[GRASS-SVN] r34419 - in grass/trunk: lib/python
scripts/i.fusion.brovey scripts/i.image.mosaic
scripts/i.in.spotvgt scripts/i.tasscap scripts/r.blend
scripts/r.buffer scripts/r.fillnulls scripts/r.grow
scripts/r.mask scripts/r.plane scripts/r.reclass.area
scripts/v.rast.stats
svn_grass at osgeo.org
Thu Nov 20 19:42:56 EST 2008
Author: glynn
Date: 2008-11-20 19:42:56 -0500 (Thu, 20 Nov 2008)
New Revision: 34419
grass/trunk/lib/python/grass.py
grass/trunk/scripts/i.fusion.brovey/i.fusion.brovey.py
grass/trunk/scripts/i.image.mosaic/i.image.mosaic.py
grass/trunk/scripts/i.in.spotvgt/i.in.spotvgt.py
grass/trunk/scripts/i.tasscap/i.tasscap.py
grass/trunk/scripts/r.blend/r.blend.py
grass/trunk/scripts/r.buffer/r.buffer.py
grass/trunk/scripts/r.fillnulls/r.fillnulls.py
grass/trunk/scripts/r.grow/r.grow.py
grass/trunk/scripts/r.mask/r.mask.py
grass/trunk/scripts/r.plane/r.plane.py
grass/trunk/scripts/r.reclass.area/r.reclass.area.py
grass/trunk/scripts/v.rast.stats/v.rast.stats.py
Add, use grass.mapcalc() function
Modified: grass/trunk/lib/python/grass.py
--- grass/trunk/lib/python/grass.py 2008-11-21 00:01:20 UTC (rev 34418)
+++ grass/trunk/lib/python/grass.py 2008-11-21 00:42:56 UTC (rev 34419)
@@ -4,6 +4,7 @@
import subprocess
import re
import atexit
+import string
# subprocess wrapper that uses shell on Windows
@@ -508,3 +509,11 @@
for k in ['min', 'max', 'north', 'south', 'east', 'west', 'nsres', 'ewres']:
kv[k] = float(kv[k])
return kv
+# interface to r.mapcalc
+def mapcalc(exp, **kwargs):
+ t = string.Template(exp)
+ e = t.substitute(**kwargs)
+ if run_command('r.mapcalc', expression = e) != 0:
+ grass.fatal("An error occurred while running r.mapcalc")
Modified: grass/trunk/scripts/i.fusion.brovey/i.fusion.brovey.py
--- grass/trunk/scripts/i.fusion.brovey/i.fusion.brovey.py 2008-11-21 00:01:20 UTC (rev 34418)
+++ grass/trunk/scripts/i.fusion.brovey/i.fusion.brovey.py 2008-11-21 00:42:56 UTC (rev 34419)
@@ -84,7 +84,6 @@
import sys
import os
-import string
import grass
def main():
@@ -133,14 +132,11 @@
# note: for RGB composite then revert brov.red and brov.green!
grass.message("Calculating %s.{red,green,blue}: ..." % out)
- t = string.Template(
- '''eval(k = float("$pan") / ("$ms1" + "$ms2" + "$ms3"))
+ e = '''eval(k = float("$pan") / ("$ms1" + "$ms2" + "$ms3"))
"$out.red" = "$ms3" * k
"$out.green" = "$ms2" * k
- "$out.blue" = "$ms1" * k''')
- e = t.substitute(out = out, pan = pan, ms1 = ms1, ms2 = ms2, ms3 = ms3)
- if grass.run_command('r.mapcalc', expression = e) != 0:
- grass.fatal("An error occurred while running r.mapcalc")
+ "$out.blue" = "$ms1" * k'''
+ grass.mapcalc(e, out = out, pan = pan, ms1 = ms1, ms2 = ms2, ms3 = ms3)
