[GRASS-SVN] r34371 - in grass/branches/develbranch_6/imagery: i.his.rgb i.rgb.his
Tue Nov 18 11:32:16 EST 2008
Author: martinl
Date: 2008-11-18 11:32:16 -0500 (Tue, 18 Nov 2008)
New Revision: 34371
   grass/branches/develbranch_6/imagery/i.his.rgb/h2rmain.c
   grass/branches/develbranch_6/imagery/i.rgb.his/openfiles.c
   grass/branches/develbranch_6/imagery/i.rgb.his/r2hmain.c
i.rgb.his & i.his.rgb: message standardization
Modified: grass/branches/develbranch_6/imagery/i.his.rgb/h2rmain.c
--- grass/branches/develbranch_6/imagery/i.his.rgb/h2rmain.c	2008-11-18 16:12:58 UTC (rev 34370)
+++ grass/branches/develbranch_6/imagery/i.his.rgb/h2rmain.c	2008-11-18 16:32:16 UTC (rev 34371)
@@ -10,7 +10,7 @@
  * PURPOSE:      Hue-intensity-saturation (his) to red-green-blue (rgb)
  *               raster map color transformation function.
- * COPYRIGHT:    (C) 2007 by the GRASS Development Team
+ * COPYRIGHT:    (C) 2007-2008 by the GRASS Development Team
  *               This program is free software under the GNU General Public
  *               License (>=v2). Read the file COPYING that comes with GRASS
@@ -42,35 +42,35 @@
     /* Set description */
     module = G_define_module();
-    module->keywords = _("imagery");
+    module->keywords = _("imagery, color transformation, RGB, HIS");
     module->description =
-	_("Hue-intensity-saturation (his) to red-green-blue (rgb) "
-	  "raster map color transformation function.");
+	_("Transforms raster maps from HIS (Hue-Intensity-Saturation) color space to "
+	  "RGB (Red-Green-Blue) color space.");
     /* Define the different options */
     opt_hue = G_define_standard_option(G_OPT_R_INPUT);
     opt_hue->key = "hue_input";
-    opt_hue->description = _("Hue map name");
+    opt_hue->description = _("Name of input raster map (hue)");
     opt_int = G_define_standard_option(G_OPT_R_INPUT);
     opt_int->key = "intensity_input";
-    opt_int->description = _("Intensity map name");
+    opt_int->description = _("Name of input raster map (intensity)");
     opt_sat = G_define_standard_option(G_OPT_R_INPUT);
     opt_sat->key = "saturation_input";
-    opt_sat->description = _("Saturation map name");
+    opt_sat->description = _("Name of input raster map (saturation)");
     opt_red = G_define_standard_option(G_OPT_R_OUTPUT);
     opt_red->key = "red_output";
-    opt_red->description = _("Output map representing the red");
+    opt_red->description = _("Name for output raster map (red)");
     opt_green = G_define_standard_option(G_OPT_R_OUTPUT);
     opt_green->key = "green_output";
-    opt_green->description = _("Output map representing the green");
+    opt_green->description = _("Name for output raster map (green)");
     opt_blue = G_define_standard_option(G_OPT_R_OUTPUT);
     opt_blue->key = "blue_output";
-    opt_blue->description = _("Output map representing the blue");
+    opt_blue->description = _("Name for output raster map (blue)");
     if (G_parser(argc, argv))
 	exit(EXIT_FAILURE);
@@ -91,7 +91,7 @@
 	/* read in a row from each cell map */
 	for (band = 0; band < 3; band++)
 	    if (G_get_map_row(fd_input[band], rowbuffer[band], i) < 0)
-		G_fatal_error(_("Cannot read row from raster map"));
+		G_fatal_error(_("Unable to read raster map row %d"), i);
 	/* process this row of the map */
 	his2rgb(rowbuffer, cols);
@@ -100,7 +100,7 @@
 	    if (G_put_raster_row(fd_output[band], rowbuffer[band], CELL_TYPE)
 		< 0)
-		G_fatal_error(_("Cannot write row to raster map"));
+		G_fatal_error(_("Failed writing raster map row %d"), i);
     closefiles(opt_red->answer, opt_green->answer, opt_blue->answer,
