[GRASS-SVN] r34446 - grass/trunk/lib/gis
Sat Nov 22 21:25:37 EST 2008
Author: glynn
Date: 2008-11-22 21:25:37 -0500 (Sat, 22 Nov 2008)
New Revision: 34446
   grass/trunk/lib/gis/null_val.c
Fix "null values not initialized" bug in previous commit
Modified: grass/trunk/lib/gis/null_val.c
--- grass/trunk/lib/gis/null_val.c	2008-11-23 01:41:03 UTC (rev 34445)
+++ grass/trunk/lib/gis/null_val.c	2008-11-23 02:25:37 UTC (rev 34446)
@@ -24,11 +24,7 @@
 #include <grass/gis.h>
 #include <grass/glocale.h>
-/* Flag to indicate null patterns are initialized */
-static int initialized = FALSE;
 static int EmbedGivenNulls(void *, char *, RASTER_MAP_TYPE, int);
-static void InitError(void);
 * int EmbedGivenNulls (void *cell, char *nulls, RASTER_MAP_TYPE map_type,
@@ -77,27 +73,6 @@
     return 1;
-* void InitError (void)
-* PURPOSE: 	To print an error message and exit the program. This function
-*   	    	is called if something tries to access a null pattern before
-*   	    	it is initialized.
-* INPUT VARS:	none
-* RETURN VAL:	none
-    char errMsg[512];		/* array to hold error message */
-    strcpy(errMsg, _("Null values have not been initialized. "));
-    strcat(errMsg, _("G_gisinit() must be called first. "));
-    strcat(errMsg, _("Please advise GRASS developers of this error.\n"));
-    G_fatal_error(errMsg);
-    return;
 /*========================== Library Functions =============================*/
@@ -273,11 +248,6 @@
     int i;			/* counter */
-    /* Check if the null patterns have been initialized */
-    if (!initialized) {
-	InitError();
     /* Check if the CELL value matches the null pattern */
     for (i = 0; i < sizeof(CELL); i++)
 	if (cellVal[i] != (CELL) 0x80000000)