# Maybe?
#r.colors $GIS_OPT_OUTPUTPREFIX.red col=grey
Modified: grass/trunk/scripts/i.image.mosaic/i.image.mosaic.py
--- grass/trunk/scripts/i.image.mosaic/i.image.mosaic.py 2008-11-21 00:01:20 UTC (rev 34418)
+++ grass/trunk/scripts/i.image.mosaic/i.image.mosaic.py 2008-11-21 00:42:56 UTC (rev 34419)
@@ -44,7 +44,6 @@
import sys
import os
-import string
import grass
def copy_colors(fh, map, offset):
@@ -90,10 +89,8 @@
grass.message("Mosaicing %d images..." % count)
- t = string.Template("$output = " + make_expression(1, count))
- print t.template
- e = t.substitute(output = output, **parms)
- grass.run_command('r.mapcalc', expression = e)
+ grass.mapcalc("$output = " + make_expression(1, count),
+ output = output, **parms)
#modify the color table:
p = grass.feed_command('r.colors', map = output, rules='-')
Modified: grass/trunk/scripts/i.in.spotvgt/i.in.spotvgt.py
--- grass/trunk/scripts/i.in.spotvgt/i.in.spotvgt.py 2008-11-21 00:01:20 UTC (rev 34418)
+++ grass/trunk/scripts/i.in.spotvgt/i.in.spotvgt.py 2008-11-21 00:42:56 UTC (rev 34419)
@@ -182,8 +182,7 @@
grass.message("Remapping digital numbers to NDVI...")
tmpname = "%s_%s" % (name, pid)
- e = "%s = 0.004 * %s - 0.1" % (tmpname, name)
+ grass.mapcalc("$tmpname = 0.004 * $name - 0.1", tmpname = tmpname, name = name)
grass.run_command('g.remove', rast = name, quiet = True)
grass.run_command('g.rename', rast = (tmpname, name), quiet = True)
@@ -251,8 +250,8 @@
grass.message("Filtering NDVI map by Status Map quality layer...")
filtfile = "%s_filt" % name
- e = "%s = if(%s >= 248, %s, null())" % (filtfile, smfile, name)
+ grass.mapcalc("$filtfile = if($smfile >= 248, $name, null())",
+ filtfile = filtfile, smfile = smfile, name = name)
grass.run_command('r.colors', map = filtfile, color = 'ndvi', quiet = True)
grass.message("Filtered SPOT VEGETATION NDVI map <%s>." % filtfile)
Modified: grass/trunk/scripts/i.tasscap/i.tasscap.py
--- grass/trunk/scripts/i.tasscap/i.tasscap.py 2008-11-21 00:01:20 UTC (rev 34418)
+++ grass/trunk/scripts/i.tasscap/i.tasscap.py 2008-11-21 00:42:56 UTC (rev 34419)
@@ -100,7 +100,6 @@
import sys
import os
-import string
import grass
parms = [[( 0.3037, 0.2793, 0.4743, 0.5585, 0.5082, 0.1863),
@@ -118,9 +117,9 @@
names = ["Brightness", "Greenness", "Wetness", "Haze"]
def calc1(out, bands, k1, k2, k3, k4, k5, k7, k0 = 0):
- t = string.Template("$out = $k1 * $band1 + $k2 * $band2 + $k3 * $band3 + $k4 * $band4 + $k5 * $band5 + $k7 * $band7 + $k0")
- e = t.substitute(out = out, k1 = k1, k2 = k2, k3 = k3, k4 = k4, k5 = k5, k7 = k7, k0 = k0, **bands)
+ grass.mapcalc(
+ "$out = $k1 * $band1 + $k2 * $band2 + $k3 * $band3 + $k4 * $band4 + $k5 * $band5 + $k7 * $band7 + $k0",
+ out = out, k1 = k1, k2 = k2, k3 = k3, k4 = k4, k5 = k5, k7 = k7, k0 = k0, **bands)
grass.run_command('r.colors', map = out, color = 'grey')
def calcN(options, i, n):
Modified: grass/trunk/scripts/r.blend/r.blend.py
--- grass/trunk/scripts/r.blend/r.blend.py 2008-11-21 00:01:20 UTC (rev 34418)
+++ grass/trunk/scripts/r.blend/r.blend.py 2008-11-21 00:42:56 UTC (rev 34419)
@@ -76,17 +76,16 @@
frac2 = perc_inv / 100.0
grass.message("Calculating the three component maps...")
