[GRASS-SVN] r34465 - grass/trunk/lib/vector/Vlib
svn_grass at osgeo.org
Mon Nov 24 00:45:25 EST 2008
Author: martinl
Date: 2008-11-24 00:45:25 -0500 (Mon, 24 Nov 2008)
New Revision: 34465
grass/trunk/lib/vector/Vlib/build.c
grass/trunk/lib/vector/Vlib/build_nat.c
vlib: print build messages in standard message mode (G_verbose_message() -> G_message())
(merge from devbr6, r34464)
Modified: grass/trunk/lib/vector/Vlib/build.c
--- grass/trunk/lib/vector/Vlib/build.c 2008-11-24 05:42:31 UTC (rev 34464)
+++ grass/trunk/lib/vector/Vlib/build.c 2008-11-24 05:45:25 UTC (rev 34465)
@@ -145,18 +145,18 @@
dig_cidx_sort(plus);
- G_verbose_message(_("Number of nodes: %d"), plus->n_nodes);
- G_verbose_message(_("Number of primitives: %d"), plus->n_lines);
- G_verbose_message(_("Number of points: %d"), plus->n_plines);
- G_verbose_message(_("Number of lines: %d"), plus->n_llines);
- G_verbose_message(_("Number of boundaries: %d"), plus->n_blines);
- G_verbose_message(_("Number of centroids: %d"), plus->n_clines);
+ G_message(_("Number of nodes: %d"), plus->n_nodes);
+ G_message(_("Number of primitives: %d"), plus->n_lines);
+ G_message(_("Number of points: %d"), plus->n_plines);
+ G_message(_("Number of lines: %d"), plus->n_llines);
+ G_message(_("Number of boundaries: %d"), plus->n_blines);
+ G_message(_("Number of centroids: %d"), plus->n_clines);
if (plus->n_flines > 0)
- G_verbose_message(_("Number of faces: %d"), plus->n_flines);
+ G_message(_("Number of faces: %d"), plus->n_flines);
if (plus->n_klines > 0)
- G_verbose_message(_("Number of kernels: %d"), plus->n_klines);
+ G_message(_("Number of kernels: %d"), plus->n_klines);
if (plus->built >= GV_BUILD_AREAS) {
int line, nlines, area, nareas, err_boundaries, err_centr_out,
@@ -196,29 +196,29 @@
err_nocentr++;
- G_verbose_message(_("Number of areas: %d"), plus->n_areas);
- G_verbose_message(_("Number of isles: %d"), plus->n_isles);
+ G_message(_("Number of areas: %d"), plus->n_areas);
+ G_message(_("Number of isles: %d"), plus->n_isles);
if (err_boundaries)
- G_verbose_message(_("Number of incorrect boundaries: %d"),
+ G_message(_("Number of incorrect boundaries: %d"),
err_boundaries);
if (err_centr_out)
- G_verbose_message(_("Number of centroids outside area: %d"),
+ G_message(_("Number of centroids outside area: %d"),
err_centr_out);
if (err_centr_dupl)
- G_verbose_message(_("Number of duplicate centroids: %d"),
+ G_message(_("Number of duplicate centroids: %d"),
err_centr_dupl);
if (err_nocentr)
- G_verbose_message(_("Number of areas without centroid: %d"),
+ G_message(_("Number of areas without centroid: %d"),
err_nocentr);
else {
- G_verbose_message(_("Number of areas: -"));
- G_verbose_message(_("Number of isles: -"));
+ G_message(_("Number of areas: -"));
+ G_message(_("Number of isles: -"));
return 1;
Modified: grass/trunk/lib/vector/Vlib/build_nat.c
--- grass/trunk/lib/vector/Vlib/build_nat.c 2008-11-24 05:42:31 UTC (rev 34464)
+++ grass/trunk/lib/vector/Vlib/build_nat.c 2008-11-24 05:45:25 UTC (rev 34465)
@@ -421,7 +421,7 @@
int Vect_build_nat(struct Map_info *Map, int build)
struct Plus_head *plus;
- int i, j, s, type, lineid;
+ int i, s, type, lineid;
long offset;
int side, line, area;
struct line_pnts *Points, *APoints;
@@ -502,9 +502,8 @@
/* register lines, create nodes */
Vect_rewind(Map);
- G_verbose_message(_("Registering primitives:"));
+ G_message(_("Registering primitives..."));
i = 1;
- j = 1;
npoints = 0;
while (1) {
/* register line */
@@ -542,12 +541,20 @@
if (Cats->n_cats == 0) /* add field 0, cat 0 */
dig_cidx_add_cat(plus, 0, 0, lineid, type);
+ if (G_verbose() > G_verbose_min() && i % 1000 == 0) {
+ fprintf(stderr, "%7d\b\b\b\b\b\b\b", i);
i++;
- j++;
- G_verbose_message(_("%d primitives registered"), plus->n_lines);
- G_verbose_message(_("%d vertices registered"), npoints);
+ if (G_verbose() > G_verbose_min())
+ fprintf(stderr, "\r");
+ G_message(_("%d primitives registered"), plus->n_lines);
+ G_message(_("%d vertices registered"), npoints);
plus->built = GV_BUILD_BASE;
@@ -557,7 +564,7 @@
if (plus->built < GV_BUILD_AREAS) {
/* Build areas */
/* Go through all bundaries and try to build area for both sides */
- G_verbose_message(_("Building areas:"));
+ G_message(_("Building areas..."));
for (i = 1; i <= plus->n_lines; i++) {
G_percent(i, plus->n_lines, 1);
@@ -580,8 +587,8 @@
Vect_build_line_area(Map, i, side);
- G_verbose_message(_("%d areas built"), plus->n_areas);
- G_verbose_message(_("%d isles built"), plus->n_isles);
+ G_message(_("%d areas built"), plus->n_areas);
+ G_message(_("%d isles built"), plus->n_isles);
plus->built = GV_BUILD_AREAS;
@@ -590,7 +597,7 @@
/* Attach isles to areas */
if (plus->built < GV_BUILD_ATTACH_ISLES) {
- G_verbose_message(_("Attaching islands:"));
+ G_message(_("Attaching islands..."));
for (i = 1; i <= plus->n_isles; i++) {
G_percent(i, plus->n_isles, 1);
Vect_attach_isle(Map, i);
@@ -605,7 +612,7 @@
if (plus->built < GV_BUILD_CENTROIDS) {
int nlines;
- G_verbose_message(_("Attaching centroids:"));
+ G_message(_("Attaching centroids..."));
nlines = Vect_get_num_lines(Map);
for (line = 1; line <= nlines; line++) {
