[GRASS-SVN] r34406 - grass/trunk/general/g.mlist
svn_grass at osgeo.org
Thu Nov 20 11:50:17 EST 2008
Author: glynn
Date: 2008-11-20 11:50:17 -0500 (Thu, 20 Nov 2008)
New Revision: 34406
grass/trunk/general/g.mlist/main.c
Add exclude= option
Modified: grass/trunk/general/g.mlist/main.c
--- grass/trunk/general/g.mlist/main.c 2008-11-20 16:40:00 UTC (rev 34405)
+++ grass/trunk/general/g.mlist/main.c 2008-11-20 16:50:17 UTC (rev 34406)
@@ -28,7 +28,7 @@
static int any;
static void make_list(const struct list *,
- const char *, const char *, const char *,
+ const char *, const char *,
int, int, int);
static int parse(const char *);
static int ls_filter(const char *, void *);
@@ -40,6 +40,7 @@
struct Option *type;
struct Option *pattern;
+ struct Option *exclude;
struct Option *separator;
struct Option *mapset;
} opt;
@@ -53,8 +54,8 @@
struct Flag *full;
} flag;
int i, n, all, num_types;
- char *pattern = NULL, separator[2], *buf;
- regex_t regex;
+ char *pattern = NULL, *exclude = NULL, separator[2], *buf;
+ regex_t regex, regex_ex;
G_gisinit(argv[0]);
@@ -91,9 +92,15 @@
opt.pattern->type = TYPE_STRING;
opt.pattern->required = NO;
opt.pattern->multiple = NO;
- opt.pattern->answer = "*";
opt.pattern->description = _("Map name search pattern (default: all)");
+ opt.exclude = G_define_option();
+ opt.exclude->key = "exclude";
+ opt.exclude->type = TYPE_STRING;
+ opt.exclude->required = NO;
+ opt.exclude->multiple = NO;
+ opt.exclude->description = _("Map name exclusion pattern (default: none)");
opt.separator = G_define_option();
opt.separator->key = "separator";
opt.separator->type = TYPE_STRING;
@@ -145,15 +152,28 @@
if (flag.regex->answer && flag.extended->answer)
G_fatal_error(_("-r and -e are mutually exclusive"));
- if (flag.regex->answer || flag.extended->answer)
- pattern = opt.pattern->answer;
- else
- pattern = wc2regex(opt.pattern->answer);
+ if (opt.pattern->answer) {
+ if (flag.regex->answer || flag.extended->answer)
+ pattern = G_store(opt.pattern->answer);
+ else
+ pattern = wc2regex(opt.pattern->answer);
- if (regcomp(®ex, pattern, (flag.regex->answer ? 0 : REG_EXTENDED) | REG_NOSUB))
- G_fatal_error(_("Unable to compile regular expression %s"), pattern);
- G_set_ls_filter(ls_filter, ®ex);
+ if (regcomp(®ex, pattern, (flag.regex->answer ? 0 : REG_EXTENDED) | REG_NOSUB))
+ G_fatal_error(_("Unable to compile regular expression %s"), pattern);
+ G_set_ls_filter(ls_filter, ®ex);
+ if (opt.exclude->answer) {
+ exclude = G_store(opt.exclude->answer);
+ else
+ exclude = wc2regex(opt.exclude->answer);
+ if (regcomp(®ex_ex, exclude, (flag.regex->answer ? 0 : REG_EXTENDED) | REG_NOSUB))
+ G_fatal_error(_("Unable to compile regular expression %s"), exclude);
+ G_set_ls_exclude_filter(ls_filter, ®ex_ex);
if (strcmp(opt.separator->answer, "newline") == 0)
separator[0] = '\n';
else if (strcmp(opt.separator->answer, "comma") == 0)
@@ -202,7 +222,7 @@
else
- make_list(&list[n], pattern, opt.mapset->answer, separator,
+ make_list(&list[n], opt.mapset->answer, separator,
flag.pretty->answer, flag.type->answer,
flag.mapset->answer);
@@ -210,17 +230,22 @@
if (!flag.pretty->answer && any)
fprintf(stdout, "\n");
- if (!flag.regex->answer)
+ if (pattern) {
G_free(pattern);
+ regfree(®ex);
- regfree(®ex);
+ if (exclude) {
+ G_free(exclude);
+ regfree(®ex_ex);
exit(EXIT_SUCCESS);
const struct list *elem,
- const char *pattern, const char *mapset, const char *separator,
+ const char *mapset, const char *separator,
int pretty, int add_type, int add_mapset)
char path[GPATH_MAX];
@@ -238,7 +263,7 @@
if (!mapset || !*mapset) {
int n;
for (n = 0; mapset = G__mapset_name(n), mapset; n++)
- make_list(elem, pattern, mapset, separator,
+ make_list(elem, mapset, separator,
pretty, add_type, add_mapset);
return;
