[GRASS-SVN] r34460 - in grass/trunk: raster/r.flow raster/r.resamp.rst raster/r.sun raster/r.terraflow vector/v.surf.rst vector/v.vol.rst
Sun Nov 23 18:21:52 EST 2008
Author: glynn
Date: 2008-11-23 18:21:52 -0500 (Sun, 23 Nov 2008)
New Revision: 34460
   grass/trunk/raster/r.flow/main.c
   grass/trunk/raster/r.resamp.rst/main.c
   grass/trunk/raster/r.sun/main.c
   grass/trunk/raster/r.terraflow/main.cc
   grass/trunk/vector/v.surf.rst/main.c
   grass/trunk/vector/v.vol.rst/main.c
Don't bother checking the return code from G_get_set_window()
 It never returns a failure code, and soon won't return anything
Modified: grass/trunk/raster/r.flow/main.c
--- grass/trunk/raster/r.flow/main.c	2008-11-23 23:09:08 UTC (rev 34459)
+++ grass/trunk/raster/r.flow/main.c	2008-11-23 23:21:52 UTC (rev 34460)
@@ -493,10 +493,8 @@
     if (G_parser(argc, argv))
 	exit(EXIT_FAILURE);
+    G_get_set_window(&region);
-    if (G_get_set_window(&region) == -1)
-	G_fatal_error(_("Unable to get current region"));
     larger = ((region.cols < region.rows) ? region.rows : region.cols);
     default_skip = (larger < 50) ? 1 : (int)(larger / 50);
Modified: grass/trunk/raster/r.resamp.rst/main.c
--- grass/trunk/raster/r.resamp.rst/main.c	2008-11-23 23:09:08 UTC (rev 34459)
+++ grass/trunk/raster/r.resamp.rst/main.c	2008-11-23 23:21:52 UTC (rev 34460)
@@ -283,8 +283,7 @@
 	exit(EXIT_FAILURE);
-    if (G_get_set_window(&winhd) == -1)
-	G_fatal_error(_("Retrieving and setting region failed"));
+    G_get_set_window(&winhd);
     inp_ew_res = winhd.ew_res;
     inp_ns_res = winhd.ns_res;
Modified: grass/trunk/raster/r.sun/main.c
--- grass/trunk/raster/r.sun/main.c	2008-11-23 23:09:08 UTC (rev 34459)
+++ grass/trunk/raster/r.sun/main.c	2008-11-23 23:21:52 UTC (rev 34460)
@@ -361,8 +361,7 @@
 	exit(EXIT_FAILURE);
-    if (G_get_set_window(&cellhd) == -1)
-	G_fatal_error("G_get_set_window() failed");
+    G_get_set_window(&cellhd);
     stepx = cellhd.ew_res;
     stepy = cellhd.ns_res;
Modified: grass/trunk/raster/r.terraflow/main.cc
--- grass/trunk/raster/r.terraflow/main.cc	2008-11-23 23:09:08 UTC (rev 34459)
+++ grass/trunk/raster/r.terraflow/main.cc	2008-11-23 23:21:52 UTC (rev 34460)
@@ -461,9 +461,8 @@
   parse_args(argc, argv);
   /* get the current region and dimensions */
-  if (G_get_set_window(region) == -1) {
-    G_fatal_error("r.terraflow: error getting current region");
+  G_get_set_window(region);
   check_args();
   int nr = G_window_rows();
Modified: grass/trunk/vector/v.surf.rst/main.c
--- grass/trunk/vector/v.surf.rst/main.c	2008-11-23 23:09:08 UTC (rev 34459)
+++ grass/trunk/vector/v.surf.rst/main.c	2008-11-23 23:21:52 UTC (rev 34460)
@@ -334,8 +334,7 @@
 	exit(EXIT_FAILURE);
     ew_res = cellhd.ew_res;
     ns_res = cellhd.ns_res;
Modified: grass/trunk/vector/v.vol.rst/main.c
--- grass/trunk/vector/v.vol.rst/main.c	2008-11-23 23:09:08 UTC (rev 34459)
+++ grass/trunk/vector/v.vol.rst/main.c	2008-11-23 23:21:52 UTC (rev 34460)
@@ -434,8 +434,7 @@
 	exit(EXIT_FAILURE);
     G3d_getWindow(&current_region);
     G3d_readWindow(&current_region, NULL);
