[GRASS-SVN] r34368 - grass/branches/develbranch_6/imagery/i.pca
svn_grass at osgeo.org
Tue Nov 18 09:24:21 EST 2008
Author: martinl
Date: 2008-11-18 09:24:21 -0500 (Tue, 18 Nov 2008)
New Revision: 34368
grass/branches/develbranch_6/imagery/i.pca/main.c
grass/branches/develbranch_6/imagery/i.pca/support.c
i.pca: message standardization, more keywords
Modified: grass/branches/develbranch_6/imagery/i.pca/main.c
--- grass/branches/develbranch_6/imagery/i.pca/main.c 2008-11-18 13:29:03 UTC (rev 34367)
+++ grass/branches/develbranch_6/imagery/i.pca/main.c 2008-11-18 14:24:21 UTC (rev 34368)
@@ -8,7 +8,7 @@
* PURPOSE: Principal Component Analysis transform of satellite data.
- * COPYRIGHT: (C) 2004-2007 by the GRASS Development Team
+ * COPYRIGHT: (C) 2004-2008 by the GRASS Development Team
* This program is free software under the GNU General Public
* License (>=v2). Read the file COPYING that comes with GRASS
@@ -60,7 +60,7 @@
G_gisinit(argv[0]);
module = G_define_module();
- module->keywords = _("imagery");
+ module->keywords = _("imagery, image transformation, PCA");
module->description = _("Principal components analysis (pca) program "
"for image processing.");
@@ -127,7 +127,7 @@
opt_in->answers[i]);
- G_message(_("Calculating covariance matrix:"));
+ G_verbose_message(_("Calculating covariance matrix..."));
calc_mu(inp_fd, mu, bands);
calc_covariance(inp_fd, covar, mu, bands);
@@ -141,7 +141,7 @@
- G_debug(1, _("Calculating eigenvalues and eigenvectors..."));
+ G_debug(1, "Calculating eigenvalues and eigenvectors...");
eigen(covar, eigmat, eigval, bands);
#ifdef PCA_DEBUG
@@ -149,10 +149,10 @@
dump_eigen(bands, eigmat, eigval);
#endif
- G_debug(1, _("Ordering eigenvalues in descending order..."));
+ G_debug(1, "Ordering eigenvalues in descending order...");
egvorder2(eigval, eigmat, bands);
- G_debug(1, _("Transposing eigen matrix..."));
+ G_debug(1, "Transposing eigen matrix...");
transpose2(eigmat, bands);
/* write output images */
@@ -203,7 +203,8 @@
if (*scale_min == 0)
*scale = 0;
else {
- G_warning(_("Scale range length should be > 0. Using default values: 0,255"));
+ G_warning(_("Scale range length should be > 0. "
+ "Using default values: 0,255."));
*scale_min = 0;
*scale_max = 255;
@@ -239,16 +240,16 @@
if (rowbuf)
G_free(rowbuf);
if ((rowbuf = G_allocate_raster_buf(maptype)) == NULL)
- G_fatal_error(_("Cannot allocate memory for row buffer"));
+ G_fatal_error(_("Unable allocate memory for row buffer"));
- G_message(_("Computing Means for band %d:"), i + 1);
+ G_message(_("Computing Means for band %d..."), i + 1);
for (row = 0; row < rows; row++) {
void *ptr = rowbuf;
G_percent(row, rows - 1, 2);
if (G_get_raster_row(fds[i], rowbuf, row, maptype) < 0)
- G_fatal_error(_("Cannot read raster row [%d]"), row);
+ G_fatal_error(_("Unable to read raster map row %d"), row);
for (col = 0; col < cols; col++) {
/* skip null cells */
@@ -288,16 +289,16 @@
if (rowbuf1)
G_free(rowbuf1);
if ((rowbuf1 = G_allocate_raster_buf(maptype)) == NULL)
- G_message(_("Computing row %d of covariance matrix:"), j + 1);
+ G_message(_("Computing row %d of covariance matrix..."), j + 1);
void *ptr1, *ptr2;
if (G_get_raster_row(fds[j], rowbuf1, row, maptype) < 0)
for (k = j; k < bands; k++) {
RASTER_MAP_TYPE maptype2 = G_get_raster_map_type(fds[k]);
@@ -306,10 +307,10 @@
if (rowbuf2)
G_free(rowbuf2);
if ((rowbuf2 = G_allocate_raster_buf(maptype2)) == NULL)
+ G_fatal_error(_("Unable to allocate memory for row buffer"));
if (G_get_raster_row(fds[k], rowbuf2, row, maptype2) < 0)
ptr1 = rowbuf1;
ptr2 = rowbuf2;
@@ -369,7 +370,7 @@
G_allocate_raster_buf(DCELL_TYPE);
if (!outbuf)
- G_fatal_error(_("Cannot allocate memory for raster row"));
+ G_fatal_error(_("Unable to allocate memory for raster row"));
for (i = 0; i < bands; i++) {
char name[100];
@@ -378,7 +379,7 @@
sprintf(name, "%s.%d", out_basename, i + 1);
- G_message("%s: Transforming:", name);
+ G_message("Transforming <%s>...", name);
/* open a new file for output */
if (scale)
@@ -397,7 +398,7 @@
int row, col;
if (scale && (pass == PASSES)) {
- G_message(_("%s: Rescaling the data to [%d,%d] range:"),
+ G_message(_("Rescaling the data <%s> to range %d,%d..."),
name, scale_min, scale_max);
old_range = max - min;
@@ -421,10 +422,10 @@
if (rowbuf)
G_free(rowbuf);
if (!(rowbuf = G_allocate_raster_buf(maptype)))
if (G_get_raster_row(inp_fd[j], rowbuf, row, maptype) < 0)
rowptr = rowbuf;
outptr = outbuf;
Modified: grass/branches/develbranch_6/imagery/i.pca/support.c
--- grass/branches/develbranch_6/imagery/i.pca/support.c 2008-11-18 13:29:03 UTC (rev 34367)
+++ grass/branches/develbranch_6/imagery/i.pca/support.c 2008-11-18 14:24:21 UTC (rev 34368)
@@ -24,7 +24,7 @@
G_mark_colors_as_fp(&colors);
if (G_write_colors(outname, mapset, &colors) < 0)
- G_message(_("Cannot write color table of raster map <%s>"), outname);
+ G_message(_("Unable to write color table for raster map <%s>"), outname);
return write_history(bands, outname, eigmat);
