[GRASS-SVN] r34381 -
grass/branches/develbranch_6/gui/wxpython/gui_modules
svn_grass at osgeo.org
Tue Nov 18 17:08:19 EST 2008
Author: martinl
Date: 2008-11-18 17:08:18 -0500 (Tue, 18 Nov 2008)
New Revision: 34381
grass/branches/develbranch_6/gui/wxpython/gui_modules/disp_print.py
grass/branches/develbranch_6/gui/wxpython/gui_modules/histogram.py
grass/branches/develbranch_6/gui/wxpython/gui_modules/mapdisp.py
glynn: Don't allocate wx.PrintData object until needed (due to warnings)
(merge from trunk, r34380)
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/disp_print.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/disp_print.py 2008-11-18 21:59:19 UTC (rev 34380)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/disp_print.py 2008-11-18 22:08:18 UTC (rev 34381)
@@ -98,16 +98,21 @@
def __init__(self, parent, mapwin):
self.mapframe = parent
self.mapwin = mapwin
-# self.frame = frame
+ #self.frame = frame
+ self.printData = None
+ #self.canvas = ScrolledWindow.MyCanvas(self)
+ def setup(self):
+ if self.printData:
+ return
self.printData = wx.PrintData()
self.printData.SetPaperId(wx.PAPER_LETTER)
self.printData.SetPrintMode(wx.PRINT_MODE_PRINTER)
-# self.canvas = ScrolledWindow.MyCanvas(self)
def OnPageSetup(self, event):
+ self.setup()
psdd = wx.PageSetupDialogData(self.printData)
psdd.CalculatePaperSizeFromId()
dlg = wx.PageSetupDialog(self.mapwin, psdd)
@@ -121,6 +126,7 @@
dlg.Destroy()
def OnPrintPreview(self, event):
+ self.setup()
data = wx.PrintDialogData(self.printData)
printout = MapPrint(self.mapwin)
printout2 = MapPrint(self.mapwin)
@@ -138,6 +144,7 @@
pfrm.Show(True)
def OnDoPrint(self, event):
+ self.setup()
pdd = wx.PrintDialogData(self.printData)
# set number of pages/copies
pdd.SetToPage(1)
@@ -149,3 +156,6 @@
else:
self.printData = wx.PrintData( printer.GetPrintDialogData().GetPrintData() )
printout.Destroy()
+ def OnReset(self):
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/histogram.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/histogram.py 2008-11-18 21:59:19 UTC (rev 34380)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/histogram.py 2008-11-18 22:08:18 UTC (rev 34381)
@@ -518,6 +518,10 @@
printmenu.AppendItem(doprint)
self.Bind(wx.EVT_MENU, self.printopt.OnDoPrint, doprint)
+ reset = wx.MenuItem(printmenu, -1,'Reset')
+ printmenu.AppendItem(reset)
+ self.Bind(wx.EVT_MENU, self.printopt.OnReset, reset)
# Popup the menu. If an item is selected then its handler
# will be called before PopupMenu returns.
self.PopupMenu(printmenu)
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/mapdisp.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/mapdisp.py 2008-11-18 21:59:19 UTC (rev 34380)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/mapdisp.py 2008-11-18 22:08:18 UTC (rev 34381)
@@ -3303,6 +3303,10 @@
