPSET"):
# only vector map in current mapset can be edited
self.popupMenu.Enable (self.popupID5, False)
self.popupMenu.Enable (self.popupID6, False)
elif digitToolbar and digitToolbar.GetLayer():
- # background vector map
- self.popupMenu.Append(self.popupID14,
- text=_("Use as background vector map"),
- kind=wx.ITEM_CHECK)
- self.Bind(wx.EVT_MENU, self.OnSetBgMap, id=self.popupID14)
# vector map already edited
vdigitLayer = digitToolbar.GetLayer()
if vdigitLayer is layer:
@@ -320,10 +324,7 @@
self.popupMenu.Enable(self.popupID6, False)
# enable 'bgmap'
self.popupMenu.Enable(self.popupID14, True)
- if UserSettings.Get(group='vdigit', key='bgmap', subkey='value',
- internal=True) == layer.GetName():
- self.popupMenu.Check(self.popupID14, True)
self.popupMenu.Append(self.popupID7, _("Metadata"))
self.Bind (wx.EVT_MENU, self.OnMetadata, id=self.popupID7)
