[GRASS-SVN] r34453 - grass/trunk/lib/gis
svn_grass at osgeo.org
Sun Nov 23 14:29:14 EST 2008
Author: glynn
Date: 2008-11-23 14:29:14 -0500 (Sun, 23 Nov 2008)
New Revision: 34453
grass/trunk/lib/gis/area.c
grass/trunk/lib/gis/area_ellipse.c
grass/trunk/lib/gis/area_poly1.c
grass/trunk/lib/gis/area_sphere.c
Bundle static variables into per-file structures
Modified: grass/trunk/lib/gis/area.c
--- grass/trunk/lib/gis/area.c 2008-11-23 19:08:29 UTC (rev 34452)
+++ grass/trunk/lib/gis/area.c 2008-11-23 19:29:14 UTC (rev 34453)
@@ -16,20 +16,22 @@
#include <grass/gis.h>
+static struct state {
+ struct Cell_head window;
+ double square_meters;
+ int projection;
-static struct Cell_head window;
-static double square_meters;
-static int projection;
+ double units_to_meters_squared;
-static double units_to_meters_squared = 0.0;
+ /* these next are for lat-long only */
+ int next_row;
+ double north_value;
+ double north;
+ double (*darea0) (double);
+} state;
-/* these next are for lat-long only */
-static int next_row;
-static double north_value;
-static double north;
-static double (*darea0) (double);
+static struct state *st = &state;
* \brief Begin cell area calculations.
@@ -52,26 +54,27 @@
double a, e2;
double factor;
- G_get_set_window(&window);
- switch (projection = window.proj) {
+ G_get_set_window(&st->window);
+ switch (st->projection = st->window.proj) {
case PROJECTION_LL:
G_get_ellipsoid_parameters(&a, &e2);
if (e2) {
- G_begin_zone_area_on_ellipsoid(a, e2, window.ew_res / 360.0);
- darea0 = G_darea0_on_ellipsoid;
+ G_begin_zone_area_on_ellipsoid(a, e2, st->window.ew_res / 360.0);
+ st->darea0 = G_darea0_on_ellipsoid;
else {
- G_begin_zone_area_on_sphere(a, window.ew_res / 360.0);
- darea0 = G_darea0_on_sphere;
+ G_begin_zone_area_on_sphere(a, st->window.ew_res / 360.0);
+ st->darea0 = G_darea0_on_sphere;
- next_row = 0;
- north_value = darea0(north = window.north);
+ st->next_row = 0;
+ st->north = st->window.north;
+ st->north_value = st->darea0(st->north);
return 2;
default:
- square_meters = window.ns_res * window.ew_res;
+ st->square_meters = st->window.ns_res * st->window.ew_res;
factor = G_database_units_to_meters_factor();
if (factor > 0.0)
- square_meters *= (factor * factor);
+ st->square_meters *= (factor * factor);
return (factor > 0.0);
@@ -93,17 +96,20 @@
double south_value;
double cell_area;
- if (projection != PROJECTION_LL)
- return square_meters;
+ if (st->projection != PROJECTION_LL)
+ return st->square_meters;
- if (row != next_row)
- north_value = darea0(north = window.north - row * window.ns_res);
+ if (row != st->next_row) {
+ st->north = st->window.north - row * st->window.ns_res;
- south_value = darea0(north -= window.ns_res);
- cell_area = north_value - south_value;
+ st->north -= st->window.ns_res;
+ south_value = st->darea0(st->north);
+ cell_area = st->north_value - south_value;
- next_row = row + 1;
- north_value = south_value;
+ st->next_row = row + 1;
+ st->north_value = south_value;
return cell_area;
@@ -125,17 +131,17 @@
double a, e2;
double factor;
- if ((projection = G_projection()) == PROJECTION_LL) {
+ if ((st->projection = G_projection()) == PROJECTION_LL) {
G_begin_ellipsoid_polygon_area(a, e2);
return 2;
if (factor > 0.0) {
- units_to_meters_squared = factor * factor;
+ st->units_to_meters_squared = factor * factor;
return 1;
- units_to_meters_squared = 1.0;
+ st->units_to_meters_squared = 1.0;
return 0;
@@ -166,10 +172,10 @@
double area;
- if (projection == PROJECTION_LL)
+ if (st->projection == PROJECTION_LL)
area = G_ellipsoid_polygon_area(x, y, n);
else
- area = G_planimetric_polygon_area(x, y, n) * units_to_meters_squared;
+ area = G_planimetric_polygon_area(x, y, n) * st->units_to_meters_squared;
return area;
Modified: grass/trunk/lib/gis/area_ellipse.c
--- grass/trunk/lib/gis/area_ellipse.c 2008-11-23 19:08:29 UTC (rev 34452)