- template = string.Template("$output.$$ch = $frac1 * $$ch#$first + $frac2 * $$ch#$second")
- s = template.substitute(output = output,
- first = first, second = second,
- frac1 = frac1, frac2 = frac2)
- template = string.Template(s)
- cmd = []
- for ch in ['r','g','b']:
- map = "%s.%s" % (output, ch)
- cmd.append(template.substitute(ch = ch))
- grass.run_command('r.mapcalc', expression = ';'.join(cmd))
+ template = string.Template("$$output.$ch = $$frac1 * $ch#$$first + $$frac2 * $ch#$$second")
+ cmd = [template.substitute(ch = ch) for ch in ['r','g','b']]
+ cmd = ';'.join(cmd)
+ grass.mapcalc(cmd,
+ output = output,
+ first = first, second = second,
+ frac1 = frac1, frac2 = frac2)
grass.run_command('r.colors', map = map, color = 'grey255')
Modified: grass/trunk/scripts/r.buffer/r.buffer.py
--- grass/trunk/scripts/r.buffer/r.buffer.py 2008-11-21 00:01:20 UTC (rev 34418)
+++ grass/trunk/scripts/r.buffer/r.buffer.py 2008-11-21 00:42:56 UTC (rev 34419)
@@ -60,7 +60,6 @@
import sys
import os
import atexit
-import string
import math
import grass
@@ -104,21 +103,18 @@
distance = temp_dist)
if zero:
- t = string.Template("$temp_src = if($input == 0,null(),1)")
+ exp = "$temp_src = if($input == 0,null(),1)"
else:
- t = string.Template("$temp_src = if(isnull($input),null(),1)")
+ exp = "$temp_src = if(isnull($input),null(),1)"
- e = t.substitute(temp_src = temp_src, input = input)
+ grass.mapcalc(exp, temp_src = temp_src, input = input)
- s = "$output = if(!isnull($input),$input,%s)"
+ exp = "$output = if(!isnull($input),$input,%s)"
for n, dist2 in enumerate(distances2):
- s %= "if($dist <= %f,%d,%%s)" % (dist2,n + 2)
- s %= "null()"
+ exp %= "if($dist <= %f,%d,%%s)" % (dist2,n + 2)
+ exp %= "null()"
- t = string.Template(s)
- e = t.substitute(output = output, input = temp_src, dist = temp_dist)
+ grass.mapcalc(exp, output = output, input = temp_src, dist = temp_dist)
p = grass.feed_command('r.category', map = output, rules = '-')
p.stdin.write("1:distances calculated from these locations\n")
Modified: grass/trunk/scripts/r.fillnulls/r.fillnulls.py
--- grass/trunk/scripts/r.fillnulls/r.fillnulls.py 2008-11-21 00:01:20 UTC (rev 34418)
+++ grass/trunk/scripts/r.fillnulls/r.fillnulls.py 2008-11-21 00:42:56 UTC (rev 34419)
@@ -97,8 +97,8 @@
grass.message("Locating and isolating NULL areas...")
#creating 0/1 map:
- e = "%s = if(isnull(%s),1,null())" % (tmp1, input)
+ grass.mapcalc("$tmp1 = if(isnull($input),1,null())",
+ tmp1 = tmp1, input = input)
#generate a ring:
# the buffer is set to three times the map resolution so you get nominally
@@ -113,7 +113,7 @@
if grass.run_command('r.buffer', input = tmp1, distances = res, out = tmp1 + '.buf') != 0:
grass.fatal("abandoned. Removing temporary map, restoring user mask if needed:")
- grass.run_command('r.mapcalc', expression = "MASK=if(%s.buf==2,1,null())" % tmp1)
+ grass.mapcalc("MASK=if($tmp1.buf==2,1,null())", tmp1 = tmp1)
