[GRASS-SVN] r34440 - grass/trunk/raster/r.mapcalc
svn_grass at osgeo.org
Fri Nov 21 19:07:17 EST 2008
Author: glynn
Date: 2008-11-21 19:07:17 -0500 (Fri, 21 Nov 2008)
New Revision: 34440
grass/trunk/raster/r.mapcalc/Makefile
grass/trunk/raster/r.mapcalc/evaluate.c
grass/trunk/raster/r.mapcalc/expression.h
Experimental pthreads (parallelism) support; use "make USE_PTHREAD=1" to test
Modified: grass/trunk/raster/r.mapcalc/Makefile
--- grass/trunk/raster/r.mapcalc/Makefile 2008-11-21 23:39:55 UTC (rev 34439)
+++ grass/trunk/raster/r.mapcalc/Makefile 2008-11-22 00:07:17 UTC (rev 34440)
@@ -15,6 +15,13 @@
LIBES2 = $(GISLIB) $(BTREELIB) $(ROWIOLIB) $(READLINELIBPATH) $(READLINELIB) $(HISTORYLIB)
LIBES3 = $(G3DLIB) $(GISLIB) $(BTREELIB) $(READLINELIBPATH) $(READLINELIB) $(HISTORYLIB)
+ifneq ($(USE_PTHREAD),)
+PTHREADLIB = -lpthread
+EXTRA_CFLAGS += -DUSE_PTHREAD
+LIBES2 += $(PTHREADLIB)
+LIBES3 += $(PTHREADLIB)
+endif
default: multi
$(BIN)/$(PGM2)$(EXE): LIBES = $(LIBES2)
Modified: grass/trunk/raster/r.mapcalc/evaluate.c
--- grass/trunk/raster/r.mapcalc/evaluate.c 2008-11-21 23:39:55 UTC (rev 34439)
+++ grass/trunk/raster/r.mapcalc/evaluate.c 2008-11-22 00:07:17 UTC (rev 34440)
@@ -1,12 +1,17 @@
#include <stdlib.h>
#include <unistd.h>
+#ifdef USE_PTHREAD
+#include <pthread.h>
+#include <signal.h>
+#endif
#include <grass/gis.h>
#include <grass/glocale.h>
#include "mapcalc.h"
#include "globals.h"
+#include "func_proto.h"
@@ -95,6 +100,127 @@
+#ifdef USE_PTHREAD
+struct worker {
+ struct expression *exp;
+ pthread_t thread;
+ pthread_cond_t cond;
+ pthread_mutex_t mutex;
+static int num_workers;
+static struct worker *workers;
+static pthread_mutex_t worker_mutex;
+static pthread_mutex_t map_mutex;
+static void *worker(void *arg)
+ struct worker *w = arg;
+ for (;;) {
+ pthread_mutex_lock(&w->mutex);
+ while (!w->exp)
+ pthread_cond_wait(&w->cond, &w->mutex);
+ evaluate(w->exp);
+ pthread_mutex_unlock(&w->mutex);
+ w->exp->worker = NULL;
+ w->exp = NULL;
+ return NULL;
+static struct worker *get_worker(void)
+ int i;
+ for (i = 0; i < num_workers; i++) {
+ struct worker *w = &workers[i];
+ if (!w->exp)
+ return w;
+ return NULL;
+static void begin_evaluate(struct expression *e)
+ struct worker *w;
+ pthread_mutex_lock(&worker_mutex);
+ w = get_worker();
+ if (!w) {
+ e->worker = NULL;
+ pthread_mutex_unlock(&worker_mutex);
+ evaluate(e);
+ return;
+ w->exp = e;
+ e->worker = w;
+ pthread_cond_signal(&w->cond);
+static void end_evaluate(struct expression *e)
+ struct worker *w = e->worker;
+ if (!w)
+ return;
+static void init_threads(void)
+ const char *p = getenv("WORKERS");
+ int i;
+ pthread_mutex_init(&map_mutex, NULL);
+ pthread_mutex_init(&worker_mutex, NULL);
+ num_workers = p ? atoi(p) : 8;
+ workers = G_calloc(num_workers, sizeof(struct worker));
+ pthread_mutex_init(&w->mutex, NULL);
+ pthread_cond_init(&w->cond, NULL);
+ pthread_create(&w->thread, NULL, worker, w);
+static void end_threads(void)
+ int i;
+ pthread_mutex_destroy(&map_mutex);
+ pthread_mutex_destroy(&worker_mutex);
+ pthread_kill(w->thread, SIGINT);
+ pthread_mutex_destroy(&w->mutex);
+ pthread_cond_destroy(&w->cond);
+#endif
static void evaluate_constant(expression * e)
int *ibuf = e->buf;
@@ -129,11 +255,19 @@
static void evaluate_map(expression * e)
+#ifdef USE_PTHREAD
+ pthread_mutex_lock(&map_mutex);
+#endif
get_map_row(e->data.map.idx,
e->data.map.mod,
current_depth + e->data.map.depth,
current_row + e->data.map.row,
e->data.map.col, e->buf, e->res_type);
+#ifdef USE_PTHREAD
+ pthread_mutex_unlock(&map_mutex);
+#endif
static void evaluate_function(expression * e)
@@ -141,6 +275,16 @@
int i;
int res;
+#ifdef USE_PTHREAD
+ if (e->data.func.argc > 1 && e->data.func.func != f_eval) {
+ for (i = 1; i <= e->data.func.argc; i++)
+ begin_evaluate(e->data.func.args[i]);
+ end_evaluate(e->data.func.args[i]);
+ else
+#endif
@@ -303,6 +447,10 @@
count = rows * depths;
n = 0;
+#ifdef USE_PTHREAD
+ init_threads();
+#endif
for (current_depth = 0; current_depth < depths; current_depth++)
for (current_row = 0; current_row < rows; current_row++) {
if (verbose)
@@ -324,6 +472,10 @@
n++;
+#ifdef USE_PTHREAD
+ end_threads();
+#endif
if (verbose)
G_percent(n, count, 2);
Modified: grass/trunk/raster/r.mapcalc/expression.h
--- grass/trunk/raster/r.mapcalc/expression.h 2008-11-21 23:39:55 UTC (rev 34439)
+++ grass/trunk/raster/r.mapcalc/expression.h 2008-11-22 00:07:17 UTC (rev 34440)
@@ -76,6 +76,7 @@
expr_data_func func;
expr_data_bind bind;
} data;
+ void *worker;
} expression;
typedef struct expr_list