+++ grass/trunk/lib/gis/area_ellipse.c 2008-11-23 19:29:14 UTC (rev 34453)
@@ -18,11 +18,13 @@
#include "pi.h"
+ double E;
+ double M;
+} state;
-static double E;
-static double M;
* a is semi-major axis, e2 is eccentricity squared, s is a scale factor
* code will fail if e2==0 (sphere)
@@ -49,8 +51,8 @@
int G_begin_zone_area_on_ellipsoid(double a, double e2, double s)
- E = sqrt(e2);
- M = s * a * a * M_PI * (1 - e2) / E;
+ st->E = sqrt(e2);
+ st->M = s * a * a * M_PI * (1 - e2) / st->E;
return 0;
@@ -70,9 +72,9 @@
double x;
- x = E * sin(Radians(lat));
+ x = st->E * sin(Radians(lat));
- return (M * (x / (1.0 - x * x) + 0.5 * log((1.0 + x) / (1.0 - x))));
+ return (st->M * (x / (1.0 - x * x) + 0.5 * log((1.0 + x) / (1.0 - x))));
Modified: grass/trunk/lib/gis/area_poly1.c
--- grass/trunk/lib/gis/area_poly1.c 2008-11-23 19:08:29 UTC (rev 34452)
+++ grass/trunk/lib/gis/area_poly1.c 2008-11-23 19:29:14 UTC (rev 34453)
@@ -21,16 +21,16 @@
#define TWOPI M_PI + M_PI
-static double QA, QB, QC;
-static double QbarA, QbarB, QbarC, QbarD;
+ double QA, QB, QC;
+ double QbarA, QbarB, QbarC, QbarD;
+ double AE; /** a^2(1-e^2) */
+ double Qp; /** Q at the north pole */
+ double E; /** Area of the earth */
+} state;
-static double AE; /** a^2(1-e^2) */
-static double Qp; /** Q at the north pole */
-static double E; /** Area of the earth */
static double Q(double x)
double sinx, sinx2;
@@ -38,7 +38,7 @@
sinx = sin(x);
sinx2 = sinx * sinx;
- return sinx * (1 + sinx2 * (QA + sinx2 * (QB + sinx2 * QC)));
+ return sinx * (1 + sinx2 * (st->QA + sinx2 * (st->QB + sinx2 * st->QC)));
static double Qbar(double x)
@@ -48,7 +48,7 @@
cosx = cos(x);
cosx2 = cosx * cosx;
- return cosx * (QbarA + cosx2 * (QbarB + cosx2 * (QbarC + cosx2 * QbarD)));
+ return cosx * (st->QbarA + cosx2 * (st->QbarB + cosx2 * (st->QbarC + cosx2 * st->QbarD)));
@@ -71,21 +71,21 @@
e4 = e2 * e2;
e6 = e4 * e2;
- AE = a * a * (1 - e2);
+ st->AE = a * a * (1 - e2);
- QA = (2.0 / 3.0) * e2;
- QB = (3.0 / 5.0) * e4;
- QC = (4.0 / 7.0) * e6;
+ st->QA = (2.0 / 3.0) * e2;
+ st->QB = (3.0 / 5.0) * e4;
+ st->QC = (4.0 / 7.0) * e6;
- QbarA = -1.0 - (2.0 / 3.0) * e2 - (3.0 / 5.0) * e4 - (4.0 / 7.0) * e6;
- QbarB = (2.0 / 9.0) * e2 + (2.0 / 5.0) * e4 + (4.0 / 7.0) * e6;
- QbarC = -(3.0 / 25.0) * e4 - (12.0 / 35.0) * e6;
- QbarD = (4.0 / 49.0) * e6;
+ st->QbarA = -1.0 - (2.0 / 3.0) * e2 - (3.0 / 5.0) * e4 - (4.0 / 7.0) * e6;
+ st->QbarB = (2.0 / 9.0) * e2 + (2.0 / 5.0) * e4 + (4.0 / 7.0) * e6;
+ st->QbarC = -(3.0 / 25.0) * e4 - (12.0 / 35.0) * e6;
+ st->QbarD = (4.0 / 49.0) * e6;
- Qp = Q(M_PI_2);
- E = 4 * M_PI * Qp * AE;
- if (E < 0.0)
- E = -E;
+ st->Qp = Q(M_PI_2);
+ st->E = 4 * M_PI * st->Qp * st->AE;
+ if (st->E < 0.0)
+ st->E = -st->E;
return 0;
@@ -136,12 +136,12 @@
x1 += TWOPI;
dx = x2 - x1;
- area += dx * (Qp - Q(y2));
+ area += dx * (st->Qp - Q(y2));
if ((dy = y2 - y1) != 0.0)
area += dx * Q(y2) - (dx / dy) * (Qbar2 - Qbar1);
- if ((area *= AE) < 0.0)
+ if ((area *= st->AE) < 0.0)
area = -area;
/* kludge - if polygon circles the south pole the area will be
@@ -149,10 +149,10 @@
* the difference between total surface area of the earth and
* the "north pole" area.
- if (area > E)
- area = E;
- if (area > E / 2)
- area = E - area;
+ if (area > st->E)
+ area = st->E;
+ if (area > st->E / 2)
+ area = st->E - area;
return area;
Modified: grass/trunk/lib/gis/area_sphere.c
--- grass/trunk/lib/gis/area_sphere.c 2008-11-23 19:08:29 UTC (rev 34452)
+++ grass/trunk/lib/gis/area_sphere.c 2008-11-23 19:29:14 UTC (rev 34453)
@@ -19,8 +19,11 @@
#include "pi.h"
-static double M;
+ double M;
+} state;
* r is radius of sphere, s is a scaling factor
@@ -41,7 +44,7 @@
int G_begin_zone_area_on_sphere(double r, double s)
- return (M = s * 2.0 * r * r * M_PI);
+ return (st->M = s * 2.0 * r * r * M_PI);
@@ -54,7 +57,7 @@
double G_darea0_on_sphere(double lat)
- return (M * sin(Radians(lat)));
+ return (st->M * sin(Radians(lat)));