Modified: grass/branches/develbranch_6/imagery/i.rgb.his/openfiles.c
--- grass/branches/develbranch_6/imagery/i.rgb.his/openfiles.c	2008-11-18 16:12:58 UTC (rev 34370)
+++ grass/branches/develbranch_6/imagery/i.rgb.his/openfiles.c	2008-11-18 16:32:16 UTC (rev 34371)
@@ -18,19 +18,19 @@
 	G_fatal_error(_("Raster map <%s> not found"), b_name);
     if ((fd_input[0] = G_open_cell_old(r_name, mapset)) < 0)
-	G_fatal_error(_("Cannot open raster map <%s>"), r_name);
+	G_fatal_error(_("Unable to open raster map <%s>"), r_name);
     if ((fd_input[1] = G_open_cell_old(g_name, mapset)) < 0)
-	G_fatal_error(_("Cannot open raster map <%s>"), g_name);
+	G_fatal_error(_("Unable to open raster map <%s>"), g_name);
     if ((fd_input[2] = G_open_cell_old(b_name, mapset)) < 0)
-	G_fatal_error(_("Cannot open raster map <%s>"), b_name);
+	G_fatal_error(_("Unable to open raster map <%s>"), b_name);
     /* open output files */
     if ((fd_output[0] = G_open_cell_new(h_name)) < 0)
-	G_fatal_error(_("Cannot create raster map <%s>"), h_name);
+	G_fatal_error(_("Unable to create raster map <%s>"), h_name);
     if ((fd_output[1] = G_open_cell_new(i_name)) < 0)
-	G_fatal_error(_("Cannot create raster map <%s>"), i_name);
+	G_fatal_error(_("Unable to create raster map <%s>"), i_name);
     if ((fd_output[2] = G_open_cell_new(s_name)) < 0)
-	G_fatal_error(_("Cannot create raster map <%s>"), s_name);
+	G_fatal_error(_("Unable to create raster map <%s>"), s_name);
     /* allocate the cell row buffer */
     if ((rowbuf[0] = G_allocate_cell_buf()) == NULL)
Modified: grass/branches/develbranch_6/imagery/i.rgb.his/r2hmain.c
--- grass/branches/develbranch_6/imagery/i.rgb.his/r2hmain.c	2008-11-18 16:12:58 UTC (rev 34370)
+++ grass/branches/develbranch_6/imagery/i.rgb.his/r2hmain.c	2008-11-18 16:32:16 UTC (rev 34371)
@@ -10,7 +10,7 @@
  * PURPOSE:      Red-green-blue (rgb) to hue-intensity-saturation (his)
@@ -42,35 +42,35 @@
-	_("Red-green-blue (rgb) to hue-intensity-saturation (his) raster "
-	  "map color transformation function");
+	_("Transforms raster maps from RGB (Red-Green-Blue) color space to "
+	  "HIS (Hue-Intensity-Saturation) color space.");
     opt_red = G_define_standard_option(G_OPT_R_INPUT);
     opt_red->key = "red_input";
-    opt_red->description = _("Red input raster map");
+    opt_red->description = _("Name of input raster map (red)");
     opt_green = G_define_standard_option(G_OPT_R_INPUT);
     opt_green->key = "green_input";
-    opt_green->description = _("Green input raster map");
+    opt_green->description = _("Name of input raster map (green)");
     opt_blue = G_define_standard_option(G_OPT_R_INPUT);
     opt_blue->key = "blue_input";
-    opt_blue->description = _("Blue input raster map");
+    opt_blue->description = _("Name of input raster map (blue)");
     opt_hue = G_define_standard_option(G_OPT_R_OUTPUT);
     opt_hue->key = "hue_output";
-    opt_hue->description = _("Output hue raster map");
+    opt_hue->description = _("Name for output raster map (hue)");
     opt_inten = G_define_standard_option(G_OPT_R_OUTPUT);
     opt_inten->key = "intensity_output";
-    opt_inten->description = _("Output intensity raster map");
+    opt_inten->description = _("Name for output raster map (intensity)");
     opt_sat = G_define_standard_option(G_OPT_R_OUTPUT);
     opt_sat->key = "saturation_output";
-    opt_sat->description = _("Output saturation raster map");
+    opt_sat->description = _("Name for output raster map (saturation)");
 	exit(EXIT_FAILURE);
@@ -89,7 +89,7 @@
 	rgb2his(rowbuffer, cols);
@@ -98,7 +98,7 @@
 		< 0)
     closefiles(opt_hue->answer, opt_inten->answer, opt_sat->answer,