# now we only see the outlines of the NULL areas if looking at INPUT.
# Use this outline (raster border) for interpolating the fill data:
Modified: grass/trunk/scripts/r.grow/r.grow.py
--- grass/trunk/scripts/r.grow/r.grow.py 2008-11-21 00:01:20 UTC (rev 34418)
+++ grass/trunk/scripts/r.grow/r.grow.py 2008-11-21 00:42:56 UTC (rev 34419)
@@ -75,7 +75,6 @@
import sys
import os
import atexit
-import string
import math
import grass
@@ -125,10 +124,10 @@
grass.run_command('r.grow.distance', input = input, metric = metric,
distance = temp_dist, value = temp_val)
- t = string.Template("$output = if(!isnull($input),$old,if($dist < $radius,$new,null()))")
- e = t.substitute(output = output, input = input, radius = radius,
- old = old, new = new, dist = temp_dist)
+ grass.mapcalc(
+ "$output = if(!isnull($input),$old,if($dist < $radius,$new,null()))",
+ output = output, input = input, radius = radius,
+ old = old, new = new, dist = temp_dist)
grass.run_command('r.colors', map = output, raster = input)
Modified: grass/trunk/scripts/r.mask/r.mask.py
--- grass/trunk/scripts/r.mask/r.mask.py 2008-11-21 00:01:20 UTC (rev 34418)
+++ grass/trunk/scripts/r.mask/r.mask.py 2008-11-21 00:42:56 UTC (rev 34419)
@@ -81,7 +81,7 @@
global tmp
tmp = "r_mask_%d" % os.getpid()
grass.run_command('g.rename', rast = ('MASK',tmp), quiet = True)
- grass.run_command('r.mapcalc', expr = "MASK=if(isnull(%s),1,null())" % tmp)
+ grass.mapcalc("MASK=if(isnull($tmp),1,null())", tmp = tmp)
grass.run_command('g.remove', rast = tmp, quiet = True)
grass.message("Inverted MASK created.")
else:
Modified: grass/trunk/scripts/r.plane/r.plane.py
--- grass/trunk/scripts/r.plane/r.plane.py 2008-11-21 00:01:20 UTC (rev 34418)
+++ grass/trunk/scripts/r.plane/r.plane.py 2008-11-21 00:42:56 UTC (rev 34419)
@@ -110,9 +110,8 @@
else:
round = ""
- t = string.Template('$name = $type($round(x() * $kx + y() * $ky + $kz))')
- e = t.substitute(name = name, type = type, round = round, kx = kx, ky = ky, kz = kz)
+ grass.mapcalc("$name = $type($round(x() * $kx + y() * $ky + $kz))",
+ name = name, type = type, round = round, kx = kx, ky = ky, kz = kz)
grass.raster_history(name)
Modified: grass/trunk/scripts/r.reclass.area/r.reclass.area.py
--- grass/trunk/scripts/r.reclass.area/r.reclass.area.py 2008-11-21 00:01:20 UTC (rev 34418)
+++ grass/trunk/scripts/r.reclass.area/r.reclass.area.py 2008-11-21 00:42:56 UTC (rev 34419)
@@ -113,7 +113,7 @@
grass.message("Written: %s" % outfile)
- grass.run_command('r.mapcalc', expression = "%s = %s" % (outfile, recfile))
+ grass.mapcalc("$outfile = $recfile", outfile = outfile, recfile = recfile)
grass.run_command('g.remove', rast = [recfile, clumpfile], quiet = True)
if __name__ == "__main__":
Modified: grass/trunk/scripts/v.rast.stats/v.rast.stats.py
--- grass/trunk/scripts/v.rast.stats/v.rast.stats.py 2008-11-21 00:01:20 UTC (rev 34418)
+++ grass/trunk/scripts/v.rast.stats/v.rast.stats.py 2008-11-21 00:42:56 UTC (rev 34419)
@@ -228,8 +228,8 @@
for i in cats:
grass.verbose("Processing category %s (%d/%d)" % (i, currnum, number))
grass.run_command('g.remove', rast = 'MASK', quiet = True, stderr = nuldev)
- grass.run_command('r.mapcalc', quiet = True,
- expression = "MASK = if(%s_%s == %s, 1, null())" % (vector, tmpname, i))
+ grass.mapcalc("MASK = if($name == $i, 1, null())",
+ name = "%s_%s" % (vector, tmpname), i = i)
#n, min, max, range, mean, stddev, variance, coeff_var, sum
# How to test r.univar $? exit status? using -e creates the real possibility of out-of-memory errors
